[petsc-users] large number of iteration.
Josh L ysjosh.lo at gmail.com
Thu Aug 16 11:32:11 CDT 2018
Hi Matt,
I have solved the error by using MatZeroRowsColumns instead of MatZeroRows.
My code is actually using Newton's method to solve nonlinear problem, and
what I do is
impose the Dirichlet BC before calculating the matrix and rhs(residual
vector), and then set the corresponding entries in rhs to zero and zeros
out the rows, so the incremental solution for Dirichlet BC is 0. By doing
so, MatzeroRowsCloumns and MatZeroRows will actually give the same solution.
Josh
2018-08-13 9:13 GMT-05:00 Matthew Knepley <knepley at gmail.com>:
> On Sun, Aug 12, 2018 at 11:02 PM Smith, Barry F. <bsmith at mcs.anl.gov>
> wrote:
>>   Sending this to PETSc users because someone else (Mark?) will know why
>> the Eigen estimator fails at iteration 0.
> Are you sure its the estimator? That should be GMRES, but the error is
> coming from Chebyshev.
> You are remembering to put something on the diagonal of the zeroed rows,
> right?
>    Matt
>>    I notice you are using a real old version of PETSc, for GAMG which is
>> a fast moving component of PETSc this may fail. You really should work with
>> the latest version of PETSc. Why aren't you?
>>    Barry
>> > On Aug 12, 2018, at 9:25 PM, Josh L <ysjosh.lo at gmail.com> wrote:
>> > Hi Barry,
>> > I set the near null space following the example, but I get error when
>> solving it with -pc_type gamg(no error if solving with default PC).
>> > Moreover, there will be no error if I don't call
>> VecSetBlockSize(vec_coord,2) (it is a 2-D problem), but the near null space
>> will not affect iteration number.
>> > Is it because the way I set Dirichlet boundary conditions?
>> > I just zero out the corresponding row and modify right hand size.
>> > There is no Neumann bc.
>> > Thanks,
>> > The following is the error I get
>> > [0]PETSC ERROR: --------------------- Error Message
>> > [0]PETSC ERROR: Petsc has generated inconsistent data
>> > [0]PETSC ERROR: Eigen estimator failed: DIVERGED_NANORINF at iteration 0
>> > [0]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html
>> for trouble shooting.
>> > [0]PETSC ERROR: Petsc Release Version 3.7.5, Jan, 01, 2017
>> > [0]PETSC ERROR: /work/03691/yslo/lonestar/inex/crack on a haswell
>> named nid00009 by yslo Sun Aug 12 21:14:17 2018
>> > [0]PETSC ERROR: Configure options --with-x=0 -with-pic --with-np=8
>> --with-external-packages-dir=/opt/apps/intel16/cray_mpich_7_3/petsc/3.7/externalpackages
>> --with-mpi-compilers=1 --with-mpi-dir=/opt/apps/intel16/cray_mpich/7.3.0
>> --with-scalar-type=real --with-shared-libraries=1 --with-precision=double
>> --with-chaco=1 --download-chaco --with-hypre=1 --download-hypre --with-ml=1
>> --download-ml --with-ml=1 --download-ml --with-plapack=1 --download-plapack
>> --with-spai=1 --download-spai --with-sundials=1 --download-sundials
>> --with-hdf5=1 --with-hdf5-dir=/opt/apps/intel16/cray_mpich_7_2/phdf5/1.8.16/x86_64
>> --with-mumps=1 --download-mumps --with-parmetis=1 --download-parmetis
>> --with-metis=1 --download-metis --with-scalapack=1 --download-scalapack
>> --with-blacs=1 --download-blacs --with-spooles=1 --download-spooles
>> --with-suitesparse=1 --download-suitesparse --with-superlu_dist=1
>> --download-superlu_dist --with-superlu=1 --download-superlu
>> --with-parmetis=1 --download-parmetis --with-metis=1 --download-metis
>> --with-debugging=no --with-blas-lapack-dir=/opt/apps/intel/16.0.1.150/
>> compilers_and_libraries_2016.1.150/linux/mkl --CFLAGS="-xhost -O2 -g"
>> --FFLAGS="-xhost -O2 -g" --CXXFLAGS="-xhost -O2 -g"
>> > [0]PETSC ERROR: #1 KSPSolve_Chebyshev() line 440 in
>> /opt/apps/intel16/cray_mpich_7_3/petsc/3.7/src/ksp/ksp/
>> impls/cheby/cheby.c
>> > [0]PETSC ERROR: #2 KSPSolve() line 656 in /opt/apps/intel16/cray_mpich_
>> 7_3/petsc/3.7/src/ksp/ksp/interface/itfunc.c
>> > [0]PETSC ERROR: #3 PCMGMCycle_Private() line 21 in
>> /opt/apps/intel16/cray_mpich_7_3/petsc/3.7/src/ksp/pc/impls/mg/mg.c
>> > [0]PETSC ERROR: #4 PCMGMCycle_Private() line 55 in
>> > [0]PETSC ERROR: #5 PCMGMCycle_Private() line 55 in
>> > [0]PETSC ERROR: #6 PCMGMCycle_Private() line 55 in
>> > [0]PETSC ERROR: #7 PCApply_MG() line 343 in
>> > [0]PETSC ERROR: #8 PCApply() line 482 in /opt/apps/intel16/cray_mpich_
>> 7_3/petsc/3.7/src/ksp/pc/interface/precon.c
>> > [0]PETSC ERROR: #9 KSP_PCApply() line 244 in
>> /opt/apps/intel16/cray_mpich_7_3/petsc/3.7/include/petsc/
>> private/kspimpl.h
>> > [0]PETSC ERROR: #10 KSPInitialResidual() line 69 in
>> /opt/apps/intel16/cray_mpich_7_3/petsc/3.7/src/ksp/ksp/interface/itres.c
>> > [0]PETSC ERROR: #11 KSPSolve_GMRES() line 239 in
>> impls/gmres/gmres.c
>> > [0]PETSC ERROR: #12 KSPSolve() line 656 in /opt/apps/intel16/cray_mpich_
>> > 2018-08-11 14:27 GMT-05:00 Smith, Barry F. <bsmith at mcs.anl.gov>:
>> > > On Aug 9, 2018, at 9:11 PM, Josh L <ysjosh.lo at gmail.com> wrote:
>> > > 2018-08-09 18:47 GMT-05:00 Smith, Barry F. <bsmith at mcs.anl.gov>:
>> > > > On Aug 9, 2018, at 3:03 PM, Josh L <ysjosh.lo at gmail.com> wrote:
>> > > > Hi Barry,
>> > > > I use the example ex49 of KSP(linear elasticity problem), and it's
>> output of ksp monitor is the same as my reduced problem, so I think my code
>> is correct , at least for the reduced problem.
>> > >    Are you using -pc_type gamg ?
>> > >       No, just with GMRES and default PC.
>> > >       strangely, with gamg, the final solution is still the same but
>> ksp output becomes different between my code and petsc example.
>> > >       with -pc_type gamg, my code take 35 iteration and petsc example
>> takes only 7.
>> >    You should use GAMG for elasticity type problems. Does you code set
>> the near null space like the example does?
>> > >      Thanks.
>> > > > Within a Newton's method, several linear system(Ax=b) is solved,
>> and b is the residual vector whose norm becomes smaller and smaller.
>> > > > Should I change rtol for KSP ? since ||b|| is reducing, and
>> converge requires ||b-Ax|| / ||b||  < rtol ( || b - Ax || < atol=10^-50 is
>> rarely satisfied )
>> > > > I observe that for the first linear solve in Newton's method,
>> iterative solver converges with okay number of iteration
>> > > > , but for the following linear solve, iterative solver takes more
>> and more iterations.
>> > >    You can probably get away with -ksp_rtol 1.e-3 or even try 1.e-2
>> > >     Try also -ksp_pc_side right
>> > >    Barry
>> > > > Thanks,
>> > > > Josh
>> > > > 2018-08-09 10:26 GMT-05:00 Smith, Barry F. <bsmith at mcs.anl.gov>:
>> > > >    Ok, PCGAMG should work well for linear elasticity so on your
>> reduced problem use -pc_type gamg then the group (Mark) will have specific
>> suggestions for options. We want to see about 20 iterations for
>> "well-behaved" linear elasticity problems.
>> > > >    Barry
>> > > > > On Aug 8, 2018, at 5:48 PM, Josh L <ysjosh.lo at gmail.com> wrote:
>> > > > > Hi Barry,
>> > > > > Thanks for your help.
>> > > > > I removed the phase field from my formulation by setting all
>> corresponding degrees of freedom as Dirichlet boundary condition, so
>> > > > > my formulation becomes simply linear elastic.
>> > > > > Then I use CG for KSP and algebraic multigrid for precondiitoner.
>> For a 150K dofs problem, the linear solver converges with 200s
>> iteration(still too much I think), but with GMRES it again takes 2000
>> iteration to converge. with GMRES and default PC, it barely converges
>> within 10K iteration.
>> > > > > I will double check my hessian. below is the  ksp monitor output
>> from GMRES and gamg PC for first 500 iteration.
>> > > > >  0 KSP preconditioned resid norm 9.175598437886e-07 true resid
>> norm 4.423520976130e-07 ||r(i)||/||b|| 1.000000000000e+00
>> > > > >   1 KSP preconditioned resid norm 9.171756840415e-07 true resid
>> norm 4.185847348836e-07 ||r(i)||/||b|| 9.462704871128e-01
>> > > > >   2 KSP preconditioned resid norm 9.171436192115e-07 true resid
>> norm 4.373193748329e-07 ||r(i)||/||b|| 9.886228124446e-01
>> > > > >   3 KSP preconditioned resid norm 9.047636402661e-07 true resid
>> norm 2.655845586443e-07 ||r(i)||/||b|| 6.003917695371e-01
>> > > > >   4 KSP preconditioned resid norm 9.032722605019e-07 true resid
>> norm 3.045614764490e-07 ||r(i)||/||b|| 6.885046506899e-01
>> > > > >   5 KSP preconditioned resid norm 8.926003608855e-07 true resid
>> norm 3.498775710352e-07 ||r(i)||/||b|| 7.909481449805e-01
>> > > > >   6 KSP preconditioned resid norm 8.788553543841e-07 true resid
>> norm 2.052341235884e-07 ||r(i)||/||b|| 4.639610045841e-01
>> > > > >   7 KSP preconditioned resid norm 8.725201948474e-07 true resid
>> norm 3.315801151567e-07 ||r(i)||/||b|| 7.495841365870e-01
>> > > > >   8 KSP preconditioned resid norm 8.704702843041e-07 true resid
>> norm 2.453167687304e-07 ||r(i)||/||b|| 5.545735400696e-01
>> > > > >   9 KSP preconditioned resid norm 8.673295560357e-07 true resid
>> norm 3.480581533019e-07 ||r(i)||/||b|| 7.868350917291e-01
>> > > > >  10 KSP preconditioned resid norm 8.650826882165e-07 true resid
>> norm 3.331076551593e-07 ||r(i)||/||b|| 7.530373586036e-01
>> > > > >  11 KSP preconditioned resid norm 8.632977966037e-07 true resid
>> norm 2.943531620635e-07 ||r(i)||/||b|| 6.654273002250e-01
>> > > > >  12 KSP preconditioned resid norm 8.622407761375e-07 true resid
>> norm 3.413473413778e-07 ||r(i)||/||b|| 7.716643443532e-01
>> > > > >  13 KSP preconditioned resid norm 8.612343318250e-07 true resid
>> norm 2.962692292083e-07 ||r(i)||/||b|| 6.697588432541e-01
>> > > > >  14 KSP preconditioned resid norm 8.579354639983e-07 true resid
>> norm 3.298514619407e-07 ||r(i)||/||b|| 7.456762694710e-01
>> > > > >  15 KSP preconditioned resid norm 8.578914052098e-07 true resid
>> norm 3.287293954137e-07 ||r(i)||/||b|| 7.431396780699e-01
>> > > > >  16 KSP preconditioned resid norm 8.564349944906e-07 true resid
