[petsc-users] exit kspsolve at half of the max iterations if residual is not reduced by an order
Jed Brown jed at jedbrown.org
Tue Aug 28 17:39:47 CDT 2018
You can use any convergence test you want, see SNESSetConvergenceTest()
if tolerances don't cut it for you.  You might also consider nested
solvers/nonlinear preconditioning.
NAN ZHAO <zhaonanavril at gmail.com> writes:
> Dear all,
> I am trying to find ways to speed up my pests kspsolve, my old code use an
> older solver and it exit the solving loop when residual is not reduced by a
> certain amount compared with initial residual, and then redo the
> computation with other tricks. I am wondering if PETSC has this function.
> Thanks,
> Nan
