[petsc-users] error building petsc with gcc
Mark Adams
mfadams at lbl.gov
Fri Aug 24 00:32:49 CDT 2018
On Thu, Aug 23, 2018 at 7:23 PM Smith, Barry F. <bsmith at mcs.anl.gov> wrote:
> Some mixup between an Intel build and a gcc build?
I was careful about this. I reconfigured and am getting missing LAPACK
methods on PETSc tests. (This __isnormal error came from building the
application, which has its own build system and that might have LAPACK in
it.) I reconfigured and download blas and PETSc tests are working.
Baky: try it again.
> > On Aug 23, 2018, at 4:15 PM, Bakytzhan Kallemov <bkallemov at lbl.gov>
> wrote:
> > Hello,
> > We are getting an error when linking our code.
> > This is our compiler:
> > kallemov at cori03:~/svn_treb/EBAMRINS/execBCG> CC --version
> > g++ (GCC) 7.3.0 20180125 (Cray Inc.)
> > Copyright (C) 2017 Free Software Foundation, Inc.
> > This is free software; see the source for copying conditions. There is
> NO
> > warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR
> PURPOSE.
> > We are missing an external function __isnormal. Do you have any ideas?
> > Baky (and Mark Adams)
> > /bin/csh -f -c "CC -march=native -std=c++11
> -Wno-unused-but-set-variable -Wno-long-long -Wno-sign-compare
> -Wno-deprecated -ftemplate-depth-99 -Wno-unused-local-typedefs
> -Wno-literal-suffix -Wno-variadic-macros -fopenmp -O3 -march=native
> -std=c++11 -Wno-unused-but-set-variable -Wno-long-long -Wno-sign-compare
> o/3d.Linux.64.CC.ftn.OPTHIGH.MPI.OPENMPCC.PETSC/viscousDriver.o
> o/3d.Linux.64.CC.ftn.OPTHIGH.MPI.OPENMPCC.PETSC/HairIF.o
> o/3d.Linux.64.CC.ftn.OPTHIGH.MPI.OPENMPCC.PETSC/EBCrankNicolson.o
> o/3d.Linux.64.CC.ftn.OPTHIGH.MPI.OPENMPCC.PETSC/AMRINSUtils.o
> o/3d.Linux.64.CC.ftn.OPTHIGH.MPI.OPENMPCC.PETSC/CotanIF.o
> o/3d.Linux.64.CC.ftn.OPTHIGH.MPI.OPENMPCC.PETSC/TrigIF.o
> o/3d.Linux.64.CC.ftn.OPTHIGH.MPI.OPENMPCC.PETSC/ArteryIF.o
> o/3d.Linux.64.CC.ftn.OPTHIGH.MPI.OPENMPCC.PETSC/HairyIF.o
> o/3d.Linux.64.CC.ftn.OPTHIGH.MPI.OPENMPCC.PETSC/EBCPPlotter.o
> o/3d.Linux.64.CC.ftn.OPTHIGH.MPI.OPENMPCC.PETSC/RampIF.o
> o/3d.Linux.64.CC.ftn.OPTHIGH.MPI.OPENMPCC.PETSC/EBAMRNoSubcycle.o
> o/3d.Linux.64.CC.ftn.OPTHIGH.MPI.OPENMPCC.PETSC/EBPetscSolver.o
> o/3d.Linux.64.CC.ftn.OPTHIGH.MPI.OPENMPCC.PETSC/EBIBC.o
> o/3d.Linux.64.CC.ftn.OPTHIGH.MPI.OPENMPCC.PETSC/EBGradDivFilter.o
