[petsc-users] MatSetValues error with ViennaCL types
Manuel Valera mvalera-w at sdsu.edu
Wed Aug 29 13:50:58 CDT 2018
Hi everyone,
Thanks for your responses, i understand communicating on this way to this
level of technicality can be hard, i still think we can work ways to solve
this problem though,
I can say the following at this point:
   - Program works without issues in any other non-gpu preconditioner, just
   by calling -pc_type ### .
   - Program works correctly with ViennaCL preconditioners with mpirun -n
   1, that is on one processor.
   - Program breaks with every ViennaCL preconditioner when attempting any
   more than 1 processors.
   - I haven't tried other GPU preconditioners because ViennaCL gave the
   best performance in 1 processor before.
   - I have made sure the matrix type is mpiaijviennacl as it is printed
   right before the error log.
   - I am attaching what i think are the backtrace logs of the run with two
   cores, as i have limited experience with this kind of debugging, and i
   cannot make sense of what they say, please let me know if you need me to do
   something else.
Current options i can think of are giving you permission to clone my model
repo, or for you to guide me trough the process remotely,
The error i get is still:
 Matrix type: mpiaijviennacl
 Of sizes:          125 x         125
 Of sizes:          125 x         125
[0]PETSC ERROR: --------------------- Error Message
[0]PETSC ERROR: No support for this operation for this object type
[0]PETSC ERROR: Currently only handles ViennaCL matrices
[0]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html for
trouble shooting.
[0]PETSC ERROR: Petsc Development GIT revision: v3.9.2-549-g779ab53  GIT
Date: 2018-05-31 17:31:13 +0300
[0]PETSC ERROR: ./gcmLEP.GPU on a cuda-debug named node50 by valera Wed Aug
29 11:43:25 2018
[0]PETSC ERROR: Configure options PETSC_ARCH=cuda-debug
--with-mpi-dir=/usr/lib64/openmpi --COPTFLAGS=-O2 --CXXOPTFLAGS=-O2
--FOPTFLAGS=-O2 --with-shared-libraries=1 --with-debugging=1 --with-cuda=1
--CUDAFLAGS=-arch=sm_60 --with-blaslapack-dir=/usr/lib64 --download-viennacl
[0]PETSC ERROR: #1 PCSetUp_SAVIENNACL() line 47 in
/home/valera/petsc/src/ksp/pc/impls/saviennaclcuda/saviennacl.cu
[0]PETSC ERROR: #2 PCSetUp() line 932 in
/home/valera/petsc/src/ksp/pc/interface/precon.c
[0]PETSC ERROR: #3 KSPSetUp() line 381 in
/home/valera/petsc/src/ksp/ksp/interface/itfunc.c
[1]PETSC ERROR:
[1]PETSC ERROR: Caught signal number 11 SEGV: Segmentation Violation,
probably memory access out of range
[1]PETSC ERROR: Try option -start_in_debugger or -on_error_attach_debugger
[1]PETSC ERROR: or see
http://www.mcs.anl.gov/petsc/documentation/faq.html#valgrind
[1]PETSC ERROR: or try http://valgrind.org on GNU/linux and Apple Mac OS X
to find memory corruption errors
[1]PETSC ERROR: likely location of problem given in stack below
[1]PETSC ERROR: ---------------------  Stack Frames
[1]PETSC ERROR: Note: The EXACT line numbers in the stack are not available,
[1]PETSC ERROR:       INSTEAD the line number of the start of the function
[1]PETSC ERROR:       is given.
[1]PETSC ERROR: [1] PetscTraceBackErrorHandler line 182
/home/valera/petsc/src/sys/error/errtrace.c
[1]PETSC ERROR: [1] PetscError line 352
/home/valera/petsc/src/sys/error/err.c
[1]PETSC ERROR: [1] PCSetUp_SAVIENNACL line 45
[1]PETSC ERROR: [1] PCSetUp line 894
[1]PETSC ERROR: [1] KSPSetUp line 294
[1]PETSC ERROR: --------------------- Error Message
[1]PETSC ERROR: Signal received
[1]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html for
trouble shooting.
