[petsc-users] MatSetValues error with ViennaCL types
Manuel Valera
mvalera-w at sdsu.edu
Wed Aug 29 17:21:29 CDT 2018
I understand that Matthew, thanks,
I am trying to see if i get any speedup in this configuration, otherwise i
will be waiting for the MPIAIJ support on PETSc,
Is there any other gpu preconditioner that works on parallel matrices
directly?
Thanks again,
On Wed, Aug 29, 2018 at 3:05 PM, Matthew Knepley <knepley at gmail.com> wrote:
> On Wed, Aug 29, 2018 at 5:49 PM Manuel Valera <mvalera-w at sdsu.edu> wrote:
>> Update:
>> I made it work like you suggested Barry, i had to comment the code line
>> to set up the pc_type saviennacl, that way i am getting as ksp_view:
>> KSP Object: 2 MPI processes
>> type: cg
>> maximum iterations=10000, initial guess is zero
>> tolerances: relative=1e-07, absolute=1e-50, divergence=10000.
>> left preconditioning
>> using PRECONDITIONED norm type for convergence test
>> PC Object: 2 MPI processes
>> type: bjacobi
>> number of blocks = 2
>> Local solve is same for all blocks, in the following KSP and PC
>> objects:
>> KSP Object: (sub_) 1 MPI processes
>> type: preonly
>> tolerances: relative=1e-05, absolute=1e-50, divergence=10000.
>> using NONE norm type for convergence test
>> PC Object: (sub_) 1 MPI processes
>> type: ilu
>> out-of-place factorization
>> 0 levels of fill
>> tolerance for zero pivot 2.22045e-14
>> matrix ordering: natural
>> factor fill ratio given 1., needed 1.
>> Factored matrix follows:
>> Mat Object: 1 MPI processes
>> type: seqaij
>> rows=75, cols=75
>> package used to perform factorization: petsc
>> total: nonzeros=927, allocated nonzeros=927
>> total number of mallocs used during MatSetValues calls =0
>> not using I-node routines
>> linear system matrix = precond matrix:
>> type: seqaijviennacl
>> rows=75, cols=75
>> total: nonzeros=927, allocated nonzeros=1335
>> total number of mallocs used during MatSetValues calls =84
>> Mat Object: 2 MPI processes
>> type: mpiaijviennacl
>> rows=125, cols=125
>> total: nonzeros=1685, allocated nonzeros=2885
>> total number of mallocs used during MatSetValues calls =184
>> has attached near null space
>> Press_Max: 1.9995807630564922E-004
>> This is what we want, right?
>> Still if i try using pc_type saviennacl directly it breaks,
> You are missing the point of the error message.
> We do not support SAVIENNACL on parallel matrices (MPIAIJ). We do support
> it
> on serial matrices (SEQAIJ). When you are setting in directly, you are
> applying it
> to a parallel matrix. If you use Block-Jacobi, you are applying it to each
> submatrix,
> and those submatrices are all serial.
> Thanks,
> Matt
>> Thanks for your help i'll try my speedup like this,
>> On Wed, Aug 29, 2018 at 2:21 PM, Manuel Valera <mvalera-w at sdsu.edu>
>> wrote:
>>> Ok, executing with:
>>> mpirun -n 2 ./gcmLEP.GPU tc=TestCases/LockRelease/LE_6x6x6/
>>> jid=tiny_cuda_test_n1 -pc_type bjacobi -pc_sub_type saviennacl -ksp_view
>>> I get:
>>> SETTING GPU TYPES
>>> Matrix type: mpiaijviennacl
>>> Of sizes: 125 x 125
>>> Of sizes: 125 x 125
>>> [0]PETSC ERROR: --------------------- Error Message
>>> [0]PETSC ERROR: No support for this operation for this object type
>>> [0]PETSC ERROR: Currently only handles ViennaCL matrices
>>> [0]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html
>>> for trouble shooting.