> o/3d.Linux.64.CC.ftn.OPTHIGH.MPI.OPENMPCC.PETSC/TrebDirichletPoissonEBBC.o
> o/3d.Linux.64.CC.ftn.OPTHIGH.MPI.OPENMPCC.PETSC/EBPetscAMRSolver.o
> o/3d.Linux.64.CC.ftn.OPTHIGH.MPI.OPENMPCC.PETSC/NoFlowAdvectBC.o
> o/3d.Linux.64.CC.ftn.OPTHIGH.MPI.OPENMPCC.PETSC/EBCompositeCCProjector.o
> o/3d.Linux.64.CC.ftn.OPTHIGH.MPI.OPENMPCC.PETSC/copyWithGhost.o
> o/3d.Linux.64.CC.ftn.OPTHIGH.MPI.OPENMPCC.PETSC/EBLevelCCProjector.o
> o/3d.Linux.64.CC.ftn.OPTHIGH.MPI.OPENMPCC.PETSC/EBPetscLinearSolverPoisson.o
> o/3d.Linux.64.CC.ftn.OPTHIGH.MPI.OPENMPCC.PETSC/TrebNeumannPoissonEBBC.o
> o/3d.Linux.64.CC.ftn.OPTHIGH.MPI.OPENMPCC.PETSC/EBCompositeMACProjector.o
> o/3d.Linux.64.CC.ftn.OPTHIGH.MPI.OPENMPCC.PETSC/EBLevelMACProjector.o
> o/3d.Linux.64.CC.ftn.OPTHIGH.MPI.OPENMPCC.PETSC/EBPetscCompGridPois.o
> o/3d.Linux.64.CC.ftn.OPTHIGH.MPI.OPENMPCC.PETSC/InflowOutflowAdvectBC.o
> o/3d.Linux.64.CC.ftn.OPTHIGH.MPI.OPENMPCC.PETSC/InflowOutflowPoissonDomainBC.o
> o/3d.Linux.64.CC.ftn.OPTHIGH.MPI.OPENMPCC.PETSC/EBIBCFactory.o
> o/3d.Linux.64.CC.ftn.OPTHIGH.MPI.OPENMPCC.PETSC/TrebEBPetscLinearSolverPoisson.o
> o/3d.Linux.64.CC.ftn.OPTHIGH.MPI.OPENMPCC.PETSC/copyOver.o
> o/3d.Linux.64.CC.ftn.OPTHIGH.MPI.OPENMPCC.PETSC/extrapolateData.o
> o/3d.Linux.64.CC.ftn.OPTHIGH.MPI.OPENMPCC.PETSC/RobinPoissonEBBC.o
> o/3d.Linux.64.CC.ftn.OPTHIGH.MPI.OPENMPCC.PETSC/SVD.o
> o/3d.Linux.64.CC.ftn.OPTHIGH.MPI.OPENMPCC.PETSC/InflowOutflowIBC.o
> o/3d.Linux.64.CC.ftn.OPTHIGH.MPI.OPENMPCC.PETSC/NoFlowVortex.o
> o/3d.Linux.64.CC.ftn.OPTHIGH.MPI.OPENMPCC.PETSC/lsStencil.o
> o/3d.Linux.64.CC.ftn.OPTHIGH.MPI.OPENMPCC.PETSC/Choose.o
> o/3d.Linux.64.CC.ftn.OPTHIGH.MPI.OPENMPCC.PETSC/PoiseuilleInflowBCValue.o
> o/3d.Linux.64.CC.ftn.OPTHIGH.MPI.OPENMPCC.PETSC/util.o
> o/3d.Linux.64.CC.ftn.OPTHIGH.MPI.OPENMPCC.PETSC/EBPetscGridConductivity.o
> o/3d.Linux.64.CC.ftn.OPTHIGH.MPI.OPENMPCC.PETSC/EBPetscMap.o
> o/3d.Linux.64.CC.ftn.OPTHIGH.MPI.OPENMPCC.PETSC/EBPetscGridPoisson.o
> o/3d.Linux.64.CC.ftn.OPTHIGH.MPI.OPENMPCC.PETSC/EBAMRNoSubcycleF.o
> o/3d.Linux.64.CC.ftn.OPTHIGH.MPI.OPENMPCC.PETSC/EBGradDivFilterF.o
> -L../../../Chombo/lib
> -lebamrtimedependent3d.Linux.64.CC.ftn.OPTHIGH.MPI.OPENMPCC.PETSC -
> lebamrelliptic3d.Linux.64.CC.ftn.OPTHIGH.MPI.OPENMPCC.PETSC -
> lebamrtools3d.Linux.64.CC.ftn.OPTHIGH.MPI.OPENMPCC.PETSC