[1]PETSC ERROR: Petsc Development GIT revision: v3.9.2-549-g779ab53  GIT
[1]PETSC ERROR: ./gcmLEP.GPU on a cuda-debug named node50 by valera Wed Aug
29 11:43:25 2018
[1]PETSC ERROR: Configure options PETSC_ARCH=cuda-debug
[1]PETSC ERROR: #1 User provided function() line 0 in  unknown file
MPI_ABORT was invoked on rank 1 in communicator MPI_COMM_WORLD
with errorcode 59.
NOTE: invoking MPI_ABORT causes Open MPI to kill all MPI processes.
You may or may not see output from other processes, depending on
exactly when Open MPI kills them.
[0]PETSC ERROR:
[0]PETSC ERROR: Caught signal number 15 Terminate: Some process (or the
batch system) has told this process to end
[0]PETSC ERROR: Try option -start_in_debugger or -on_error_attach_debugger
[0]PETSC ERROR: or see
[0]PETSC ERROR: or try http://valgrind.org on GNU/linux and Apple Mac OS X
[0]PETSC ERROR: likely location of problem given in stack below
[0]PETSC ERROR: ---------------------  Stack Frames
[0]PETSC ERROR: Note: The EXACT line numbers in the stack are not available,
[0]PETSC ERROR:       INSTEAD the line number of the start of the function
[0]PETSC ERROR:       is given.
[0]PETSC ERROR: [0] MatSetErrorIfFailure line 116
/home/valera/petsc/src/mat/utils/gcreate.c
[0]PETSC ERROR: [0] PCSetUp line 894
[0]PETSC ERROR: [0] PCSetUp_SAVIENNACL line 45
[0]PETSC ERROR: [0] KSPSetUp line 294
[0]PETSC ERROR: Signal received
trouble shooting.
29 11:43:25 2018
[0]PETSC ERROR: #4 User provided function() line 0 in  unknown file
[node50:32783] 1 more process has sent help message help-mpi-api.txt /
mpi-abort
[node50:32783] Set MCA parameter "orte_base_help_aggregate" to 0 to see all
help / error messages
On Tue, Aug 28, 2018 at 9:34 PM, Karl Rupp <rupp at iue.tuwien.ac.at> wrote:
> Hi Manuel,
> as Barry said, it is hard for us to provide any help without having a more
> complete picture of what is going on.
> The error you report seems to come from the AMG preconditioner in
> ViennaCL. This can have many origins. Do other preconditioners run without
> error? Can you run in a debugger and provide a complete backtrace?
> Thanks and best regards,
> Karli
> On 08/29/2018 01:33 AM, Manuel Valera wrote:
>> Talked too fast,
>> After fixing that problem, i tried more than one mpi processor and got
>> the following:
>>   Of sizes:          125 x         125
>>   Of sizes:          125 x         125
>> for trouble shooting.
>> [0]PETSC ERROR: ./gcmLEP.GPU on a cuda-debug named node50 by valera Tue
>> Aug 28 16:30:02 2018
>> --download-viennacl
>> /home/valera/petsc/src/ksp/pc/impls/saviennaclcuda/saviennacl.cu <
>> http://saviennacl.cu>
>> [0]PETSC ERROR: #2 PCSetUp() line 932 in /home/valera/petsc/src/ksp/pc/
>> interface/precon.c
>> [1]PETSC ERROR: ------------------------------
>> [1]PETSC ERROR: or see http://www.mcs.anl.gov/petsc/d
>> X to find memory corruption errors
>> available,
>> [1]PETSC ERROR: [1] PetscError line 352 /home/valera/petsc/src/sys/err
>> or/err.c
>> [1]PETSC ERROR: [1] PCSetUp line 894 /home/valera/petsc/src/ksp/pc/
>> interface/precon.c
>> [1]PETSC ERROR: ./gcmLEP.GPU on a cuda-debug named node50 by valera Tue
>> --download-viennacl
>> with errorcode 59.
