[petsc-users] mkl_cpardiso: Matrix B must be MATSEQDENSE matrix RICHARD MILLS READ THIS!
    Smith, Barry F.
    bsmith at mcs.anl.gov
    Fri Aug 31 12:18:41 CDT 2018
    Thanks for the update.
> On Aug 31, 2018, at 4:16 AM, Marius Buerkle <mbuerkle at web.de> wrote:
> Thanks. I had addtionally to change  MatDenseGet/RestoreArrayRead(B,&barray); to MatDenseGet/RestoreArray(B,&barray); as I got
> [1]PETSC ERROR: No support for this operation for this object type
> [1]PETSC ERROR: Cannot locate function MatDenseRestoreArrayRead_C in object
     I have fixed this in the maint and master branch.
     I have also removed the error check that required on MATSEQDENSE in maint and master so now your code should run properly with maint or master without needing you to change PETSc code.
> One more question, do I need to use MATAIJMKL as matrix type?
     To use MatMatSolve() with MKL_CPADISO you do NOT need need to use MATAIJMKL. MATAIJMKL is actually for some optimized matrix-vector operations that MKL provides and has nothing to do with MKL_CPADISO. (But since MATAIJMKL is a subclass of MATAIJ it will work with functions that work with MATAIJ such as the MatMatSolve with MKL_CPADISO.)
> It seems to work fine with MATAIJ.  And another odd thing I realized is that when I use MatAXPY on two MATAIJMKL wit DIFFERENT_NONZERO_PATTERN the resulting matrix Y is of type MATAIJ.
    This is a mis-feature, I''l report it to Richard Mills and he can determine how difficult it would be to fix (I think is should be easy just need a MatAXPY_XXXAIJMKL wrapper that uses the correct type and then calls MatAXPY_XXXAIJ)
    Barry
> best,
> Marius
> Marius,
> Try editing src/mat/impls/aij/mpi/mkl_cpardiso/mkl_cpardiso.c at the subroutine MatMatSolve_MKL_CPARDISO() and remove the lines
> ierr = PetscObjectTypeCompare((PetscObject)B,MATSEQDENSE,&flg);CHKERRQ(ierr);
> if (!flg) SETERRQ(PetscObjectComm((PetscObject)A),PETSC_ERR_ARG_WRONG,"Matrix B must be MATSEQDENSE matrix");
> ierr = PetscObjectTypeCompare((PetscObject)X,MATSEQDENSE,&flg);CHKERRQ(ierr);
> if (!flg) SETERRQ(PetscObjectComm((PetscObject)A),PETSC_ERR_ARG_WRONG,"Matrix X must be MATSEQDENSE matrix");
> Run
> make gnumake
> then try compiling and running your application again.
> Barry
> It could be that this code was cut and pasted from some other solver (Mumps) and hence has checks for SEQDENSE that are not needed for MKL_CPARDISO.
> > On Aug 31, 2018, at 2:03 AM, Marius Buerkle <mbuerkle at web.de> wrote:
> > Hi !
> > I tried to use MKL_CPARDISO solver in parallel but I get the following error
> > [0]PETSC ERROR: Invalid argument
> > [0]PETSC ERROR: Matrix B must be MATSEQDENSE matrix
> > [0]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html for trouble shooting.
> > [0]PETSC ERROR: Petsc Development GIT revision: v3.9.3-1202-ge6d955127a GIT Date: 2018-08-23 16:59:59 -0500
> > [0]PETSC ERROR: /home/marius/prog/ownstuff/fortran/programs/transomat_dev/transomat/transomat on a named tono-hpc1 by marius Fri Aug 31 15:57:15 2018
> > [0]PETSC ERROR: Configure options --prefix=/home/marius/prog/petsc/master_opt --with-64-bit-indices=0 --CC=mpicc --COPTFLAGS="-O3 -march=native -g -std=c11" --CXX=mpicxx --CXXOPTFLAGS="-O3 -march=native -g -std=c++11" --FC=mpiifort --FOPTFLAGS="-O2 -xHost -g" --with-mpi=1 --with-x=1 --download-parmetis=yes --download-metis=yes --download-ptscotch=yes --download-scotch=yes --download-mumps=yes --with-blaslapack-lib="-L/home/marius/intel/compilers_and_libraries_2018.3.222/linux/mkl/lib/intel64 -lmkl_scalapack_lp64 -lmkl_intel_lp64 -lmkl_intel_thread -lmkl_core -lmkl_blacs_intelmpi_lp64 -liomp5 -lpthread -lm -ldl" --with-scalapack-lib="-L/home/marius/intel/compilers_and_libraries_2018.3.222/linux/mkl/lib/intel64 -lmkl_scalapack_lp64 -lmkl_intel_lp64 -lmkl_intel_thread -lmkl_core -lmkl_blacs_intelmpi_lp64 -liomp5 -lpthread -lm -ldl" --download-pastix=no --download-superlu_dist=yes --download-superlu_dist-commit=803c8ab665b33e9136b199c4521be465e026bb0d --download-hwloc=yes --with-mkl_pardiso-dir=/home/marius/intel/compilers_and_libraries_2018.3.222/linux/mkl --with-openmp=0 --with-pthread=0 --download-elemental=yes --download-elemental-commit=de7b5bea1abf5f626b91582f742cf99e2e551bff --with-mkl_cpardiso-dir=/home/marius/intel/compilers_and_libraries_2018.3.222/linux/mkl --with-mkl_sparse_optimize-dir=/home/marius/intel/compilers_and_libraries_2018.3.222/linux/mkl --with-mkl_sparse_sp2m-dir=/home/marius/intel/compilers_and_libraries_2018.3.222/linux/mkl --download-sowing=yes --with-cxx-dialect=c++11 --with-scalar-type=complex --with-debugging=0
> > [0]PETSC ERROR: #1 MatMatSolve_MKL_CPARDISO() line 319 in /home/marius/prog/petsc/petsc/src/mat/impls/aij/mpi/mkl_cpardiso/mkl_cpardiso.c
> > [0]PETSC ERROR: #2 MatMatSolve() line 3385 in /home/marius/prog/petsc/petsc/src/mat/interface/matrix.c
> > I wonder isn't CPARDISO supposed to work with MATMPIDENSE ?
> > best,
> > marius