>> norm 3.231662390796e-07 ||r(i)||/||b|| 7.305633698212e-01
>> > > > >  17 KSP preconditioned resid norm 8.544772830576e-07 true resid
>> norm 3.522175745975e-07 ||r(i)||/||b|| 7.962380567383e-01
>> > > > >  18 KSP preconditioned resid norm 8.518664697660e-07 true resid
>> norm 2.957457436154e-07 ||r(i)||/||b|| 6.685754294176e-01
>> > > > >  19 KSP preconditioned resid norm 8.502444318835e-07 true resid
>> norm 3.231647326483e-07 ||r(i)||/||b|| 7.305599643183e-01
>> > > > >  20 KSP preconditioned resid norm 8.488626061229e-07 true resid
>> norm 3.034773190650e-07 ||r(i)||/||b|| 6.860537583129e-01
>> > > > >  21 KSP preconditioned resid norm 8.472536047506e-07 true resid
>> norm 3.142174821592e-07 ||r(i)||/||b|| 7.103334286301e-01
>> > > > >  22 KSP preconditioned resid norm 8.465622251926e-07 true resid
>> norm 3.109996301173e-07 ||r(i)||/||b|| 7.030590151951e-01
>> > > > >  23 KSP preconditioned resid norm 8.455410030133e-07 true resid
>> norm 3.026169375479e-07 ||r(i)||/||b|| 6.841087431955e-01
>> > > > >  24 KSP preconditioned resid norm 8.441686432481e-07 true resid
>> norm 3.247156730398e-07 ||r(i)||/||b|| 7.340660862513e-01
>> > > > >  25 KSP preconditioned resid norm 8.422635872670e-07 true resid
>> norm 2.949977317008e-07 ||r(i)||/||b|| 6.668844418115e-01
>> > > > >  26 KSP preconditioned resid norm 8.391013229654e-07 true resid
>> norm 3.503429354312e-07 ||r(i)||/||b|| 7.920001675626e-01
>> > > > >  27 KSP preconditioned resid norm 8.369135179081e-07 true resid
>> norm 2.932796516614e-07 ||r(i)||/||b|| 6.630004768691e-01
>> > > > >  28 KSP preconditioned resid norm 8.344557411519e-07 true resid
>> norm 3.290576497205e-07 ||r(i)||/||b|| 7.438817437425e-01
>> > > > >  29 KSP preconditioned resid norm 8.255611852636e-07 true resid
>> norm 3.228082527538e-07 ||r(i)||/||b|| 7.297540906796e-01
>> > > > >  30 KSP preconditioned resid norm 8.191145448615e-07 true resid
>> norm 2.695709281706e-07 ||r(i)||/||b|| 6.094035263430e-01
>> > > > >  31 KSP preconditioned resid norm 8.190911648438e-07 true resid
>> norm 2.661586473845e-07 ||r(i)||/||b|| 6.016895790044e-01
>> > > > >  32 KSP preconditioned resid norm 8.188934260789e-07 true resid
>> norm 3.000926727757e-07 ||r(i)||/||b|| 6.784022826953e-01
>> > > > >  33 KSP preconditioned resid norm 8.166449659697e-07 true resid
>> norm 2.081220810731e-07 ||r(i)||/||b|| 4.704896443267e-01
>> > > > >  34 KSP preconditioned resid norm 8.130668560598e-07 true resid
>> norm 3.175998062677e-07 ||r(i)||/||b|| 7.179796546271e-01
>> > > > >  35 KSP preconditioned resid norm 8.103250854289e-07 true resid
>> norm 2.675762536241e-07 ||r(i)||/||b|| 6.048942800723e-01
>> > > > >  36 KSP preconditioned resid norm 8.079447876546e-07 true resid
>> norm 2.624343353237e-07 ||r(i)||/||b|| 5.932702404709e-01
>> > > > >  37 KSP preconditioned resid norm 8.064590891986e-07 true resid
>> norm 2.891085928184e-07 ||r(i)||/||b|| 6.535712035243e-01
>> > > > >  38 KSP preconditioned resid norm 8.039981484367e-07 true resid
>> norm 2.435760434885e-07 ||r(i)||/||b|| 5.506383824173e-01
>> > > > >  39 KSP preconditioned resid norm 8.030132361660e-07 true resid
>> norm 2.791572408348e-07 ||r(i)||/||b|| 6.310747532139e-01
>> > > > >  40 KSP preconditioned resid norm 8.025869823713e-07 true resid
>> norm 2.673367609434e-07 ||r(i)||/||b|| 6.043528727137e-01
>> > > > >  41 KSP preconditioned resid norm 8.011717744772e-07 true resid
>> norm 2.626259645676e-07 ||r(i)||/||b|| 5.937034457049e-01
>> > > > >  42 KSP preconditioned resid norm 7.994420264672e-07 true resid
>> norm 2.931234480129e-07 ||r(i)||/||b|| 6.626473562454e-01
>> > > > >  43 KSP preconditioned resid norm 7.976276065412e-07 true resid
>> norm 2.565425485040e-07 ||r(i)||/||b|| 5.799510161438e-01
>> > > > >  44 KSP preconditioned resid norm 7.963529254232e-07 true resid
>> norm 2.683594511633e-07 ||r(i)||/||b|| 6.066648098007e-01
>> > > > >  45 KSP preconditioned resid norm 7.951914923472e-07 true resid
>> norm 2.726317559874e-07 ||r(i)||/||b|| 6.163229641241e-01
>> > > > >  46 KSP preconditioned resid norm 7.943011197327e-07 true resid
>> norm 2.561291446355e-07 ||r(i)||/||b|| 5.790164577440e-01
>> > > > >  47 KSP preconditioned resid norm 7.926385476568e-07 true resid
>> norm 2.978344787798e-07 ||r(i)||/||b|| 6.732973131290e-01
>> > > > >  48 KSP preconditioned resid norm 7.909780991424e-07 true resid
>> norm 2.498059973427e-07 ||r(i)||/||b|| 5.647220815515e-01
>> > > > >  49 KSP preconditioned resid norm 7.863002375447e-07 true resid
>> norm 3.283898230799e-07 ||r(i)||/||b|| 7.423720263834e-01
>> > > > >  50 KSP preconditioned resid norm 7.778093966862e-07 true resid
>> norm 2.908211438411e-07 ||r(i)||/||b|| 6.574426693360e-01
>> > > > >  51 KSP preconditioned resid norm 7.727705792892e-07 true resid
>> norm 2.662262655905e-07 ||r(i)||/||b|| 6.018424396020e-01
>> > > > >  52 KSP preconditioned resid norm 7.580949386500e-07 true resid
>> norm 4.077725304210e-07 ||r(i)||/||b|| 9.218279570084e-01
>> > > > >  53 KSP preconditioned resid norm 7.223569984502e-07 true resid
>> norm 2.806806877450e-07 ||r(i)||/||b|| 6.345187222115e-01
>> > > > >  54 KSP preconditioned resid norm 6.833104315428e-07 true resid
>> norm 3.167664065828e-07 ||r(i)||/||b|| 7.160956357890e-01
>> > > > >  55 KSP preconditioned resid norm 6.480813314286e-07 true resid
>> norm 3.449389182846e-07 ||r(i)||/||b|| 7.797836161419e-01
>> > > > >  56 KSP preconditioned resid norm 5.628534804207e-07 true resid
>> norm 5.008589310744e-07 ||r(i)||/||b|| 1.132263040635e+00
>> > > > >  57 KSP preconditioned resid norm 4.676624755957e-07 true resid
>> norm 2.747589656053e-07 ||r(i)||/||b|| 6.211318248245e-01
>> > > > >  58 KSP preconditioned resid norm 4.266847724428e-07 true resid
>> norm 2.051356033363e-07 ||r(i)||/||b|| 4.637382855043e-01
>> > > > >  59 KSP preconditioned resid norm 3.963440719602e-07 true resid
>> norm 1.462894974865e-07 ||r(i)||/||b|| 3.307082712524e-01
>> > > > >  60 KSP preconditioned resid norm 3.710732500804e-07 true resid
>> norm 2.006153077396e-07 ||r(i)||/||b|| 4.535195126737e-01
>> > > > >  61 KSP preconditioned resid norm 3.700288732490e-07 true resid
>> norm 1.637656172799e-07 ||r(i)||/||b|| 3.702155322956e-01
>> > > > >  62 KSP preconditioned resid norm 3.681230892718e-07 true resid
>> norm 2.598403207310e-07 ||r(i)||/||b|| 5.874061005545e-01
>> > > > >  63 KSP preconditioned resid norm 3.447874366524e-07 true resid
>> norm 9.834277028700e-08 ||r(i)||/||b|| 2.223178567880e-01
>> > > > >  64 KSP preconditioned resid norm 3.308954457293e-07 true resid
>> norm 8.462173093522e-08 ||r(i)||/||b|| 1.912994905910e-01
>> > > > >  65 KSP preconditioned resid norm 3.238105866460e-07 true resid
>> norm 1.508442004566e-07 ||r(i)||/||b|| 3.410048268575e-01
>> > > > >  66 KSP preconditioned resid norm 3.149261250545e-07 true resid
>> norm 6.146735546031e-08 ||r(i)||/||b|| 1.389557228100e-01
>> > > > >  67 KSP preconditioned resid norm 3.080685419183e-07 true resid
>> norm 1.469742604456e-07 ||r(i)||/||b|| 3.322562755748e-01
>> > > > >  68 KSP preconditioned resid norm 3.017036477950e-07 true resid
>> norm 8.246002370676e-08 ||r(i)||/||b|| 1.864126431224e-01
>> > > > >  69 KSP preconditioned resid norm 2.951373085123e-07 true resid
>> norm 9.600472070625e-08 ||r(i)||/||b|| 2.170323622840e-01
>> > > > >  70 KSP preconditioned resid norm 2.854303567501e-07 true resid
>> norm 1.353606365274e-07 ||r(i)||/||b|| 3.060020225015e-01
>> > > > >  71 KSP preconditioned resid norm 2.720605973489e-07 true resid
>> norm 7.105192119695e-08 ||r(i)||/||b|| 1.606230005020e-01
>> > > > >  72 KSP preconditioned resid norm 2.679746464067e-07 true resid
>> norm 1.093157769657e-07 ||r(i)||/||b|| 2.471239032336e-01
>> > > > >  73 KSP preconditioned resid norm 2.560436669192e-07 true resid
>> norm 1.046442873472e-07 ||r(i)||/||b|| 2.365633347550e-01
>> > > > >  74 KSP preconditioned resid norm 2.486272155786e-07 true resid
>> norm 6.788331443968e-08 ||r(i)||/||b|| 1.534599130557e-01
>> > > > >  75 KSP preconditioned resid norm 2.450613653917e-07 true resid
>> norm 8.385393991346e-08 ||r(i)||/||b|| 1.895637894925e-01
>> > > > >  76 KSP preconditioned resid norm 2.381548789947e-07 true resid
>> norm 9.639184405623e-08 ||r(i)||/||b|| 2.179075098239e-01
>> > > > >  77 KSP preconditioned resid norm 2.318084665470e-07 true resid
>> norm 5.817254053914e-08 ||r(i)||/||b|| 1.315073238107e-01
>> > > > >  78 KSP preconditioned resid norm 2.301457113250e-07 true resid
>> norm 7.214348778091e-08 ||r(i)||/||b|| 1.630906424322e-01
>> > > > >  79 KSP preconditioned resid norm 2.288069605204e-07 true resid
>> norm 6.520316797685e-08 ||r(i)||/||b|| 1.474010597637e-01
>> > > > >  80 KSP preconditioned resid norm 2.272182407377e-07 true resid
>> norm 6.553558340584e-08 ||r(i)||/||b|| 1.481525322463e-01
>> > > > >  81 KSP preconditioned resid norm 2.261791202938e-07 true resid
>> norm 6.410731366977e-08 ||r(i)||/||b|| 1.449237248240e-01
>> > > > >  82 KSP preconditioned resid norm 2.250209367027e-07 true resid
>> norm 6.108112632184e-08 ||r(i)||/||b|| 1.380825967627e-01
>> > > > >  83 KSP preconditioned resid norm 2.237071893420e-07 true resid
>> norm 6.644497913123e-08 ||r(i)||/||b|| 1.502083509715e-01
>> > > > >  84 KSP preconditioned resid norm 2.234300550868e-07 true resid
>> norm 5.793844170260e-08 ||r(i)||/||b|| 1.309781100061e-01
>> > > > >  85 KSP preconditioned resid norm 2.229005171876e-07 true resid
>> norm 6.926007074308e-08 ||r(i)||/||b|| 1.565722670172e-01
>> > > > >  86 KSP preconditioned resid norm 2.225791427950e-07 true resid
>> norm 6.289120214757e-08 ||r(i)||/||b|| 1.421745312997e-01
>> > > > >  87 KSP preconditioned resid norm 2.224479658210e-07 true resid
>> norm 6.242310048343e-08 ||r(i)||/||b|| 1.411163207325e-01
>> > > > >  88 KSP preconditioned resid norm 2.217191418500e-07 true resid
>> norm 7.465963600280e-08 ||r(i)||/||b|| 1.687787543128e-01
