[petsc-users] MatSetValues error with ViennaCL types
Matthew Knepley
knepley at gmail.com
Mon Aug 27 19:35:38 CDT 2018
On Mon, Aug 27, 2018 at 6:51 PM Manuel Valera <mvalera-w at sdsu.edu> wrote:
> Hello everyone,
> I just had time to work on this again, and checked the code for errors on
> the matrix entries, this is the exact code i was using for creating the
> matrix without DMSetMatrixPreallocateOnly, using MatMPIAIJSetPreallocation
> and it worked that way, but trying this way i get the same 'Column too
> large' error using any number at the column position of MatSetValues,
> I have set up my code to print the column argument (n) of MatSetValues and
> in this case is 7 (lower than 124), it still gives error, even entering a
> specific number in the MatSetValues column argument position gives the same
> error.
> So next i went back to ex.50 here:
> http://www.mcs.anl.gov/petsc/petsc-current/src/ts/examples/tutorials/ex50.c.html
> and it has a very similar structure except the PetscMalloc1() call, so i
> tried adding that and got:
> /home/valera/ParGCCOM/Src/DMDALaplacian.f90:114: undefined reference to
> `petscmalloc1_'
> Any ideas on this behaviour?
This is a macro. I am guessing you are using Fortran. Just use PetscMalloc
instead.
Matt
> Thanks so much,
> On Thu, Aug 16, 2018 at 11:20 AM, Smith, Barry F. <bsmith at mcs.anl.gov>
> wrote:
>> Column too large: col 10980 max 124
>> You need to check the code that is generating the matrix entries. The
>> matrix has 124 columns but you are attempting to put a value at column 10980
>> Barry
>> > On Aug 15, 2018, at 9:44 PM, Manuel Valera <mvalera-w at sdsu.edu> wrote:
>> > Thanks Matthew and Barry,
>> > Now my code looks like:
>> > call DMSetMatrixPreallocateOnly(daDummy,PETSC_TRUE,ierr)
>> > call DMSetMatType(daDummy,MATMPIAIJVIENNACL,ierr)
>> > call DMSetVecType(daDummy,VECMPIVIENNACL,ierr)
>> > call DMCreateMatrix(daDummy,A,ierr)
>> > call MatSetFromOptions(A,ierr)
>> > call MatSetUp(A,ierr)
>> > call
>> MatSetValues(A,1,row,sumpos,pos(0:iter-1),vals(0:iter-1),INSERT_VALUES,ierr)
>> > call MatAssemblyBegin(A, MAT_FINAL_ASSEMBLY, ierr)
>> > call MatAssemblyEnd(A, MAT_FINAL_ASSEMBLY, ierr)
>> > And i get a different error, now is:
>> > [0]PETSC ERROR: --------------------- Error Message
>> > [0]PETSC ERROR: Argument out of range
>> > [0]PETSC ERROR: Column too large: col 10980 max 124
>> > [0]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html
>> for trouble shooting.
>> > [0]PETSC ERROR: Petsc Development GIT revision: v3.9.2-549-g779ab53
>> GIT Date: 2018-05-31 17:31:13 +0300
>> > [0]PETSC ERROR: ./gcmLEP.GPU on a cuda-debug named node50 by valera Wed
>> Aug 15 19:40:00 2018
>> > [0]PETSC ERROR: Configure options PETSC_ARCH=cuda-debug
>> --with-mpi-dir=/usr/lib64/openmpi --COPTFLAGS=-O2 --CXXOPTFLAGS=-O2
>> --FOPTFLAGS=-O2 --with-shared-libraries=1 --with-debugging=1 --with-cuda=1
>> --CUDAFLAGS=-arch=sm_60 --with-blaslapack-dir=/usr/lib64 --download-viennacl
>> > [0]PETSC ERROR: #1 MatSetValues_SeqAIJ() line 442 in
>> /home/valera/petsc/src/mat/impls/aij/seq/aij.c
>> > [0]PETSC ERROR: #2 MatSetValues() line 1339 in
>> /home/valera/petsc/src/mat/interface/matrix.c
>> > Thanks again,
>> > On Wed, Aug 15, 2018 at 7:02 PM, Smith, Barry F. <bsmith at mcs.anl.gov>
>> wrote:
>> > Should be
>> > and remove the rest. You need to set the type of Mat you want the DM
>> to return BEFORE you create the matrix.