>>> [0]PETSC ERROR: Petsc Development GIT revision: v3.9.3-1264-g6fb0cd4
>>> GIT Date: 2018-08-29 12:42:36 -0600
>>> [0]PETSC ERROR: ./gcmLEP.GPU on a cuda-debug named node50 by valera Wed
>>> Aug 29 14:20:42 2018
>>> [0]PETSC ERROR: Configure options PETSC_ARCH=cuda-debug --with-cc=mpicc
>>> --with-cxx=mpic++ --with-fc=mpifort --COPTFLAGS=-O2 --CXXOPTFLAGS=-O2
>>> --FOPTFLAGS=-O2 --with-shared-libraries=1 --with-debugging=1 --with-cuda=1
>>> --CUDAFLAGS=-arch=sm_60 --with-blaslapack-dir=/usr/lib64
>>> --download-viennacl --download-cusp
>>> [0]PETSC ERROR: #1 PCSetUp_SAVIENNACL() line 47 in
>>> /home/valera/petsc/src/ksp/pc/impls/saviennaclcuda/saviennacl.cu
>>> [0]PETSC ERROR: #2 PCSetUp() line 932 in /home/valera/petsc/src/ksp/pc/
>>> interface/precon.c
>>> [1]PETSC ERROR: ------------------------------
>>> [1]PETSC ERROR: Caught signal number 11 SEGV: Segmentation Violation,
>>> probably memory access out of range
>>> [1]PETSC ERROR: Try option -start_in_debugger or
>>> -on_error_attach_debugger
>>> [1]PETSC ERROR: or see http://www.mcs.anl.gov/petsc/
>>> documentation/faq.html#valgrind
>>> [1]PETSC ERROR: or try http://valgrind.org on GNU/linux and Apple Mac
>>> OS X to find memory corruption errors
>>> [1]PETSC ERROR: likely location of problem given in stack below
>>> [1]PETSC ERROR: --------------------- Stack Frames
>>> [1]PETSC ERROR: Note: The EXACT line numbers in the stack are not
>>> available,
>>> [1]PETSC ERROR: INSTEAD the line number of the start of the
>>> function
>>> [1]PETSC ERROR: is given.
>>> [1]PETSC ERROR: [1] PetscTraceBackErrorHandler line 182
>>> /home/valera/petsc/src/sys/error/errtrace.c
>>> [1]PETSC ERROR: [1] PetscError line 352 /home/valera/petsc/src/sys/
>>> error/err.c
>>> [1]PETSC ERROR: [1] PCSetUp_SAVIENNACL line 45
>>> [1]PETSC ERROR: [1] PCSetUp line 894 /home/valera/petsc/src/ksp/pc/
>>> interface/precon.c
>>> [1]PETSC ERROR: --------------------- Error Message
>>> [1]PETSC ERROR: Signal received
>>> [1]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html
>>> [1]PETSC ERROR: Petsc Development GIT revision: v3.9.3-1264-g6fb0cd4
>>> [1]PETSC ERROR: ./gcmLEP.GPU on a cuda-debug named node50 by valera Wed
>>> [1]PETSC ERROR: Configure options PETSC_ARCH=cuda-debug --with-cc=mpicc
>>> [1]PETSC ERROR: #1 User provided function() line 0 in unknown file
>>> MPI_ABORT was invoked on rank 1 in communicator MPI_COMM_WORLD
>>> with errorcode 59.
>>> NOTE: invoking MPI_ABORT causes Open MPI to kill all MPI processes.
>>> You may or may not see output from other processes, depending on
>>> exactly when Open MPI kills them.
>>> [0]PETSC ERROR: ------------------------------
>>> [0]PETSC ERROR: Caught signal number 15 Terminate: Some process (or the
>>> batch system) has told this process to end
>>> [0]PETSC ERROR: Try option -start_in_debugger or
>>> [0]PETSC ERROR: or see http://www.mcs.anl.gov/petsc/
>>> [0]PETSC ERROR: or try http://valgrind.org on GNU/linux and Apple Mac
>>> [0]PETSC ERROR: likely location of problem given in stack below
>>> [0]PETSC ERROR: --------------------- Stack Frames
>>> [0]PETSC ERROR: Note: The EXACT line numbers in the stack are not
>>> available,
>>> [0]PETSC ERROR: INSTEAD the line number of the start of the
>>> function
>>> [0]PETSC ERROR: is given.