>> > > > >  89 KSP preconditioned resid norm 2.208527637102e-07 true resid
>> norm 5.960066095409e-08 ||r(i)||/||b|| 1.347357936714e-01
>> > > > >  90 KSP preconditioned resid norm 2.204546869923e-07 true resid
>> norm 6.334569716267e-08 ||r(i)||/||b|| 1.432019820964e-01
>> > > > >  91 KSP preconditioned resid norm 2.204546270123e-07 true resid
>> norm 6.327475947831e-08 ||r(i)||/||b|| 1.430416173445e-01
>> > > > >  92 KSP preconditioned resid norm 2.204329606031e-07 true resid
>> norm 6.775206679705e-08 ||r(i)||/||b|| 1.531632090424e-01
>> > > > >  93 KSP preconditioned resid norm 2.203318409249e-07 true resid
>> norm 6.059983893344e-08 ||r(i)||/||b|| 1.369945779854e-01
>> > > > >  94 KSP preconditioned resid norm 2.202099673600e-07 true resid
>> norm 7.148771248833e-08 ||r(i)||/||b|| 1.616081688639e-01
>> > > > >  95 KSP preconditioned resid norm 2.200347850341e-07 true resid
>> norm 6.555792528003e-08 ||r(i)||/||b|| 1.482030392391e-01
>> > > > >  96 KSP preconditioned resid norm 2.196138742262e-07 true resid
>> norm 6.418387078605e-08 ||r(i)||/||b|| 1.450967931030e-01
>> > > > >  97 KSP preconditioned resid norm 2.193396877997e-07 true resid
>> norm 7.242613574407e-08 ||r(i)||/||b|| 1.637296084610e-01
>> > > > >  98 KSP preconditioned resid norm 2.186895327006e-07 true resid
>> norm 5.717301192712e-08 ||r(i)||/||b|| 1.292477468416e-01
>> > > > >  99 KSP preconditioned resid norm 2.183391464984e-07 true resid
>> norm 6.921630451950e-08 ||r(i)||/||b|| 1.564733272273e-01
>> > > > > 100 KSP preconditioned resid norm 2.182400010423e-07 true resid
>> norm 6.548314285564e-08 ||r(i)||/||b|| 1.480339829041e-01
>> > > > > 101 KSP preconditioned resid norm 2.177799012029e-07 true resid
>> norm 6.272281990396e-08 ||r(i)||/||b|| 1.417938792252e-01
>> > > > > 102 KSP preconditioned resid norm 2.169682429176e-07 true resid
>> norm 7.907535208604e-08 ||r(i)||/||b|| 1.787611102394e-01
>> > > > > 103 KSP preconditioned resid norm 2.164150347952e-07 true resid
>> norm 5.949404986863e-08 ||r(i)||/||b|| 1.344947841090e-01
>> > > > > 104 KSP preconditioned resid norm 2.163293952130e-07 true resid
>> norm 6.398348014122e-08 ||r(i)||/||b|| 1.446437814729e-01
>> > > > > 105 KSP preconditioned resid norm 2.160399869141e-07 true resid
>> norm 6.102742478406e-08 ||r(i)||/||b|| 1.379611967782e-01
>> > > > > 106 KSP preconditioned resid norm 2.152042538469e-07 true resid
>> norm 5.769020450098e-08 ||r(i)||/||b|| 1.304169344110e-01
>> > > > > 107 KSP preconditioned resid norm 2.150064693173e-07 true resid
>> norm 6.321432589105e-08 ||r(i)||/||b|| 1.429049986022e-01
>> > > > > 108 KSP preconditioned resid norm 2.144289854705e-07 true resid
>> norm 5.801860121360e-08 ||r(i)||/||b|| 1.311593220122e-01
>> > > > > 109 KSP preconditioned resid norm 2.131016574445e-07 true resid
>> norm 5.968888809818e-08 ||r(i)||/||b|| 1.349352437126e-01
>> > > > > 110 KSP preconditioned resid norm 2.131016340852e-07 true resid
>> norm 5.978688769843e-08 ||r(i)||/||b|| 1.351567857846e-01
>> > > > > 111 KSP preconditioned resid norm 2.128679373780e-07 true resid
>> norm 7.339671126222e-08 ||r(i)||/||b|| 1.659237328325e-01
>> > > > > 112 KSP preconditioned resid norm 2.124763157021e-07 true resid
>> norm 6.095583088857e-08 ||r(i)||/||b|| 1.377993485676e-01
>> > > > > 113 KSP preconditioned resid norm 2.114936950060e-07 true resid
>> norm 7.680678889067e-08 ||r(i)||/||b|| 1.736326996190e-01
>> > > > > 114 KSP preconditioned resid norm 2.111409526125e-07 true resid
>> norm 6.861513382847e-08 ||r(i)||/||b|| 1.551142951480e-01
>> > > > > 115 KSP preconditioned resid norm 2.104578242179e-07 true resid
>> norm 6.666552557721e-08 ||r(i)||/||b|| 1.507069276645e-01
>> > > > > 116 KSP preconditioned resid norm 2.095794193794e-07 true resid
>> norm 8.409379058143e-08 ||r(i)||/||b|| 1.901060061323e-01
>> > > > > 117 KSP preconditioned resid norm 2.088313732014e-07 true resid
>> norm 6.461621062155e-08 ||r(i)||/||b|| 1.460741589567e-01
>> > > > > 118 KSP preconditioned resid norm 2.076780694200e-07 true resid
>> norm 8.889797338722e-08 ||r(i)||/||b|| 2.009665464840e-01
>> > > > > 119 KSP preconditioned resid norm 2.059381548473e-07 true resid
>> norm 7.343872609510e-08 ||r(i)||/||b|| 1.660187133539e-01
>> > > > > 120 KSP preconditioned resid norm 2.036694513953e-07 true resid
>> norm 7.626153726963e-08 ||r(i)||/||b|| 1.724000805719e-01
>> > > > > 121 KSP preconditioned resid norm 2.036437947430e-07 true resid
>> norm 7.403000216323e-08 ||r(i)||/||b|| 1.673553772271e-01
>> > > > > 122 KSP preconditioned resid norm 2.034858116471e-07 true resid
>> norm 9.140544194375e-08 ||r(i)||/||b|| 2.066350367433e-01
>> > > > > 123 KSP preconditioned resid norm 2.013655754252e-07 true resid
>> norm 4.519978376641e-08 ||r(i)||/||b|| 1.021805570954e-01
>> > > > > 124 KSP preconditioned resid norm 1.998009157253e-07 true resid
>> norm 7.924252610751e-08 ||r(i)||/||b|| 1.791390309555e-01
>> > > > > 125 KSP preconditioned resid norm 1.978761477601e-07 true resid
>> norm 6.193706028697e-08 ||r(i)||/||b|| 1.400175575547e-01
>> > > > > 126 KSP preconditioned resid norm 1.966003019512e-07 true resid
>> norm 5.417132474463e-08 ||r(i)||/||b|| 1.224620048983e-01
>> > > > > 127 KSP preconditioned resid norm 1.957579266801e-07 true resid
>> norm 7.621152479630e-08 ||r(i)||/||b|| 1.722870202437e-01
>> > > > > 128 KSP preconditioned resid norm 1.950451407619e-07 true resid
>> norm 5.429984244536e-08 ||r(i)||/||b|| 1.227525374885e-01
>> > > > > 129 KSP preconditioned resid norm 1.948052418686e-07 true resid
>> norm 6.458532086853e-08 ||r(i)||/||b|| 1.460043282648e-01
>> > > > > 130 KSP preconditioned resid norm 1.946142511609e-07 true resid
>> norm 5.988337322193e-08 ||r(i)||/||b|| 1.353749050701e-01
>> > > > > 131 KSP preconditioned resid norm 1.942556458837e-07 true resid
>> norm 5.860812144886e-08 ||r(i)||/||b|| 1.324920165748e-01
>> > > > > 132 KSP preconditioned resid norm 1.935241717066e-07 true resid
>> norm 8.129956448465e-08 ||r(i)||/||b|| 1.837892595590e-01
>> > > > > 133 KSP preconditioned resid norm 1.924599958511e-07 true resid
>> norm 5.461025246990e-08 ||r(i)||/||b|| 1.234542636162e-01
>> > > > > 134 KSP preconditioned resid norm 1.920525995377e-07 true resid
>> norm 6.091841929726e-08 ||r(i)||/||b|| 1.377147743302e-01
>> > > > > 135 KSP preconditioned resid norm 1.912474104817e-07 true resid
>> norm 6.146257286777e-08 ||r(i)||/||b|| 1.389449110775e-01
>> > > > > 136 KSP preconditioned resid norm 1.899112302838e-07 true resid
>> norm 5.363752248243e-08 ||r(i)||/||b|| 1.212552687596e-01
>> > > > > 137 KSP preconditioned resid norm 1.871603374495e-07 true resid
>> norm 1.033541760028e-07 ||r(i)||/||b|| 2.336468540796e-01
>> > > > > 138 KSP preconditioned resid norm 1.848601023477e-07 true resid
>> norm 4.885699993060e-08 ||r(i)||/||b|| 1.104482157861e-01
>> > > > > 139 KSP preconditioned resid norm 1.827750189949e-07 true resid
>> norm 8.191132589117e-08 ||r(i)||/||b|| 1.851722334610e-01
>> > > > > 140 KSP preconditioned resid norm 1.793562029798e-07 true resid
>> norm 6.003412567942e-08 ||r(i)||/||b|| 1.357157024989e-01
>> > > > > 141 KSP preconditioned resid norm 1.762198590085e-07 true resid
>> norm 5.955815320828e-08 ||r(i)||/||b|| 1.346396988500e-01
>> > > > > 142 KSP preconditioned resid norm 1.735812332311e-07 true resid
>> norm 7.966870349397e-08 ||r(i)||/||b|| 1.801024657142e-01
>> > > > > 143 KSP preconditioned resid norm 1.688412385715e-07 true resid
>> norm 5.688299429377e-08 ||r(i)||/||b|| 1.285921206223e-01
>> > > > > 144 KSP preconditioned resid norm 1.661476005287e-07 true resid
>> norm 7.082505578352e-08 ||r(i)||/||b|| 1.601101388819e-01
>> > > > > 145 KSP preconditioned resid norm 1.610383377332e-07 true resid
>> norm 5.920400760597e-08 ||r(i)||/||b|| 1.338391022117e-01
>> > > > > 146 KSP preconditioned resid norm 1.544803228895e-07 true resid
>> norm 6.998127061136e-08 ||r(i)||/||b|| 1.582026421690e-01
>> > > > > 147 KSP preconditioned resid norm 1.526491664454e-07 true resid
>> norm 5.645428190677e-08 ||r(i)||/||b|| 1.276229551333e-01
>> > > > > 148 KSP preconditioned resid norm 1.514873753547e-07 true resid
>> norm 5.864109468824e-08 ||r(i)||/||b|| 1.325665572848e-01
>> > > > > 149 KSP preconditioned resid norm 1.504821676672e-07 true resid
>> norm 6.213039985019e-08 ||r(i)||/||b|| 1.404546292093e-01
>> > > > > 150 KSP preconditioned resid norm 1.486089733443e-07 true resid
>> norm 5.614398416742e-08 ||r(i)||/||b|| 1.269214828423e-01
>> > > > > 151 KSP preconditioned resid norm 1.485963531298e-07 true resid
>> norm 5.477576327252e-08 ||r(i)||/||b|| 1.238284243888e-01
>> > > > > 152 KSP preconditioned resid norm 1.485376571004e-07 true resid
>> norm 6.371560914841e-08 ||r(i)||/||b|| 1.440382208929e-01
>> > > > > 153 KSP preconditioned resid norm 1.474539380136e-07 true resid
>> norm 3.640242097893e-08 ||r(i)||/||b|| 8.229286393207e-02
>> > > > > 154 KSP preconditioned resid norm 1.468139621410e-07 true resid
>> norm 4.869307908912e-08 ||r(i)||/||b|| 1.100776493474e-01
>> > > > > 155 KSP preconditioned resid norm 1.460083083948e-07 true resid
>> norm 4.630532787515e-08 ||r(i)||/||b|| 1.046797972136e-01
>> > > > > 156 KSP preconditioned resid norm 1.443569894841e-07 true resid
>> norm 3.603261718441e-08 ||r(i)||/||b|| 8.145686971725e-02
>> > > > > 157 KSP preconditioned resid norm 1.423163427629e-07 true resid
>> norm 6.442826410227e-08 ||r(i)||/||b|| 1.456492790470e-01
>> > > > > 158 KSP preconditioned resid norm 1.409955526676e-07 true resid
>> norm 3.683864351150e-08 ||r(i)||/||b|| 8.327900717616e-02
>> > > > > 159 KSP preconditioned resid norm 1.392132231651e-07 true resid
>> norm 6.633950516791e-08 ||r(i)||/||b|| 1.499699120359e-01
>> > > > > 160 KSP preconditioned resid norm 1.373585912794e-07 true resid
>> norm 4.602835576127e-08 ||r(i)||/||b|| 1.040536622515e-01
>> > > > > 161 KSP preconditioned resid norm 1.358554686788e-07 true resid
