[petsc-users] Use block Jacobi preconditioner with SNES
    Ali Reza Khaz'ali
    arkhazali at cc.iut.ac.ir
    Sat Aug 25 13:30:14 CDT 2018
Dear Barry and Jed,
Thanks for your great suggestions. I set the options as Jed proposed and
it worked. However, Block Jacobi preconditioner treats the entire
Jacobian matrix as only one giant block. It is good in small systems,
but in larger ones, it requires a lot of memory and runtime, as direct
methods do.  In addition, I cannot use -pc_bjacobi_blocks option,
because the block sizes of the Jacobain matrix are variable (In my
sample code, SadeqSize array contain block sizes), and apparently
-pc_bjacobi_blocks option assumes the block sizes are equal.
I have to add an explanation about unusual high tolerances in my code
sample, in fact, I am facing a serious ill-conditioned problem. The
direct methods (like LU) solve the system without problem, but I could
not find any preconditioner+iterative solver that can solve it with the
required precision.  Since direct solvers are useless in large systems,
I had to design an specific preconditioner for it (I wrote a paper about
it: https://link.springer.com/article/10.1007/s10596-014-9421-3), but
the designed preconditioner was rather slow (even on GPU), and I hope
that I can find a faster solution in PETSc. So for now I am searching
for a combination that just works for me, and then, I'll refine it.
Best wishes,
Ali
On 8/25/2018 4:31 AM, Smith, Barry F. wrote:
>     What you would like to do is reasonable but unfortunately the order of the operations in SNES/KSP means that the KSPSetUp() cannot be called before the SNESSolve() because the Jacobian matrix has yet to be provided to KSP. Thus you have to, as Jed suggested, use the options database to set the options. Note that if you want the options "hardwired" into the code you can use PetscOptionsSetValue() from the code.
>    Barry
>> On Aug 24, 2018, at 1:48 PM, Ali Reza Khaz'ali <arkhazali at cc.iut.ac.ir> wrote:
>> Hi,
>> I am trying to use block Jacobi preconditioner in SNES (SNESNEWTONLS). However, PCBJacobiGetSubKSP function returns an error stating "Object is in wrong state, Must call KSPSetUp() or PCSetUp() first". When I add KSPSetUp, I got and error from them as: "Must call DMShellSetGlobalVector() or DMShellSetCreateGlobalVector()", and if PCSetUp is added, "Object is in wrong state, Matrix must be set first" error is printed.
>> Below is a part of my code. It is run serially. Any help is much appreciated.
>>      ierr = SNESGetKSP(snes, &Petsc_ksp);
>>      CHKERRQ(ierr);
>>      ierr = KSPGetPC(Petsc_ksp, &Petsc_pc);
>>      CHKERRQ(ierr);
>>      ierr = KSPSetTolerances(Petsc_ksp, 1.e-3, 1e-3, PETSC_DEFAULT, 20000);
>>      CHKERRQ(ierr);
>>      ierr = SNESSetTolerances(snes, 1e-1, 1e-1, 1e-1, 2000, 2000);
>>      CHKERRQ(ierr);
>>      ierr = SNESSetType(snes, SNESNEWTONLS);
>>      CHKERRQ(ierr);
>>      ierr = KSPSetType(Petsc_ksp, KSPGMRES);
>>      CHKERRQ(ierr);
>>      ierr = PCSetType(Petsc_pc, PCBJACOBI);
>>      CHKERRQ(ierr);
>>      CHKERRQ(ierr);
>>      ierr = PCBJacobiSetTotalBlocks(Petsc_pc, 2*Nx*Ny*Nz, SadeqSize);
>>      CHKERRQ(ierr);
>>      SNESSetUp(snes);
>>      CHKERRQ(ierr);
>>      ierr = PCBJacobiGetSubKSP(Petsc_pc, &nLocal, &Firstly, &subKSP);
>>      CHKERRQ(ierr);
>>      for (i = 0; i < nLocal; i++) {
>>          ierr = KSPGetPC(subKSP[i], &SubPc);
>>          CHKERRQ(ierr);
>>          ierr = PCSetType(SubPc, PCLU);
>>          CHKERRQ(ierr);
>>          ierr = PCFactorSetMatSolverPackage(SubPc, "mkl_pardiso");
>>          CHKERRQ(ierr);
>>          ierr = KSPSetType(subKSP[i], KSPPREONLY);
>>          CHKERRQ(ierr);
>>          ierr = KSPSetTolerances(subKSP[i], 1.e-6, PETSC_DEFAULT, PETSC_DEFAULT, PETSC_DEFAULT);
>>          CHKERRQ(ierr);
>>      ierr = SNESSolve(snes, NULL, Petsc_X);
>>      CHKERRQ(ierr);
>> Ali Reza Khaz’ali
>> Assistant Professor of Petroleum Engineering,
>> Department of Chemical Engineering
>> Isfahan University of Technology
>> Isfahan, Iran