>>> [0]PETSC ERROR: [0] PetscCommDuplicate line 130
>>> /home/valera/petsc/src/sys/objects/tagm.c
>>> [0]PETSC ERROR: [0] PetscHeaderCreate_Private line 41
>>> /home/valera/petsc/src/sys/objects/inherit.c
>>> [0]PETSC ERROR: [0] ISCreate line 35 /home/valera/petsc/src/vec/is/
>>> is/interface/isreg.c
>>> [0]PETSC ERROR: [0] ISCreateGeneral line 658
>>> /home/valera/petsc/src/vec/is/is/impls/general/general.c
>>> [0]PETSC ERROR: [0] PCSetUp_SAVIENNACL line 45
>>> [0]PETSC ERROR: [0] PCSetUp line 894 /home/valera/petsc/src/ksp/pc/
>>> interface/precon.c
>>> [0]PETSC ERROR: Signal received
>>> [0]PETSC ERROR: #3 User provided function() line 0 in unknown file
>>> [node50:77836] 1 more process has sent help message help-mpi-api.txt /
>>> mpi-abort
>>> [node50:77836] Set MCA parameter "orte_base_help_aggregate" to 0 to see
>>> all help / error messages
>>> On Wed, Aug 29, 2018 at 2:02 PM, Smith, Barry F. <bsmith at mcs.anl.gov>
>>> wrote:
>>>> Please send complete error message
>>>> > On Aug 29, 2018, at 3:40 PM, Manuel Valera <mvalera-w at sdsu.edu>
>>>> wrote:
>>>> > Yeah, no sorry, i get the same error with -pc_type bjacobi
>>>> -sub_pc_type SAVIENNACL : "Currently only handles ViennaCL matrices"
>>>> > Thanks and let me know of any progress on this issue,
>>>> > On Wed, Aug 29, 2018 at 1:37 PM, Manuel Valera <mvalera-w at sdsu.edu>
>>>> wrote:
>>>> > Awesome, thanks!
>>>> > On Wed, Aug 29, 2018 at 1:29 PM, Smith, Barry F. <bsmith at mcs.anl.gov>
>>>> wrote:
>>>> > > On Aug 29, 2018, at 3:26 PM, Manuel Valera <mvalera-w at sdsu.edu>
>>>> wrote:
>>>> > > You may need to use just plain PCBJACOBI or PCASM for parallelism
>>>> and then SAVIENNACL sequentially on each block.
>>>> > > Can you elaborate a little in how to do this? do you mean i can
>>>> only use viennacl in serial at the moment or this is a suggestion of a
>>>> workaround on how to make it work?
>>>> > -pc_type bjacobi -sub_pc_type SAVIENNACL
>>>> > This will run in parallel and utilize the GPU for each block of
>>>> the preconditioner.
>>>> > Barry
>>>> > > Thanks,
>>>> > > > On Aug 29, 2018, at 1:50 PM, Manuel Valera <mvalera-w at sdsu.edu>
>>>> wrote:
>>>> > > > Hi everyone,
>>>> > > > Thanks for your responses, i understand communicating on this way
>>>> to this level of technicality can be hard, i still think we can work ways
>>>> to solve this problem though,
>>>> > > > I can say the following at this point:
>>>> > > > • Program works without issues in any other non-gpu
>>>> preconditioner, just by calling -pc_type ### .
>>>> > > > • Program works correctly with ViennaCL preconditioners
>>>> with mpirun -n 1, that is on one processor.
>>>> > > > • Program breaks with every ViennaCL preconditioner when
>>>> attempting any more than 1 processors.
>>>> > > > • I haven't tried other GPU preconditioners because
>>>> ViennaCL gave the best performance in 1 processor before.
>>>> > > > • I have made sure the matrix type is mpiaijviennacl as it
>>>> is printed right before the error log.
>>>> > > > • I am attaching what i think are the backtrace logs of the
>>>> run with two cores, as i have limited experience with this kind of
>>>> debugging, and i cannot make sense of what they say, please let me know if
>>>> you need me to do something else.
>>>> > > > Current options i can think of are giving you permission to clone
>>>> my model repo, or for you to guide me trough the process remotely,
>>>> > > > Thanks,
>>>> > > > The error i get is still:
>>>> > > > Of sizes: 125 x 125
>>>> > > > Of sizes: 125 x 125
>>>> documentation/faq.html for trouble shooting.
