[petsc-users] How can I update a global application vector with local petsc results?
Klaus Burkart
k_burkart at yahoo.com
Sun Dec 2 05:13:41 CST 2018
Hello,
I use the following routine to transfer the petsc result back to my application which works fine using one core as the local parts of the linear system == global parts:
VecGetArray(petsc_x, &array);
for (i=rstart; i < rend; ++i) {
application_x[i] = array[i];
VecRestoreArray(petsc_x, &array);
As this updates only the local portion of x on each core but nowhere the entire/global application_x vector, multicore simulations don't work correctly.
How can I update the entire/global application_x vector with all local parts on all cores?
Klaus
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20181202/2948ccb9/attachment-0001.html>
