[petsc-users] Use block Jacobi preconditioner with SNES
Jed Brown
jed at jedbrown.org
Fri Aug 24 17:32:14 CDT 2018
Ali Reza Khaz'ali <arkhazali at cc.iut.ac.ir> writes:
> Hi,
> I am trying to use block Jacobi preconditioner in SNES (SNESNEWTONLS).
> However, PCBJacobiGetSubKSP function returns an error stating "Object is
> in wrong state, Must call KSPSetUp() or PCSetUp() first". When I add
> KSPSetUp, I got and error from them as: "Must call
> DMShellSetGlobalVector() or DMShellSetCreateGlobalVector()", and if
> PCSetUp is added, "Object is in wrong state, Matrix must be set first"
> error is printed.
We'd need the entire trace, but this is a run-time option
-snes_rtol 1e-1 # Really? Then why solve KSP that much more accurately?
-ksp_rtol 1e-3
-pc_type bjacobi -sub_pc_type lu -sub_pc_factor_mat_solver_type mkl_pardiso
optionally setting the number of blocks (it's uncommon to not want the
default)
-pc_bjacobi_blocks N
> Below is a part of my code. It is run serially. Any help is much
> appreciated.
> ierr = SNESGetKSP(snes, &Petsc_ksp);
> CHKERRQ(ierr);
> ierr = KSPGetPC(Petsc_ksp, &Petsc_pc);
> CHKERRQ(ierr);
> ierr = KSPSetTolerances(Petsc_ksp, 1.e-3, 1e-3, PETSC_DEFAULT, 20000);
> CHKERRQ(ierr);
> ierr = SNESSetTolerances(snes, 1e-1, 1e-1, 1e-1, 2000, 2000);
> CHKERRQ(ierr);
> ierr = SNESSetType(snes, SNESNEWTONLS);
> CHKERRQ(ierr);
> ierr = KSPSetType(Petsc_ksp, KSPGMRES);
> CHKERRQ(ierr);
> ierr = PCSetType(Petsc_pc, PCBJACOBI);
> CHKERRQ(ierr);
> CHKERRQ(ierr);
> ierr = PCBJacobiSetTotalBlocks(Petsc_pc, 2*Nx*Ny*Nz, SadeqSize);
> CHKERRQ(ierr);
> SNESSetUp(snes);
> CHKERRQ(ierr);
> ierr = PCBJacobiGetSubKSP(Petsc_pc, &nLocal, &Firstly, &subKSP);
> CHKERRQ(ierr);
> for (i = 0; i < nLocal; i++) {
> ierr = KSPGetPC(subKSP[i], &SubPc);
> CHKERRQ(ierr);
> ierr = PCSetType(SubPc, PCLU);
> CHKERRQ(ierr);
> ierr = PCFactorSetMatSolverPackage(SubPc, "mkl_pardiso");
> CHKERRQ(ierr);
> ierr = KSPSetType(subKSP[i], KSPPREONLY);
> CHKERRQ(ierr);
> ierr = KSPSetTolerances(subKSP[i], 1.e-6, PETSC_DEFAULT,
> PETSC_DEFAULT, PETSC_DEFAULT);
> CHKERRQ(ierr);
> ierr = SNESSolve(snes, NULL, Petsc_X);
> CHKERRQ(ierr);
> Ali Reza Khaz’ali
> Assistant Professor of Petroleum Engineering,
> Department of Chemical Engineering
> Isfahan University of Technology
> Isfahan, Iran