>> norm 4.404395475469e-08 ||r(i)||/||b|| 9.956764078290e-02
>> > > > > 162 KSP preconditioned resid norm 1.356117729059e-07 true resid
>> norm 5.220262213455e-08 ||r(i)||/||b|| 1.180114718936e-01
>> > > > > 163 KSP preconditioned resid norm 1.345828776136e-07 true resid
>> norm 4.364444677578e-08 ||r(i)||/||b|| 9.866449602318e-02
>> > > > > 164 KSP preconditioned resid norm 1.335743316358e-07 true resid
>> norm 4.365564289163e-08 ||r(i)||/||b|| 9.868980643971e-02
>> > > > > 165 KSP preconditioned resid norm 1.335181864567e-07 true resid
>> norm 4.195338231508e-08 ||r(i)||/||b|| 9.484160364891e-02
>> > > > > 166 KSP preconditioned resid norm 1.334081155239e-07 true resid
>> norm 4.320705771627e-08 ||r(i)||/||b|| 9.767571567858e-02
>> > > > > 167 KSP preconditioned resid norm 1.330652717803e-07 true resid
>> norm 4.671646276077e-08 ||r(i)||/||b|| 1.056092262541e-01
>> > > > > 168 KSP preconditioned resid norm 1.327117008156e-07 true resid
>> norm 4.076640307294e-08 ||r(i)||/||b|| 9.215826779826e-02
>> > > > > 169 KSP preconditioned resid norm 1.323823831437e-07 true resid
>> norm 4.609403230274e-08 ||r(i)||/||b|| 1.042021334396e-01
>> > > > > 170 KSP preconditioned resid norm 1.321738715249e-07 true resid
>> norm 4.115763769210e-08 ||r(i)||/||b|| 9.304270944840e-02
>> > > > > 171 KSP preconditioned resid norm 1.317312129565e-07 true resid
>> norm 4.587805680503e-08 ||r(i)||/||b|| 1.037138900270e-01
>> > > > > 172 KSP preconditioned resid norm 1.315622581976e-07 true resid
>> norm 4.346795666887e-08 ||r(i)||/||b|| 9.826551496744e-02
>> > > > > 173 KSP preconditioned resid norm 1.313903001504e-07 true resid
>> norm 4.268100404068e-08 ||r(i)||/||b|| 9.648649632497e-02
>> > > > > 174 KSP preconditioned resid norm 1.310657837357e-07 true resid
>> norm 4.888365697755e-08 ||r(i)||/||b|| 1.105084778423e-01
>> > > > > 175 KSP preconditioned resid norm 1.308286004287e-07 true resid
>> norm 4.218058360777e-08 ||r(i)||/||b|| 9.535522457196e-02
>> > > > > 176 KSP preconditioned resid norm 1.305438769953e-07 true resid
>> norm 5.026215795117e-08 ||r(i)||/||b|| 1.136247758797e-01
>> > > > > 177 KSP preconditioned resid norm 1.303521375300e-07 true resid
>> norm 4.518428840914e-08 ||r(i)||/||b|| 1.021455276305e-01
>> > > > > 178 KSP preconditioned resid norm 1.302430349652e-07 true resid
>> norm 4.699834591242e-08 ||r(i)||/||b|| 1.062464633174e-01
>> > > > > 179 KSP preconditioned resid norm 1.299950133828e-07 true resid
>> norm 4.780011567673e-08 ||r(i)||/||b|| 1.080589782091e-01
>> > > > > 180 KSP preconditioned resid norm 1.297967984970e-07 true resid
>> norm 4.439369158202e-08 ||r(i)||/||b|| 1.003582707567e-01
>> > > > > 181 KSP preconditioned resid norm 1.297963590960e-07 true resid
>> norm 4.419939374367e-08 ||r(i)||/||b|| 9.991903278447e-02
>> > > > > 182 KSP preconditioned resid norm 1.297926195884e-07 true resid
>> norm 4.616612604888e-08 ||r(i)||/||b|| 1.043651116339e-01
>> > > > > 183 KSP preconditioned resid norm 1.297319003442e-07 true resid
>> norm 3.981403448576e-08 ||r(i)||/||b|| 9.000530279069e-02
>> > > > > 184 KSP preconditioned resid norm 1.296224619385e-07 true resid
>> norm 5.101974490162e-08 ||r(i)||/||b|| 1.153374092198e-01
>> > > > > 185 KSP preconditioned resid norm 1.294198893701e-07 true resid
>> norm 4.272250450111e-08 ||r(i)||/||b|| 9.658031403412e-02
>> > > > > 186 KSP preconditioned resid norm 1.292654432794e-07 true resid
>> norm 4.341411289813e-08 ||r(i)||/||b|| 9.814379344509e-02
>> > > > > 187 KSP preconditioned resid norm 1.291166048974e-07 true resid
>> norm 4.903770559588e-08 ||r(i)||/||b|| 1.108567267127e-01
>> > > > > 188 KSP preconditioned resid norm 1.287267461311e-07 true resid
>> norm 3.838768901036e-08 ||r(i)||/||b|| 8.678084543401e-02
>> > > > > 189 KSP preconditioned resid norm 1.285403517589e-07 true resid
>> norm 4.836219780019e-08 ||r(i)||/||b|| 1.093296450071e-01
>> > > > > 190 KSP preconditioned resid norm 1.283960766544e-07 true resid
>> norm 4.373642319734e-08 ||r(i)||/||b|| 9.887242184076e-02
>> > > > > 191 KSP preconditioned resid norm 1.281846985469e-07 true resid
>> norm 4.196631979171e-08 ||r(i)||/||b|| 9.487085065985e-02
>> > > > > 192 KSP preconditioned resid norm 1.279291087436e-07 true resid
>> norm 5.017898447715e-08 ||r(i)||/||b|| 1.134367503804e-01
>> > > > > 193 KSP preconditioned resid norm 1.277583114588e-07 true resid
>> norm 4.217096345089e-08 ||r(i)||/||b|| 9.533347683541e-02
>> > > > > 194 KSP preconditioned resid norm 1.275868702813e-07 true resid
>> norm 4.784228026600e-08 ||r(i)||/||b|| 1.081542972762e-01
>> > > > > 195 KSP preconditioned resid norm 1.273992295764e-07 true resid
>> norm 4.379242155010e-08 ||r(i)||/||b|| 9.899901410304e-02
>> > > > > 196 KSP preconditioned resid norm 1.272302392639e-07 true resid
>> norm 4.236252438739e-08 ||r(i)||/||b|| 9.576652765067e-02
>> > > > > 197 KSP preconditioned resid norm 1.269756464572e-07 true resid
>> norm 5.265147070813e-08 ||r(i)||/||b|| 1.190261581040e-01
>> > > > > 198 KSP preconditioned resid norm 1.266399406059e-07 true resid
>> norm 3.658633711709e-08 ||r(i)||/||b|| 8.270863259045e-02
>> > > > > 199 KSP preconditioned resid norm 1.262216614405e-07 true resid
>> norm 4.823243517156e-08 ||r(i)||/||b|| 1.090362980798e-01
>> > > > > 200 KSP preconditioned resid norm 1.256037114182e-07 true resid
>> norm 4.118749777942e-08 ||r(i)||/||b|| 9.311021243410e-02
>> > > > > 201 KSP preconditioned resid norm 1.252357182659e-07 true resid
>> norm 4.297385591425e-08 ||r(i)||/||b|| 9.714852974845e-02
>> > > > > 202 KSP preconditioned resid norm 1.242188985573e-07 true resid
>> norm 4.735199275670e-08 ||r(i)||/||b|| 1.070459324421e-01
>> > > > > 203 KSP preconditioned resid norm 1.231408970960e-07 true resid
>> norm 3.893514112125e-08 ||r(i)||/||b|| 8.801843900221e-02
>> > > > > 204 KSP preconditioned resid norm 1.220276184666e-07 true resid
>> norm 4.828090901382e-08 ||r(i)||/||b|| 1.091458801130e-01
>> > > > > 205 KSP preconditioned resid norm 1.200057581901e-07 true resid
>> norm 3.901824500784e-08 ||r(i)||/||b|| 8.820630718920e-02
>> > > > > 206 KSP preconditioned resid norm 1.190463271301e-07 true resid
>> norm 3.812404409291e-08 ||r(i)||/||b|| 8.618483850000e-02
>> > > > > 207 KSP preconditioned resid norm 1.176408472739e-07 true resid
>> norm 4.100938913911e-08 ||r(i)||/||b|| 9.270757245280e-02
>> > > > > 208 KSP preconditioned resid norm 1.166353857162e-07 true resid
>> norm 3.610482888020e-08 ||r(i)||/||b|| 8.162011455361e-02
>> > > > > 209 KSP preconditioned resid norm 1.159620049487e-07 true resid
>> norm 3.566307135323e-08 ||r(i)||/||b|| 8.062145866534e-02
>> > > > > 210 KSP preconditioned resid norm 1.146020921987e-07 true resid
>> norm 3.592344723620e-08 ||r(i)||/||b|| 8.121007548070e-02
>> > > > > 211 KSP preconditioned resid norm 1.145847448331e-07 true resid
>> norm 3.473565983922e-08 ||r(i)||/||b|| 7.852491268077e-02
>> > > > > 212 KSP preconditioned resid norm 1.145177079586e-07 true resid
>> norm 4.122532839361e-08 ||r(i)||/||b|| 9.319573393247e-02
>> > > > > 213 KSP preconditioned resid norm 1.132872800274e-07 true resid
>> norm 2.141692237998e-08 ||r(i)||/||b|| 4.841600728366e-02
>> > > > > 214 KSP preconditioned resid norm 1.123613362087e-07 true resid
>> norm 3.246863698820e-08 ||r(i)||/||b|| 7.339998422842e-02
>> > > > > 215 KSP preconditioned resid norm 1.111053137881e-07 true resid
>> norm 2.903254997529e-08 ||r(i)||/||b|| 6.563221951914e-02
>> > > > > 216 KSP preconditioned resid norm 1.099813982910e-07 true resid
>> norm 2.173780265025e-08 ||r(i)||/||b|| 4.914140289501e-02
>> > > > > 217 KSP preconditioned resid norm 1.089711486676e-07 true resid
>> norm 4.266914180936e-08 ||r(i)||/||b|| 9.645968005942e-02
>> > > > > 218 KSP preconditioned resid norm 1.077041044884e-07 true resid
>> norm 2.174207697189e-08 ||r(i)||/||b|| 4.915106560862e-02
>> > > > > 219 KSP preconditioned resid norm 1.068087285500e-07 true resid
>> norm 3.726239717827e-08 ||r(i)||/||b|| 8.423696277093e-02
>> > > > > 220 KSP preconditioned resid norm 1.060944039406e-07 true resid
>> norm 2.612138847397e-08 ||r(i)||/||b|| 5.905112378786e-02
>> > > > > 221 KSP preconditioned resid norm 1.052145789908e-07 true resid
>> norm 2.848574746885e-08 ||r(i)||/||b|| 6.439609447443e-02
>> > > > > 222 KSP preconditioned resid norm 1.034013372786e-07 true resid
>> norm 4.496176952774e-08 ||r(i)||/||b|| 1.016424919659e-01
>> > > > > 223 KSP preconditioned resid norm 1.016447882738e-07 true resid
>> norm 2.629128290689e-08 ||r(i)||/||b|| 5.943519438194e-02
>> > > > > 224 KSP preconditioned resid norm 1.002724751991e-07 true resid
>> norm 3.297488178025e-08 ||r(i)||/||b|| 7.454442277585e-02
>> > > > > 225 KSP preconditioned resid norm 9.969279422176e-08 true resid
>> norm 3.069952269998e-08 ||r(i)||/||b|| 6.940064908846e-02
>> > > > > 226 KSP preconditioned resid norm 9.811249548568e-08 true resid
>> norm 3.219822477037e-08 ||r(i)||/||b|| 7.278867884683e-02
>> > > > > 227 KSP preconditioned resid norm 9.637808562080e-08 true resid
>> norm 4.091298315961e-08 ||r(i)||/||b|| 9.248963298779e-02
>> > > > > 228 KSP preconditioned resid norm 9.526012021860e-08 true resid
>> norm 2.720466192827e-08 ||r(i)||/||b|| 6.150001791574e-02
>> > > > > 229 KSP preconditioned resid norm 9.392714618074e-08 true resid
>> norm 4.018517470597e-08 ||r(i)||/||b|| 9.084431818639e-02
>> > > > > 230 KSP preconditioned resid norm 9.288540879331e-08 true resid
>> norm 2.742429822661e-08 ||r(i)||/||b|| 6.199653709024e-02
>> > > > > 231 KSP preconditioned resid norm 9.182683719708e-08 true resid
>> norm 3.418196050419e-08 ||r(i)||/||b|| 7.727319637148e-02
>> > > > > 232 KSP preconditioned resid norm 9.152618596319e-08 true resid
>> norm 3.061702948039e-08 ||r(i)||/||b|| 6.921416140130e-02
>> > > > > 233 KSP preconditioned resid norm 9.028012081487e-08 true resid
>> norm 3.309940751576e-08 ||r(i)||/||b|| 7.482593095946e-02