>> [0]PETSC ERROR: ------------------------------
>> [0]PETSC ERROR: or see http://www.mcs.anl.gov/petsc/d
>> available,
>> [0]PETSC ERROR: [0] PetscCommDuplicate line 130
>> /home/valera/petsc/src/sys/objects/tagm.c
>> [0]PETSC ERROR: [0] PetscHeaderCreate_Private line 34
>> /home/valera/petsc/src/sys/objects/inherit.c
>> [0]PETSC ERROR: [0] ISCreate line 35 /home/valera/petsc/src/vec/is/
>> is/interface/isreg.c
>> [0]PETSC ERROR: [0] ISCreateGeneral line 668
>> /home/valera/petsc/src/vec/is/is/impls/general/general.c
>> [0]PETSC ERROR: [0] PCSetUp line 894 /home/valera/petsc/src/ksp/pc/
>> interface/precon.c
>> --download-viennacl
>> [0]PETSC ERROR: #3 User provided function() line 0 in  unknown file
>> [node50:30582] 1 more process has sent help message help-mpi-api.txt /
>> mpi-abort
>> [node50:30582] Set MCA parameter "orte_base_help_aggregate" to 0 to see
>> all help / error messages
>> It is currently running in 1 mpi processor + GPU but i would like to call
>> at least 16 mpi processors + GPU to do the rest of the data management who
>> is not part of the main laplacian on the mpi and the laplacian solution on
>> the GPU, is this currently possible?
>> Thanks for your help,
>> On Tue, Aug 28, 2018 at 4:21 PM, Manuel Valera <mvalera-w at sdsu.edu
>> <mailto:mvalera-w at sdsu.edu>> wrote:
>>     Ok, i found the culprit and we can close this thread,
>>     The problem was a missing variable for setting the maximum columns,
>>     which i deleted at some point without realizing. The error message
>>     was too ambiguous to catch this so i had to compare with a previous
>>     working version of the arguments of MatSetValues, it was evident then.
>>     Good news is that i can now set the values with the viennacl types
>> too,
>>     Thanks for your kind help,
>>     Manuel
>>     On Tue, Aug 28, 2018 at 11:25 AM, Smith, Barry F.
>>     <bsmith at mcs.anl.gov <mailto:bsmith at mcs.anl.gov>> wrote:
>>             1) PetscMalloc() is never valid or needed in Fortran
>>              2) there is no reason to use DMSetMatrixPreallocateOnly()
>>         just use DMCreateMatrix() assuming that using a DM (DMDA,
>>         DMPLEX, etc) is suitable for your problem.
>>              At this end we are totally guessing at what you are doing
>>         and so have little help we can provide.  A simple, nonworking
>>         code that tries to do what you would need would help us a great
>>         deal in understanding that you are trying to do.
>>               Barry
>>          > On Aug 28, 2018, at 1:18 PM, Manuel Valera
>>         <mvalera-w at sdsu.edu <mailto:mvalera-w at sdsu.edu>> wrote:
>>          > Matthew, PetscMalloc gives the same error,
>>          > Barry, it would be very hard for me to get the code to a
>>         minimum working example, i guess all i need to understand is how
>>         to setup a DM matrix with DMSetMatrixPreallocateOnly() instead
>>         of MatMPIAIJSetPreallocation() as we were doing before, is there
>>         a simple example who does this in Fortran?
>>          > Is the PetscMalloc call needed? is 'call
>>         PetscMalloc(1,row,ierr)' a valid, compilable call to
>>         PetscMalloc? what other reason may there be for this error to
>>         happen ?
