[petsc-users] Use block Jacobi preconditioner with SNES
Jed Brown jed at jedbrown.org
Mon Aug 27 14:38:29 CDT 2018
Ali Reza Khaz'ali <arkhazali at cc.iut.ac.ir> writes:
>> This is very odd. A sparse linear system of 7K unknowns needs less than a second to be factored. If it is dense, seconds.
>> How many nonzero per rows do you have?
>> Is 7 thousand the typical size of your blocks in bjacobi?
> There are less than 100 non-zeros per row. 7K was the total size of
> Jacobian matrix. The block sizes of Jacobian are in range of 4-10. I
> could not inform bjacobi about the block sizes (see the communication
> about it please), so it treats the entire Jacobian matrix as one giant
> block.
This should take on the order of a second to solve with a sparse direct
solver.  What shape is your domain?  Can you send a solver profile and
output from running with -snes_view -log_view?
