[petsc-users] Debugging SNES when "everything" looks okay
Smith, Barry F. bsmith at mcs.anl.gov
Tue Aug 21 21:13:35 CDT 2018
  Ellen,
1)    The number one cause of failed Newton's method is incorrect Jacobians.
    PETSc 3.9 has an improved way of checking the Jacobian. Just run the code with the same options as given below plus -snes_test_jacobian and confirm if it believes the the Jacobian is correct.
    If the Jacobians look good you can run with -snes_linesearch_monitor to see how the SNES solve is failing.
2)    A less common but possible cause is that the initial guess you are using is too far from the "basin of attraction" of Newton's method so that convergence just won't happen. To test this start with a very small N (say 4), does Newton's method converge? What about N of say 8? If it converges for small N you can use grid sequencing to generate initial guesses for the finer mesh from the coarser mesh. The SNES options for this is -
snes_grid_sequence
    Good luck,
    Barry
3) The solvers can also fail if the function evaluation is "wrong" but that is much harder to test for.
> On Aug 21, 2018, at 9:00 PM, Ellen M. Price <ellen.price at cfa.harvard.edu> wrote:
> Hi PETSc users,
> I'm having trouble applying SNES to a new problem I'm working on. I'll
> try to be as complete as possible but can't post the full code because
> it's ongoing research and is pretty long anyway.
> The nonlinear problem arises from trying to solve a set of two coupled
> ODEs using a Galerkin method. I am using Mathematica to generate the
> objective function to solve and the Jacobian, so I *think* I can rule
> out human error on that front.
> There are four things I can easily change:
> - number of DMDA grid points N (I've tried 100 and 1000)
> - preconditioner (I've tried LU and SVD, LU appears to work better, and
> SVD is too slow for N = 1000)
> - linear solver (haven't played with this much, but sometimes smaller
> tolerances work better)
> - nonlinear solver (what I'm having trouble with)
> Trying different solvers should, as far as I'm aware, give comparable
> answers, but that's not the case here. NEWTONTR works best of the ones
> I've tried, but I'm suspicious that the function value barely decreases
> before SNES "converges" -- and none of the options I've tried changing
> seem to affect this, as it just finds another reason to converge without
> making any real progress. For example:
>  0 SNES Function norm 7.197788479418e+00
>    0 KSP Residual norm 1.721996766619e+01
>    1 KSP Residual norm 5.186021549059e-14
>  Linear solve converged due to CONVERGED_STEP_LENGTH iterations 1
>  1 SNES Function norm 7.197777674987e+00
>    0 KSP Residual norm 3.296112185897e+01
>    1 KSP Residual norm 2.713415432045e-13
> 50 SNES Function norm 7.197376803542e+00
>    0 KSP Residual norm 6.222518656302e+02
>    1 KSP Residual norm 9.630659996504e-12
> 51 SNES Function norm 7.197376803542e+00
> Nonlinear solve converged due to CONVERGED_SNORM_RELATIVE iterations 50
> I've tried everything I can think of and the FAQ suggestions, including
> non-dimensionalizing the problem; I observe the same behavior either
> way. The particularly strange thing I can't understand is why some of
> the SNES methods fail outright, after just one iteration (NCG, NGMRES,
> and others) with DIVERGED_DTOL. Unless I've misunderstood, it seems
> like, for the most part, I should be able to substitute in one method
> for another, possibly adjusting a few parameters along the way.
> Furthermore, the default method, NEWTONLS, diverges with
> DIVERGED_LINE_SEARCH, which I'm not sure how to debug.
> So the only viable method is NEWTONTR, and that doesn't appear to
> "really" converge. Any suggestions for further things to try are
> appreciated. My current options are:
> -pc_type lu -snes_monitor -snes_converged_reason -ksp_converged_reason
> -snes_max_it 10000 -ksp_monitor -snes_type newtonls
> Thanks in advance,
> Ellen Price
