[petsc-users] strange error by changing the number of cells.
Yann JOBIC yann.jobic at univ-amu.fr
Tue Dec 18 04:23:08 CST 2018
Le 18/12/2018 à 03:01, Matthew Knepley a écrit :
> On Mon, Dec 17, 2018 at 4:24 PM Yann Jobic via petsc-users
> <petsc-users at mcs.anl.gov <mailto:petsc-users at mcs.anl.gov>> wrote:
>     Dear petsc users,
>     I'm using petsc FEM framework, with p4est. I'm getting a strange
>     error,
>     when changing the number of point in DMPlexCreateBoxMesh() (2D,
>     20x20 is
>     ok, 22x22 is not) :
>     [0]PETSC ERROR: Nonconforming object sizes
>     [0]PETSC ERROR: The section point closure size 20 != dual space
>     dimension 18
> Okay, here is what the nomenclature means. The closure size is the
> size I get from the Section
> when I take the closure of the given point. So for example, if we have
> quads and Q2 elements,
> that would have a closure size of
>   3 x 3 = 9
> per component. So a 2-component Q2 element would have closure size 18.
> The dual space
> dimension is the number of dual space basis vectors. If we use a
> Lagrange element, there
> would be 1 dof per vertex, 1 per edge and 1 per cell for quadratic
> fields, so on a quad that is
> 9 dofs, and for 2 component fields that is 18. This is why the two
> numbers are designed to match.
> Could you give
>   -petscds_view
> so I can see the element you are using, and also PetscSectionView() on
> the DM section (or use
> -petscsection_view although that catches all sections, so it hard to
> find the right one).
>   Thanks,
The problem arise in parallel, and for a 6x6 grid size. I'm doing
something wrong, but i don't know where. It's working fine in older
petsc version.
You will find in attachment the log files.
The code for the section is the following :
     ierr = DMGetSection(dmAux,&section);CHKERRQ(ierr);
     PetscSectionView(section, PETSC_VIEWER_STDOUT_WORLD);
Thanks for the help !
Yann
>     Matt
>     [0]PETSC ERROR: See
>     http://www.mcs.anl.gov/petsc/documentation/faq.html
>     for trouble shooting.
>     [0]PETSC ERROR: Petsc Release Version 3.10.2, Oct, 09, 2018
>     [0]PETSC ERROR: ./gauss on a  named crabe by yann Mon Dec 17
>     22:17:38 2018
>     [0]PETSC ERROR: Configure options
>     --prefix=/local/lib/petsc/3.10/p2/gcc/openmpi_gcc_all
>     --with-single-library=0 --with-debugging=1 --download-scalapack=1
>     --download-metis=1 --download-parmetis=1 --download-ptscotch=1
>     --download-mumps=1 --download-hypre=1 --download-superlu=1
>     --download-superlu_dist=1 --download-fblaslapack=1 --download-metis=1
>     --download-ml=1 --download-p4est=1 --download-netcdf=1
>     --download-pragmatic=1 --with-cxx-dialect=C++11 --download-eigen=1
>     --download-parms=1 --download-triangle=1 --download-hdf5=1
>     --with-zlib=1
>     --download-szlib=1 --download-suitesparse=1 --with-shared-libraries=0
>     PETSC_ARCH=openmpi_gcc_all
>     [0]PETSC ERROR: #1 DMProjectLocal_Generic_Plex() line 400 in
>     /local/yann/petsc-3.10.2/src/dm/impls/plex/plexproject.c
>     [0]PETSC ERROR: #2 DMProjectFunctionLocal_Plex() line 530 in
>     [0]PETSC ERROR: #3 DMProjectFunctionLocal() line 6320 in
>     /local/yann/petsc-3.10.2/src/dm/interface/dm.c
>     [0]PETSC ERROR: #4 DMProjectFunctionLocal_p4est() line 4393 in
>     /local/yann/petsc-3.10.2/src/dm/impls/forest/p4est/pforest.c
>     [0]PETSC ERROR: #5 DMProjectFunctionLocal() line 6320 in
>     [0]PETSC ERROR: #6 SetupVelocity() line 332 in
>     /local/yann/fe-utils/petsc/3.10/gauss.c
>     [0]PETSC ERROR: #7 SetupVelBC() line 359 in
>     [0]PETSC ERROR: #8 main() line 652 in
>     I'm using petscspace_degree == 2 for the primary field, and also
>     for the
>     auxiliary one (velocity). The error occurs when i project the
>     velocity
>     function into the auxiliary field.
>     Do you see where the problem could come from ?
>     Best regards,
>     Yann
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20181218/4186d5b9/attachment-0001.html>
Type: text/x-log
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20181218/4186d5b9/attachment-0002.bin>
Type: text/x-log
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20181218/4186d5b9/attachment-0003.bin>