>> > Barry
>> > > On Aug 15, 2018, at 4:45 PM, Manuel Valera <mvalera-w at sdsu.edu>
>> wrote:
>> > > Ok thanks for clarifying that, i wasn't sure if there were different
>> types,
>> > > Here is a stripped down version of my code, it seems like the
>> preallocation is working now since the matrix population part is working
>> without problem, but here it is for illustration purposes:
>> > > call
>> MatMPIAIJSetPreallocation(A,19,PETSC_NULL_INTEGER,19,PETSC_NULL_INTEGER,ierr)
>> > > call
>> > > Adding the first line there did the trick,
>> > > Now the problem seems to be the program is not recognizing the matrix
>> as ViennaCL type when i try with more than one processor, i get now:
>> > > [0]PETSC ERROR: No support for this operation for this object type
>> > > [0]PETSC ERROR: Currently only handles ViennaCL matrices
>> > > [0]PETSC ERROR: See
>> http://www.mcs.anl.gov/petsc/documentation/faq.html for trouble shooting.
>> Wed Aug 15 14:44:22 2018
>> > > [0]PETSC ERROR: #1 PCSetUp_SAVIENNACL() line 47 in
>> /home/valera/petsc/src/ksp/pc/impls/saviennaclcuda/saviennacl.cu
>> > > [0]PETSC ERROR: #2 PCSetUp() line 932 in
>> /home/valera/petsc/src/ksp/pc/interface/precon.c
>> > > [0]PETSC ERROR: #3 KSPSetUp() line 381 in
>> /home/valera/petsc/src/ksp/ksp/interface/itfunc.c
>> > > When running with:
>> > > mpirun -n 1 ./gcmLEP.GPU tc=TestCases/LockRelease/LE_6x6x6/
>> jid=tiny_cuda_test_n2 -ksp_type cg -dm_vec_type viennacl -dm_mat_type
>> aijviennacl -pc_type saviennacl -log_view
>> > > Thanks,
>> > > On Wed, Aug 15, 2018 at 2:32 PM, Matthew Knepley <knepley at gmail.com>
>> wrote:
>> > > On Wed, Aug 15, 2018 at 5:20 PM Manuel Valera <mvalera-w at sdsu.edu>
>> wrote:
>> > > It seems to be resumed on: I do not know how to preallocate a DM
>> Matrix correctly.
>> > > There is only one matrix type, Mat. There are no separate DM
>> matrices. A DM can create a matrix for you
>> > > using DMCreateMatrix(), but that is a Mat and it is preallocated
>> correctly. I am not sure what you are doing.
>> > > Thanks,
>> > > Matt
>> > > The interesting part is that it only breaks when i need to populate a
>> GPU matrix from MPI, so kudos on that, but it seems i need to do better on
>> my code to get this setup working,
>> > > Any help would be appreciated,
>> > > Thanks,
>> > > On Wed, Aug 15, 2018 at 2:15 PM, Matthew Knepley <knepley at gmail.com>
>> wrote:
>> > > On Wed, Aug 15, 2018 at 4:53 PM Manuel Valera <mvalera-w at sdsu.edu>
>> wrote:
>> > > Thanks Matthew,
>> > > I try to do that when calling:
>> > > call
>> > > But i am not aware on how to do this for the DM if it needs something
>> more specific/different,
>> > > The error says that your preallocation is wrong for the values you
>> are putting in. The DM does not control either,
>> > > so I do not understand your email.