>>>> v3.9.2-549-g779ab53 GIT Date: 2018-05-31 17:31:13 +0300
>>>> valera Wed Aug 29 11:43:25 2018
>>>> --with-mpi-dir=/usr/lib64/openmpi --COPTFLAGS=-O2 --CXXOPTFLAGS=-O2
>>>> --download-viennacl
>>>> /home/valera/petsc/src/ksp/pc/interface/precon.c
>>>> > > > [0]PETSC ERROR: #3 KSPSetUp() line 381 in
>>>> /home/valera/petsc/src/ksp/ksp/interface/itfunc.c
>>>> Violation, probably memory access out of range
>>>> Apple Mac OS X to find memory corruption errors
>>>> available,
>>>> function
>>>> /home/valera/petsc/src/sys/error/err.c
>>>> > > > [1]PETSC ERROR: [1] KSPSetUp line 294 /home/valera/petsc/src/ksp/
>>>> --download-viennacl
>>>> file
>>>> > > > with errorcode 59.
>>>> processes.
>>>> (or the batch system) has told this process to end
>>>> available,
>>>> function
>>>> > > > [0]PETSC ERROR: [0] MatSetErrorIfFailure line 116
>>>> /home/valera/petsc/src/mat/utils/gcreate.c
>>>> > > > [0]PETSC ERROR: [0] KSPSetUp line 294 /home/valera/petsc/src/ksp/
>>>> --download-viennacl
>>>> > > > [0]PETSC ERROR: #4 User provided function() line 0 in unknown
>>>> file
>>>> > > > [node50:32783] 1 more process has sent help message
>>>> help-mpi-api.txt / mpi-abort
>>>> > > > [node50:32783] Set MCA parameter "orte_base_help_aggregate" to 0
>>>> to see all help / error messages
>>>> > > > On Tue, Aug 28, 2018 at 9:34 PM, Karl Rupp <rupp at iue.tuwien.ac.at>
>>>> wrote:
>>>> > > > Hi Manuel,
>>>> > > > as Barry said, it is hard for us to provide any help without
>>>> having a more complete picture of what is going on.
>>>> > > > The error you report seems to come from the AMG preconditioner in
>>>> ViennaCL. This can have many origins. Do other preconditioners run without
>>>> error? Can you run in a debugger and provide a complete backtrace?
>>>> > > > Thanks and best regards,
>>>> > > > Karli
>>>> > > > On 08/29/2018 01:33 AM, Manuel Valera wrote:
>>>> > > > Talked too fast,
>>>> > > > After fixing that problem, i tried more than one mpi processor
>>>> and got the following:
>>>> > > > Of sizes: 125 x 125
>>>> > > > Of sizes: 125 x 125
>>>> valera Tue Aug 28 16:30:02 2018
>>>> --download-viennacl
>>>> /home/valera/petsc/src/ksp/pc/impls/saviennaclcuda/saviennacl.cu <
>>>> http://saviennacl.cu>
>>>> available,
>>>> function
>>>> /home/valera/petsc/src/ksp/pc/impls/saviennaclcuda/saviennacl.cu<
>>>> --download-viennacl
>>>> file
>>>> > > > with errorcode 59.
>>>> processes.
>>>> available,
>>>> function
>>>> > > > [0]PETSC ERROR: [0] PetscHeaderCreate_Private line 34
>>>> /home/valera/petsc/src/vec/is/is/interface/isreg.c
>>>> > > > [0]PETSC ERROR: [0] ISCreateGeneral line 668
>>>> --download-viennacl
>>>> file
>>>> > > > [node50:30582] 1 more process has sent help message
>>>> > > > [node50:30582] Set MCA parameter "orte_base_help_aggregate" to 0
>>>> > > > It is currently running in 1 mpi processor + GPU but i would like
>>>> to call at least 16 mpi processors + GPU to do the rest of the data
>>>> management who is not part of the main laplacian on the mpi and the
>>>> laplacian solution on the GPU, is this currently possible?
