[petsc-users] MatSetValues error with ViennaCL types
Manuel Valera
mvalera-w at sdsu.edu
Tue Aug 28 18:33:52 CDT 2018
Talked too fast,
After fixing that problem, i tried more than one mpi processor and got the
following:
Matrix type: mpiaijviennacl
Of sizes: 125 x 125
Of sizes: 125 x 125
[0]PETSC ERROR: --------------------- Error Message
[0]PETSC ERROR: No support for this operation for this object type
[0]PETSC ERROR: Currently only handles ViennaCL matrices
[0]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html for
trouble shooting.
[0]PETSC ERROR: Petsc Development GIT revision: v3.9.2-549-g779ab53 GIT
Date: 2018-05-31 17:31:13 +0300
[0]PETSC ERROR: ./gcmLEP.GPU on a cuda-debug named node50 by valera Tue Aug
28 16:30:02 2018
[0]PETSC ERROR: Configure options PETSC_ARCH=cuda-debug
--with-mpi-dir=/usr/lib64/openmpi --COPTFLAGS=-O2 --CXXOPTFLAGS=-O2
--FOPTFLAGS=-O2 --with-shared-libraries=1 --with-debugging=1 --with-cuda=1
--CUDAFLAGS=-arch=sm_60 --with-blaslapack-dir=/usr/lib64 --download-viennacl
[0]PETSC ERROR: #1 PCSetUp_SAVIENNACL() line 47 in
/home/valera/petsc/src/ksp/pc/impls/saviennaclcuda/saviennacl.cu
[0]PETSC ERROR: #2 PCSetUp() line 932 in
/home/valera/petsc/src/ksp/pc/interface/precon.c
[1]PETSC ERROR:
[1]PETSC ERROR: Caught signal number 11 SEGV: Segmentation Violation,
probably memory access out of range
[1]PETSC ERROR: Try option -start_in_debugger or -on_error_attach_debugger
[1]PETSC ERROR: or see
http://www.mcs.anl.gov/petsc/documentation/faq.html#valgrind
[1]PETSC ERROR: or try http://valgrind.org on GNU/linux and Apple Mac OS X
to find memory corruption errors
[1]PETSC ERROR: likely location of problem given in stack below
[1]PETSC ERROR: --------------------- Stack Frames
[1]PETSC ERROR: Note: The EXACT line numbers in the stack are not available,
[1]PETSC ERROR: INSTEAD the line number of the start of the function
[1]PETSC ERROR: is given.
[1]PETSC ERROR: [1] PetscTraceBackErrorHandler line 182
/home/valera/petsc/src/sys/error/errtrace.c
[1]PETSC ERROR: [1] PetscError line 352
/home/valera/petsc/src/sys/error/err.c
[1]PETSC ERROR: [1] PCSetUp_SAVIENNACL line 45
[1]PETSC ERROR: [1] PCSetUp line 894
[1]PETSC ERROR: --------------------- Error Message
[1]PETSC ERROR: Signal received
[1]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html for
trouble shooting.
[1]PETSC ERROR: Petsc Development GIT revision: v3.9.2-549-g779ab53 GIT
[1]PETSC ERROR: ./gcmLEP.GPU on a cuda-debug named node50 by valera Tue Aug
28 16:30:02 2018
[1]PETSC ERROR: Configure options PETSC_ARCH=cuda-debug
[1]PETSC ERROR: #1 User provided function() line 0 in unknown file
MPI_ABORT was invoked on rank 1 in communicator MPI_COMM_WORLD
with errorcode 59.
NOTE: invoking MPI_ABORT causes Open MPI to kill all MPI processes.
You may or may not see output from other processes, depending on
exactly when Open MPI kills them.
[0]PETSC ERROR:
[0]PETSC ERROR: Caught signal number 15 Terminate: Some process (or the
batch system) has told this process to end
[0]PETSC ERROR: Try option -start_in_debugger or -on_error_attach_debugger
[0]PETSC ERROR: or see
[0]PETSC ERROR: or try http://valgrind.org on GNU/linux and Apple Mac OS X
[0]PETSC ERROR: likely location of problem given in stack below
[0]PETSC ERROR: --------------------- Stack Frames
[0]PETSC ERROR: Note: The EXACT line numbers in the stack are not available,
[0]PETSC ERROR: INSTEAD the line number of the start of the function
[0]PETSC ERROR: is given.