>>          > Just remembering, that trying to setup the matrix with the
>>         MatAIJSetPreallocation() brings up an error to acknowledge the
>>         viennacl datatypes and that's why i'm trying to make this change
>>         on your recommendation,
>>          > On Mon, Aug 27, 2018 at 7:35 PM, Smith, Barry F.
>>          >    Send your code in a way we can compile and run it; it must
>>         be some simple issue that is hard to communicate in email.
>>          >    Barry
>>          > > On Aug 27, 2018, at 5:51 PM, Manuel Valera
>>          > > Hello everyone,
>>          > > I just had time to work on this again, and checked the code
>>         for errors on the matrix entries, this is the exact code i was
>>         using for creating the matrix without
>>         DMSetMatrixPreallocateOnly, using MatMPIAIJSetPreallocation and
>>         it worked that way, but trying this way i get the same 'Column
>>         too large' error using any number at the column position of
>>         MatSetValues,
>>          > > I have set up my code to print the column argument (n) of
>>         MatSetValues and in this case is 7 (lower than 124), it still
>>         gives error, even entering a specific number in the MatSetValues
>>         column argument position gives the same error.
>>          > > So next i went back to ex.50 here:
>>         http://www.mcs.anl.gov/petsc/petsc-current/src/ts/examples/t
>> utorials/ex50.c.html
>>         <http://www.mcs.anl.gov/petsc/petsc-current/src/ts/examples/
>> tutorials/ex50.c.html>
>>         and it has a very similar structure except the PetscMalloc1()
>>         call, so i tried adding that and got:
>>          > >  /home/valera/ParGCCOM/Src/DMDALaplacian.f90:114: undefined
>>         reference to `petscmalloc1_'
>>          > > Any ideas on this behaviour?
>>          > > Thanks so much,
>>          > > On Thu, Aug 16, 2018 at 11:20 AM, Smith, Barry F.
>>          > > Column too large: col 10980 max 124
>>          > >    You need to check the code that is generating the matrix
>>         entries. The matrix has 124 columns but you are attempting to
>>         put a value at column 10980
>>          > >    Barry
>>          > > > On Aug 15, 2018, at 9:44 PM, Manuel Valera
>>          > > > Thanks Matthew and Barry,
>>          > > > Now my code looks like:
>>          > > > call DMSetMatrixPreallocateOnly(daDummy,PETSC_TRUE,ierr)
>>          > > > call DMSetMatType(daDummy,MATMPIAIJVIENNACL,ierr)
>>          > > > call DMSetVecType(daDummy,VECMPIVIENNACL,ierr)
>>          > > > call DMCreateMatrix(daDummy,A,ierr)
>>          > > > call MatSetFromOptions(A,ierr)
>>          > > > call MatSetUp(A,ierr)
>>          > > >             call
>>         MatSetValues(A,1,row,sumpos,pos(0:iter-1),vals(0:iter-1),INS
>> ERT_VALUES,ierr)
>>          > > > call MatAssemblyBegin(A, MAT_FINAL_ASSEMBLY, ierr)
>>          > > > call MatAssemblyEnd(A, MAT_FINAL_ASSEMBLY, ierr)
>>          > > > And i get a different error, now is:
>>          > > > [0]PETSC ERROR: Argument out of range
>>          > > > [0]PETSC ERROR: Column too large: col 10980 max 124
>>          > > > [0]PETSC ERROR: See
>>         <http://www.mcs.anl.gov/petsc/documentation/faq.html> for
>>         trouble shooting.
>>         v3.9.2-549-g779ab53  GIT Date: 2018-05-31 17:31:13 +0300
>>         by valera Wed Aug 15 19:40:00 2018
>>         --CXXOPTFLAGS=-O2 --FOPTFLAGS=-O2 --with-shared-libraries=1
>>         --with-debugging=1 --with-cuda=1 --CUDAFLAGS=-arch=sm_60
>>          > > > [0]PETSC ERROR: #1 MatSetValues_SeqAIJ() line 442 in
>>         /home/valera/petsc/src/mat/impls/aij/seq/aij.c
>>          > > > [0]PETSC ERROR: #2 MatSetValues() line 1339 in
>>         /home/valera/petsc/src/mat/interface/matrix.c
>>          > > > Thanks again,
>>          > > > On Wed, Aug 15, 2018 at 7:02 PM, Smith, Barry F.
