[petsc-users] How to solve multiple linear systems in parallel, one on each process?
Mon Dec 3 08:10:59 CST 2018
On Mon, Dec 3, 2018 at 8:52 AM Klaus Burkart via petsc-users <
petsc-users at mcs.anl.gov> wrote:
> Hello,
> I want to solve a cfd case, after decomposition, I get a sub matrix
> allocated to each process. The example below shows how the data is
> allocated to the processes (the sample data includes only the lower parts
> of the matrices). Row and column addresses are local.
> What petsc program setup/concept can be used to solve multiple linear
Create the Mat and KSP with PETSC_COMM_SELF.
     Matt
> Klaus
> Sample raw data:
> process    matrix section    value                row           column
> 0        lower        1,80E-05        1        0
> 0        lower        1,80E-05        5        0
> 0        lower        1,96E-05        2        1
> 0        lower        2,20E-05        6        1
> 0        lower        1,96E-05        3        2
> 0        lower        2,20E-05        7        2
> 0        lower        1,96E-05        4        3
> 0        lower        2,20E-05        8        3
> 0        lower        2,20E-05        9        4
> 0        lower        2,20E-05        6        5
> 0        lower        1,96E-05        10        5
> 0        lower        2,44E-05        7        6
> 0        lower        2,44E-05        11        6
> 0        lower        2,44E-05        8        7
> 0        lower        2,44E-05        12        7
> 0        lower        2,44E-05        9        8
> 0        lower        2,44E-05        13        8
> 0        lower        2,44E-05        14        9
> 0        lower        2,20E-05        11        10
> 0        lower        1,96E-05        15        10
> 0        lower        2,44E-05        12        11
> 0        lower        2,44E-05        16        11
> 0        lower        2,44E-05        13        12
> 0        lower        2,44E-05        17        12
> 0        lower        2,44E-05        14        13
> 0        lower        2,44E-05        18        13
> 0        lower        2,44E-05        19        14
> 0        lower        2,20E-05        16        15
> 0        lower        1,96E-05        20        15
> 0        lower        2,44E-05        17        16
> 0        lower        2,44E-05        21        16
> 0        lower        2,44E-05        18        17
> 0        lower        2,44E-05        22        17
> 0        lower        2,44E-05        19        18
> 0        lower        2,44E-05        23        18
> 0        lower        2,44E-05        24        19
> 0        lower        2,20E-05        21        20
> 0        lower        2,44E-05        22        21
> 0        lower        2,44E-05        23        22
> 0        lower        2,44E-05        24        23
> 1        lower        2,20E-05        1        0
> 1        lower        1,96E-05        5        0
> 1        lower        2,44E-05        2        1
> 1        lower        2,44E-05        6        1
> 1        lower        2,44E-05        3        2
> 1        lower        2,44E-05        7        2
> 1        lower        2,44E-05        4        3
> 1        lower        2,44E-05        8        3
> 1        lower        2,44E-05        9        4
> 1        lower        2,20E-05        6        5
> 1        lower        1,96E-05        10        5
> 1        lower        2,44E-05        7        6
> 1        lower        2,44E-05        11        6
> 1        lower        2,44E-05        8        7
> 1        lower        2,44E-05        12        7
> 1        lower        2,44E-05        9        8
> 1        lower        2,44E-05        13        8
> 1        lower        2,44E-05        14        9
> 1        lower        2,20E-05        11        10
> 1        lower        1,96E-05        15        10
> 1        lower        2,44E-05        12        11
> 1        lower        2,44E-05        16        11
> 1        lower        2,44E-05        13        12
> 1        lower        2,44E-05        17        12
> 1        lower        2,44E-05        14        13
> 1        lower        2,44E-05        18        13
> 1        lower        2,44E-05        19        14
> 1        lower        2,20E-05        16        15
> 1        lower        1,80E-05        20        15
> 1        lower        2,44E-05        17        16
> 1        lower        2,20E-05        21        16
> 1        lower        2,44E-05        18        17
> 1        lower        2,20E-05        22        17
> 1        lower        2,44E-05        19        18
