[petsc-users] PETSc binary write format
Sajid Ali sajidsyed2021 at u.northwestern.edu
Wed Dec 5 13:05:23 CST 2018
To clarify :
The data from xxd -b petsc_output_dat is what I've reordered. The binary
dump is confusing to read since it contains 6 bytes per line (alongside the
unnecessary ascii conversions) and the numbers start and end in odd places.
I wanted each line to have only one number and copy pasted the data into a
new file. Then I changed the spacing so that the first two lines have 4
bytes (corresponding to int-32) each and correspond to VEC_FILE_CLASSID and
num_elements (20 in this case). This is followed by 8 bytes (64-bit double)
per line which store the actual elements of the vector.
On Wed, Dec 5, 2018 at 12:57 PM Sajid Ali <sajidsyed2021 at u.northwestern.edu>
wrote:
> It's just a cleaner re-write of the petsc output that I can understand
> (which I intend to modify from python in the future). I tried removing the
> new line characters but that didn't work either.
> Looking at the first line of the binary dump from petsc output :
> [sajid at xrm <https://lists.mcs.anl.gov/mailman/listinfo/petsc-users> temp]$ xxd -b vector.dat
> 0000000: 00000000 00010010 01111011 01001110 00000000 00000000  ..{N..
> The first 4 bytes combine to give
> *00000000000100100111101101001110*
> Which is int-32 representation of VEC_FILE_CLASSID and this is the first
> line of my file as well.
> Thank You,
> Sajid Ali
> Applied Physics
> Northwestern University
Sajid Ali
Applied Physics
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20181205/e622c576/attachment.html>