>>          > > >   Should be
>>          > > >   and remove the rest. You need to set the type of Mat
>>         you want the DM to return BEFORE you create the matrix.
>>          > > >   Barry
>>          > > > > On Aug 15, 2018, at 4:45 PM, Manuel Valera
>>          > > > > Ok thanks for clarifying that, i wasn't sure if there
>>         were different types,
>>          > > > > Here is a stripped down version of my code, it seems
>>         like the preallocation is working now since the matrix
>>         population part is working without problem, but here it is for
>>         illustration purposes:
>>          > > > > call
>>         MatMPIAIJSetPreallocation(A,19,PETSC_NULL_INTEGER,19,PETSC_
>> NULL_INTEGER,ierr)
>>          > > > >             call
>> ERT_VALUES,ierr)
>>          > > > > Adding the first line there did the trick,
>>          > > > > Now the problem seems to be the program is not
>>         recognizing the matrix as ViennaCL type when i try with more
>>         than one processor, i get now:
>>         object type
>>          > > > > [0]PETSC ERROR: See
>>         trouble shooting.
>>         node50 by valera Wed Aug 15 14:44:22 2018
>>         <http://saviennacl.cu>
>>          > > > > When running with:
>>          > > > > mpirun -n 1 ./gcmLEP.GPU
>>         tc=TestCases/LockRelease/LE_6x6x6/ jid=tiny_cuda_test_n2
>>         -ksp_type cg -dm_vec_type viennacl -dm_mat_type aijviennacl
>>         -pc_type saviennacl -log_view
>>          > > > > Thanks,
>>          > > > > On Wed, Aug 15, 2018 at 2:32 PM, Matthew Knepley
>>         <knepley at gmail.com <mailto:knepley at gmail.com>> wrote:
>>          > > > > On Wed, Aug 15, 2018 at 5:20 PM Manuel Valera
>>          > > > > It seems to be resumed on: I do not know how to
>>         preallocate a DM Matrix correctly.
>>          > > > > There is only one matrix type, Mat. There are no
>>         separate DM matrices. A DM can create a matrix for you
>>          > > > > using DMCreateMatrix(), but that is a Mat and it is
>>         preallocated correctly. I am not sure what you are doing.
>>          > > > >   Thanks,
>>          > > > >     Matt
>>          > > > > The interesting part is that it only breaks when i need
>>         to populate a GPU matrix from MPI, so kudos on that, but it
>>         seems i need to do better on my code to get this setup working,
>>          > > > > Any help would be appreciated,
>>          > > > > Thanks,
>>          > > > > On Wed, Aug 15, 2018 at 2:15 PM, Matthew Knepley
>>          > > > > On Wed, Aug 15, 2018 at 4:53 PM Manuel Valera
>>          > > > > Thanks Matthew,
>>          > > > > I try to do that when calling:
>>          > > > > call
>> NULL_INTEGER,ierr)
>>          > > > > But i am not aware on how to do this for the DM if it
>>         needs something more specific/different,
>>          > > > > The error says that your preallocation is wrong for the
>>         values you are putting in. The DM does not control either,
>>          > > > > so I do not understand your email.
>>          > > > >   Thanks,
>>          > > > >      Matt
>>          > > > > Thanks,
>>          > > > > On Wed, Aug 15, 2018 at 1:51 PM, Matthew Knepley
>>          > > > > On Wed, Aug 15, 2018 at 4:39 PM Manuel Valera
>>          > > > > Hello PETSc devs,
>>          > > > > I am running into an error when trying to use the
>>         MATMPIAIJVIENNACL Matrix type in MPI calls, the same code runs
>>         for MATSEQAIJVIENNACL type in one processor. The error happens
>>         when calling MatSetValues for this specific configuration. It
>>         does not occur when using MPI DMMatrix types only.