> 1        lower        2,20E-05        23        18
> 1        lower        2,20E-05        24        19
> 1        lower        1,80E-05        21        20
> 1        lower        1,96E-05        22        21
> 1        lower        1,96E-05        23        22
> 1        lower        1,96E-05        24        23
> 2        lower        1,96E-05        1        0
> 2        lower        2,20E-05        5        0
> 2        lower        1,96E-05        2        1
> 2        lower        2,20E-05        6        1
> 2        lower        1,96E-05        3        2
> 2        lower        2,20E-05        7        2
> 2        lower        1,80E-05        4        3
> 2        lower        2,20E-05        8        3
> 2        lower        1,80E-05        9        4
> 2        lower        2,44E-05        6        5
> 2        lower        2,44E-05        10        5
> 2        lower        2,44E-05        7        6
> 2        lower        2,44E-05        11        6
> 2        lower        2,44E-05        8        7
> 2        lower        2,44E-05        12        7
> 2        lower        2,20E-05        9        8
> 2        lower        2,44E-05        13        8
> 2        lower        1,96E-05        14        9
> 2        lower        2,44E-05        11        10
> 2        lower        2,44E-05        15        10
> 2        lower        2,44E-05        12        11
> 2        lower        2,44E-05        16        11
> 2        lower        2,44E-05        13        12
> 2        lower        2,44E-05        17        12
> 2        lower        2,20E-05        14        13
> 2        lower        2,44E-05        18        13
> 2        lower        1,96E-05        19        14
> 2        lower        2,44E-05        16        15
> 2        lower        2,44E-05        20        15
> 2        lower        2,44E-05        17        16
> 2        lower        2,44E-05        21        16
> 2        lower        2,44E-05        18        17
> 2        lower        2,44E-05        22        17
> 2        lower        2,20E-05        19        18
> 2        lower        2,44E-05        23        18
> 2        lower        1,96E-05        24        19
> 2        lower        2,44E-05        21        20
> 2        lower        2,44E-05        22        21
> 2        lower        2,44E-05        23        22
> 2        lower        2,20E-05        24        23
> 3        lower        2,44E-05        1        0
> 3        lower        2,44E-05        5        0
> 3        lower        2,44E-05        2        1
> 3        lower        2,44E-05        6        1
> 3        lower        2,44E-05        3        2
> 3        lower        2,44E-05        7        2
> 3        lower        2,20E-05        4        3
> 3        lower        2,44E-05        8        3
> 3        lower        1,96E-05        9        4
> 3        lower        2,44E-05        6        5
> 3        lower        2,44E-05        10        5
> 3        lower        2,44E-05        7        6
> 3        lower        2,44E-05        11        6
> 3        lower        2,44E-05        8        7
> 3        lower        2,44E-05        12        7
> 3        lower        2,20E-05        9        8
> 3        lower        2,44E-05        13        8
> 3        lower        1,96E-05        14        9
> 3        lower        2,44E-05        11        10
> 3        lower        2,44E-05        15        10
> 3        lower        2,44E-05        12        11
> 3        lower        2,44E-05        16        11
> 3        lower        2,44E-05        13        12
> 3        lower        2,44E-05        17        12
> 3        lower        2,20E-05        14        13
> 3        lower        2,44E-05        18        13
> 3        lower        1,96E-05        19        14
> 3        lower        2,44E-05        16        15
> 3        lower        2,20E-05        20        15
> 3        lower        2,44E-05        17        16
> 3        lower        2,20E-05        21        16
> 3        lower        2,44E-05        18        17
> 3        lower        2,20E-05        22        17
> 3        lower        2,20E-05        19        18
> 3        lower        2,20E-05        23        18
> 3        lower        1,80E-05        24        19
> 3        lower        1,96E-05        21        20
> 3        lower        1,96E-05        22        21
> 3        lower        1,96E-05        23        22
> 3        lower        1,80E-05        24        23
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20181203/ca2182fc/attachment.html>
