[petsc-users] Problem compiling with 64bit PETSc
TAY wee-beng zonexo at gmail.com
Fri Aug 31 00:52:12 CDT 2018
Hi Randy,
I was about to email why it didn't work even after changing them to
PetscInt. Then I realise that ierr should be defined as PetscErrorCode.
Thank you very much.
Yours sincerely,
TAY Wee-Beng (Zheng Weiming) 郑伟明
Personal research webpage: http://tayweebeng.wixsite.com/website
Youtube research showcase: https://www.youtube.com/channel/UC72ZHtvQNMpNs2uRTSToiLA
linkedin: www.linkedin.com/in/tay-weebeng
On 31/8/2018 11:36 AM, Randall Mackie wrote:
> Don’t forget that not all integers passed into PETSc routines are 64 bit.
> For example, the error codes when called from Fortran should be
> defined as PetscErrorCode and not PetscInt.
> It’s really good to get into the habit of correctly declaring all
> PETSc variables according to the web pages, so that you can easily
> switch between 32bit and 64bit integers.
> Randy
>> On Aug 30, 2018, at 7:43 PM, Smith, Barry F. <bsmith at mcs.anl.gov
>> <mailto:bsmith at mcs.anl.gov>> wrote:
>>> On Aug 30, 2018, at 9:40 PM, TAY wee-beng <zonexo at gmail.com
>>> <mailto:zonexo at gmail.com>> wrote:
>>> On 31/8/2018 10:38 AM, Smith, Barry F. wrote:
>>>>  PetscReal is by default real(8) you can leave those alone
>>>>   Any integer you pass to a PETSc routine needs to be declared as
>>>> PetscInt (not integer) otherwise the 64 bit indices stuff won't work.
>>>>   Barry
>>> Hi,
>>> ok, I got it. Btw, is it advisable to change all integer in my code
>>> to PetscInt?
>>> Will it cause any conflict or waste a lot of memory?
>>> Or should I only change those related to PETSc?
>>    That is up to you. Since you probably pass the values between
>> PETSc and non-PETSc part of the code it is probably easier just to
>> make all the integer PetscInt instead. No performance difference that
>> you can measure by keeping a few integer around.
>>    Barry
>>> Thanks!
>>>>> On Aug 30, 2018, at 9:35 PM, TAY wee-beng <zonexo at gmail.com
>>>>> On 31/8/2018 10:21 AM, Matthew Knepley wrote:
>>>>>> On Thu, Aug 30, 2018 at 10:17 PM TAY wee-beng <zonexo at gmail.com
>>>>>> Hi,
>>>>>> Due to my increase grid size, I have to go 64bit. I compiled the
>>>>>> 64bit
>>>>>> PETSc w/o error. However, when I tried to compile my code using the
>>>>>> 64bit PETSc, I got the error below. May I know why is this so?
>>>>>> What changes should I make?
>>>>>> Is it possible that you did not declare some inputs as PetscInt,
>>>>>> so the interface check is failing?
>>>>>>   Matt
>>>>> Hi,
>>>>> I'm using the standard
>>>>> integer ::
>>>>> real(8) ::
>>>>> for some variables. For some others relating to PETSc, I use PetscInt.
>>>>> Should I change all to PetscInt and PetscReal?
>>>>> Currently, I use real(8) for all real values. If I change all to
>>>>> PetscReal, will PetscReal be real or real(8) by default?
>>>>> Thanks!
>>>>>> [tsltaywb at nus02 ibm3d_IIB_mpi]$ make -f makefile_2018
>>>>>> /app/intel/xe2018/compilers_and_libraries_2018.0.128/linux/mpi/intel64/bin/mpif90
>>>>>> -g -ip -ipo -O3 -c -fPIC  -save kinefunc.F90
>>>>>> -g -ip -ipo -O3 -c -fPIC  -save  -w
>>>>>> -I/home/users/nus/tsltaywb/propeller/lib/petsc-3.9.3_intel_2018_64bit_rel/include
>>>>>> -I/app/intel/xe2018/compilers_and_libraries_2018.0.128/linux/mpi/intel64/include
>>>>>> global.F90
>>>>>> global.F90(979): error #6285: There is no matching specific
>>>>>> subroutine
>>>>>> for this generic subroutine call.   [DMDACREATE3D]
>>>>>> call
>>>>>> DMDACreate3d(MPI_COMM_WORLD,DM_BOUNDARY_NONE,DM_BOUNDARY_NONE,DM_BOUNDARY_NONE,DMDA_STENCIL_STAR,size_x,size_y,&
>>>>>> global.F90(989): error #6285: There is no matching specific
>>>>>> subroutine
>>>>>>     call
>>>>>> global.F90(997): error #6285: There is no matching specific
>>>>>> subroutine
>>>>>>     call
>>>>>> global.F90(1005): error #6285: There is no matching specific
>>>>>> subroutine
>>>>>>     call
>>>>>> global.F90(1013): error #6285: There is no matching specific
>>>>>> subroutine
>>>>>>     call
>>>>>> global.F90(1021): error #6285: There is no matching specific
>>>>>> subroutine
>>>>>>     call
>>>>>> global.F90(1029): error #6285: There is no matching specific
>>>>>> subroutine
>>>>>>     call
>>>>>> compilation aborted for global.F90 (code 1)
>>>>>> Yours sincerely,
>>>>>> <http://www.linkedin.com/in/tay-weebeng>
>>>>>> What most experimenters take for granted before they begin their
>>>>>> experiments is infinitely more interesting than any results to
>>>>>> which their experiments lead.
>>>>>> -- Norbert Wiener
>>>>>> https://www.cse.buffalo.edu/~knepley/
>>>>>> <https://www.cse.buffalo.edu/%7Eknepley/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20180831/58f2a449/attachment-0001.html>
