[petsc-users] Use block Jacobi preconditioner with SNES
Smith, Barry F. bsmith at mcs.anl.gov
Mon Aug 27 16:01:24 CDT 2018
    I have added new functionality within SNES to allow one to do as you desire in the branch barry/feature-snessetkspsetupcallback. Please see src/snes/examples/tests/ex3.c
    Please let us know if it works for you and if you have any questions or problems.
    Barry
   Note that it has to be handled by a callback called from within the SNES solver because that is the first time the matrix exists in a form that the block sizes may be set.
    Sorry for the runaround with so many emails.
> On Aug 24, 2018, at 3:48 PM, Ali Reza Khaz'ali <arkhazali at cc.iut.ac.ir> wrote:
> Hi,
> I am trying to use block Jacobi preconditioner in SNES (SNESNEWTONLS). However, PCBJacobiGetSubKSP function returns an error stating "Object is in wrong state, Must call KSPSetUp() or PCSetUp() first". When I add KSPSetUp, I got and error from them as: "Must call DMShellSetGlobalVector() or DMShellSetCreateGlobalVector()", and if PCSetUp is added, "Object is in wrong state, Matrix must be set first" error is printed.
> Below is a part of my code. It is run serially. Any help is much appreciated.
>     ierr = SNESGetKSP(snes, &Petsc_ksp);
>     CHKERRQ(ierr);
>     ierr = KSPGetPC(Petsc_ksp, &Petsc_pc);
>     CHKERRQ(ierr);
>     ierr = KSPSetTolerances(Petsc_ksp, 1.e-3, 1e-3, PETSC_DEFAULT, 20000);
>     CHKERRQ(ierr);
>     ierr = SNESSetTolerances(snes, 1e-1, 1e-1, 1e-1, 2000, 2000);
>     CHKERRQ(ierr);
>     ierr = SNESSetType(snes, SNESNEWTONLS);
>     CHKERRQ(ierr);
>     ierr = KSPSetType(Petsc_ksp, KSPGMRES);
>     CHKERRQ(ierr);
>     ierr = PCSetType(Petsc_pc, PCBJACOBI);
>     CHKERRQ(ierr);
>     CHKERRQ(ierr);
>     ierr = PCBJacobiSetTotalBlocks(Petsc_pc, 2*Nx*Ny*Nz, SadeqSize);
>     CHKERRQ(ierr);
>     SNESSetUp(snes);
>     CHKERRQ(ierr);
>     ierr = PCBJacobiGetSubKSP(Petsc_pc, &nLocal, &Firstly, &subKSP);
>     CHKERRQ(ierr);
>     for (i = 0; i < nLocal; i++) {
>         ierr = KSPGetPC(subKSP[i], &SubPc);
>         CHKERRQ(ierr);
>         ierr = PCSetType(SubPc, PCLU);
>         CHKERRQ(ierr);
>         ierr = PCFactorSetMatSolverPackage(SubPc, "mkl_pardiso");
>         CHKERRQ(ierr);
>         ierr = KSPSetType(subKSP[i], KSPPREONLY);
>         CHKERRQ(ierr);
>         ierr = KSPSetTolerances(subKSP[i], 1.e-6, PETSC_DEFAULT, PETSC_DEFAULT, PETSC_DEFAULT);
>         CHKERRQ(ierr);
>     ierr = SNESSolve(snes, NULL, Petsc_X);
>     CHKERRQ(ierr);
> Ali Reza Khaz’ali
> Assistant Professor of Petroleum Engineering,
> Department of Chemical Engineering
> Isfahan University of Technology
> Isfahan, Iran