>> > > Thanks,
>> > > Matt
>> > > Thanks,
>> > > On Wed, Aug 15, 2018 at 1:51 PM, Matthew Knepley <knepley at gmail.com>
>> wrote:
>> > > On Wed, Aug 15, 2018 at 4:39 PM Manuel Valera <mvalera-w at sdsu.edu>
>> wrote:
>> > > Hello PETSc devs,
>> > > I am running into an error when trying to use the MATMPIAIJVIENNACL
>> Matrix type in MPI calls, the same code runs for MATSEQAIJVIENNACL type in
>> one processor. The error happens when calling MatSetValues for this
>> specific configuration. It does not occur when using MPI DMMatrix types
>> only.
>> > > The DM properly preallocates the matrix. I am assuming you do not
>> here.
>> > > Matt
>> > > Any help will be appreciated,
>> > > Thanks,
>> > > My program call:
>> > > mpirun -n 2 ./gcmLEP.GPU tc=TestCases/LockRelease/LE_6x6x6/
>> > > The error (repeats after each MatSetValues call):
>> > > [1]PETSC ERROR: --------------------- Error Message
>> > > [1]PETSC ERROR: Argument out of range
>> > > [1]PETSC ERROR: Inserting a new nonzero at global row/column (75, 50)
>> into matrix
>> > > [1]PETSC ERROR: See
>> > > [1]PETSC ERROR: Petsc Development GIT revision: v3.9.2-549-g779ab53
>> > > [1]PETSC ERROR: ./gcmLEP.GPU on a cuda-debug named node50 by valera
>> Wed Aug 15 13:10:44 2018
>> > > [1]PETSC ERROR: Configure options PETSC_ARCH=cuda-debug
>> > > [1]PETSC ERROR: #1 MatSetValues_MPIAIJ() line 608 in
>> /home/valera/petsc/src/mat/impls/aij/mpi/mpiaij.c
>> > > [1]PETSC ERROR: #2 MatSetValues() line 1339 in
>> > > My Code structure:
>> > > call MPI_Comm_size(PETSC_COMM_WORLD, numprocs, ierr)
>> > > if (numprocs > 1) then ! set matrix type parallel
>> > > ! Get local size
>> > > call DMDACreateNaturalVector(daDummy,Tmpnat,ierr)
>> > > call VecGetLocalSize(Tmpnat,locsize,ierr)
>> > > call VecDestroy(Tmpnat,ierr)
>> > > ! Set matrix
>> > > #ifdef GPU
>> > > call MatSetType(A,MATAIJVIENNACL,ierr)
>> > > print*,'SETTING GPU TYPES'
>> > > #else
>> > > call DMSetMatType(daDummy,MATMPIAIJ,ierr)
>> > > call DMSetMatType(daDummy,VECMPI,ierr)
>> > > call MatSetType(A,MATMPIAIJ,ierr)!
>> > > #endif
>> > > call
>> > > else ! set matrix type sequential
>> > > #ifdef GPU
>> > > call DMSetMatType(daDummy,MATSEQAIJVIENNACL,ierr)
>> > > call DMSetVecType(daDummy,VECSEQVIENNACL,ierr)
>> > > call MatSetType(A,MATSEQAIJVIENNACL,ierr)
>> > > #else
>> > > call DMSetMatType(daDummy,MATSEQAIJ,ierr)
>> > > call DMSetMatType(daDummy,VECSEQ,ierr)
>> > > call MatSetType(A,MATSEQAIJ,ierr)
>> > > #endif
>> > > call getCenterInfo(daGrid,xstart,ystart,zstart,xend,yend,zend)
>> > > do k=zstart,zend-1
>> > > do j=ystart,yend-1
>> > > do i=xstart,xend-1
>> > > call
>> > > What most experimenters take for granted before they begin their
>> experiments lead.
>> > > -- Norbert Wiener
>> > > https://www.cse.buffalo.edu/~knepley/
>> experiments lead.
>> > > -- Norbert Wiener
>> experiments lead.
>> > > -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20180827/a95635a0/attachment.html>
