[petsc-users] Integration of hyper & trilinos
Fazlul Huq huq2090 at gmail.com
Thu Aug 30 10:59:41 CDT 2018
I did that and I got the following error:
**************************ERROR*************************************
  Error during compile, check arch-linux2-c-debug/lib/petsc/conf/make.log
  Send it and arch-linux2-c-debug/lib/petsc/conf/configure.log to
petsc-maint at mcs.anl.gov
Huq
On Thu, Aug 30, 2018 at 10:55 AM Jed Brown <jed at jedbrown.org> wrote:
> Fazlul Huq <huq2090 at gmail.com> writes:
> > I have run:
> > jimmy at dave:~/projects/petsc$ ./configure --download-hyper
> > jimmy at dave:~/projects/petsc$ ./configure --download-ml
> The package name is hypre, not hyper.  And you need to pass both at once
> if you want both libraries to be available.
> > At the end I got following message:
> xxx=========================================================================xxx
> >  Configure stage complete. Now build PETSc libraries with (gnumake
> build):
> >    make PETSC_DIR=/home/jimmy/projects/petsc
> PETSC_ARCH=arch-linux2-c-debug
> > all
> > Am I ready to use it now or do I need no make it first?
> As the message says, you need to issue that command to build.
> > Or do I need to edit .bashrc file with,
> > export PETSC_DIR=/home/jimmy/projects/petsc
> > export PETSC_ARCH=arch-linux2-c-debug all
> > And then run make from command window?
> > Thanks.
> > Huq
> > On Thu, Aug 30, 2018 at 9:40 AM Jed Brown <jed at jedbrown.org> wrote:
> >> You would configure PETSc with --download-hypre and --download-ml (this
> >> part of Trilinos can be installed on its own).  Then run your
> >> application with run-time options like -pc_type hypre or -pc_type ml.
> >> See the user's manual and/or tutorials.
> >> > Hello Petsc developers,
> >> > 1. I want to integrate petsc with hyper and trilinos cause I want to
> >> solve
> >> > some   problems using multigrid. I know, I need to download and
> install
> >> > both of them and then configure petsc with hyper and trilinos to use
> them
> >> > with petsc. But, I don't know how to configure petsc with hyper and
> >> > trilinos or any other package. Is it like, running some command from
> >> > terminal or editing .bashrc file? Currently, this is the .bashrc file
> >> > regarding petsc in my desktop:
> >> > 2. Can I use c programming routine in petsc code and make and run it?
> If
> >> > yes then what is the procedure? Last day I tried to do that but I got
> >> error
> >> > message while making the file.
> >> > Thanks.
> >> > Fazlul Huq
> >> > Graduate Research Assistant
> >> > Department of Nuclear, Plasma & Radiological Engineering (NPRE)
> >> > University of Illinois at Urbana-Champaign (UIUC)
> >> > E-mail: huq2090 at gmail.com
> > Fazlul Huq
Fazlul Huq
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20180830/8183b2a9/attachment.html>