> -lworkshop3d.Linux.64.CC.ftn.OPTHIGH.MPI.OPENMPCC.PETSC
> -lebtools3d.Linux.64.CC.ftn.OPTHIGH.MPI.OPENMPCC.PETSC
> -lamrtimedependent3d.Linux.64.CC.ftn.OPTHIGH.MPI.OPENMPCC.PETSC -
> lamrelliptic3d.Linux.64.CC.ftn.OPTHIGH.MPI.OPENMPCC.PETSC
> -lamrtools3d.Linux.64.CC.ftn.OPTHIGH.MPI.OPENMPCC.PETSC
> -lboxtools3d.Linux.64.CC.ftn.OPTHIGH.MPI.OPENMPCC.PETSC
> -lbasetools3d.Linux.64.CC.ftn.OPTHIGH.MPI.OPENMPCC.PETSC
> -L/opt/cray/pe/hdf5-parallel/1.10.1.1/GNU/5.1/lib -lhdf5 -lz
> -L/global/homes/m/madams/petsc_install/petsc-cori-knl-opt64-gcc-omp/lib
> -Wl,-rpath,/global/homes/m/madams/petsc_install/petsc-cori-knl-opt64-gcc-omp/lib
> -lpetsc -lsuperlu_dist -lHYPRE -lparmetis -lmetis -lstdc++ -ldl
> -lgfortran -lm -lgomp -o viscousDriver3d.Linux.64.CC.ftn.OPTHIGH.MPI.OPENMPCC.PETSC.ex
> |& awk -f ../../../Chombo/lib/mk/tempnam.awk"
> > /opt/cray/pe/hdf5-parallel/1.10.1.1/GNU/5.1/lib/libhdf5.a(H5PL.o): In
> function `H5PL_load':
> > H5PL.c:(.text+0x7a0): warning: Using 'dlopen' in statically linked
> applications requires at runtime the shared libraries from the glibc
> version used for linking
> /global/homes/m/madams/petsc_install/petsc-cori-knl-opt64-gcc-omp/lib/libpetsc.a(send.o):
> In function `PetscOpenSocket':
> /global/u2/m/madams/petsc_install/petsc/src/sys/classes/viewer/impls/socket/send.c:107:
> warning: Using 'gethostbyname' in statically linked applications requires
> at runtime the shared libraries from the glibc version used for linking
> /global/homes/m/madams/petsc_install/petsc-cori-knl-opt64-gcc-omp/lib/libpetsc.a(mathinf.o):
> In function `PetscIsNormalReal':
> > /global/u2/m/madams/petsc_install/petsc/src/sys/utils/mathinf.c:23:
> undefined reference to `__isnormal'
> > /usr/bin/ld: link errors found, deleting executable `
> viscousDriver3d.Linux.64.CC.ftn.OPTHIGH.MPI.OPENMPCC.PETSC.ex'
> > collect2: error: ld returned 1 exit status
> > ../../../Chombo/lib/mk/Make.rules:412: recipe for target '
> viscousDriver3d.Linux.64.CC.ftn.OPTHIGH.MPI.OPENMPCC.PETSC.ex' failed
> > gmake[1]: *** [viscousDriver3d.Linux.64.CC.ftn.OPTHIGH.MPI.OPENMPCC.PETSC.ex]
> Error 1
> > ../../../Chombo/lib/mk/Make.rules:325: recipe for target 'all-example'
> failed
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20180823/acd101fa/attachment.html>
