[petsc-users] VecLoad hdf5
Josh L ysjosh.lo at gmail.com
Tue Dec 4 16:52:29 CST 2018
Smith, Barry F. <bsmith at mcs.anl.gov> 於 2018年12月4日 週二 下午4:43寫道:
> > On Dec 4, 2018, at 4:09 PM, Josh L <ysjosh.lo at gmail.com> wrote:
> > I haven't figured out what causes it. I just use binaryopen instead of
> HDF5, and everything works fine.
>    Did you originally save the data into the file with HDF5 format?
Yes, by
    Set Vec name, and block size
    PetscViewerHDF5Open(write)
    VecView(vec,viewer)
> > Josh L <ysjosh.lo at gmail.com> 於 2018年12月4日 週二 下午2:55寫道:
> > The first error comes from
> > PetscStackCallHDF5Return(group,H5Gcreate2,(file_id, groupName, 0,
> H5P_DEFAULT, H5P_DEFAULT));
> >  #000: H5G.c line 314 in H5Gcreate2(): unable to create group
> >     major: Symbol table
> >     minor: Unable to initialize object
> > Josh L <ysjosh.lo at gmail.com> 於 2018年12月4日 週二 下午2:38寫道:
> > I set the name of 2 vectors to be the same, but still get the same error.
> > Josh L <ysjosh.lo at gmail.com> 於 2018年12月4日 週二 下午2:06寫道:
> > I just found out that I missed that note in VecLoad manual page, and I
> am trying it now.
> > Thanks.
> > Smith, Barry F. <bsmith at mcs.anl.gov> 於 2018年12月4日 週二 下午2:00寫道:
> >    Hmm, this is a guess. HDF5 files read in objects based on their
> names. Are you sure that the vector you saved and the vector you later try
> to read in have the same name? You can set the name of the loaded vector
> with PetscObjectSetName((PetscObject)nv,"name") after you create it to
> match the name you used to save the vector.
> >    Barry
> > > On Dec 4, 2018, at 1:42 PM, Josh L via petsc-users <
> petsc-users at mcs.anl.gov> wrote:
> > > Hi,
> > > I have a vec.h5 that generated serially by
> > >   gv is a sequential vec
> > >  VecSetblockSize(gv,3)
> > >  PetscViewerHDF5Open(vec,h5,write)
> > >   VecView(gv)
> > > and I want to read in with different number of processor by
> > >   DMGetGlobalVector(dm,nv)
> > >   VecLoad(nv)
> > > nv has bs=3, and I have set bs for gv as 3.
> > > I get the following error. any hint to solve it ? thanks
> > > Error in HDF5 call H5Gcreate2() Status -1
> > >     major: Symbol table
> > >   #001: H5Gint.c line 194 in H5G__create_named(): unable to create and
> link to group
> > >     major: Symbol table
> > >   #002: H5L.c line 1638 in H5L_link_object(): unable to create new
> link to object
> > >     major: Links
> > >   #003: H5L.c line 1882 in H5L_create_real(): can't insert link
> > >     major: Symbol table
> > >     minor: Unable to insert object
> > >   #004: H5Gtraverse.c line 861 in H5G_traverse(): internal path
> traversal failed
> > >     major: Symbol table
> > >     minor: Object not found
> > >   #005: H5Gtraverse.c line 641 in H5G_traverse_real(): traversal
> operator failed
> > >     major: Symbol table
> > >     minor: Callback failed
> > >   #006: H5L.c line 1685 in H5L_link_cb(): unable to create object
> > >     major: Object header
> > >   #007: H5O.c line 3016 in H5O_obj_create(): unable to open object
> > >     minor: Can't open object
> > >   #008: H5Goh.c line 268 in H5O_group_create(): unable to create group
> > >     major: Symbol table
> > >   #009: H5Gint.c line 245 in H5G__create(): unable to create group
> object header
> > >     major: Symbol table
> > >   #010: H5Gobj.c line 163 in H5G__obj_create(): unable to create group
> > >     major: Symbol table
> > >     minor: Unable to create file
> > >   #011: H5Gobj.c line 206 in H5G__obj_create_real(): no write intent
> on file
> > >     major: Object cache
> > >     minor: Bad value
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20181204/f3f371c5/attachment.html>
