[petsc-users] Fortran example for PETSc global to natural ordering test
    Danyang Su
    danyang.su at gmail.com
    Tue Dec  4 14:37:17 CST 2018
On 2018-12-04 11:06 a.m., Matthew Knepley wrote:
> On Mon, Dec 3, 2018 at 8:32 PM Danyang Su <danyang.su at gmail.com
> <mailto:danyang.su at gmail.com>> wrote:
>     Hi Matt,
>     Attached is the test example with source code, makefile, data and
>     screen output I wrote this afternoon. This example reads 2D mesh
>     from vtk file and then distribute over all processors. I can get
>     correct global order of local nodes after distribution, but the
>     natural order of local nodes is always zero after using
>     DMPlexGlobalToNaturalBegin/End(). Sounds like it does not take
>     effect.
>     Would you mind helping me to check/test this code at you most
>     convenience?
> On 2 procs, I get an SEGV
> rank1 local nodes with ghost 47 local cells with ghost 75
> rank0 local nodes with ghost 52 local cells with ghost 78
Interesting. The output on your side is different.  On my computer, run
the code with 2 processors, I get
rank    0 local nodes with ghost   47 local cells with ghost   76
rank    1 local nodes with ghost   49 local cells with ghost   74
and there is no error. I can run this example using 1 to 5 processors
without error. With 6 or more processors, it returns some error as shown
below.
Error in `./natural': corrupted size vs. prev_size: 0x0000000001b9a600
This seems reasonable if the mesh is too small with overlap = 1.
The version I use is
Petsc Development GIT revision: v3.10.2-832-ge28ad50  GIT Date:
2018-12-02 07:18:52 +0100
Configure options --with-cc=gcc --with-cxx=g++ --with-fc=gfortran
--download-mpich --download-scalapack --download-parmetis
--download-metis --download-ptscotch --download-fblaslapack
--download-hypre --download-superlu_dist --download-hdf5=yes
--download-ctetgen --download-zlib --download-netcdf --download-pnetcdf
--download-exodusii --download-netcdf --with-debugging=1
Danyang
> [1]PETSC ERROR:
> [1]PETSC ERROR: Caught signal number 11 SEGV: Segmentation Violation,
> probably memory access out of range
> [1]PETSC ERROR: Try option -start_in_debugger or -on_error_attach_debugger
> [1]PETSC ERROR: or see
> http://www.mcs.anl.gov/petsc/documentation/faq.html#valgrind
> [1]PETSC ERROR: or try http://valgrind.org on GNU/linux and Apple Mac
> OS X to find memory corruption errors
> [1]PETSC ERROR: likely location of problem given in stack below
> [1]PETSC ERROR: ---------------------Stack Frames
> [1]PETSC ERROR: Note: The EXACT line numbers in the stack are not
> available,
> [1]PETSC ERROR: INSTEAD the line number of the start of the function
> [1]PETSC ERROR: is given.
> [1]PETSC ERROR: --------------------- Error Message
> [1]PETSC ERROR: Signal received
> [1]PETSC ERROR: See
> http://www.mcs.anl.gov/petsc/documentation/faq.html for trouble shooting.
> [1]PETSC ERROR: Petsc Development GIT revision:
> v3.9.3-1021-g8625415GIT Date: 2018-08-02 12:57:14 -0500
> [1]PETSC ERROR: Unknown Name on a arch-master-debug named
> MATTHEW-KNEPLEYs-MacBook-Air-2.local by knepley Tue Dec4 14:00:46 2018
> [1]PETSC ERROR: Configure options --PETSC_ARCH=arch-master-debug
> --download-chaco
> --download-cmake=/Users/knepley/Downloads/cmake-3.7.2.tar.gz
> --download-ctetgen --download-eigen --download-fftw --download-hdf5
> --download-med --download-metis --download-mpich --download-netcdf
> --download-p4est --download-parmetis --download-pnetcdf
> --download-superlu_dist --download-triangle
> --with-cc="/Users/knepley/MacSoftware/bin/ccache gcc
> -Qunused-arguments" --with-cxx="/Users/knepley/MacSoftware/bin/ccache
> g++ -Qunused-arguments"
> --with-fc="/Users/knepley/MacSoftware/bin/ccache gfortran"
> --with-shared-libraries
> [1]PETSC ERROR: #1 User provided function() line 0 inunknown file
> [0]PETSC ERROR: application called MPI_Abort(MPI_COMM_WORLD, 59) -
> process 1
> [0]PETSC ERROR: Caught signal number 11 SEGV: Segmentation Violation,
> [0]PETSC ERROR: Try option -start_in_debugger or -on_error_attach_debugger
> [0]PETSC ERROR: or see
> [0]PETSC ERROR: or try http://valgrind.org on GNU/linux and Apple Mac
> [0]PETSC ERROR: likely location of problem given in stack below
> [0]PETSC ERROR: ---------------------Stack Frames
> [0]PETSC ERROR: Note: The EXACT line numbers in the stack are not
> available,
> [0]PETSC ERROR: INSTEAD the line number of the start of the function
> [0]PETSC ERROR: is given.
