[petsc-users] Fortran: undefined reference to petscsfdistributesection
Danyang Su
danyang.su at gmail.com
Mon Dec 3 13:27:08 CST 2018
Hi Matt,
Thanks.
BTW: DmPlexGetVertexNumbering now can work using the latest develop
version. But the index is not in natural ordering when DMSetUseNatural
is called. That's why I want to use PetscSFDistributeSection to check if
I miss anything in the code.
Danyang
On 2018-12-03 5:22 a.m., Matthew Knepley wrote:
> I need to write a custom Fortran stub for this one. I will get it done
> as soon as possible.
> Thanks,
> Matt
> On Sat, Dec 1, 2018 at 7:16 PM Danyang Su via petsc-users
> <petsc-users at mcs.anl.gov <mailto:petsc-users at mcs.anl.gov>> wrote:
> Hi All,
> I got a simple compilation error when use PetscSFDistributeSection in
> Fortran. It looks like the required head files are included and the
> parameters are correctly defined. However, when compile the code,
> I got
> error undefined reference to `petscsfdistributesection_'. The code is
> shown below. Did I miss anything here?
> #include <petsc/finclude/petscsys.h>
> #include <petsc/finclude/petscvec.h>
> #include <petsc/finclude/petscdm.h>
> #include <petsc/finclude/petscdmplex.h>
> use petscsys
> use petscvec
> use petscdm
> use petscdmplex
> implicit none
> PetscSection :: section, section_seq
> PetscSF :: migrationsf_inv, sf_natural
> Vec :: vec_global, vec_natural
> PetscErrorCode :: ierr
> call PetscSFDistributeSection(migrationsf_inv,section,
> PETSC_NULL_INTEGER,section_seq,ierr)
> CHKERRQ(ierr)
> CHKERRQ(ierr)
> Thanks,
> Danyang
> experiments is infinitely more interesting than any results to which
> their experiments lead.
> -- Norbert Wiener
> <http://www.cse.buffalo.edu/~knepley/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20181203/77e5e22a/attachment.html>
