[petsc-users] seg fault with superlu
Balay, Satish balay at mcs.anl.gov
Thu Dec 6 08:36:07 CST 2018
Don't remember - but you can try with latest superlu_dist and see if
the problem persists. [it has a bunch of fixes]
To try latest superlu_dist - you can use balay/update-superlu_dist_6.1.0/maint_no_merge
[this branch is off maint - so to try with master - you can merge this with master]
git checkout master
git checkout -b test
git merge origin/balay/update-superlu_dist_6.1.0/maint_no_merge
Satish
On Thu, 6 Dec 2018, Matthew Knepley via petsc-users wrote:
> Satish,
> This is exactly the same method (pzgssvx) that had a problem before. Do you
> remember what happened?
>   Thanks,
>      Matt
> On Wed, Dec 5, 2018 at 8:38 PM Smith, Barry F. via petsc-users <
> petsc-users at mcs.anl.gov> wrote:
> >    I would start with valgrind see if it finds anything. If not and if you
> > can provide the code that reproduces the problem we can take a look at it.
> >     Barry
> > https://www.mcs.anl.gov/petsc/documentation/faq.html#valgrind
> > > On Dec 5, 2018, at 7:16 PM, Marius Buerkle via petsc-users <
> > > Hi,
> > > I get the following error duing MatMatSolve. It works for smaller number
> > of processes but if I  increade the number pf processes used it crashes.
> > > [25]PETSC ERROR:
> > > [25]PETSC ERROR: Caught signal number 11 SEGV: Segmentation Violation,
> > probably memory access out of range
> > > [25]PETSC ERROR: Try option -start_in_debugger or
> > -on_error_attach_debugger
> > > [25]PETSC ERROR: or see
> > http://www.mcs.anl.gov/petsc/documentation/faq.html#valgrind
> > > [25]PETSC ERROR: or try http://valgrind.org on GNU/linux and Apple Mac
> > OS X to find memory corruption errors
> > > [25]PETSC ERROR: likely location of problem given in stack below
> > > [25]PETSC ERROR: ---------------------  Stack Frames
> > > [25]PETSC ERROR: Note: The EXACT line numbers in the stack are not
> > available,
> > > [25]PETSC ERROR:       INSTEAD the line number of the start of the
> > function
> > > [25]PETSC ERROR:       is given.
> > > [25]PETSC ERROR: [25] SuperLU_DIST:pzgssvx line 236
> > /home/cdfmat_marius/prog/petsc/master_build_gcc_local/petsc/src/mat/impls/aij/mpi/superlu_dist/superlu_dist.c
> > > [25]PETSC ERROR: [25] MatMatSolve_SuperLU_DIST line 200
> > > [25]PETSC ERROR: [25] MatMatSolve line 3396
> > /home/cdfmat_marius/prog/petsc/master_build_gcc_local/petsc/src/mat/interface/matrix.c
> > > [25]PETSC ERROR: --------------------- Error Message
> > > [25]PETSC ERROR: Signal received
> > > [25]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html
> > for trouble shooting.
> > > [25]PETSC ERROR: Petsc Development GIT revision: v3.10.2-723-g2a65a22
> > GIT Date: 2018-11-25 07:45:29 +0100
> > > [25]PETSC ERROR:
> > /home/cdfmat_marius/prog/transomat_latest_test4/transomat on a  named a003
> > by cdfmat_marius Thu Dec  6 10:12:23 2018
> > > [25]PETSC ERROR: Configure options
> > --prefix=/home/cdfmat_marius/prog/petsc/master_gcc_local_debug
> > --with-64-bit-indices=0 --CC=mpicc --COPTFLAGS="-O0 -mtune=generic -g
> > -std=c11 " --CXX=mpicxx --CXXOPTFLAGS="-O0 -mtune=generic -g -std=c++11 "
> > --FC=mpif90 --FOPTFLAGS="-O0 -mtune=generic -g -fbacktrace -g "
> > --with-mpi=1 --with-x=0
> > --download-parmetis=/home/cdfmat_marius/prog/petsc/master_build_gcc_local/petsc/externalpackages/git.parmetis.tar.gz
> > --download-metis=/home/cdfmat_marius/prog/petsc/master_build_gcc_local/petsc/externalpackages/git.metis.tar.gz
> > --with-blaslapack-lib="
> > -L/home/cdfmat_marius/intel/compilers_and_libraries_2019.1.144/linux/mkl/lib/intel64
> > -Wl,--no-as-needed -lmkl_scalapack_lp64 -lmkl_intel_lp64 -lmkl_sequential
> > -lmkl_core -lmkl_blacs_openmpi_lp64 -lpthread -lm -ldl "
> > --with-scalapack-lib="
> > --download-pastix=no
> > --download-superlu_dist=/home/cdfmat_marius/prog/petsc/master_build_gcc_local/petsc/externalpackages/git.superlu_dist.tar.gz
> > --download-superlu_dist-commit=HEAD
> > --download-hwloc=/home/cdfmat_marius/prog/petsc/master_build_gcc_local/petsc/externalpackages/hwloc-1.11.1.tar.gz
> > --download-sowing=/home/cdfmat_marius/prog/petsc/master_build_gcc_local/petsc/externalpackages/git.sowing.tar.gz
> > --with-mkl_pardiso-dir=/home/cdfmat_marius/intel/compilers_and_libraries_2019.1.144/linux/mkl
> > --with-openmp=0 --with-pthread=0
> > --download-elemental=/home/cdfmat_marius/prog/petsc/master_build_gcc_local/petsc/externalpackages/git.elemental.tar.gz
> > --download-elemental-commit=HEAD
> > --with-mkl_cpardiso-dir=/home/cdfmat_marius/intel/compilers_and_libraries_2019.1.144/linux/mkl
> > --with-mkl_sparse_optimize-dir=/home/cdfmat_marius/intel/compilers_and_libraries_2019.1.144/linux/mkl
> > --with-mkl_sparse_sp2m-dir=/home/cdfmat_marius/intel/compilers_and_libraries_2019.1.144/linux/mkl
> > --with-cxx-dialect=c++11 --with-scalar-type=complex --with-debugging=1
> > > bestm
> > > marius