>>>> > > > Thanks for your help,
>>>> > > > On Tue, Aug 28, 2018 at 4:21 PM, Manuel Valera <
>>>> mvalera-w at sdsu.edu <mailto:mvalera-w at sdsu.edu>> wrote:
>>>> > > > Ok, i found the culprit and we can close this thread,
>>>> > > > The problem was a missing variable for setting the maximum
>>>> columns,
>>>> > > > which i deleted at some point without realizing. The error
>>>> message
>>>> > > > was too ambiguous to catch this so i had to compare with a
>>>> previous
>>>> > > > working version of the arguments of MatSetValues, it was
>>>> evident then.
>>>> > > > Good news is that i can now set the values with the viennacl
>>>> types too,
>>>> > > > Thanks for your kind help,
>>>> > > > Manuel
>>>> > > > On Tue, Aug 28, 2018 at 11:25 AM, Smith, Barry F.
>>>> > > > <bsmith at mcs.anl.gov <mailto:bsmith at mcs.anl.gov>> wrote:
>>>> > > > 1) PetscMalloc() is never valid or needed in Fortran
>>>> > > > 2) there is no reason to use
>>>> DMSetMatrixPreallocateOnly()
>>>> > > > just use DMCreateMatrix() assuming that using a DM (DMDA,
>>>> > > > DMPLEX, etc) is suitable for your problem.
>>>> > > > At this end we are totally guessing at what you are
>>>> doing
>>>> > > > and so have little help we can provide. A simple,
>>>> nonworking
>>>> > > > code that tries to do what you would need would help us a
>>>> great
>>>> > > > deal in understanding that you are trying to do.
>>>> > > > Barry
>>>> > > > > On Aug 28, 2018, at 1:18 PM, Manuel Valera
>>>> > > > <mvalera-w at sdsu.edu <mailto:mvalera-w at sdsu.edu>> wrote:
>>>> > > > > Matthew, PetscMalloc gives the same error,
>>>> > > > > Barry, it would be very hard for me to get the code to
>>>> a
>>>> > > > minimum working example, i guess all i need to understand
>>>> is how
>>>> > > > to setup a DM matrix with DMSetMatrixPreallocateOnly()
>>>> instead
>>>> > > > of MatMPIAIJSetPreallocation() as we were doing before,
>>>> is there
>>>> > > > a simple example who does this in Fortran?
>>>> > > > > Is the PetscMalloc call needed? is 'call
>>>> > > > PetscMalloc(1,row,ierr)' a valid, compilable call to
>>>> > > > PetscMalloc? what other reason may there be for this
>>>> error to
>>>> > > > happen ?
>>>> > > > > Just remembering, that trying to setup the matrix with
>>>> the
>>>> > > > MatAIJSetPreallocation() brings up an error to
>>>> acknowledge the
>>>> > > > viennacl datatypes and that's why i'm trying to make this
>>>> change
>>>> > > > on your recommendation,
>>>> > > > > On Mon, Aug 27, 2018 at 7:35 PM, Smith, Barry F.
>>>> > > > > Send your code in a way we can compile and run it;
>>>> it must
>>>> > > > be some simple issue that is hard to communicate in email.
>>>> > > > > Barry
>>>> > > > > > On Aug 27, 2018, at 5:51 PM, Manuel Valera
>>>> > > > > > Hello everyone,
>>>> > > > > > I just had time to work on this again, and checked
>>>> the code
>>>> > > > for errors on the matrix entries, this is the exact code
>>>> i was
>>>> > > > using for creating the matrix without
>>>> > > > DMSetMatrixPreallocateOnly, using
>>>> MatMPIAIJSetPreallocation and
>>>> > > > it worked that way, but trying this way i get the same
>>>> 'Column
>>>> > > > too large' error using any number at the column position
>>>> of
>>>> > > > MatSetValues,
>>>> > > > > > I have set up my code to print the column argument
>>>> (n) of
>>>> > > > MatSetValues and in this case is 7 (lower than 124), it
>>>> still
>>>> > > > gives error, even entering a specific number in the
>>>> MatSetValues
>>>> > > > column argument position gives the same error.
