[petsc-users] VecLoad hdf5
Josh L
ysjosh.lo at gmail.com
Tue Dec 4 16:09:37 CST 2018
I haven't figured out what causes it. I just use binaryopen instead of
HDF5, and everything works fine.
Josh L <ysjosh.lo at gmail.com> 於 2018年12月4日 週二 下午2:55寫道:
> The first error comes from
> PetscStackCallHDF5Return(group,H5Gcreate2,(file_id, groupName, 0, H5P_DEFAULT, H5P_DEFAULT));
> #000: H5G.c line 314 in H5Gcreate2(): unable to create group
> major: Symbol table
> minor: Unable to initialize object
> Josh L <ysjosh.lo at gmail.com> 於 2018年12月4日 週二 下午2:38寫道:
>> I set the name of 2 vectors to be the same, but still get the same error.
>> Josh L <ysjosh.lo at gmail.com> 於 2018年12月4日 週二 下午2:06寫道:
>>> I just found out that I missed that note in VecLoad manual page, and I
>>> am trying it now.
>>> Thanks.
>>> Smith, Barry F. <bsmith at mcs.anl.gov> 於 2018年12月4日 週二 下午2:00寫道:
>>>> Hmm, this is a guess. HDF5 files read in objects based on their
>>>> names. Are you sure that the vector you saved and the vector you later try
>>>> to read in have the same name? You can set the name of the loaded vector
>>>> with PetscObjectSetName((PetscObject)nv,"name") after you create it to
>>>> match the name you used to save the vector.
>>>> Barry
>>>> > On Dec 4, 2018, at 1:42 PM, Josh L via petsc-users <
>>>> petsc-users at mcs.anl.gov> wrote:
>>>> > Hi,
>>>> > I have a vec.h5 that generated serially by
>>>> > gv is a sequential vec
>>>> > VecSetblockSize(gv,3)
>>>> > PetscViewerHDF5Open(vec,h5,write)
>>>> > VecView(gv)
>>>> > and I want to read in with different number of processor by
>>>> > DMGetGlobalVector(dm,nv)
>>>> > PetscViewerHDF5Open(write)
>>>> > VecLoad(nv)
>>>> > nv has bs=3, and I have set bs for gv as 3.
>>>> > I get the following error. any hint to solve it ? thanks
>>>> > Error in HDF5 call H5Gcreate2() Status -1
>>>> > major: Symbol table
>>>> > #001: H5Gint.c line 194 in H5G__create_named(): unable to create
>>>> and link to group
>>>> > major: Symbol table
>>>> > #002: H5L.c line 1638 in H5L_link_object(): unable to create new
>>>> link to object
>>>> > major: Links
>>>> > #003: H5L.c line 1882 in H5L_create_real(): can't insert link
>>>> > major: Symbol table
>>>> > minor: Unable to insert object
>>>> > #004: H5Gtraverse.c line 861 in H5G_traverse(): internal path
>>>> traversal failed
>>>> > major: Symbol table
>>>> > minor: Object not found
>>>> > #005: H5Gtraverse.c line 641 in H5G_traverse_real(): traversal
>>>> operator failed
>>>> > major: Symbol table
>>>> > minor: Callback failed
>>>> > #006: H5L.c line 1685 in H5L_link_cb(): unable to create object
>>>> > major: Object header
>>>> > #007: H5O.c line 3016 in H5O_obj_create(): unable to open object
>>>> > minor: Can't open object
>>>> > #008: H5Goh.c line 268 in H5O_group_create(): unable to create group
>>>> > major: Symbol table
>>>> > #009: H5Gint.c line 245 in H5G__create(): unable to create group
>>>> object header
>>>> > major: Symbol table
>>>> > #010: H5Gobj.c line 163 in H5G__obj_create(): unable to create group
>>>> > major: Symbol table
>>>> > minor: Unable to create file
>>>> > #011: H5Gobj.c line 206 in H5G__obj_create_real(): no write intent
>>>> on file
>>>> > major: Object cache
>>>> > minor: Bad value
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20181204/39314d50/attachment.html>
