[petsc-users] Solution "jumps" after setting timestep
Zhang, Hong
hongzhang at anl.gov
Thu Dec 13 11:36:55 CST 2018
Please make sure your messages go to petsc-users when replying.
On Dec 13, 2018, at 11:25 AM, Moritz.Huck at isea.rwth-aachen.de<mailto:Moritz.Huck at isea.rwth-aachen.de> wrote:
The first solve to 1e-3
TSAdapt basic arkimex 0:1bee step 0 rejected t=0 + 1.000e-03 dt=1.000e-04 wlte= 102 wltea= -1 wlter= -1
TSAdapt basic arkimex 0:1bee step 0 rejected t=0 + 1.000e-04 dt=1.000e-05 wlte= 127 wltea= -1 wlter= -1
TSAdapt basic arkimex 0:1bee step 0 rejected t=0 + 1.000e-05 dt=1.995e-06 wlte= 5.09 wltea= -1 wlter= -1
TSAdapt basic arkimex 0:1bee step 0 accepted t=0 + 1.995e-06 dt=3.232e-06 wlte=0.309 wltea= -1 wlter= -1
TSAdapt basic arkimex 0:4 step 1 accepted t=1.99488e-06+ 3.232e-06 dt=3.232e-05 wlte=1.65e-06 wltea= -1 wlter= -1
TSAdapt basic arkimex 0:4 step 2 accepted t=5.22663e-06+ 3.232e-05 dt=3.232e-04 wlte=3.96e-05 wltea= -1 wlter= -1
TSAdapt basic arkimex 0:4 step 3 accepted t=3.75441e-05+ 3.232e-04 dt=6.393e-04 wlte=0.000973 wltea= -1 wlter= -1
TSAdapt basic arkimex 0:4 step 4 accepted t=0.000360719+ 6.393e-04 dt=2.962e-03 wlte=0.00142 wltea= -1 wlter= -1
the solve steps afterwards:
TSAdapt basic arkimex 0:4 step 5 accepted t=0.001 + 2.962e-03 dt=7.110e-03 wlte=0.0197 wltea= -1 wlter= -1
TSAdapt basic arkimex 0:4 step 6 accepted t=0.00396151 + 7.110e-03 dt=2.489e-02 wlte=0.00437 wltea= -1 wlter= -1
TSAdapt basic arkimex 0:4 step 7 accepted t=0.0110717 + 2.489e-02 dt=7.079e-02 wlte= 0.01 wltea= -1 wlter= -1
TSAdapt basic arkimex 0:4 step 8 accepted t=0.03596 + 7.079e-02 dt=9.672e-02 wlte=0.188 wltea= -1 wlter= -1
TSAdapt basic arkimex 0:4 step 9 accepted t=0.106753 + 9.672e-02 dt=1.329e-01 wlte=0.184 wltea= -1 wlter= -1
around here it reaches a steady state
TSAdapt basic arkimex 0:4 step 10 accepted t=0.203478 + 1.329e-01 dt=2.432e-01 wlte=0.0586 wltea= -1 wlter= -1
TSAdapt basic arkimex 0:4 step 11 accepted t=0.336424 + 2.432e-01 dt=4.536e-01 wlte=0.0542 wltea= -1 wlter= -1
TSAdapt basic arkimex 0:4 step 12 accepted t=0.579616 + 4.536e-01 dt=1.112e+00 wlte=0.0182 wltea= -1 wlter= -1
TSAdapt basic arkimex 0:4 step 13 accepted t=1.03324 + 9.668e-01 dt=3.286e+00 wlte=0.00492 wltea= -1 wlter= -1
here I set the timestep to 1e-3 artificially and the solution deviates from the steady state solution
The TS time jumps between step 13 and step 14, which is probably the cause of the jump in the solution.
Did you reset the time to t=2 by calling TSSetTime() after step 13?
Hong
TSAdapt basic arkimex 0:4 step 14 accepted t=2 + 1.000e-03 dt=3.845e-03 wlte=0.003 wltea= -1 wlter= -1
TSAdapt basic arkimex 0:4 step 15 accepted t=2.001 + 3.845e-03 dt=3.845e-02 wlte=6.95e-06 wltea= -1 wlter= -1
TSAdapt basic arkimex 0:4 step 16 accepted t=2.00485 + 3.845e-02 dt=3.845e-01 wlte=4.31e-05 wltea= -1 wlter= -1
TSAdapt basic arkimex 0:4 step 17 accepted t=2.0433 + 3.845e-01 dt=2.473e+00 wlte=0.000384 wltea= -1 wlter= -1
TSAdapt basic arkimex 0:4 step 18 accepted t=2.42784 + 2.473e+00 dt=4.540e+00 wlte=0.0578 wltea= -1 wlter= -1
this point is "back on track"
TSAdapt basic arkimex 0:4 step 19 accepted t=4.90058 + 4.540e+00 dt=4.649e+00 wlte=0.596 wltea= -1 wlter= -1
Von: Zhang, Hong <hongzhang at anl.gov<mailto:hongzhang at anl.gov>>
Gesendet: Donnerstag, 13. Dezember 2018 17:39
An: Huck, Moritz <Moritz.Huck at isea.rwth-aachen.de<mailto:Moritz.Huck at isea.rwth-aachen.de>>
Cc: petsc-users at mcs.anl.gov<mailto:petsc-users at mcs.anl.gov>
Betreff: Re: [petsc-users] Solution "jumps" after setting timestep
Can you show the outputs of -ts_monitor for both cases (one with oscillations and one without)?
