[petsc-users] Implementing of a variable block size BILU preconditioner
Mark Adams mfadams at lbl.gov
Sat Dec 1 21:07:59 CST 2018
There is a reason PETSc does not have variable block matrices. It is messy
and rarely a big win. It is doable, ML/Aztec does it, but it is messy.
On Sat, Dec 1, 2018 at 6:20 PM Smith, Barry F. via petsc-users <
petsc-users at mcs.anl.gov> wrote:
>    Well, you need to start somewhere. It is going to take a combination of
> this, MatLUFactorSymbolic_SeqAIJ(), MatLUFactorSymbolic_SeqAIJ() and
> MatLUFactorNumerical_SeqAIJ() to get what you want. Note that one of the
> first things you need to do is given the MatGetVariableBlockSizes()
> determine the nonzero pattern of the "variable block" matrix from the
> nonzero pattern of the SeqAIJ matrix and then do a symbolic factorization
> on that new "reduced" sparse matrix. Them you do a numerical factorization
> using the "reduced sparse matrix" factorization.
>     Barry
> > On Dec 1, 2018, at 4:54 PM, Ali Reza Khaz'ali <arkhazali at cc.iut.ac.ir>
> wrote:
> > Hi,
> > I want to implement a variable block size BILU preconditioner in PETSc.
> I am wondering if modifying the PCVPBJACOBI preconditioner (vpbjacobi.c),
> to get what I want, is a good idea.
> > Any help is much appreciated.
> > Ali Reza Khaz’ali
> > Assistant Professor of Petroleum Engineering,
> > Department of Chemical Engineering
> > Isfahan University of Technology
> > Isfahan, Iran
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20181201/5d49f71a/attachment.html>