>> > > > > 234 KSP preconditioned resid norm 8.964512632411e-08 true resid
>> norm 3.657895201743e-08 ||r(i)||/||b|| 8.269193751948e-02
>> > > > > 235 KSP preconditioned resid norm 8.927591956786e-08 true resid
>> norm 2.996402299113e-08 ||r(i)||/||b|| 6.773794710778e-02
>> > > > > 236 KSP preconditioned resid norm 8.863790942206e-08 true resid
>> norm 3.770401488950e-08 ||r(i)||/||b|| 8.523530258577e-02
>> > > > > 237 KSP preconditioned resid norm 8.842416675824e-08 true resid
>> norm 3.294247881070e-08 ||r(i)||/||b|| 7.447117124223e-02
>> > > > > 238 KSP preconditioned resid norm 8.793063593991e-08 true resid
>> norm 3.836231748404e-08 ||r(i)||/||b|| 8.672348948056e-02
>> > > > > 239 KSP preconditioned resid norm 8.778266322588e-08 true resid
>> norm 3.572179823322e-08 ||r(i)||/||b|| 8.075421915252e-02
>> > > > > 240 KSP preconditioned resid norm 8.738590572964e-08 true resid
>> norm 3.574931934089e-08 ||r(i)||/||b|| 8.081643454117e-02
>> > > > > 241 KSP preconditioned resid norm 8.738404146064e-08 true resid
>> norm 3.532576961772e-08 ||r(i)||/||b|| 7.985893998998e-02
>> > > > > 242 KSP preconditioned resid norm 8.737492315747e-08 true resid
>> norm 3.850858638399e-08 ||r(i)||/||b|| 8.705415118814e-02
>> > > > > 243 KSP preconditioned resid norm 8.704894133677e-08 true resid
>> norm 2.725999899728e-08 ||r(i)||/||b|| 6.162511525180e-02
>> > > > > 244 KSP preconditioned resid norm 8.691957267756e-08 true resid
>> norm 3.445507385918e-08 ||r(i)||/||b|| 7.789060805883e-02
>> > > > > 245 KSP preconditioned resid norm 8.664547872292e-08 true resid
>> norm 3.233777274784e-08 ||r(i)||/||b|| 7.310414695067e-02
>> > > > > 246 KSP preconditioned resid norm 8.647910251595e-08 true resid
>> norm 2.869258593620e-08 ||r(i)||/||b|| 6.486368232688e-02
>> > > > > 247 KSP preconditioned resid norm 8.602870326813e-08 true resid
>> norm 3.830342792446e-08 ||r(i)||/||b|| 8.659036123294e-02
>> > > > > 248 KSP preconditioned resid norm 8.584186792773e-08 true resid
>> norm 2.914852049114e-08 ||r(i)||/||b|| 6.589438740865e-02
>> > > > > 249 KSP preconditioned resid norm 8.568202493555e-08 true resid
>> norm 3.726679821110e-08 ||r(i)||/||b|| 8.424691193326e-02
>> > > > > 250 KSP preconditioned resid norm 8.535775976392e-08 true resid
>> norm 3.374879488937e-08 ||r(i)||/||b|| 7.629396372591e-02
>> > > > > 251 KSP preconditioned resid norm 8.505569181999e-08 true resid
>> norm 3.019219829750e-08 ||r(i)||/||b|| 6.825376992767e-02
>> > > > > 252 KSP preconditioned resid norm 8.489565939881e-08 true resid
>> norm 3.532505625863e-08 ||r(i)||/||b|| 7.985732734003e-02
>> > > > > 253 KSP preconditioned resid norm 8.454497959931e-08 true resid
>> norm 2.833135878246e-08 ||r(i)||/||b|| 6.404707683166e-02
>> > > > > 254 KSP preconditioned resid norm 8.448142425824e-08 true resid
>> norm 3.023601426215e-08 ||r(i)||/||b|| 6.835282216432e-02
>> > > > > 255 KSP preconditioned resid norm 8.447314709431e-08 true resid
>> norm 2.955565650261e-08 ||r(i)||/||b|| 6.681477642380e-02
>> > > > > 256 KSP preconditioned resid norm 8.434191340398e-08 true resid
>> norm 3.011718192322e-08 ||r(i)||/||b|| 6.808418471561e-02
>> > > > > 257 KSP preconditioned resid norm 8.420519688672e-08 true resid
>> norm 3.194610164662e-08 ||r(i)||/||b|| 7.221871857057e-02
>> > > > > 258 KSP preconditioned resid norm 8.414920999588e-08 true resid
>> norm 2.927199782498e-08 ||r(i)||/||b|| 6.617352553076e-02
>> > > > > 259 KSP preconditioned resid norm 8.411142889741e-08 true resid
>> norm 3.116811073402e-08 ||r(i)||/||b|| 7.045995916421e-02
>> > > > > 260 KSP preconditioned resid norm 8.393401673483e-08 true resid
>> norm 2.913633916610e-08 ||r(i)||/||b|| 6.586684978622e-02
>> > > > > 261 KSP preconditioned resid norm 8.386932870420e-08 true resid
>> norm 2.931516814567e-08 ||r(i)||/||b|| 6.627111819715e-02
>> > > > > 262 KSP preconditioned resid norm 8.383102906154e-08 true resid
>> norm 2.947670084156e-08 ||r(i)||/||b|| 6.663628589221e-02
>> > > > > 263 KSP preconditioned resid norm 8.371299202072e-08 true resid
>> norm 2.900846382950e-08 ||r(i)||/||b|| 6.557776935168e-02
>> > > > > 264 KSP preconditioned resid norm 8.354612585259e-08 true resid
>> norm 3.153902284033e-08 ||r(i)||/||b|| 7.129845887590e-02
>> > > > > 265 KSP preconditioned resid norm 8.348749379055e-08 true resid
>> norm 2.912311287048e-08 ||r(i)||/||b|| 6.583694985881e-02
>> > > > > 266 KSP preconditioned resid norm 8.328479663117e-08 true resid
>> norm 3.201390360666e-08 ||r(i)||/||b|| 7.237199457042e-02
>> > > > > 267 KSP preconditioned resid norm 8.304748250656e-08 true resid
>> norm 3.103708076427e-08 ||r(i)||/||b|| 7.016374723157e-02
>> > > > > 268 KSP preconditioned resid norm 8.294564373794e-08 true resid
>> norm 2.975578688471e-08 ||r(i)||/||b|| 6.726719969290e-02
>> > > > > 269 KSP preconditioned resid norm 8.286083099532e-08 true resid
>> norm 3.122272154943e-08 ||r(i)||/||b|| 7.058341470044e-02
>> > > > > 270 KSP preconditioned resid norm 8.249515525349e-08 true resid
>> norm 2.958445476571e-08 ||r(i)||/||b|| 6.687987900443e-02
>> > > > > 271 KSP preconditioned resid norm 8.249243482197e-08 true resid
>> norm 2.915759140675e-08 ||r(i)||/||b|| 6.591489350698e-02
>> > > > > 272 KSP preconditioned resid norm 8.247967811026e-08 true resid
>> norm 3.226477388325e-08 ||r(i)||/||b|| 7.293912260697e-02
>> > > > > 273 KSP preconditioned resid norm 8.225540420138e-08 true resid
>> norm 2.335784346654e-08 ||r(i)||/||b|| 5.280373619246e-02
>> > > > > 274 KSP preconditioned resid norm 8.208649428128e-08 true resid
>> norm 3.103095297226e-08 ||r(i)||/||b|| 7.014989448385e-02
>> > > > > 275 KSP preconditioned resid norm 8.177662092059e-08 true resid
>> norm 2.780330970969e-08 ||r(i)||/||b|| 6.285334659815e-02
>> > > > > 276 KSP preconditioned resid norm 8.156719698267e-08 true resid
>> norm 2.529092246235e-08 ||r(i)||/||b|| 5.717373693676e-02
>> > > > > 277 KSP preconditioned resid norm 8.129665601936e-08 true resid
>> norm 3.216359520748e-08 ||r(i)||/||b|| 7.271039378141e-02
>> > > > > 278 KSP preconditioned resid norm 8.111942990953e-08 true resid
>> norm 2.578429842977e-08 ||r(i)||/||b|| 5.828908367091e-02
>> > > > > 279 KSP preconditioned resid norm 8.103355449576e-08 true resid
>> norm 3.114448259432e-08 ||r(i)||/||b|| 7.040654438485e-02
>> > > > > 280 KSP preconditioned resid norm 8.096927476093e-08 true resid
>> norm 2.905799246198e-08 ||r(i)||/||b|| 6.568973588864e-02
>> > > > > 281 KSP preconditioned resid norm 8.069018681340e-08 true resid
>> norm 2.806750078967e-08 ||r(i)||/||b|| 6.345058821044e-02
>> > > > > 282 KSP preconditioned resid norm 8.047055052412e-08 true resid
>> norm 3.356282539492e-08 ||r(i)||/||b|| 7.587355316280e-02
>> > > > > 283 KSP preconditioned resid norm 8.023864541552e-08 true resid
>> norm 2.697346140135e-08 ||r(i)||/||b|| 6.097735615340e-02
>> > > > > 284 KSP preconditioned resid norm 8.014006658762e-08 true resid
>> norm 3.033393715647e-08 ||r(i)||/||b|| 6.857419083160e-02
>> > > > > 285 KSP preconditioned resid norm 8.000866139550e-08 true resid
>> norm 2.744969989335e-08 ||r(i)||/||b|| 6.205396118040e-02
>> > > > > 286 KSP preconditioned resid norm 7.963315124505e-08 true resid
>> norm 2.853888338671e-08 ||r(i)||/||b|| 6.451621579442e-02
>> > > > > 287 KSP preconditioned resid norm 7.901906690217e-08 true resid
>> norm 3.213929486191e-08 ||r(i)||/||b|| 7.265545938481e-02
>> > > > > 288 KSP preconditioned resid norm 7.847487693433e-08 true resid
>> norm 2.531887675170e-08 ||r(i)||/||b|| 5.723693159436e-02
>> > > > > 289 KSP preconditioned resid norm 7.776109704697e-08 true resid
>> norm 3.151424977919e-08 ||r(i)||/||b|| 7.124245583834e-02
>> > > > > 290 KSP preconditioned resid norm 7.697887176101e-08 true resid
>> norm 2.452083040958e-08 ||r(i)||/||b|| 5.543283402950e-02
>> > > > > 291 KSP preconditioned resid norm 7.630186207736e-08 true resid
>> norm 2.646550673478e-08 ||r(i)||/||b|| 5.982905219075e-02
>> > > > > 292 KSP preconditioned resid norm 7.539569101676e-08 true resid
>> norm 2.639665425804e-08 ||r(i)||/||b|| 5.967340134812e-02
>> > > > > 293 KSP preconditioned resid norm 7.387540581378e-08 true resid
>> norm 2.766591414879e-08 ||r(i)||/||b|| 6.254274433891e-02
>> > > > > 294 KSP preconditioned resid norm 7.148854762848e-08 true resid
>> norm 4.506538736910e-08 ||r(i)||/||b|| 1.018767348732e-01
>> > > > > 295 KSP preconditioned resid norm 6.875818761377e-08 true resid
>> norm 1.988285545247e-08 ||r(i)||/||b|| 4.494803022244e-02
>> > > > > 296 KSP preconditioned resid norm 6.720148343751e-08 true resid
>> norm 2.185917455369e-08 ||r(i)||/||b|| 4.941578139143e-02
>> > > > > 297 KSP preconditioned resid norm 6.559210493364e-08 true resid
>> norm 2.579380002545e-08 ||r(i)||/||b|| 5.831056338297e-02
>> > > > > 298 KSP preconditioned resid norm 6.296172453909e-08 true resid
>> norm 2.690729261887e-08 ||r(i)||/||b|| 6.082777218435e-02
>> > > > > 299 KSP preconditioned resid norm 6.126664666716e-08 true resid
>> norm 2.523269850506e-08 ||r(i)||/||b|| 5.704211337804e-02
>> > > > > 300 KSP preconditioned resid norm 5.996078539496e-08 true resid
>> norm 1.432165407581e-08 ||r(i)||/||b|| 3.237614143370e-02
>> > > > > 301 KSP preconditioned resid norm 5.994360410331e-08 true resid
>> norm 1.354971586959e-08 ||r(i)||/||b|| 3.063106503328e-02
>> > > > > 302 KSP preconditioned resid norm 5.968927298570e-08 true resid
>> norm 2.119292714347e-08 ||r(i)||/||b|| 4.790963410783e-02
>> > > > > 303 KSP preconditioned resid norm 5.871687993468e-08 true resid
>> norm 8.809042798461e-09 ||r(i)||/||b|| 1.991409749382e-02
>> > > > > 304 KSP preconditioned resid norm 5.799650512507e-08 true resid
>> norm 1.745679956812e-08 ||r(i)||/||b|| 3.946358491871e-02
>> > > > > 305 KSP preconditioned resid norm 5.745928074883e-08 true resid
>> norm 1.274997712124e-08 ||r(i)||/||b|| 2.882314154277e-02
>> > > > > 306 KSP preconditioned resid norm 5.632393272566e-08 true resid