[0]PETSC ERROR: [0] PetscCommDuplicate line 130
/home/valera/petsc/src/sys/objects/tagm.c
[0]PETSC ERROR: [0] PetscHeaderCreate_Private line 34
/home/valera/petsc/src/sys/objects/inherit.c
[0]PETSC ERROR: [0] ISCreate line 35
/home/valera/petsc/src/vec/is/is/interface/isreg.c
[0]PETSC ERROR: [0] ISCreateGeneral line 668
/home/valera/petsc/src/vec/is/is/impls/general/general.c
[0]PETSC ERROR: [0] PCSetUp_SAVIENNACL line 45
[0]PETSC ERROR: [0] PCSetUp line 894
[0]PETSC ERROR: Signal received
trouble shooting.
28 16:30:02 2018
[0]PETSC ERROR: #3 User provided function() line 0 in unknown file
[node50:30582] 1 more process has sent help message help-mpi-api.txt /
mpi-abort
[node50:30582] Set MCA parameter "orte_base_help_aggregate" to 0 to see all
help / error messages
It is currently running in 1 mpi processor + GPU but i would like to call
at least 16 mpi processors + GPU to do the rest of the data management who
is not part of the main laplacian on the mpi and the laplacian solution on
the GPU, is this currently possible?
Thanks for your help,
On Tue, Aug 28, 2018 at 4:21 PM, Manuel Valera <mvalera-w at sdsu.edu> wrote:
> Ok, i found the culprit and we can close this thread,
> The problem was a missing variable for setting the maximum columns, which
> i deleted at some point without realizing. The error message was too
> ambiguous to catch this so i had to compare with a previous working version
> of the arguments of MatSetValues, it was evident then.
> Good news is that i can now set the values with the viennacl types too,
> Thanks for your kind help,
> Manuel
> On Tue, Aug 28, 2018 at 11:25 AM, Smith, Barry F. <bsmith at mcs.anl.gov>
> wrote:
>> 1) PetscMalloc() is never valid or needed in Fortran
>> 2) there is no reason to use DMSetMatrixPreallocateOnly() just use
>> DMCreateMatrix() assuming that using a DM (DMDA, DMPLEX, etc) is suitable
>> for your problem.
>> At this end we are totally guessing at what you are doing and so have
>> little help we can provide. A simple, nonworking code that tries to do
>> what you would need would help us a great deal in understanding that you
>> are trying to do.
>> Barry
>> > On Aug 28, 2018, at 1:18 PM, Manuel Valera <mvalera-w at sdsu.edu> wrote:
>> > Matthew, PetscMalloc gives the same error,
>> > Barry, it would be very hard for me to get the code to a minimum
>> working example, i guess all i need to understand is how to setup a DM
>> matrix with DMSetMatrixPreallocateOnly() instead of
>> MatMPIAIJSetPreallocation() as we were doing before, is there a simple
>> example who does this in Fortran?
>> > Is the PetscMalloc call needed? is 'call PetscMalloc(1,row,ierr)' a
>> valid, compilable call to PetscMalloc? what other reason may there be for
>> this error to happen ?
>> > Just remembering, that trying to setup the matrix with the
>> MatAIJSetPreallocation() brings up an error to acknowledge the viennacl
>> datatypes and that's why i'm trying to make this change on your
>> recommendation,
>> > On Mon, Aug 27, 2018 at 7:35 PM, Smith, Barry F. <bsmith at mcs.anl.gov>
>> wrote:
>> > Send your code in a way we can compile and run it; it must be some
>> simple issue that is hard to communicate in email.
>> > Barry
>> > > On Aug 27, 2018, at 5:51 PM, Manuel Valera <mvalera-w at sdsu.edu>
>> wrote:
>> > > Hello everyone,
>> > > I just had time to work on this again, and checked the code for
>> errors on the matrix entries, this is the exact code i was using for
>> creating the matrix without DMSetMatrixPreallocateOnly, using
>> MatMPIAIJSetPreallocation and it worked that way, but trying this way i get
>> the same 'Column too large' error using any number at the column position
>> of MatSetValues,
>> > > I have set up my code to print the column argument (n) of
>> MatSetValues and in this case is 7 (lower than 124), it still gives error,
>> even entering a specific number in the MatSetValues column argument
>> position gives the same error.
>> > > So next i went back to ex.50 here: http://www.mcs.anl.gov/petsc/p
>> etsc-current/src/ts/examples/tutorials/ex50.c.html and it has a very
>> similar structure except the PetscMalloc1() call, so i tried adding that
>> and got:
>> > > /home/valera/ParGCCOM/Src/DMDALaplacian.f90:114: undefined
>> reference to `petscmalloc1_'
>> > > Any ideas on this behaviour?
>> > > Thanks so much,
>> > > On Thu, Aug 16, 2018 at 11:20 AM, Smith, Barry F. <bsmith at mcs.anl.gov>
>> wrote:
>> > > Column too large: col 10980 max 124
>> > > You need to check the code that is generating the matrix entries.