>>>> > > > > > So next i went back to ex.50 here:
>>>> petsc-current/src/ts/examples/tutorials/ex50.c.html
>>>> > > > <http://www.mcs.anl.gov/petsc/petsc-current/src/ts/
>>>> examples/tutorials/ex50.c.html>
>>>> > > > and it has a very similar structure except the
>>>> PetscMalloc1()
>>>> > > > call, so i tried adding that and got:
>>>> > > > > > /home/valera/ParGCCOM/Src/DMDALaplacian.f90:114:
>>>> undefined
>>>> > > > reference to `petscmalloc1_'
>>>> > > > > > Any ideas on this behaviour?
>>>> > > > > > Thanks so much,
>>>> > > > > > On Thu, Aug 16, 2018 at 11:20 AM, Smith, Barry F.
>>>> > > > > > Column too large: col 10980 max 124
>>>> > > > > > You need to check the code that is generating the
>>>> matrix
>>>> > > > entries. The matrix has 124 columns but you are
>>>> attempting to
>>>> > > > put a value at column 10980
>>>> > > > > > Barry
>>>> > > > > > > On Aug 15, 2018, at 9:44 PM, Manuel Valera
>>>> > > > > > > Thanks Matthew and Barry,
>>>> > > > > > > Now my code looks like:
>>>> > > > > > > call DMSetMatrixPreallocateOnly(
>>>> daDummy,PETSC_TRUE,ierr)
>>>> > > > > > > call DMSetMatType(daDummy,MATMPIAIJVIENNACL,ierr)
>>>> > > > > > > call DMSetVecType(daDummy,VECMPIVIENNACL,ierr)
>>>> > > > > > > call DMCreateMatrix(daDummy,A,ierr)
>>>> > > > > > > call MatSetFromOptions(A,ierr)
>>>> > > > > > > call MatSetUp(A,ierr)
>>>> > > > > > > call
>>>> > > > MatSetValues(A,1,row,sumpos,pos(0:iter-1),vals(0:iter-1),
>>>> INSERT_VALUES,ierr)
>>>> > > > > > > call MatAssemblyBegin(A, MAT_FINAL_ASSEMBLY, ierr)
>>>> > > > > > > call MatAssemblyEnd(A, MAT_FINAL_ASSEMBLY, ierr)
>>>> > > > > > > And i get a different error, now is:
>>>> > > > > > > [0]PETSC ERROR: Argument out of range
>>>> > > > > > > [0]PETSC ERROR: Column too large: col 10980 max 124
>>>> > > > > > > [0]PETSC ERROR: See
>>>> > > > <http://www.mcs.anl.gov/petsc/documentation/faq.html> for
>>>> > > > trouble shooting.
>>>> node50
>>>> > > > by valera Wed Aug 15 19:40:00 2018
>>>> > > > --CXXOPTFLAGS=-O2 --FOPTFLAGS=-O2
>>>> > > > --with-debugging=1 --with-cuda=1 --CUDAFLAGS=-arch=sm_60
>>>> > > > --with-blaslapack-dir=/usr/lib64 --download-viennacl
>>>> > > > > > > [0]PETSC ERROR: #1 MatSetValues_SeqAIJ() line 442
>>>> in
>>>> > > > /home/valera/petsc/src/mat/impls/aij/seq/aij.c
>>>> > > > > > > [0]PETSC ERROR: #2 MatSetValues() line 1339 in
>>>> > > > /home/valera/petsc/src/mat/interface/matrix.c
>>>> > > > > > > Thanks again,
>>>> > > > > > > On Wed, Aug 15, 2018 at 7:02 PM, Smith, Barry F.
>>>> > > > > > > Should be
>>>> > > > > > > and remove the rest. You need to set the type of
>>>> Mat
>>>> > > > you want the DM to return BEFORE you create the matrix.