>>          > > > > The DM properly preallocates the matrix. I am assuming
>>         you do not here.
>>          > > > >    Matt
>>          > > > > Any help will be appreciated,
>>          > > > > Thanks,
>>          > > > > My program call:
>>          > > > > mpirun -n 2 ./gcmLEP.GPU
>>          > > > > The error (repeats after each MatSetValues call):
>>          > > > > [1]PETSC ERROR: Argument out of range
>>          > > > > [1]PETSC ERROR: Inserting a new nonzero at global
>>         row/column (75, 50) into matrix
>>          > > > > [1]PETSC ERROR: See
>>         trouble shooting.
>>         node50 by valera Wed Aug 15 13:10:44 2018
>>          > > > > [1]PETSC ERROR: #1 MatSetValues_MPIAIJ() line 608 in
>>         /home/valera/petsc/src/mat/impls/aij/mpi/mpiaij.c
>>          > > > > [1]PETSC ERROR: #2 MatSetValues() line 1339 in
>>          > > > > My Code structure:
>>          > > > > call MPI_Comm_size(PETSC_COMM_WORLD, numprocs, ierr)
>>          > > > > if (numprocs > 1) then  ! set matrix type parallel
>>          > > > >     ! Get local size
>>          > > > >     call DMDACreateNaturalVector(daDummy,Tmpnat,ierr)
>>          > > > >     call VecGetLocalSize(Tmpnat,locsize,ierr)
>>          > > > >     call VecDestroy(Tmpnat,ierr)
>>          > > > >     ! Set matrix
>>          > > > > #ifdef GPU
>>          > > > >     call MatSetType(A,MATAIJVIENNACL,ierr)
>>          > > > >     print*,'SETTING GPU TYPES'
>>          > > > > #else
>>          > > > >     call DMSetMatType(daDummy,MATMPIAIJ,ierr)
>>          > > > >     call DMSetMatType(daDummy,VECMPI,ierr)
>>          > > > >     call MatSetType(A,MATMPIAIJ,ierr)!
>>          > > > > #endif
>>          > > > >     call
>> NULL_INTEGER,ierr)
>>          > > > > else                    ! set matrix type sequential
>>          > > > > #ifdef GPU
>>          > > > >     call DMSetMatType(daDummy,MATSEQAIJVIENNACL,ierr)
>>          > > > >     call DMSetVecType(daDummy,VECSEQVIENNACL,ierr)
>>          > > > >     call MatSetType(A,MATSEQAIJVIENNACL,ierr)
>>          > > > > #else
>>          > > > >     call DMSetMatType(daDummy,MATSEQAIJ,ierr)
>>          > > > >     call DMSetMatType(daDummy,VECSEQ,ierr)
>>          > > > >     call MatSetType(A,MATSEQAIJ,ierr)
>>          > > > > #endif
>>          > > > > call
>>         getCenterInfo(daGrid,xstart,ystart,zstart,xend,yend,zend)
>>          > > > > do k=zstart,zend-1
>>          > > > >     do j=ystart,yend-1
>>          > > > >         do i=xstart,xend-1
>>          > > > >            call
>> ERT_VALUES,ierr)
>>          > > > > What most experimenters take for granted before they
>>         begin their experiments is infinitely more interesting than any
>>         results to which their experiments lead.
>>          > > > > -- Norbert Wiener
>>          > > > > https://www.cse.buffalo.edu/~knepley/
>>         <https://www.cse.buffalo.edu/%7Eknepley/>
>>          > > > > -- Norbert Wiener
>>          > > > > -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20180829/20865f51/attachment-0001.html>
Type: text/x-log
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20180829/20865f51/attachment-0002.bin>
Type: text/x-log
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20180829/20865f51/attachment-0003.bin>
