[petsc-users] Can I use TAO for embarrassingly parallel problems with multiple threads?
Krzysztof Kamieniecki
krys at kamieniecki.com
Thu Dec 20 10:59:55 CST 2018
That example seems to have critical sections around certain Vec calls, and
it looks like my problem occurs in VecDotBegin/VecDotEnd which is called by
TAO/BLMVM.
I assume PetscSplitReductionGet is pulling the PetscSplitReduction for
PETSC_COMM_SELF which is shared across the whole process?
I tried PetscCommDuplicate/PetscCommDestroy but that does not seem to help.
PetscErrorCode VecDotBegin(Vec x,Vec y,PetscScalar *result)
PetscErrorCode ierr;
PetscSplitReduction *sr;
MPI_Comm comm;
PetscFunctionBegin;
PetscValidHeaderSpecific(x,VEC_CLASSID,1);
PetscValidHeaderSpecific(y,VEC_CLASSID,1);
ierr = PetscObjectGetComm((PetscObject)x,&comm);CHKERRQ(ierr);
ierr = PetscSplitReductionGet(comm,&sr);CHKERRQ(ierr);
if (sr->state != STATE_BEGIN)
SETERRQ(PETSC_COMM_SELF,PETSC_ERR_ORDER,"Called before all VecxxxEnd()
called");
if (sr->numopsbegin >= sr->maxops) {
ierr = PetscSplitReductionExtend(sr);CHKERRQ(ierr);
sr->reducetype[sr->numopsbegin] = PETSC_SR_REDUCE_SUM;
sr->invecs[sr->numopsbegin] = (void*)x;
if (!x->ops->dot_local) SETERRQ(PETSC_COMM_SELF,PETSC_ERR_SUP,"Vector
does not suppport local dots");
ierr = PetscLogEventBegin(VEC_ReduceArithmetic,0,0,0,0);CHKERRQ(ierr);
ierr =
(*x->ops->dot_local)(x,y,sr->lvalues+sr->numopsbegin++);CHKERRQ(ierr);
ierr = PetscLogEventEnd(VEC_ReduceArithmetic,0,0,0,0);CHKERRQ(ierr);
PetscFunctionReturn(0);
On Thu, Dec 20, 2018 at 11:26 AM Smith, Barry F. <bsmith at mcs.anl.gov> wrote:
> The code src/ksp/ksp/examples/tutorials/ex61f.F90 demonstrates working
> with multiple threads each managing their own collection of PETSc objects.
> Hope this helps.
> Barry
> > On Dec 20, 2018, at 9:28 AM, Krzysztof Kamieniecki via petsc-users <
> petsc-users at mcs.anl.gov> wrote:
> > Hello All,
> > I have an embarrassingly parallel problem that I would like to use TAO
> on, is there some way to do this with threads as opposed to multiple
> processes?
> > I compiled PETSc with the following flags
> > ./configure \
> > --prefix=${DEP_INSTALL_DIR} \
> > --with-threadsafety --with-log=0 --download-concurrencykit \
> > --with-openblas=1 \
> > --with-openblas-dir=${DEP_INSTALL_DIR} \
> > --with-mpi=0 \
> > --with-shared=0 \
> > --with-debugging=0 COPTFLAGS='-O3' CXXOPTFLAGS='-O3' FOPTFLAGS='-O3'
> > When I run TAO in multiple threads I get the error "Called VecxxxEnd()
> in a different order or with a different vector than VecxxxBegin()"
> > Thanks,
> > Krys
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20181220/02066608/attachment.html>