>> norm 1.202295750268e-08 ||r(i)||/||b|| 2.717961001553e-02
>> > > > > 307 KSP preconditioned resid norm 5.396643228430e-08 true resid
>> norm 2.502414535309e-08 ||r(i)||/||b|| 5.657064923649e-02
>> > > > > 308 KSP preconditioned resid norm 5.160090231555e-08 true resid
>> norm 1.262817440249e-08 ||r(i)||/||b|| 2.854778912689e-02
>> > > > > 309 KSP preconditioned resid norm 4.907022431548e-08 true resid
>> norm 2.171207321606e-08 ||r(i)||/||b|| 4.908323783977e-02
>> > > > > 310 KSP preconditioned resid norm 4.776335659862e-08 true resid
>> norm 1.151540470517e-08 ||r(i)||/||b|| 2.603221453522e-02
>> > > > > 311 KSP preconditioned resid norm 4.697621190386e-08 true resid
>> norm 1.508650195148e-08 ||r(i)||/||b|| 3.410518913076e-02
>> > > > > 312 KSP preconditioned resid norm 4.595176479120e-08 true resid
>> norm 1.933671761706e-08 ||r(i)||/||b|| 4.371340776138e-02
>> > > > > 313 KSP preconditioned resid norm 4.509046368009e-08 true resid
>> norm 1.186794873424e-08 ||r(i)||/||b|| 2.682919058886e-02
>> > > > > 314 KSP preconditioned resid norm 4.450909170016e-08 true resid
>> norm 1.579009874879e-08 ||r(i)||/||b|| 3.569577003024e-02
>> > > > > 315 KSP preconditioned resid norm 4.337869810365e-08 true resid
>> norm 1.647588479037e-08 ||r(i)||/||b|| 3.724608717643e-02
>> > > > > 316 KSP preconditioned resid norm 4.223810751226e-08 true resid
>> norm 1.498137614524e-08 ||r(i)||/||b|| 3.386753725389e-02
>> > > > > 317 KSP preconditioned resid norm 4.156026722749e-08 true resid
>> norm 1.333299778266e-08 ||r(i)||/||b|| 3.014114289185e-02
>> > > > > 318 KSP preconditioned resid norm 4.099199515842e-08 true resid
>> norm 1.310678580056e-08 ||r(i)||/||b|| 2.962975844646e-02
>> > > > > 319 KSP preconditioned resid norm 4.066386009421e-08 true resid
>> norm 1.506644976724e-08 ||r(i)||/||b|| 3.405985830867e-02
>> > > > > 320 KSP preconditioned resid norm 4.023087548652e-08 true resid
>> norm 1.240117063260e-08 ||r(i)||/||b|| 2.803461473228e-02
>> > > > > 321 KSP preconditioned resid norm 3.991268177919e-08 true resid
>> norm 1.312932289209e-08 ||r(i)||/||b|| 2.968070675585e-02
>> > > > > 322 KSP preconditioned resid norm 3.956889976017e-08 true resid
>> norm 1.421972275585e-08 ||r(i)||/||b|| 3.214571114861e-02
>> > > > > 323 KSP preconditioned resid norm 3.900185975518e-08 true resid
>> norm 1.347489145169e-08 ||r(i)||/||b|| 3.046191376598e-02
>> > > > > 324 KSP preconditioned resid norm 3.877682049038e-08 true resid
>> norm 1.279539901604e-08 ||r(i)||/||b|| 2.892582421352e-02
>> > > > > 325 KSP preconditioned resid norm 3.869150965109e-08 true resid
>> norm 1.224801722014e-08 ||r(i)||/||b|| 2.768838960238e-02
>> > > > > 326 KSP preconditioned resid norm 3.851624335552e-08 true resid
>> norm 1.309261686557e-08 ||r(i)||/||b|| 2.959772754831e-02
>> > > > > 327 KSP preconditioned resid norm 3.836778709819e-08 true resid
>> norm 1.256963552910e-08 ||r(i)||/||b|| 2.841545365542e-02
>> > > > > 328 KSP preconditioned resid norm 3.810190892142e-08 true resid
>> norm 1.532295260746e-08 ||r(i)||/||b|| 3.463971955858e-02
>> > > > > 329 KSP preconditioned resid norm 3.779873511822e-08 true resid
>> norm 1.357026597966e-08 ||r(i)||/||b|| 3.067752148771e-02
>> > > > > 330 KSP preconditioned resid norm 3.758209190896e-08 true resid
>> norm 1.326727470061e-08 ||r(i)||/||b|| 2.999256649217e-02
>> > > > > 331 KSP preconditioned resid norm 3.758046617049e-08 true resid
>> norm 1.304204653926e-08 ||r(i)||/||b|| 2.948340611389e-02
>> > > > > 332 KSP preconditioned resid norm 3.756576997625e-08 true resid
>> norm 1.547320887283e-08 ||r(i)||/||b|| 3.497939527431e-02
>> > > > > 333 KSP preconditioned resid norm 3.735750946435e-08 true resid
>> norm 9.401475437163e-09 ||r(i)||/||b|| 2.125337595977e-02
>> > > > > 334 KSP preconditioned resid norm 3.726816411327e-08 true resid
>> norm 1.293737018744e-08 ||r(i)||/||b|| 2.924677029283e-02
>> > > > > 335 KSP preconditioned resid norm 3.715836120670e-08 true resid
>> norm 1.137076112403e-08 ||r(i)||/||b|| 2.570522709260e-02
>> > > > > 336 KSP preconditioned resid norm 3.711352115906e-08 true resid
>> norm 1.100868545692e-08 ||r(i)||/||b|| 2.488670341188e-02
>> > > > > 337 KSP preconditioned resid norm 3.697154209112e-08 true resid
>> norm 1.292178506561e-08 ||r(i)||/||b|| 2.921153790237e-02
>> > > > > 338 KSP preconditioned resid norm 3.687250442553e-08 true resid
>> norm 1.038256633339e-08 ||r(i)||/||b|| 2.347127184298e-02
>> > > > > 339 KSP preconditioned resid norm 3.681163672322e-08 true resid
>> norm 1.217819776625e-08 ||r(i)||/||b|| 2.753055276999e-02
>> > > > > 340 KSP preconditioned resid norm 3.676709918842e-08 true resid
>> norm 1.163124964184e-08 ||r(i)||/||b|| 2.629409853509e-02
>> > > > > 341 KSP preconditioned resid norm 3.664698023565e-08 true resid
>> norm 1.141439938468e-08 ||r(i)||/||b|| 2.580387760401e-02
>> > > > > 342 KSP preconditioned resid norm 3.656190729093e-08 true resid
>> norm 1.232477473873e-08 ||r(i)||/||b|| 2.786191091946e-02
>> > > > > 343 KSP preconditioned resid norm 3.650243259584e-08 true resid
>> norm 1.132768943490e-08 ||r(i)||/||b|| 2.560785739692e-02
>> > > > > 344 KSP preconditioned resid norm 3.650130795451e-08 true resid
>> norm 1.141084292815e-08 ||r(i)||/||b|| 2.579583772683e-02
>> > > > > 345 KSP preconditioned resid norm 3.647229125147e-08 true resid
>> norm 1.138306478808e-08 ||r(i)||/||b|| 2.573304127980e-02
>> > > > > 346 KSP preconditioned resid norm 3.643856164392e-08 true resid
>> norm 1.116515940173e-08 ||r(i)||/||b|| 2.524043507871e-02
>> > > > > 347 KSP preconditioned resid norm 3.639892567434e-08 true resid
>> norm 1.174359887576e-08 ||r(i)||/||b|| 2.654808000036e-02
>> > > > > 348 KSP preconditioned resid norm 3.632894120883e-08 true resid
>> norm 1.064588448828e-08 ||r(i)||/||b|| 2.406654008362e-02
>> > > > > 349 KSP preconditioned resid norm 3.632109543324e-08 true resid
>> norm 1.070526312693e-08 ||r(i)||/||b|| 2.420077396422e-02
>> > > > > 350 KSP preconditioned resid norm 3.628173432975e-08 true resid
>> norm 1.071879321292e-08 ||r(i)||/||b|| 2.423136065311e-02
>> > > > > 351 KSP preconditioned resid norm 3.621714360676e-08 true resid
>> norm 1.066953807038e-08 ||r(i)||/||b|| 2.412001237918e-02
>> > > > > 352 KSP preconditioned resid norm 3.614598721323e-08 true resid
>> norm 1.067226627219e-08 ||r(i)||/||b|| 2.412617986843e-02
>> > > > > 353 KSP preconditioned resid norm 3.608734513646e-08 true resid
>> norm 1.072773727635e-08 ||r(i)||/||b|| 2.425157998401e-02
>> > > > > 354 KSP preconditioned resid norm 3.593202477726e-08 true resid
>> norm 1.166649044369e-08 ||r(i)||/||b|| 2.637376539332e-02
>> > > > > 355 KSP preconditioned resid norm 3.574816645908e-08 true resid
>> norm 1.093827518487e-08 ||r(i)||/||b|| 2.472753095079e-02
>> > > > > 356 KSP preconditioned resid norm 3.551731486762e-08 true resid
>> norm 1.076438469683e-08 ||r(i)||/||b|| 2.433442670423e-02
>> > > > > 357 KSP preconditioned resid norm 3.526513581484e-08 true resid
>> norm 1.110249798589e-08 ||r(i)||/||b|| 2.509878001212e-02
>> > > > > 358 KSP preconditioned resid norm 3.465142744209e-08 true resid
>> norm 1.363275954561e-08 ||r(i)||/||b|| 3.081879710568e-02
>> > > > > 359 KSP preconditioned resid norm 3.445104570595e-08 true resid
>> norm 1.002161340638e-08 ||r(i)||/||b|| 2.265528627639e-02
>> > > > > 360 KSP preconditioned resid norm 3.412299596043e-08 true resid
>> norm 1.132489003434e-08 ||r(i)||/||b|| 2.560152895272e-02
>> > > > > 361 KSP preconditioned resid norm 3.411529696237e-08 true resid
>> norm 1.086147186780e-08 ||r(i)||/||b|| 2.455390609972e-02
>> > > > > 362 KSP preconditioned resid norm 3.406577468016e-08 true resid
>> norm 1.456732293497e-08 ||r(i)||/||b|| 3.293151092439e-02
>> > > > > 363 KSP preconditioned resid norm 3.365555787056e-08 true resid
>> norm 7.711588827294e-09 ||r(i)||/||b|| 1.743314628529e-02
>> > > > > 364 KSP preconditioned resid norm 3.345269937851e-08 true resid
>> norm 1.136806437719e-08 ||r(i)||/||b|| 2.569913071178e-02
>> > > > > 365 KSP preconditioned resid norm 3.314065779377e-08 true resid
>> norm 9.636397417285e-09 ||r(i)||/||b|| 2.178445059780e-02
>> > > > > 366 KSP preconditioned resid norm 3.276476852537e-08 true resid
>> norm 8.198503499564e-09 ||r(i)||/||b|| 1.853388634033e-02
>> > > > > 367 KSP preconditioned resid norm 3.259579551722e-08 true resid
>> norm 1.047105927610e-08 ||r(i)||/||b|| 2.367132275987e-02
>> > > > > 368 KSP preconditioned resid norm 3.250921252208e-08 true resid
>> norm 8.145570438537e-09 ||r(i)||/||b|| 1.841422360715e-02
>> > > > > 369 KSP preconditioned resid norm 3.241361225044e-08 true resid
>> norm 1.107380056199e-08 ||r(i)||/||b|| 2.503390539290e-02
>> > > > > 370 KSP preconditioned resid norm 3.226640160009e-08 true resid
>> norm 8.914996078156e-09 ||r(i)||/||b|| 2.015361999245e-02
>> > > > > 371 KSP preconditioned resid norm 3.219199485113e-08 true resid
>> norm 9.028612338383e-09 ||r(i)||/||b|| 2.041046575138e-02
>> > > > > 372 KSP preconditioned resid norm 3.215039853884e-08 true resid
>> norm 9.957541741887e-09 ||r(i)||/||b|| 2.251044314161e-02
>> > > > > 373 KSP preconditioned resid norm 3.191438320482e-08 true resid
>> norm 8.943736857091e-09 ||r(i)||/||b|| 2.021859262192e-02
>> > > > > 374 KSP preconditioned resid norm 3.186200739666e-08 true resid
>> norm 8.758295038024e-09 ||r(i)||/||b|| 1.979937494427e-02
>> > > > > 375 KSP preconditioned resid norm 3.183870059099e-08 true resid
>> norm 8.943256269651e-09 ||r(i)||/||b|| 2.021750618548e-02
>> > > > > 376 KSP preconditioned resid norm 3.179122668815e-08 true resid
>> norm 8.590862092304e-09 ||r(i)||/||b|| 1.942086889304e-02
>> > > > > 377 KSP preconditioned resid norm 3.167956879702e-08 true resid
>> norm 9.582658100383e-09 ||r(i)||/||b|| 2.166296520824e-02
>> > > > > 378 KSP preconditioned resid norm 3.136955166729e-08 true resid
