[petsc-users] Configure error after upgrading GCC
Amneet Bhalla mail2amneet at gmail.com
Mon Dec 10 00:53:53 CST 2018
Hi Folks,
I upgraded GCC (GCC-5 to GCC-7) on Ubuntu following the first suggestion
given here:
https://gist.github.com/application2000/73fd6f4bf1be6600a2cf9f56315a2d91
I then removed system mpich (which was using GCC-5) and reinstalled it
using Ubuntu package manager. However, now I am getting the following
configure error with PETSc
TESTING: CxxMPICheck from
config.packages.MPI(config/BuildSystem/config/packages/MPI.py:381)
         UNABLE to CONFIGURE with GIVEN OPTIONS    (see configure.log for
details):
C++ error! mpi.h could not be located at: []
I am attaching the configure.log as well. Any hints on what I should be
doing?
--Amneet
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20181209/2f4e380d/attachment-0001.html>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20181209/2f4e380d/attachment-0001.obj>
