[petsc-users] Periodic domains in DMPlex / petsc4py
    Artur Palha Da Silva Clérigo - LR
    A.PalhaDaSilvaClerigo at tudelft.nl
    Wed Dec 12 08:45:36 CST 2018
On 12 Dec 2018, at 15:26, Stefano Zampini <stefano.zampini at gmail.com<mailto:stefano.zampini at gmail.com>> wrote:
What do you mean by "I always get the first numbering”?
I mean that if I use as input a periodic and a non-periodic mesh I get the following numbering in both cases:
1                3                5
X-------------X-------------X
0                2                 4
That is, the numbering of the degrees of freedom is ignoring the periodicity in the mesh file.
I understand you are using GMSH right? To have PETSc read the periodic section of the .msh file, you need to pass -dm_plex_gmsh_periodic
I am not doing that. For an executable I see that you can do this by passing the -dm_plex_gmsh_periodic switch. Is there any way of doing that? For example using PetscOptionsSetValue? I ask this because I am using petsc4py so I do not see how to pass the -dm_plex_gmsh_periodic switch in python.
Note that DMLocalizeCoordinates will localize coordinates ONLY if you use DMSetPerioidicity(), which is done in the GMSH reader
Could you point me to an example of this? I do not see how to use DMSetPeriodicity() for a general domain.
Thank you.
-artur palha
Il giorno mer 12 dic 2018 alle ore 17:17 Artur Palha Da Silva Clérigo - LR via petsc-users <petsc-users at mcs.anl.gov<mailto:petsc-users at mcs.anl.gov>> ha scritto:
On 12 Dec 2018, at 15:14, Matthew Knepley <knepley at gmail.com<mailto:knepley at gmail.com>> wrote:
On Wed, Dec 12, 2018 at 9:12 AM Artur Palha Da Silva Clérigo - LR <A.PalhaDaSilvaClerigo at tudelft.nl<mailto:A.PalhaDaSilvaClerigo at tudelft.nl>> wrote:
Dear Matt,
Thank you for your quick reply. As for your question: "why would there be a difference? They should be numbered in the same way.”
I see the degrees of freedom living on the periodic domain as the ones living at boundaries between interior elements. This is what I expect for non-periodic domain for nodal scalar field:
Non-periodic:
1                3                5
0                2                 4
Periodic (vertical boundaries, topologically, the domain is a cylinder)
1                3                1
0                2                 0
This is not the expected behaviour?
What I mean is that each vertex in the periodic domain gets 1 dof. Same procedure as non-periodic.
We do not duplicate vertices or anything like that.
Yes, I agree. That happens yes. What I meant was that for both the periodic and non-periodic case I always get the first numbering. Is this because I miss DMLocalizeCoordinates?
    Matt
Once again thank you for your help.
-artur palha
On 12 Dec 2018, at 15:04, Matthew Knepley <knepley at gmail.com<mailto:knepley at gmail.com>> wrote:
On Wed, Dec 12, 2018 at 9:01 AM Artur Palha Da Silva Clérigo - LR via petsc-users <petsc-users at mcs.anl.gov<mailto:petsc-users at mcs.anl.gov>> wrote:
Dear All,
I having been trying to add periodic domain functionality to my code. I am able to generate a periodic mesh with gmsh and load it using dmplex. The problem is that I am unable to have a numbering of the degrees of freedom that reflects the periodicity (they are numbered as if there was no periodicity).
Why would there be a difference? They should be numbered in the same way.
I read this thread: https://lists.mcs.anl.gov/mailman/htdig/petsc-users/2018-October/036539.html
There it is mentioned that DMLocalizeCoordinates is required after loading the mesh.
Yes, this makes cell-wise coordinates, which have a jump at the periodic boundary.
My questions are the following:
1. Is it correct that I need to run DMLocalizeCoordinates on my DM?
Yes.
2. I am currently using petsc4py but I am unable to find DMLocalizeCoordinates. Is this functionality missing or is there an alternative to it?\
Its possible no wrapper has been written for this yet. Lisandro, is it missing? (I am at a meeting, or I would check).
    Matt
Thank you for your time.
Kind regards,
-artur palha
-- Norbert Wiener
https://www.cse.buffalo.edu/~knepley/<http://www.cse.buffalo.edu/~knepley/>
-- Norbert Wiener
Stefano
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20181212/61b7d057/attachment.html>