>> norm 9.977269021243e-09 ||r(i)||/||b|| 2.255503946987e-02
>> > > > > 379 KSP preconditioned resid norm 3.130691641774e-08 true resid
>> norm 8.509125545196e-09 ||r(i)||/||b|| 1.923609177194e-02
>> > > > > 380 KSP preconditioned resid norm 3.117879107848e-08 true resid
>> norm 9.053973136302e-09 ||r(i)||/||b|| 2.046779745176e-02
>> > > > > 381 KSP preconditioned resid norm 3.088492490292e-08 true resid
>> norm 1.048308325237e-08 ||r(i)||/||b|| 2.369850467295e-02
>> > > > > 382 KSP preconditioned resid norm 3.050052142818e-08 true resid
>> norm 9.220813554635e-09 ||r(i)||/||b|| 2.084496401033e-02
>> > > > > 383 KSP preconditioned resid norm 2.985444875009e-08 true resid
>> norm 1.234239992416e-08 ||r(i)||/||b|| 2.790175516463e-02
>> > > > > 384 KSP preconditioned resid norm 2.952644478108e-08 true resid
>> norm 8.796660599472e-09 ||r(i)||/||b|| 1.988610576719e-02
>> > > > > 385 KSP preconditioned resid norm 2.923012320168e-08 true resid
>> norm 9.047640736274e-09 ||r(i)||/||b|| 2.045348215843e-02
>> > > > > 386 KSP preconditioned resid norm 2.885571723790e-08 true resid
>> norm 1.000194856842e-08 ||r(i)||/||b|| 2.261083110579e-02
>> > > > > 387 KSP preconditioned resid norm 2.854406928323e-08 true resid
>> norm 7.861779671019e-09 ||r(i)||/||b|| 1.777267410608e-02
>> > > > > 388 KSP preconditioned resid norm 2.797557513811e-08 true resid
>> norm 1.546960768219e-08 ||r(i)||/||b|| 3.497125426932e-02
>> > > > > 389 KSP preconditioned resid norm 2.745355913117e-08 true resid
>> norm 7.687966698265e-09 ||r(i)||/||b|| 1.737974509390e-02
>> > > > > 390 KSP preconditioned resid norm 2.661217744985e-08 true resid
>> norm 1.052014137922e-08 ||r(i)||/||b|| 2.378227985352e-02
>> > > > > 391 KSP preconditioned resid norm 2.658120474029e-08 true resid
>> norm 9.465616738864e-09 ||r(i)||/||b|| 2.139837651939e-02
>> > > > > 392 KSP preconditioned resid norm 2.623787329422e-08 true resid
>> norm 1.909951824281e-08 ||r(i)||/||b|| 4.317718474915e-02
>> > > > > 393 KSP preconditioned resid norm 2.543325628802e-08 true resid
>> norm 5.948456163537e-09 ||r(i)||/||b|| 1.344733346046e-02
>> > > > > 394 KSP preconditioned resid norm 2.517323260201e-08 true resid
>> norm 1.034609461157e-08 ||r(i)||/||b|| 2.338882231462e-02
>> > > > > 395 KSP preconditioned resid norm 2.490676685335e-08 true resid
>> norm 8.641670445923e-09 ||r(i)||/||b|| 1.953572842212e-02
>> > > > > 396 KSP preconditioned resid norm 2.439513980463e-08 true resid
>> norm 7.519572419040e-09 ||r(i)||/||b|| 1.699906581119e-02
>> > > > > 397 KSP preconditioned resid norm 2.414249722638e-08 true resid
>> norm 1.073069104260e-08 ||r(i)||/||b|| 2.425825739384e-02
>> > > > > 398 KSP preconditioned resid norm 2.392817846978e-08 true resid
>> norm 7.116187521104e-09 ||r(i)||/||b|| 1.608715672313e-02
>> > > > > 399 KSP preconditioned resid norm 2.371648249227e-08 true resid
>> norm 1.098047911448e-08 ||r(i)||/||b|| 2.482293895233e-02
>> > > > > 400 KSP preconditioned resid norm 2.345879128128e-08 true resid
>> norm 8.016833131810e-09 ||r(i)||/||b|| 1.812319456621e-02
>> > > > > 401 KSP preconditioned resid norm 2.331728390350e-08 true resid
>> norm 7.808056352388e-09 ||r(i)||/||b|| 1.765122488290e-02
>> > > > > 402 KSP preconditioned resid norm 2.325356933312e-08 true resid
>> norm 9.927418776284e-09 ||r(i)||/||b|| 2.244234588206e-02
>> > > > > 403 KSP preconditioned resid norm 2.314519860272e-08 true resid
>> norm 7.444871113908e-09 ||r(i)||/||b|| 1.683019285787e-02
>> > > > > 404 KSP preconditioned resid norm 2.308308693430e-08 true resid
>> norm 7.801054524067e-09 ||r(i)||/||b|| 1.763539625145e-02
>> > > > > 405 KSP preconditioned resid norm 2.306358661113e-08 true resid
>> norm 7.805058505977e-09 ||r(i)||/||b|| 1.764444782357e-02
>> > > > > 406 KSP preconditioned resid norm 2.305322796876e-08 true resid
>> norm 7.571079190824e-09 ||r(i)||/||b|| 1.711550421413e-02
>> > > > > 407 KSP preconditioned resid norm 2.298488633980e-08 true resid
>> norm 8.830501095637e-09 ||r(i)||/||b|| 1.996260703473e-02
>> > > > > 408 KSP preconditioned resid norm 2.287294808434e-08 true resid
>> norm 7.013326899093e-09 ||r(i)||/||b|| 1.585462561823e-02
>> > > > > 409 KSP preconditioned resid norm 2.286549605315e-08 true resid
>> norm 7.082627748739e-09 ||r(i)||/||b|| 1.601129007177e-02
>> > > > > 410 KSP preconditioned resid norm 2.286053015844e-08 true resid
>> norm 7.033545134087e-09 ||r(i)||/||b|| 1.590033182173e-02
>> > > > > 411 KSP preconditioned resid norm 2.280043141482e-08 true resid
>> norm 7.319703904833e-09 ||r(i)||/||b|| 1.654723453179e-02
>> > > > > 412 KSP preconditioned resid norm 2.278834021186e-08 true resid
>> norm 7.137620865339e-09 ||r(i)||/||b|| 1.613560985436e-02
>> > > > > 413 KSP preconditioned resid norm 2.274834174042e-08 true resid
>> norm 7.536215034436e-09 ||r(i)||/||b|| 1.703668881668e-02
>> > > > > 414 KSP preconditioned resid norm 2.271641465026e-08 true resid
>> norm 7.111204145035e-09 ||r(i)||/||b|| 1.607589109085e-02
>> > > > > 415 KSP preconditioned resid norm 2.271597283066e-08 true resid
>> norm 7.105850673247e-09 ||r(i)||/||b|| 1.606378880442e-02
>> > > > > 416 KSP preconditioned resid norm 2.264562496921e-08 true resid
>> norm 7.590206017147e-09 ||r(i)||/||b|| 1.715874313269e-02
>> > > > > 417 KSP preconditioned resid norm 2.264130303752e-08 true resid
>> norm 7.322331610853e-09 ||r(i)||/||b|| 1.655317483599e-02
>> > > > > 418 KSP preconditioned resid norm 2.257869016612e-08 true resid
>> norm 8.689110661905e-09 ||r(i)||/||b|| 1.964297379574e-02
>> > > > > 419 KSP preconditioned resid norm 2.252448770837e-08 true resid
>> norm 7.589690206564e-09 ||r(i)||/||b|| 1.715757706931e-02
>> > > > > 420 KSP preconditioned resid norm 2.251854717911e-08 true resid
>> norm 7.606351482008e-09 ||r(i)||/||b|| 1.719524225849e-02
>> > > > > 421 KSP preconditioned resid norm 2.251852680166e-08 true resid
>> norm 7.587363564342e-09 ||r(i)||/||b|| 1.715231736276e-02
>> > > > > 422 KSP preconditioned resid norm 2.251740722171e-08 true resid
>> norm 8.042777274478e-09 ||r(i)||/||b|| 1.818184500057e-02
>> > > > > 423 KSP preconditioned resid norm 2.251066763399e-08 true resid
>> norm 7.161199860439e-09 ||r(i)||/||b|| 1.618891353535e-02
>> > > > > 424 KSP preconditioned resid norm 2.250468324723e-08 true resid
>> norm 7.892076688728e-09 ||r(i)||/||b|| 1.784116483524e-02
>> > > > > 425 KSP preconditioned resid norm 2.248157980181e-08 true resid
>> norm 7.381796123970e-09 ||r(i)||/||b|| 1.668760284806e-02
>> > > > > 426 KSP preconditioned resid norm 2.245901138193e-08 true resid
>> norm 7.147464780092e-09 ||r(i)||/||b|| 1.615786342748e-02
>> > > > > 427 KSP preconditioned resid norm 2.241049755791e-08 true resid
>> norm 8.351728267326e-09 ||r(i)||/||b|| 1.888027277907e-02
>> > > > > 428 KSP preconditioned resid norm 2.234407003838e-08 true resid
>> norm 6.648970113909e-09 ||r(i)||/||b|| 1.503094514480e-02
>> > > > > 429 KSP preconditioned resid norm 2.225463790450e-08 true resid
>> norm 9.144039069449e-09 ||r(i)||/||b|| 2.067140433784e-02
>> > > > > 430 KSP preconditioned resid norm 2.219515360063e-08 true resid
>> norm 7.964312082788e-09 ||r(i)||/||b|| 1.800446324492e-02
>> > > > > 431 KSP preconditioned resid norm 2.207622538143e-08 true resid
>> norm 7.744159741884e-09 ||r(i)||/||b|| 1.750677748263e-02
>> > > > > 432 KSP preconditioned resid norm 2.189830543256e-08 true resid
>> norm 1.088914113364e-08 ||r(i)||/||b|| 2.461645642103e-02
>> > > > > 433 KSP preconditioned resid norm 2.136231265645e-08 true resid
>> norm 6.923381943847e-09 ||r(i)||/||b|| 1.565129221995e-02
>> > > > > 434 KSP preconditioned resid norm 2.037470395914e-08 true resid
>> norm 1.030114953089e-08 ||r(i)||/||b|| 2.328721755017e-02
>> > > > > 435 KSP preconditioned resid norm 1.961890283205e-08 true resid
>> norm 7.295267301635e-09 ||r(i)||/||b|| 1.649199210539e-02
>> > > > > 436 KSP preconditioned resid norm 1.913560642295e-08 true resid
>> norm 6.039280397468e-09 ||r(i)||/||b|| 1.365265459361e-02
>> > > > > 437 KSP preconditioned resid norm 1.877609800000e-08 true resid
>> norm 8.984892222755e-09 ||r(i)||/||b|| 2.031163019513e-02
>> > > > > 438 KSP preconditioned resid norm 1.811081731215e-08 true resid
>> norm 6.564934723165e-09 ||r(i)||/||b|| 1.484097115983e-02
>> > > > > 439 KSP preconditioned resid norm 1.785755067179e-08 true resid
>> norm 5.336927073942e-09 ||r(i)||/||b|| 1.206488474394e-02
>> > > > > 440 KSP preconditioned resid norm 1.772971743003e-08 true resid
>> norm 4.970154886573e-09 ||r(i)||/||b|| 1.123574390942e-02
>> > > > > 441 KSP preconditioned resid norm 1.735301571457e-08 true resid
>> norm 5.652698869454e-09 ||r(i)||/||b|| 1.277873191957e-02
>> > > > > 442 KSP preconditioned resid norm 1.631139023345e-08 true resid
>> norm 7.160283137945e-09 ||r(i)||/||b|| 1.618684115342e-02
>> > > > > 443 KSP preconditioned resid norm 1.483956291991e-08 true resid
>> norm 7.988466840254e-09 ||r(i)||/||b|| 1.805906851886e-02
>> > > > > 444 KSP preconditioned resid norm 1.410013314968e-08 true resid
>> norm 7.482143551338e-09 ||r(i)||/||b|| 1.691445251806e-02
>> > > > > 445 KSP preconditioned resid norm 1.356330060794e-08 true resid
>> norm 3.083065574605e-09 ||r(i)||/||b|| 6.969709403983e-03
>> > > > > 446 KSP preconditioned resid norm 1.314115350470e-08 true resid
>> norm 4.164976230172e-09 ||r(i)||/||b|| 9.415522730979e-03
>> > > > > 447 KSP preconditioned resid norm 1.236636402318e-08 true resid
>> norm 5.761202097878e-09 ||r(i)||/||b|| 1.302401894094e-02
>> > > > > 448 KSP preconditioned resid norm 1.180595146541e-08 true resid
>> norm 4.038199940007e-09 ||r(i)||/||b|| 9.128926847635e-03
>> > > > > 449 KSP preconditioned resid norm 1.131424900987e-08 true resid
>> norm 5.090038236142e-09 ||r(i)||/||b|| 1.150675731755e-02
>> > > > > 450 KSP preconditioned resid norm 1.063388583397e-08 true resid
>> norm 3.010230442125e-09 ||r(i)||/||b|| 6.805055200074e-03
