[petsc-users] (no subject)
Matthew Knepley
knepley at gmail.com
Fri Dec 7 09:54:39 CST 2018
On Fri, Dec 7, 2018 at 10:05 AM Yingjie Wu via petsc-users <
petsc-users at mcs.anl.gov> wrote:
> Dear Petsc developer:
> Hi,
> I recently begin a new program, which is a two-dimensional nonlinear PDEs
> problem, and solved by SNES. However, there is an error. The log is :
> Linear solve did not converge due to DIVERGED_PCSETUP_FAILED iterations 0
> PCSETUP_FAILED due to FACTOR_NUMERIC_ZEROPIVOT
> Nonlinear solve did not converge due to DIVERGED_LINEAR_SOLVE iterations 0
> SNES Object: 1 MPI processes
> type: newtonls
> maximum iterations=50, maximum function evaluations=10000
> tolerances: relative=1e-08, absolute=1e-50, solution=1e-08
> total number of linear solver iterations=0
> total number of function evaluations=18903
> norm schedule ALWAYS
> Jacobian is built using finite differences one column at a time
> SNESLineSearch Object: 1 MPI processes
> type: bt
> interpolation: cubic
> alpha=1.000000e-04
> maxstep=1.000000e+08, minlambda=1.000000e-12
> tolerances: relative=1.000000e-08, absolute=1.000000e-15,
> lambda=1.000000e-08
> maximum iterations=40
> KSP Object: 1 MPI processes
> type: gmres
> restart=30, using Classical (unmodified) Gram-Schmidt
> Orthogonalization with no iterative refinement
> happy breakdown tolerance 1e-30
> maximum iterations=10000, initial guess is zero
> tolerances: relative=1e-05, absolute=1e-50, divergence=10000.
> left preconditioning
> using PRECONDITIONED norm type for convergence test
> PC Object: 1 MPI processes
> type: lu
> out-of-place factorization
> tolerance for zero pivot 2.22045e-14
> matrix ordering: nd
> factor fill ratio given 5., needed 20.7926
> Factored matrix follows:
> Mat Object: 1 MPI processes
> type: seqaij
> rows=18901, cols=18901
> package used to perform factorization: petsc
> total: nonzeros=3029644, allocated nonzeros=3029644
> total number of mallocs used during MatSetValues calls =0
> not using I-node routines
> linear system matrix = precond matrix:
> type: seqaij
> total: nonzeros=145708, allocated nonzeros=341390
> total number of mallocs used during MatSetValues calls =16459
> I used "-snes_fd -pc_type lu" to test the program.
> The error shows that there are some zero elements in the matrix. What
> might cause this problem?
Error in the residual? It looks like changes in some variable do not effect
it.
Matt
> Thanks,
> Yingjie
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20181207/7a2ebc24/attachment.html>
