[petsc-users] RAW binary write
Jed Brown jed at jedbrown.org
Tue Dec 4 11:59:01 CST 2018
Matthew Knepley via petsc-users <petsc-users at mcs.anl.gov> writes:
> On Tue, Dec 4, 2018 at 11:11 AM Lisandro Dalcin via petsc-users <
> petsc-users at mcs.anl.gov> wrote:
>> PetscByteSwap ? But be careful, you should (1) vec get array, byteswap,
>> vec restore array, (2) view, (3) vec get array, byteswap, vec restore
>> array. Of course, if you do not care about the final Vec contents, you can
>> just omit step (3) and let it be, let it be...
>> PS: Eventually, PETSc binary viewers should gain an API like
>> PetscViewerBinarySetByteOrder(viewer, PETSC_LITTLE_ENDIAN) ...
> Note that this enables exactly what we wanted to avoid, namely binary files
> that an incompatible with some installations.
PETSc files should contain this metadata (int sizes, endianness,
precision, and scalar type), but that would break backward
compatibility, thus be a new format (or better, adopt an existing
format, perhaps in the Apache Arrow ecosystem).
