[petsc-users] converting matrices between petsc and scalapack/blacs format?
Giacomo Mulas
giacomo.mulas at inaf.it
Fri Aug 31 11:32:51 CDT 2018
On Fri, 31 Aug 2018, Matthew Knepley wrote:
> Yes, that is all correct. I wonder if you could convince a) SLEPc to
> support Elpa, or better convince Elpa to support Elemental. BLACS is icky
> inside :)
Yes, I know BLACS is... complicated, and I'd rather do without it
altogether if I could. But unfortunately both ELPA and the scalapack
implementation in MKL distribute big arrays with that. And I'm afraid I have
no superpowers to convince either SLEPc to support Elpa or Elpa to support
Elemental, unfortunately. I'm a mere end (ab)user...
Thanks for your help. I was able to reread a Petsc matrix saved via MatView
in binary format into a BLACS one, it was not even as bad as I was afraid it
would be.
Cheers
Giacomo
_________________________________________________________________
Giacomo Mulas <giacomo.mulas at inaf.it>
INAF - Osservatorio Astronomico di Cagliari
via della scienza 5 - 09047 Selargius (CA)
tel. +39 070 71180255
mob. : +39 329 6603810
"When the storms are raging around you, stay right where you are"
(Freddy Mercury)
