[petsc-users] Solution "jumps" after setting timestep
Zhang, Hong
hongzhang at anl.gov
Thu Dec 13 09:41:50 CST 2018
Can you please add command line options -ts_monitor -snes_monitor and show us the outputs?
Hong (Mr.)
On Nov 4, 2018, at 6:19 AM, Moritz.Huck--- via petsc-users <petsc-users at mcs.anl.gov<mailto:petsc-users at mcs.anl.gov>> wrote:
I using the basic adaptor.
If I let the adaptor handle everything it does not oscillates.
I don’t mean setting the timestep at the start (which does not produces the
problem),
I need to set during runtime between two steps.
Best Regards,
Moritz
-----Ursprüngliche Nachricht-----
Von: Constantinescu, Emil M. <emconsta at anl.gov<mailto:emconsta at anl.gov>>
Gesendet: Samstag, 3. November 2018 15:43
An: Huck, Moritz <Moritz.Huck at isea.rwth-aachen.de<mailto:Moritz.Huck at isea.rwth-aachen.de>>; petsc-users at mcs.anl.gov<mailto:petsc-users at mcs.anl.gov>
Betreff: Re: [petsc-users] Solution "jumps" after setting timestep
On 11/3/18 4:56 AM, Moritz.Huck--- via petsc-users wrote:
I am using the IMEX Runge Kutta to solve an implicit DAE (G=0).
When I manually set the time step (TSSetTimestep) my solution jumps.
When you don't set the time step, does it still oscillates? If not, can you
check if it oscillates when reducing the fixed initial time step?
Did you turn the adaptivity off (-ts_adapt_type none)?
Emil
If I go from a steady state to the same state, it oscillates a few
time and comes back to the steady solution.
Can this be prevented?
Thank you,
Moritz
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20181213/a84f032b/attachment-0001.html>