> [0]PETSC ERROR: --------------------- Error Message
> [0]PETSC ERROR: Signal received
> [0]PETSC ERROR: See
> [0]PETSC ERROR: Petsc Development GIT revision:
> [0]PETSC ERROR: Unknown Name on a arch-master-debug named
> [0]PETSC ERROR: Configure options --PETSC_ARCH=arch-master-debug
> --download-chaco
> [0]PETSC ERROR: #1 User provided function() line 0 inunknown file
> application called MPI_Abort(MPI_COMM_WORLD, 59) - process 0
> which valgrind says comes from DMPlexCreateSection()
> ==14766== Invalid write of size 4
> ==14766==at 0x1151A3B: dmplexcreatesection_ (zplexsectionf90.c:20)
> ==14766==by 0x1000042FA: MAIN__ (in ./natural)
> ==14766==by 0x10000497D: main (in ./natural)
> ==14766==Address 0x600001000 is not stack'd, malloc'd or (recently) free'd
> ==14766==
> ==14767== Invalid write of size 4
> ==14767==at 0x1151A3B: dmplexcreatesection_ (zplexsectionf90.c:20)
> ==14767==by 0x1000042FA: MAIN__ (in ./natural)
> ==14767==by 0x10000497D: main (in ./natural)
> ==14767==Address 0x600001000 is not stack'd, malloc'd or (recently) free'd
> ==14767==
> I cannot run the debugger on it because command line arguments are not
> working with
> my Fortran compiler (Ugh). Do you see this error?
>   Thanks,
>     Matt
>     Thanks,
>     Danyang
>     On 2018-12-03 1:12 p.m., Danyang Su wrote:
>>     On 2018-12-03 12:56 p.m., Matthew Knepley wrote:
>>>     On Mon, Dec 3, 2018 at 3:40 PM Danyang Su <danyang.su at gmail.com
>>>         On 2018-12-03 12:03 p.m., Matthew Knepley wrote:
>>>>         On Mon, Dec 3, 2018 at 2:27 PM Danyang Su
>>>>         <danyang.su at gmail.com <mailto:danyang.su at gmail.com>> wrote:
>>>>             Hi Matt,
>>>>             Thanks.
>>>>             BTW: DmPlexGetVertexNumbering now can work using the
>>>>             latest develop version. But the index is not in natural
>>>>             ordering when DMSetUseNatural is called. That's why I
>>>>             want to use PetscSFDistributeSection to check if I miss
>>>>             anything in the code.
>>>>         Can you explain that a little more? Maybe you can just push
>>>>         forward what you want using the migrationSF.
>>>         Hi Matt,
>>>         Since I cannot figure what is wrong or missing in my code, I
>>>         followed an old ex26.c example in
>>>         src/dm/impls/plex/examples/tests to create similar code as
>>>         shown below to test global to natural ordering. The code may
>>>         be ugly with unnecessary functions in it. Using
>>>         DmPlexGetVertexNumbering, I can get the value but it is not
>>>         in natural order, instead, it is still in default PETSc
>>>         order without calling DMSetUseNatural(dm,PETSC_TRUE,ierr).
>>>     I do not understand what you are doing below. You just need to call
>>>         ierr = DMSetUseNatural(dm,PETSC_TRUE);CHKERRQ(ierr);
>>>         ierr = DMPlexDistribute(dm,0,&migrationSF,&pdm);CHKERRQ(ierr);
>>>         if (pdm) {
>>>           ierr = DMPlexSetMigrationSF(pdm,migrationSF);CHKERRQ(ierr);
>>>     and the DMGlobalToNaturalBegin/End() should work.
>>     You mean to use DMPlexGlobalToNaturalBegin/End(), right? That's
>>     what I tried at first, but without success.
>>     I will create a test example to make further check if I can
>>     reproduce the problem.
