[petsc-users] Is it possible to start MPI with n processes from within the code so it takes only effect on the petsc code?
Klaus Burkart k_burkart at yahoo.com
Tue Dec 4 16:22:04 CST 2018
Hello,
I try to integrate petsc into an application and I think it would be much simpler if I could bypass the applications original MPI functionality by starting MPI with n processes when initializing Petsc and stopping it when PetscFinalize(); is called. The standard  mpirun -np 4 application -parameters  triggers a couple of events which are of no use to petsc and at the same time make the implementation very complicated as e.g. relevant data is lost.
I see a simple way to provide the number of processes through the configuration file which will hold the solver settings.
Klaus
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20181204/46656836/attachment.html>
