[petsc-users] Use block Jacobi preconditioner with SNES
Ali Reza Khaz'ali
arkhazali at cc.iut.ac.ir
Wed Aug 29 11:26:03 CDT 2018
Barry,
Thank you very much. I placed MatSetVariableBlockSizes after Jacobian
assembly and/or before SNESSolve. In both cases, It could not solve a
30x30x10 system (which has been solved before), apparently because of
the huge amount of RAM it required (~3GB). I don't have a lot of RAM on
my laptop (I only have 4GB). The log output is as follows, please note
that the number of blocks of the bjacobi preconditioner is reported as
1, which I think it means that it has tried to solve the whole Jacobian
matrix with the direct method. If it is true, the amount of required RAM
is justified. However, the same code can successfully solve a smaller
system (10x10x5 for example).
Best regards,
Ali
On 8/29/2018 7:40 PM, Smith, Barry F. wrote:
> You need to add the line
> ierr = MatSetVariableBlockSizes(J,3,lens);CHKERRQ(ierr);
> with the number of blocks replacing 3 and the sizes of each block in lens
> Barry
>> On Aug 29, 2018, at 4:27 AM, Ali Reza Khaz'ali <arkhazali at cc.iut.ac.ir> wrote:
>> Barry,
>> Thanks a lot for your efforts. Using PCVPBJACOBI causes SNESSolve to throw the following error (the code and the system being simulated is the same, just PCBJACOBI changed to PCVPBJACOBI):
>> [0]PETSC ERROR: --------------------- Error Message ---------------------------------------
>> [0]PETSC ERROR: Nonconforming object sizes
>> [0]PETSC ERROR: Total blocksizes 0 doesn't match number matrix rows 108000
>> [0]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html for trouble shooting.
>> [0]PETSC ERROR: Petsc Development GIT revision: v3.9.3-1238-g434eb0c8b5 GIT Date: 2018-08-28 19:19:26 -0500
>> [0]PETSC ERROR: E:\Documents\Visual Studio 2015\Projects\compsim\x64\Release\compsim.exe on a named ALIREZA-PC by AliReza Wed Aug 29 13:46:38 2018
>> [0]PETSC ERROR: Configure options --prefix=/home/alireza/PetscGit --with-mkl_pardiso-dir=/cygdrive/E/Program_Files_x86/IntelSWTools/compilers_and_libraries/windows/mkl --
>> with-hypre-include=/cygdrive/E/hypre-2.11.2/Builds/Bins/include --with-hypre-lib=/cygdrive/E/hypre-2.11.2/Builds/Bins/lib/HYPRE.lib --with-ml-include=/cygdrive/E/Trilinos
>> -master/Bins/include --with-ml-lib=/cygdrive/E/Trilinos-master/Bins/lib/ml.lib ظôwith-openmp --with-cc="win32fe icl" --with-fc="win32fe ifort" --with-mpi-include=/cygdri
>> ve/E/Program_Files_x86/IntelSWTools/compilers_and_libraries/windows/mpi/intel64/include --with-mpi-lib=/cygdrive/E/Program_Files_x86/IntelSWTools/compilers_and_libraries/
>> windows/mpi/intel64/lib/impi.lib --with-mpi-mpiexec=/cygdrive/E/Program_Files_x86/IntelSWTools/compilers_and_libraries/windows/mpi/intel64/bin/mpiexec.exe --with-debuggin
>> g=0 --with-blas-lib=/cygdrive/E/Program_Files_x86/IntelSWTools/compilers_and_libraries/windows/mkl/lib/intel64_win/mkl_rt.lib --with-lapack-lib=/cygdrive/E/Program_Files_
>> x86/IntelSWTools/compilers_and_libraries/windows/mkl/lib/intel64_win/mkl_rt.lib -CFLAGS="-O2 -MT -wd4996 -Qopenmp" -CXXFLAGS="-O2 -MT -wd4996 -Qopenmp" -FFLAGS="-MT -O2 -
>> Qopenmp"
>> [0]PETSC ERROR: #1 MatInvertVariableBlockDiagonal_SeqAIJ() line 1569 in E:\cygwin64\home\alireza\PETSc\src\mat\impls\aij\seq\aij.c
>> [0]PETSC ERROR: #2 MatInvertVariableBlockDiagonal() line 10482 in E:\cygwin64\home\alireza\PETSc\src\mat\interface\matrix.c
>> [0]PETSC ERROR: #3 PCSetUp_VPBJacobi() line 120 in E:\cygwin64\home\alireza\PETSc\src\ksp\pc\impls\vpbjacobi\vpbjacobi.c
>> [0]PETSC ERROR: #4 PCSetUp() line 932 in E:\cygwin64\home\alireza\PETSc\src\ksp\pc\interface\precon.c
>> [0]PETSC ERROR: #5 KSPSetUp() line 381 in E:\cygwin64\home\alireza\PETSc\src\ksp\ksp\interface\itfunc.c
>> [0]PETSC ERROR: #6 KSPSolve() line 612 in E:\cygwin64\home\alireza\PETSc\src\ksp\ksp\interface\itfunc.c
>> [0]PETSC ERROR: #7 SNESSolve_NEWTONLS() line 224 in E:\cygwin64\home\alireza\PETSc\src\snes\impls\ls\ls.c
>> [0]PETSC ERROR: #8 SNESSolve() line 4355 in E:\cygwin64\home\alireza\PETSc\src\snes\interface\snes.c
>> Many thanks,
>> Ali
>> On 8/29/2018 2:24 AM, Smith, Barry F. wrote:
>>> Ali,
>>> In the branch barry/feature-PCVPBJACOBI (see src/snes/examples/tutorials/ex5.c) I have implemented PCVPBJACOBI that is a point block Jacobi with variable size blocks. It has very little testing.