>>>> > > > > > > Barry
>>>> > > > > > > > On Aug 15, 2018, at 4:45 PM, Manuel Valera
>>>> > > > > > > > Ok thanks for clarifying that, i wasn't sure if
>>>> there
>>>> > > > were different types,
>>>> > > > > > > > Here is a stripped down version of my code, it
>>>> seems
>>>> > > > like the preallocation is working now since the matrix
>>>> > > > population part is working without problem, but here it
>>>> is for
>>>> > > > illustration purposes:
>>>> > > > > > > > call
>>>> > > > MatMPIAIJSetPreallocation(A,19,PETSC_NULL_INTEGER,19,
>>>> PETSC_NULL_INTEGER,ierr)
>>>> > > > > > > > call
>>>> INSERT_VALUES,ierr)
>>>> ierr)
>>>> > > > > > > > Adding the first line there did the trick,
>>>> > > > > > > > Now the problem seems to be the program is not
>>>> > > > recognizing the matrix as ViennaCL type when i try with
>>>> more
>>>> > > > than one processor, i get now:
>>>> Message
>>>> for this
>>>> > > > object type
>>>> matrices
>>>> > > > > > > > [0]PETSC ERROR: See
>>>> > > > trouble shooting.
>>>> named
>>>> > > > node50 by valera Wed Aug 15 14:44:22 2018
>>>> in
>>>> nacl.cu
>>>> > > > <http://saviennacl.cu>
>>>> > > > > > > > When running with:
>>>> > > > > > > > mpirun -n 1 ./gcmLEP.GPU
>>>> > > > tc=TestCases/LockRelease/LE_6x6x6/ jid=tiny_cuda_test_n2
>>>> > > > -ksp_type cg -dm_vec_type viennacl -dm_mat_type
>>>> aijviennacl
>>>> > > > -pc_type saviennacl -log_view
>>>> > > > > > > > Thanks,
>>>> > > > > > > > On Wed, Aug 15, 2018 at 2:32 PM, Matthew Knepley
>>>> > > > <knepley at gmail.com <mailto:knepley at gmail.com>> wrote:
>>>> > > > > > > > On Wed, Aug 15, 2018 at 5:20 PM Manuel Valera
>>>> > > > > > > > It seems to be resumed on: I do not know how to
>>>> > > > preallocate a DM Matrix correctly.
>>>> > > > > > > > There is only one matrix type, Mat. There are no
>>>> > > > separate DM matrices. A DM can create a matrix for you
>>>> > > > > > > > using DMCreateMatrix(), but that is a Mat and it
>>>> is
>>>> > > > preallocated correctly. I am not sure what you are doing.
>>>> > > > > > > > Thanks,
>>>> > > > > > > > Matt
>>>> > > > > > > > The interesting part is that it only breaks when
>>>> i need
>>>> > > > to populate a GPU matrix from MPI, so kudos on that, but
>>>> it
>>>> > > > seems i need to do better on my code to get this setup
>>>> working,
>>>> > > > > > > > Any help would be appreciated,
>>>> > > > > > > > Thanks,
>>>> > > > > > > > On Wed, Aug 15, 2018 at 2:15 PM, Matthew Knepley
>>>> > > > > > > > On Wed, Aug 15, 2018 at 4:53 PM Manuel Valera
>>>> > > > > > > > Thanks Matthew,
>>>> > > > > > > > I try to do that when calling:
>>>> > > > > > > > call
>>>> > > > > > > > But i am not aware on how to do this for the DM
>>>> if it
>>>> > > > needs something more specific/different,
>>>> > > > > > > > The error says that your preallocation is wrong
>>>> for the
>>>> > > > values you are putting in. The DM does not control either,
>>>> > > > > > > > so I do not understand your email.
>>>> > > > > > > > Thanks,
>>>> > > > > > > > Matt
>>>> > > > > > > > Thanks,
>>>> > > > > > > > On Wed, Aug 15, 2018 at 1:51 PM, Matthew Knepley
>>>> > > > > > > > On Wed, Aug 15, 2018 at 4:39 PM Manuel Valera
>>>> > > > > > > > Hello PETSc devs,
>>>> > > > > > > > I am running into an error when trying to use the
>>>> > > > MATMPIAIJVIENNACL Matrix type in MPI calls, the same code
>>>> runs
>>>> > > > for MATSEQAIJVIENNACL type in one processor. The error
>>>> happens
>>>> > > > when calling MatSetValues for this specific
>>>> configuration. It
>>>> > > > does not occur when using MPI DMMatrix types only.
>>>> > > > > > > > The DM properly preallocates the matrix. I am
>>>> assuming
>>>> > > > you do not here.
