[petsc-users] Problem compiling with 64bit PETSc
TAY wee-beng
zonexo at gmail.com
Thu Aug 30 21:35:05 CDT 2018
On 31/8/2018 10:21 AM, Matthew Knepley wrote:
> On Thu, Aug 30, 2018 at 10:17 PM TAY wee-beng <zonexo at gmail.com
> <mailto:zonexo at gmail.com>> wrote:
> Hi,
> Due to my increase grid size, I have to go 64bit. I compiled the
> 64bit
> PETSc w/o error. However, when I tried to compile my code using the
> 64bit PETSc, I got the error below. May I know why is this so?
> What changes should I make?
> Is it possible that you did not declare some inputs as PetscInt, so
> the interface check is failing?
> Matt
I'm using the standard
integer ::
real(8) ::
for some variables. For some others relating to PETSc, I use PetscInt.
Should I change all to PetscInt and PetscReal?
Currently, I use real(8) for all real values. If I change all to
PetscReal, will PetscReal be real or real(8) by default?
Thanks!
> [tsltaywb at nus02 ibm3d_IIB_mpi]$ make -f makefile_2018
> /app/intel/xe2018/compilers_and_libraries_2018.0.128/linux/mpi/intel64/bin/mpif90
> -g -ip -ipo -O3 -c -fPIC -save kinefunc.F90
> -g -ip -ipo -O3 -c -fPIC -save -w
> -I/home/users/nus/tsltaywb/propeller/lib/petsc-3.9.3_intel_2018_64bit_rel/include
> -I/app/intel/xe2018/compilers_and_libraries_2018.0.128/linux/mpi/intel64/include
> global.F90
> global.F90(979): error #6285: There is no matching specific
> subroutine
> for this generic subroutine call. [DMDACREATE3D]
> call
> DMDACreate3d(MPI_COMM_WORLD,DM_BOUNDARY_NONE,DM_BOUNDARY_NONE,DM_BOUNDARY_NONE,DMDA_STENCIL_STAR,size_x,size_y,&
> global.F90(989): error #6285: There is no matching specific
> subroutine
> call
> global.F90(997): error #6285: There is no matching specific
> subroutine
> call
> global.F90(1005): error #6285: There is no matching specific
> subroutine
> call
> global.F90(1013): error #6285: There is no matching specific
> subroutine
> call
> global.F90(1021): error #6285: There is no matching specific
> subroutine
> call
> global.F90(1029): error #6285: There is no matching specific
> subroutine
> call
> compilation aborted for global.F90 (code 1)
> Thank you very much.
> Yours sincerely,
> TAY Wee-Beng (Zheng Weiming) 郑伟明
> Personal research webpage: http://tayweebeng.wixsite.com/website
> Youtube research showcase:
> https://www.youtube.com/channel/UC72ZHtvQNMpNs2uRTSToiLA
> linkedin: www.linkedin.com/in/tay-weebeng
> <http://www.linkedin.com/in/tay-weebeng>
> experiments is infinitely more interesting than any results to which
> their experiments lead.
> -- Norbert Wiener
> <http://www.cse.buffalo.edu/%7Eknepley/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20180831/38074943/attachment.html>