>> The matrix has 124 columns but you are attempting to put a value at column
>> 10980
>> > > Barry
>> > > > On Aug 15, 2018, at 9:44 PM, Manuel Valera <mvalera-w at sdsu.edu>
>> wrote:
>> > > > Thanks Matthew and Barry,
>> > > > Now my code looks like:
>> > > > call DMSetMatrixPreallocateOnly(daDummy,PETSC_TRUE,ierr)
>> > > > call DMSetMatType(daDummy,MATMPIAIJVIENNACL,ierr)
>> > > > call DMSetVecType(daDummy,VECMPIVIENNACL,ierr)
>> > > > call DMCreateMatrix(daDummy,A,ierr)
>> > > > call MatSetFromOptions(A,ierr)
>> > > > call MatSetUp(A,ierr)
>> > > > call MatSetValues(A,1,row,sumpos,po
>> s(0:iter-1),vals(0:iter-1),INSERT_VALUES,ierr)
>> > > > call MatAssemblyBegin(A, MAT_FINAL_ASSEMBLY, ierr)
>> > > > call MatAssemblyEnd(A, MAT_FINAL_ASSEMBLY, ierr)
>> > > > And i get a different error, now is:
>> > > > [0]PETSC ERROR: Argument out of range
>> > > > [0]PETSC ERROR: Column too large: col 10980 max 124
>> ocumentation/faq.html for trouble shooting.
>> v3.9.2-549-g779ab53 GIT Date: 2018-05-31 17:31:13 +0300
>> Wed Aug 15 19:40:00 2018
>> --download-viennacl
>> > > > [0]PETSC ERROR: #1 MatSetValues_SeqAIJ() line 442 in
>> /home/valera/petsc/src/mat/impls/aij/seq/aij.c
>> > > > [0]PETSC ERROR: #2 MatSetValues() line 1339 in
>> /home/valera/petsc/src/mat/interface/matrix.c
>> > > > Thanks again,
>> > > > On Wed, Aug 15, 2018 at 7:02 PM, Smith, Barry F. <
>> bsmith at mcs.anl.gov> wrote:
>> > > > Should be
>> > > > and remove the rest. You need to set the type of Mat you want the
>> DM to return BEFORE you create the matrix.
>> > > > Barry
>> > > > > On Aug 15, 2018, at 4:45 PM, Manuel Valera <mvalera-w at sdsu.edu>
>> wrote:
>> > > > > Ok thanks for clarifying that, i wasn't sure if there were
>> different types,
>> > > > > Here is a stripped down version of my code, it seems like the
>> preallocation is working now since the matrix population part is working
>> without problem, but here it is for illustration purposes:
>> > > > > call MatMPIAIJSetPreallocation(A,19,PETSC_NULL_INTEGER,19,PETSC_
>> NULL_INTEGER,ierr)
>> > > > > Adding the first line there did the trick,
>> > > > > Now the problem seems to be the program is not recognizing the
>> matrix as ViennaCL type when i try with more than one processor, i get now:
>> valera Wed Aug 15 14:44:22 2018
>> --download-viennacl
>> > > > > [0]PETSC ERROR: #3 KSPSetUp() line 381 in
>> /home/valera/petsc/src/ksp/ksp/interface/itfunc.c
>> > > > > When running with:
>> > > > > mpirun -n 1 ./gcmLEP.GPU tc=TestCases/LockRelease/LE_6x6x6/
>> jid=tiny_cuda_test_n2 -ksp_type cg -dm_vec_type viennacl -dm_mat_type
>> aijviennacl -pc_type saviennacl -log_view
>> > > > > Thanks,
>> > > > > On Wed, Aug 15, 2018 at 2:32 PM, Matthew Knepley <
>> knepley at gmail.com> wrote:
>> > > > > On Wed, Aug 15, 2018 at 5:20 PM Manuel Valera <mvalera-w at sdsu.edu>
>> wrote:
>> > > > > It seems to be resumed on: I do not know how to preallocate a DM
>> Matrix correctly.
>> > > > > There is only one matrix type, Mat. There are no separate DM
>> matrices. A DM can create a matrix for you
>> > > > > using DMCreateMatrix(), but that is a Mat and it is preallocated
>> correctly. I am not sure what you are doing.