>>> Could you please try your code with it; you should see very very similar convergence history with this branch and the previous approach you used (the only numerical difference between the two approaches is that this one uses a dense LU factorization for each small block while the previous used a sparse factorization). This new one should also be slightly faster in the KSPSolve().
>>> Thanks
>>> Barry
>>>> On Aug 27, 2018, at 4:04 PM, Jed Brown <jed at jedbrown.org> wrote:
>>>> "Smith, Barry F." <bsmith at mcs.anl.gov> writes:
>>>>> I have added new functionality within SNES to allow one to do as you desire in the branch barry/feature-snessetkspsetupcallback. Please see src/snes/examples/tests/ex3.c
>>>> Note that this example is block Jacobi with O(1) sparse blocks per
>>>> process, not variable-sized point-block Jacobi which I think is what Ali
>>>> had in mind.
>>>>> Please let us know if it works for you and if you have any questions or problems.
>>>>> Barry
>>>>> Note that it has to be handled by a callback called from within the SNES solver because that is the first time the matrix exists in a form that the block sizes may be set.
>>>>> Sorry for the runaround with so many emails.
>>>>>> On Aug 24, 2018, at 3:48 PM, Ali Reza Khaz'ali <arkhazali at cc.iut.ac.ir> wrote:
>>>>>> Hi,
>>>>>> I am trying to use block Jacobi preconditioner in SNES (SNESNEWTONLS). However, PCBJacobiGetSubKSP function returns an error stating "Object is in wrong state, Must call KSPSetUp() or PCSetUp() first". When I add KSPSetUp, I got and error from them as: "Must call DMShellSetGlobalVector() or DMShellSetCreateGlobalVector()", and if PCSetUp is added, "Object is in wrong state, Matrix must be set first" error is printed.
>>>>>> Below is a part of my code. It is run serially. Any help is much appreciated.
>>>>>> ierr = SNESGetKSP(snes, &Petsc_ksp);
>>>>>> CHKERRQ(ierr);
>>>>>> ierr = KSPGetPC(Petsc_ksp, &Petsc_pc);
>>>>>> CHKERRQ(ierr);
>>>>>> ierr = KSPSetTolerances(Petsc_ksp, 1.e-3, 1e-3, PETSC_DEFAULT, 20000);
>>>>>> CHKERRQ(ierr);
>>>>>> ierr = SNESSetTolerances(snes, 1e-1, 1e-1, 1e-1, 2000, 2000);
>>>>>> CHKERRQ(ierr);
>>>>>> ierr = SNESSetType(snes, SNESNEWTONLS);
>>>>>> CHKERRQ(ierr);
>>>>>> ierr = KSPSetType(Petsc_ksp, KSPGMRES);
>>>>>> CHKERRQ(ierr);
>>>>>> ierr = PCSetType(Petsc_pc, PCBJACOBI);
>>>>>> CHKERRQ(ierr);
>>>>>> CHKERRQ(ierr);
>>>>>> ierr = PCBJacobiSetTotalBlocks(Petsc_pc, 2*Nx*Ny*Nz, SadeqSize);
>>>>>> CHKERRQ(ierr);
>>>>>> SNESSetUp(snes);
>>>>>> CHKERRQ(ierr);
>>>>>> ierr = PCBJacobiGetSubKSP(Petsc_pc, &nLocal, &Firstly, &subKSP);
>>>>>> CHKERRQ(ierr);
>>>>>> for (i = 0; i < nLocal; i++) {
>>>>>> ierr = KSPGetPC(subKSP[i], &SubPc);
>>>>>> CHKERRQ(ierr);
>>>>>> ierr = PCSetType(SubPc, PCLU);
>>>>>> CHKERRQ(ierr);
>>>>>> ierr = PCFactorSetMatSolverPackage(SubPc, "mkl_pardiso");
>>>>>> CHKERRQ(ierr);
>>>>>> ierr = KSPSetType(subKSP[i], KSPPREONLY);
>>>>>> CHKERRQ(ierr);
>>>>>> ierr = KSPSetTolerances(subKSP[i], 1.e-6, PETSC_DEFAULT, PETSC_DEFAULT, PETSC_DEFAULT);
>>>>>> CHKERRQ(ierr);
>>>>>> ierr = SNESSolve(snes, NULL, Petsc_X);
>>>>>> CHKERRQ(ierr);