>>     Thanks,
>>     Danyang
>>>       Thanks,
>>>          Matt
>>>                   if (rank == 0) then
>>>                     call
>>>         DMPlexCreateFromCellList(Petsc_Comm_World,ndim,num_cells,
>>>         num_nodes,num_nodes_per_cell,    &
>>>         Petsc_False,dmplex_cells,ndim, dmplex_verts,dm,ierr)
>>>                     CHKERRQ(ierr)
>>>                   else
>>>                     call
>>>         DMPlexCreateFromCellList(Petsc_Comm_World,ndim,0,
>>>         0,num_nodes_per_cell,    &
>>>         Petsc_False,dmplex_cells,ndim,dmplex_verts,dm,ierr)
>>>                     CHKERRQ(ierr)
>>>                   end if
>>>                   if (nprocs > 1) then
>>>                     call DMSetUseNatural(dm,PETSC_TRUE,ierr)
>>>                     CHKERRQ(ierr)
>>>                   end if
>>>                   call DMPlexDistribute(dm,stencil_width, &
>>>         migrationsf,distributedMesh,ierr)
>>>                   CHKERRQ(ierr)
>>>                   if (distributedMesh /= PETSC_NULL_DM) then
>>>                     call
>>>         PetscSFCreateInverseSF(migrationsf,migrationsf_inv,ierr)
>>>                     CHKERRQ(ierr)
>>>                     call
>>>         DMCreateGlobalToNatural(distributedMesh,migrationsf,migrationsf_inv,ierr)
>>>                     CHKERRQ(ierr)
>>>                     call DMGetSection(distributedMesh,section,ierr)
>>>                     CHKERRQ(ierr)
>>>                     call
>>>         PetscSectionCreate(Petsc_Comm_World,section_seq,ierr)
>>>                     CHKERRQ(ierr)
>>>                     call
>>>         PetscSFDistributeSection(migrationsf_inv,section, &
>>>         PETSC_NULL_INTEGER,section_seq,ierr)
>>>                     CHKERRQ(ierr)
>>>                     call
>>>         DMPlexCreateGlobalToNaturalSF(distributedMesh, &
>>>         section_seq,migrationsf,sf_natural,ierr)
>>>                     CHKERRQ(ierr)
>>>                     call
>>>         DMSetUseNatural(distributedMesh,PETSC_TRUE,ierr)
>>>                     CHKERRQ(ierr)
>>>                     call PetscSFDestroy(migrationsf,ierr)
>>>                     CHKERRQ(ierr)
>>>                     call PetscSFDestroy(migrationsf_inv,ierr)
>>>                     CHKERRQ(ierr)
>>>                   end if
>>>         Thanks,
>>>         Danyang
>>>>           Thanks,
>>>>              Matt
>>>>             Regards,
>>>>             Danyang
>>>>             On 2018-12-03 5:22 a.m., Matthew Knepley wrote:
>>>>>             I need to write a custom Fortran stub for this one. I
>>>>>             will get it done as soon as possible.
>>>>>               Thanks,
>>>>>                 Matt
>>>>>             On Sat, Dec 1, 2018 at 7:16 PM Danyang Su via
>>>>>             petsc-users <petsc-users at mcs.anl.gov
>>>>>             <mailto:petsc-users at mcs.anl.gov>> wrote:
>>>>>                 Hi All,
>>>>>                 I got a simple compilation error when use
>>>>>                 PetscSFDistributeSection in
>>>>>                 Fortran. It looks like the required head files are
>>>>>                 included and the
>>>>>                 parameters are correctly defined. However, when
>>>>>                 compile the code, I got
>>>>>                 error undefined reference to
>>>>>                 `petscsfdistributesection_'. The code is
>>>>>                 shown below. Did I miss anything here?
>>>>>                 #include <petsc/finclude/petscsys.h>
>>>>>                 #include <petsc/finclude/petscvec.h>
>>>>>                 #include <petsc/finclude/petscdm.h>
>>>>>                 #include <petsc/finclude/petscdmplex.h>
>>>>>                        use petscsys
>>>>>                        use petscvec
>>>>>                        use petscdm
>>>>>                        use petscdmplex
>>>>>                        implicit none
>>>>>                        PetscSection :: section, section_seq
>>>>>                        PetscSF :: migrationsf_inv, sf_natural
>>>>>                        Vec :: vec_global, vec_natural
>>>>>                        PetscErrorCode :: ierr
>>>>>                        call
>>>>>                        CHKERRQ(ierr)
>>>>>                            call
>>>>>                            CHKERRQ(ierr)
>>>>>                 Thanks,
>>>>>                 Danyang
>>>>>             What most experimenters take for granted before they
>>>>>             begin their experiments is infinitely more interesting
>>>>>             than any results to which their experiments lead.
>>>>>             -- Norbert Wiener
>>>>>             https://www.cse.buffalo.edu/~knepley/
>>>>>             <http://www.cse.buffalo.edu/~knepley/>
>>>>         What most experimenters take for granted before they begin
>>>>         their experiments is infinitely more interesting than any
>>>>         -- Norbert Wiener
>>>     What most experimenters take for granted before they begin their
>>>     experiments is infinitely more interesting than any results to
>>>     -- Norbert Wiener
> experiments is infinitely more interesting than any results to which
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20181204/b9e798a9/attachment-0001.html>
