[petsc-users] Problems about Preconditioner in SNES
    Matthew Knepley
    knepley at gmail.com
    Wed Dec 19 11:46:25 CST 2018
On Wed, Dec 19, 2018 at 10:08 AM Yingjie Wu via petsc-users <
petsc-users at mcs.anl.gov> wrote:
> Respected Petsc developers:
> Hi,
> Recently, I developed a two-dimensional non-linear equations solver (SNES)
> using Petsc to solve temperature, velocity and pressure fields.  Since the
> coupling characteristics of the problem are complex, it is difficult to
> construct Jacobian matrix explicitly, so Matrix-Free method with
> Preconditioner is adopted.
Which preconditioner?
> I have the following questions about the Petsc's Preconditioner.
> 1. Is the preconditioning matrix updated in linear or non-linear steps?
> Because the elements in my preconditioning matrix are functions of
> variables (such as density is a function of temperature and pressure, and
> preconditioning matrix elements often contain density).
You are in control of this.
> 2.For some problems the preconditioning matrix element are constant, if it
> possible that the preconditioning matrix is constructed and decomposed only
> once at the beginning of the program and used for subsequent calculation?
> 3. What is the difference between using Matrix-Free method and using
> normal Newton method for preconditioning matrix?
In MF, the PC cannot use matrix elements to form the preconditioner, only
the action of the operator.
> As far as I know, when using the Matrix-Free method, the type of
> preconditioning matrix needs to be defined as MATMFFD. Are there any other
> differences?
No, that is not the PC, only the action of the operator.
    Matt
> Thanks,
> Yingjie
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20181219/fd9cb7d3/attachment-0001.html>