>> > > > > 451 KSP preconditioned resid norm 1.051458985758e-08 true resid
>> norm 1.649000916776e-09 ||r(i)||/||b|| 3.727801734579e-03
>> > > > > 452 KSP preconditioned resid norm 1.012147631812e-08 true resid
>> norm 5.884734670038e-09 ||r(i)||/||b|| 1.330328193716e-02
>> > > > > 453 KSP preconditioned resid norm 9.390240831193e-09 true resid
>> norm 2.031511507263e-09 ||r(i)||/||b|| 4.592521473788e-03
>> > > > > 454 KSP preconditioned resid norm 9.098339938653e-09 true resid
>> norm 1.769428017679e-09 ||r(i)||/||b|| 4.000044370146e-03
>> > > > > 455 KSP preconditioned resid norm 8.890748233216e-09 true resid
>> norm 2.050221736547e-09 ||r(i)||/||b|| 4.634818615330e-03
>> > > > > 456 KSP preconditioned resid norm 8.527203662681e-09 true resid
>> norm 2.051638846865e-09 ||r(i)||/||b|| 4.638022195295e-03
>> > > > > 457 KSP preconditioned resid norm 8.268992410262e-09 true resid
>> norm 2.382052265392e-09 ||r(i)||/||b|| 5.384968847771e-03
>> > > > > 458 KSP preconditioned resid norm 7.908973261474e-09 true resid
>> norm 3.438027649085e-09 ||r(i)||/||b|| 7.772151794095e-03
>> > > > > 459 KSP preconditioned resid norm 7.427882465376e-09 true resid
>> norm 2.945117076322e-09 ||r(i)||/||b|| 6.657857150931e-03
>> > > > > 460 KSP preconditioned resid norm 7.015919500900e-09 true resid
>> norm 1.769207642661e-09 ||r(i)||/||b|| 3.999546180990e-03
>> > > > > 461 KSP preconditioned resid norm 6.803968849346e-09 true resid
>> norm 1.305695673120e-09 ||r(i)||/||b|| 2.951711272911e-03
>> > > > > 462 KSP preconditioned resid norm 6.710918799980e-09 true resid
>> norm 1.795032965660e-09 ||r(i)||/||b|| 4.057928006550e-03
>> > > > > 463 KSP preconditioned resid norm 6.577483627377e-09 true resid
>> norm 1.782001044516e-09 ||r(i)||/||b|| 4.028467490336e-03
>> > > > > 464 KSP preconditioned resid norm 6.417912605066e-09 true resid
>> norm 1.290960823243e-09 ||r(i)||/||b|| 2.918401043442e-03
>> > > > > 465 KSP preconditioned resid norm 6.365751616365e-09 true resid
>> norm 1.263290494523e-09 ||r(i)||/||b|| 2.855848319336e-03
>> > > > > 466 KSP preconditioned resid norm 6.293400160765e-09 true resid
>> norm 1.425147805149e-09 ||r(i)||/||b|| 3.221749852300e-03
>> > > > > 467 KSP preconditioned resid norm 5.891998607109e-09 true resid
>> norm 2.318264750150e-09 ||r(i)||/||b|| 5.240768072899e-03
>> > > > > 468 KSP preconditioned resid norm 5.803460471252e-09 true resid
>> norm 1.081820742140e-09 ||r(i)||/||b|| 2.445610064874e-03
>> > > > > 469 KSP preconditioned resid norm 5.754085062170e-09 true resid
>> norm 1.656644764768e-09 ||r(i)||/||b|| 3.745081743044e-03
>> > > > > 470 KSP preconditioned resid norm 5.525556632876e-09 true resid
>> norm 1.979760762585e-09 ||r(i)||/||b|| 4.475531535326e-03
>> > > > > 471 KSP preconditioned resid norm 5.443965422137e-09 true resid
>> norm 9.955797379882e-10 ||r(i)||/||b|| 2.250649976253e-03
>> > > > > 472 KSP preconditioned resid norm 5.414797083501e-09 true resid
>> norm 1.143450718543e-09 ||r(i)||/||b|| 2.584933415516e-03
>> > > > > 473 KSP preconditioned resid norm 5.408283291827e-09 true resid
>> norm 1.029764590400e-09 ||r(i)||/||b|| 2.327929710194e-03
>> > > > > 474 KSP preconditioned resid norm 5.355045752288e-09 true resid
>> norm 1.886388210190e-09 ||r(i)||/||b|| 4.264449564882e-03
>> > > > > 475 KSP preconditioned resid norm 5.241533530016e-09 true resid
>> norm 1.425455398363e-09 ||r(i)||/||b|| 3.222445210625e-03
>> > > > > 476 KSP preconditioned resid norm 5.125189682735e-09 true resid
>> norm 1.354368288121e-09 ||r(i)||/||b|| 3.061742660270e-03
>> > > > > 477 KSP preconditioned resid norm 5.057977457429e-09 true resid
>> norm 1.740562818023e-09 ||r(i)||/||b|| 3.934790469888e-03
>> > > > > 478 KSP preconditioned resid norm 4.979286088604e-09 true resid
>> norm 1.417735808423e-09 ||r(i)||/||b|| 3.204993976684e-03
>> > > > > 479 KSP preconditioned resid norm 4.894533209216e-09 true resid
>> norm 1.326984715102e-09 ||r(i)||/||b|| 2.999838188318e-03
>> > > > > 480 KSP preconditioned resid norm 4.777786489681e-09 true resid
>> norm 1.456212644054e-09 ||r(i)||/||b|| 3.291976350766e-03
>> > > > > 481 KSP preconditioned resid norm 4.775308813328e-09 true resid
>> norm 1.364283691096e-09 ||r(i)||/||b|| 3.084157842718e-03
>> > > > > 482 KSP preconditioned resid norm 4.760397485605e-09 true resid
>> norm 2.049838358389e-09 ||r(i)||/||b|| 4.633951934330e-03
>> > > > > 483 KSP preconditioned resid norm 4.670996943034e-09 true resid
>> norm 8.889456596556e-10 ||r(i)||/||b|| 2.009588435214e-03
>> > > > > 484 KSP preconditioned resid norm 4.597559289814e-09 true resid
>> norm 1.386989122943e-09 ||r(i)||/||b|| 3.135486709406e-03
>> > > > > 485 KSP preconditioned resid norm 4.570207496163e-09 true resid
>> norm 1.099843879320e-09 ||r(i)||/||b|| 2.486353936728e-03
>> > > > > 486 KSP preconditioned resid norm 4.542158022055e-09 true resid
>> norm 1.011236566485e-09 ||r(i)||/||b|| 2.286044469873e-03
>> > > > > 487 KSP preconditioned resid norm 4.526766510181e-09 true resid
>> norm 1.399400517345e-09 ||r(i)||/||b|| 3.163544436426e-03
>> > > > > 488 KSP preconditioned resid norm 4.505705850329e-09 true resid
>> norm 9.117728324580e-10 ||r(i)||/||b|| 2.061192514692e-03
>> > > > > 489 KSP preconditioned resid norm 4.487150083935e-09 true resid
>> norm 1.381092775475e-09 ||r(i)||/||b|| 3.122157175082e-03
>> > > > > 490 KSP preconditioned resid norm 4.473919835893e-09 true resid
>> norm 9.652867482479e-10 ||r(i)||/||b|| 2.182168352895e-03
>> > > > > 491 KSP preconditioned resid norm 4.452517186816e-09 true resid
>> norm 1.131636320873e-09 ||r(i)||/||b|| 2.558225284743e-03
>> > > > > 492 KSP preconditioned resid norm 4.400952072877e-09 true resid
>> norm 1.786271233792e-09 ||r(i)||/||b|| 4.038120862161e-03
>> > > > > 493 KSP preconditioned resid norm 4.366719039095e-09 true resid
>> norm 1.028221901066e-09 ||r(i)||/||b|| 2.324442240954e-03
>> > > > > 494 KSP preconditioned resid norm 4.331818466820e-09 true resid
>> norm 1.573868226869e-09 ||r(i)||/||b|| 3.557953574452e-03
>> > > > > 495 KSP preconditioned resid norm 4.302438670088e-09 true resid
>> norm 1.043943800033e-09 ||r(i)||/||b|| 2.359983835651e-03
>> > > > > 496 KSP preconditioned resid norm 4.254710406786e-09 true resid
>> norm 1.390625661617e-09 ||r(i)||/||b|| 3.143707623679e-03
>> > > > > 497 KSP preconditioned resid norm 4.221208729086e-09 true resid
>> norm 1.442390433810e-09 ||r(i)||/||b|| 3.260729273340e-03
>> > > > > 498 KSP preconditioned resid norm 4.194726771303e-09 true resid
>> norm 1.122208863419e-09 ||r(i)||/||b|| 2.536913172729e-03
>> > > > > 499 KSP preconditioned resid norm 4.161552261100e-09 true resid
>> norm 1.685040004550e-09 ||r(i)||/||b|| 3.809273231987e-03
>> > > > > 500 KSP preconditioned resid norm 4.157891682720e-09 true resid
>> norm 1.444023641507e-09 ||r(i)||/||b|| 3.264421372248e-03
>> > > > > 2018-08-06 15:40 GMT-05:00 Smith, Barry F. <bsmith at mcs.anl.gov>:
>> > > > >     Ok, I think you want to use PCFIELDSPLIT with two fields u
>> and c. Start by using PC_COMPOSITE_MULTIPLICATIVE with direct solvers (LU)
>> for each field. Then try replacing the direct solvers LU with hypre
>> BoomerAMG first one at a time.
>> > > > >     Let us know how it goes and we'll make additional suggestions,
>> > > > >     Barry
>> > > > > > On Aug 6, 2018, at 12:58 PM, Josh L <ysjosh.lo at gmail.com>
>> wrote:
>> > > > > > Hi Barry,
>> > > > > > (1)
>> > > > > > I am basically solving the equilibrium coupled with phase field
>> equation:
>> > > > > > 1-D example
>> > > > > > u is displacement and c is phase-field parameter.
>> > > > > > equilibrium: (c^2)*E* (\Delta u) = 0
>> > > > > > phase-field equation:  2*G_c*L*(\Delta
>> c)-E*(\epsilon)^2*c+G_c/2L(1-c)=0
>> > > > > > I solve the above 2 equations coupled.
>> > > > > > it is the formulation for quasi-static fracture problem, where
>> G_c is the critical energy release rate and L is the length scale in
>> phase-field method (both constant).
>> > > > > > The free energy I am using now is
>> > > > > > 1-D:
>> > > > > > \psi=c^2*0.5*E*\epsilon^2+G_c/4L*(1-c)^2+G_c*L*grad c * grad c
>> > > > > > it is not convex w.r.t u and c simultaneously.
>> > > > > > (2)
>> > > > > > with an appropriate step size. Newton's method usually
>> converges with 5 iteration, and I can see the quadratic convergence of
>> Newton's method.
>> > > > > > Thanks,
>> > > > > > Josh
>> > > > > > 2018-08-05 22:23 GMT-05:00 Smith, Barry F. <bsmith at mcs.anl.gov
>> > > > > > > On Aug 5, 2018, at 9:38 PM, Josh L <ysjosh.lo at gmail.com>
>> wrote:
>> > > > > > > Hi,
>> > > > > > > I am using GRMES to solve the linear systems within Newton
>> Raphson.
>> > > > > > > I am using finite element method to solve fracture problem
>> with phase field method.(the formulation gives symmetric but indefinite
>> hessian so can't use CG)
>> > > > > >     What exact equations are you using for the phase field
>> method?
>> > > > > >      With the direct LU solver roughly how many iterations does
>> your Newton's method take?
>> > > > > >    Barry
>> > > > > > > The total iteration number to solve one linear system is
>> often very large( > 2000) even for a small sized problem(120K degree of
>> freedom). I've tried different preconditioner, but it doesn't help a lot.
>> I have checked my hessian and right hand side, and sure they are correct.
>> > > > > > > I think it might stem from the great difference in element
>> size(max/min=100) and damage stiffness around crack.
>> > > > > > > Anyone has idea to reduce the number of iteration?
>> > > > > > > Now, I get away with it by using LU, which is not ideal for
>> large size problem (I will have to run it in the future)
>> > > > > > > Thanks,
>> > > > > > > Josh
> experiments lead.
> -- Norbert Wiener
> https://www.cse.buffalo.edu/~knepley/ <http://www.caam.rice.edu/~mk51/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20180816/3ca9df18/attachment-0001.html>