>>>> > > > > > > > Matt
>>>> > > > > > > > Any help will be appreciated,
>>>> > > > > > > > Thanks,
>>>> > > > > > > > My program call:
>>>> aijviennacl
>>>> > > > > > > > The error (repeats after each MatSetValues call):
>>>> Message
>>>> > > > > > > > [1]PETSC ERROR: Argument out of range
>>>> > > > > > > > [1]PETSC ERROR: Inserting a new nonzero at global
>>>> > > > row/column (75, 50) into matrix
>>>> > > > > > > > [1]PETSC ERROR: See
>>>> > > > trouble shooting.
>>>> named
>>>> > > > node50 by valera Wed Aug 15 13:10:44 2018
>>>> > > > > > > > [1]PETSC ERROR: #1 MatSetValues_MPIAIJ() line
>>>> 608 in
>>>> > > > /home/valera/petsc/src/mat/impls/aij/mpi/mpiaij.c
>>>> > > > > > > > [1]PETSC ERROR: #2 MatSetValues() line 1339 in
>>>> > > > > > > > My Code structure:
>>>> > > > > > > > call MPI_Comm_size(PETSC_COMM_WORLD, numprocs,
>>>> ierr)
>>>> > > > > > > > if (numprocs > 1) then ! set matrix type
>>>> parallel
>>>> > > > > > > > ! Get local size
>>>> > > > > > > > call DMDACreateNaturalVector(
>>>> daDummy,Tmpnat,ierr)
>>>> > > > > > > > call VecGetLocalSize(Tmpnat,locsize,ierr)
>>>> > > > > > > > call VecDestroy(Tmpnat,ierr)
>>>> > > > > > > > ! Set matrix
>>>> > > > > > > > #ifdef GPU
>>>> > > > > > > > call MatSetType(A,MATAIJVIENNACL,ierr)
>>>> > > > > > > > print*,'SETTING GPU TYPES'
>>>> > > > > > > > #else
>>>> > > > > > > > call DMSetMatType(daDummy,MATMPIAIJ,ierr)
>>>> > > > > > > > call DMSetMatType(daDummy,VECMPI,ierr)
>>>> > > > > > > > call MatSetType(A,MATMPIAIJ,ierr)!
>>>> > > > > > > > #endif
>>>> > > > > > > > call
>>>> > > > > > > > else ! set matrix type
>>>> sequential
>>>> > > > > > > > #ifdef GPU
>>>> MATSEQAIJVIENNACL,ierr)
>>>> VECSEQVIENNACL,ierr)
>>>> > > > > > > > call MatSetType(A,MATSEQAIJVIENNACL,ierr)
>>>> > > > > > > > #else
>>>> > > > > > > > call DMSetMatType(daDummy,MATSEQAIJ,ierr)
>>>> > > > > > > > call DMSetMatType(daDummy,VECSEQ,ierr)
>>>> > > > > > > > call MatSetType(A,MATSEQAIJ,ierr)
>>>> > > > > > > > #endif
>>>> > > > > > > > call
>>>> > > > getCenterInfo(daGrid,xstart,ystart,zstart,xend,yend,zend)
>>>> > > > > > > > do k=zstart,zend-1
>>>> > > > > > > > do j=ystart,yend-1
>>>> > > > > > > > do i=xstart,xend-1
>>>> > > > > > > > call
>>>> INSERT_VALUES,ierr)
>>>> > > > > > > > What most experimenters take for granted before
>>>> they
>>>> > > > begin their experiments is infinitely more interesting
>>>> than any
>>>> > > > results to which their experiments lead.
>>>> > > > > > > > -- Norbert Wiener
>>>> > > > > > > > https://www.cse.buffalo.edu/~knepley/
>>>> > > > <https://www.cse.buffalo.edu/%7Eknepley/>
>>>> they
>>>> than any
>>>> > > > > > > > -- Norbert Wiener
>>>> they
>>>> than any
>>>> > > > > > > > -- Norbert Wiener
>>>> > > > <backt-2.log><backt.log>
> experiments lead.
> -- Norbert Wiener
> <http://www.cse.buffalo.edu/~knepley/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20180829/29153d48/attachment-0001.html>
