[petsc-users] RAW binary write
Sal Am
tempohoper at gmail.com
Tue Dec 4 03:33:39 CST 2018
Thank you so much Lisandro!
That was very helpful actually and what I was looking for, but now it still
requires an intermediate step of a short python script where I have to use
byteswap() on the data to get it to work on other platforms.
Would you happen to know any way of byteswapping in petsc? I was reading
and it seems PetscBinaryWrite does byteswapping but I am not sure it would
work in my case as there are no examples with it writing a petsc vector.
Thanks and all the best
On Sun, Dec 2, 2018 at 10:01 AM Lisandro Dalcin <dalcinl at gmail.com> wrote:
> Use PetscViewerBinarySetSkipHeader(viewer, PETSC_TRUE) before VecView().
> On Thu, 29 Nov 2018 at 18:50, Sal Am via petsc-users <
> petsc-users at mcs.anl.gov> wrote:
>> Is there a way to write the solution from the system Ax=b in raw binary
>> instead of PETSc binary format?
>> Currently I am doing:
>> ierr = PetscViewerBinaryOpen(PETSC_COMM_WORLD,
>> "../../python/petscpy/Vector_x_petsc.dat", FILE_MODE_WRITE,
>> &viewer);CHKERRQ(ierr);
>> ierr = VecView(x,viewer);CHKERRQ(ierr);CHKERRQ(ierr);
>> ierr = PetscViewerDestroy(&viewer);CHKERRQ(ierr);
>> And then use PetscBinaryIO to read it back and save it using
>> write('newformat', 'wb') to get to raw... however this approach is not good
>> it seems as there are some troubles with little/big endian when using the
>> resulting converted file on other systems for post-processing.
>> Thanks,
> Lisandro Dalcin
> Research Scientist
> Computer, Electrical and Mathematical Sciences & Engineering (CEMSE)
> Extreme Computing Research Center (ECRC)
> King Abdullah University of Science and Technology (KAUST)
> http://ecrc.kaust.edu.sa/
> 4700 King Abdullah University of Science and Technology
> al-Khawarizmi Bldg (Bldg 1), Office # 0109
> Thuwal 23955-6900, Kingdom of Saudi Arabia
> http://www.kaust.edu.sa
> Office Phone: +966 12 808-0459
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20181204/1ca5011f/attachment-0001.html>