Hong
On Dec 13, 2018, at 9:48 AM, Moritz.Huck at isea.rwth-aachen.de<mailto:Moritz.Huck at isea.rwth-aachen.de> wrote:
Sure after reaching a steady state it looks like this:
0 SNES Function norm 3.767377637168e-03
1 SNES Function norm 2.529971638368e-05
2 SNES Function norm 4.433873358247e-09
3 SNES Function norm 4.535675922104e-11
0 SNES Function norm 9.898938706929e-04
1 SNES Function norm 1.322473621975e-05
2 SNES Function norm 1.672724799379e-09
3 SNES Function norm 1.338501638801e-11
0 SNES Function norm 1.624500221071e-03
1 SNES Function norm 2.448515345247e-05
2 SNES Function norm 6.225549426481e-09
3 SNES Function norm 1.062516222150e-10
4 SNES Function norm 6.493758120241e-13
0 SNES Function norm 1.106311709708e-03
1 SNES Function norm 2.475673243430e-05
2 SNES Function norm 9.969586735411e-09
3 SNES Function norm 2.479591395229e-10
4 SNES Function norm 1.542689576708e-12
0 SNES Function norm 6.070943996748e-04
1 SNES Function norm 1.648134285171e-05
2 SNES Function norm 8.461078655420e-09
3 SNES Function norm 2.480863447790e-10
4 SNES Function norm 1.513977618851e-12
TSAdapt basic arkimex 0:4 step 15 accepted t=5.67201 + 4.328e+00 dt=4.687e+00 wlte$
0.477 wltea= -1 wlter= -1
If I set the next target time (in tssolve) to be tlast+1e-3 it looks like this:
0 SNES Function norm 4.734802409365e-03
1 SNES Function norm 6.173939866359e-13
0 SNES Function norm 5.633294284900e-04
1 SNES Function norm 3.575533754564e-13
0 SNES Function norm 9.651618110271e-04
1 SNES Function norm 6.863177319359e-13
0 SNES Function norm 7.706102281617e-04
1 SNES Function norm 8.490865565002e-13
0 SNES Function norm 5.028108294534e-04
1 SNES Function norm 6.905750968862e-13
TSAdapt basic arkimex 0:4 step 16 accepted t=10 + 1.000e-03 dt=2.612e-03 wlte$
0.0141 wltea= -1 wlter= -1
The SNES solver has a atoll of 1e-10, setting the atoll to lower values does not change the result.
Thank you,
Moritz
Gesendet: Donnerstag, 13. Dezember 2018 16:42
Can you please add command line options -ts_monitor -snes_monitor and show us the outputs?
Hong (Mr.)
On Nov 4, 2018, at 6:19 AM, Moritz.Huck--- via petsc-users <petsc-users at mcs.anl.gov<mailto:petsc-users at mcs.anl.gov>> wrote:
I using the basic adaptor.
If I let the adaptor handle everything it does not oscillates.
I don’t mean setting the timestep at the start (which does not produces the
problem),
I need to set during runtime between two steps.
Best Regards,
Moritz
-----Ursprüngliche Nachricht-----
Von: Constantinescu, Emil M. <emconsta at anl.gov<mailto:emconsta at anl.gov>>
Gesendet: Samstag, 3. November 2018 15:43
An: Huck, Moritz <Moritz.Huck at isea.rwth-aachen.de<mailto:Moritz.Huck at isea.rwth-aachen.de>>; petsc-users at mcs.anl.gov<mailto:petsc-users at mcs.anl.gov>
On 11/3/18 4:56 AM, Moritz.Huck--- via petsc-users wrote:
I am using the IMEX Runge Kutta to solve an implicit DAE (G=0).
When I manually set the time step (TSSetTimestep) my solution jumps.
When you don't set the time step, does it still oscillates? If not, can you
check if it oscillates when reducing the fixed initial time step?
Did you turn the adaptivity off (-ts_adapt_type none)?
Emil
If I go from a steady state to the same state, it oscillates a few
time and comes back to the steady solution.
Can this be prevented?
Thank you,
Moritz
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20181213/273f14c4/attachment-0001.html>
