[petsc-users] How can I get the global integer ids in a label?
Matthew Knepley
knepley at gmail.com
Thu Dec 6 19:26:31 CST 2018
On Thu, Dec 6, 2018 at 8:06 PM leejearl <leejearl at mail.nwpu.edu.cn> wrote:
> Hi Matt:
> Thank you for your helps. I want to implement the periodic boundary in
> dmplex. For a cell or face, the donor cell or face might be not distributed
> in the same local dm. Maybe I should ask that how
> can I implement the topology of the periodic boundary in demplex.
Plex directly encodes a periodic topology. For example, with a circle, each
vertex is connected
to two neighbors. There are example with periodic boundary conditions like
SNES ex12.
Matt
> Thanks again for your kind reply.
> leejearl
> On Thu, 2018-12-06 at 12:02 -0500, Matthew Knepl
> On Thu, Dec 6, 2018 at 9:47 AM leejearl via petsc-users <
> petsc-users at mcs.anl.gov> wrote:
> Hi, Petsc developer:
> I have a problem for helps.
> There is a dmplex object, and I have distribute it use the
> routine DMPlexDistribute(). Then, I want to get the global integer ids
> in the label "Face Sets". The code is as follow,
> ierr = DMGetLabelIdIS(dm, "Face Sets", &bcIdIS);CHKERRQ(ierr);
> The values of bcIdIs are the local integer ids. How can I get the
> global integer ids.
> The problem also can be described as follow. The global ids might look
> likes
> IS Object: 1 MPI processes
> type: general
> Number of indices in set 4
> 0 1
> 1 4
> 2 3
> 3 2
> But after the dm is distributed, I can only get the local ids as follow
> using the routine "DMGetLabelIdIS"
> type: general
> [0] Number of indices in set 3
> [0] 0 1
> [0] 1 2
> [0] 2 4
> How can I get the global integer ids in a label after the dm is
> distributed?
> Any helps are appreciate!
> You can make a conversion from local point numbers to global point numbers
> using
> https://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/DMPLEX/DMPlexCreatePointNumbering.html
> You could even make a replacement DMLabel with the global point numbers,
> but I think the win would be small
> or nonexistent for most cases.
> Thanks,
> Matt
> Thanks
> leejearl
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20181206/33cb5dcb/attachment-0001.html>