>> > > > > Thanks,
>> > > > > Matt
>> > > > > The interesting part is that it only breaks when i need to
>> populate a GPU matrix from MPI, so kudos on that, but it seems i need to do
>> better on my code to get this setup working,
>> > > > > Any help would be appreciated,
>> > > > > Thanks,
>> > > > > On Wed, Aug 15, 2018 at 2:15 PM, Matthew Knepley <
>> > > > > On Wed, Aug 15, 2018 at 4:53 PM Manuel Valera <mvalera-w at sdsu.edu>
>> wrote:
>> > > > > Thanks Matthew,
>> > > > > I try to do that when calling:
>> NULL_INTEGER,ierr)
>> > > > > But i am not aware on how to do this for the DM if it needs
>> something more specific/different,
>> > > > > The error says that your preallocation is wrong for the values
>> you are putting in. The DM does not control either,
>> > > > > so I do not understand your email.
>> > > > > Thanks,
>> > > > > Matt
>> > > > > Thanks,
>> > > > > On Wed, Aug 15, 2018 at 1:51 PM, Matthew Knepley <
>> > > > > On Wed, Aug 15, 2018 at 4:39 PM Manuel Valera <mvalera-w at sdsu.edu>
>> wrote:
>> > > > > Hello PETSc devs,
>> > > > > I am running into an error when trying to use the
>> MATMPIAIJVIENNACL Matrix type in MPI calls, the same code runs for
>> MATSEQAIJVIENNACL type in one processor. The error happens when calling
>> MatSetValues for this specific configuration. It does not occur when using
>> MPI DMMatrix types only.
>> > > > > The DM properly preallocates the matrix. I am assuming you do not
>> here.
>> > > > > Matt
>> > > > > Any help will be appreciated,
>> > > > > Thanks,
>> > > > > My program call:
>> > > > > mpirun -n 2 ./gcmLEP.GPU tc=TestCases/LockRelease/LE_6x6x6/
>> > > > > The error (repeats after each MatSetValues call):
>> > > > > [1]PETSC ERROR: Argument out of range
>> > > > > [1]PETSC ERROR: Inserting a new nonzero at global row/column (75,
>> 50) into matrix
>> valera Wed Aug 15 13:10:44 2018
>> --download-viennacl
>> > > > > [1]PETSC ERROR: #1 MatSetValues_MPIAIJ() line 608 in
>> /home/valera/petsc/src/mat/impls/aij/mpi/mpiaij.c
>> > > > > [1]PETSC ERROR: #2 MatSetValues() line 1339 in
>> > > > > My Code structure:
>> > > > > call MPI_Comm_size(PETSC_COMM_WORLD, numprocs, ierr)
>> > > > > if (numprocs > 1) then ! set matrix type parallel
>> > > > > ! Get local size
>> > > > > call DMDACreateNaturalVector(daDummy,Tmpnat,ierr)
>> > > > > call VecGetLocalSize(Tmpnat,locsize,ierr)
>> > > > > call VecDestroy(Tmpnat,ierr)
>> > > > > ! Set matrix
>> > > > > #ifdef GPU
>> > > > > call MatSetType(A,MATAIJVIENNACL,ierr)
>> > > > > print*,'SETTING GPU TYPES'
>> > > > > #else
>> > > > > call DMSetMatType(daDummy,MATMPIAIJ,ierr)
>> > > > > call DMSetMatType(daDummy,VECMPI,ierr)
>> > > > > call MatSetType(A,MATMPIAIJ,ierr)!
>> > > > > #endif
>> ,PETSC_NULL_INTEGER,19,PETSC_NULL_INTEGER,ierr)
>> > > > > else ! set matrix type sequential
>> > > > > #ifdef GPU
>> > > > > call DMSetMatType(daDummy,MATSEQAIJVIENNACL,ierr)
>> > > > > call DMSetVecType(daDummy,VECSEQVIENNACL,ierr)
>> > > > > call MatSetType(A,MATSEQAIJVIENNACL,ierr)
>> > > > > #else
>> > > > > call DMSetMatType(daDummy,MATSEQAIJ,ierr)
>> > > > > call DMSetMatType(daDummy,VECSEQ,ierr)
>> > > > > call MatSetType(A,MATSEQAIJ,ierr)
>> > > > > #endif
>> > > > > call getCenterInfo(daGrid,xstart,ystart,zstart,xend,yend,zend)
>> > > > > do k=zstart,zend-1
>> > > > > do j=ystart,yend-1
>> > > > > do i=xstart,xend-1
>> > > > > What most experimenters take for granted before they begin their
>> experiments lead.
>> > > > > -- Norbert Wiener
>> > > > > https://www.cse.buffalo.edu/~knepley/
>> experiments lead.
>> > > > > -- Norbert Wiener
>> experiments lead.
>> > > > > -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20180828/9ef4e5dc/attachment-0001.html>
