[petsc-users] MatSetValues error with ViennaCL types
Manuel Valera
mvalera-w at sdsu.edu
Wed Aug 15 16:45:10 CDT 2018
Ok thanks for clarifying that, i wasn't sure if there were different types,
Here is a stripped down version of my code, it seems like the preallocation
is working now since the matrix population part is working without problem,
but here it is for illustration purposes:
call DMSetMatrixPreallocateOnly(daDummy,PETSC_TRUE,ierr)
> call DMCreateMatrix(daDummy,A,ierr)
> call MatSetFromOptions(A,ierr)
> call DMSetMatType(daDummy,MATMPIAIJVIENNACL,ierr)
> call DMSetVecType(daDummy,VECMPIVIENNACL,ierr)
> call
> MatMPIAIJSetPreallocation(A,19,PETSC_NULL_INTEGER,19,PETSC_NULL_INTEGER,ierr)
> call MatSetUp(A,ierr)
> call
> MatSetValues(A,1,row,sumpos,pos(0:iter-1),vals(0:iter-1),INSERT_VALUES,ierr)
> call MatAssemblyBegin(A, MAT_FINAL_ASSEMBLY, ierr)
> call MatAssemblyEnd(A, MAT_FINAL_ASSEMBLY, ierr)
Adding the first line there did the trick,
Now the problem seems to be the program is not recognizing the matrix as
ViennaCL type when i try with more than one processor, i get now:
[0]PETSC ERROR: --------------------- Error Message
[0]PETSC ERROR: No support for this operation for this object type
[0]PETSC ERROR: Currently only handles ViennaCL matrices
[0]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html for
trouble shooting.
[0]PETSC ERROR: Petsc Development GIT revision: v3.9.2-549-g779ab53 GIT
Date: 2018-05-31 17:31:13 +0300
[0]PETSC ERROR: ./gcmLEP.GPU on a cuda-debug named node50 by valera Wed Aug
15 14:44:22 2018
[0]PETSC ERROR: Configure options PETSC_ARCH=cuda-debug
--with-mpi-dir=/usr/lib64/openmpi --COPTFLAGS=-O2 --CXXOPTFLAGS=-O2
--FOPTFLAGS=-O2 --with-shared-libraries=1 --with-debugging=1 --with-cuda=1
--CUDAFLAGS=-arch=sm_60 --with-blaslapack-dir=/usr/lib64 --download-viennacl
[0]PETSC ERROR: #1 PCSetUp_SAVIENNACL() line 47 in
/home/valera/petsc/src/ksp/pc/impls/saviennaclcuda/saviennacl.cu
[0]PETSC ERROR: #2 PCSetUp() line 932 in
/home/valera/petsc/src/ksp/pc/interface/precon.c
[0]PETSC ERROR: #3 KSPSetUp() line 381 in
/home/valera/petsc/src/ksp/ksp/interface/itfunc.c
When running with:
mpirun -n 1 ./gcmLEP.GPU tc=TestCases/LockRelease/LE_6x6x6/
jid=tiny_cuda_test_n2 -ksp_type cg -dm_vec_type viennacl -dm_mat_type
aijviennacl -pc_type saviennacl -log_view
On Wed, Aug 15, 2018 at 2:32 PM, Matthew Knepley <knepley at gmail.com> wrote:
> On Wed, Aug 15, 2018 at 5:20 PM Manuel Valera <mvalera-w at sdsu.edu> wrote:
>> It seems to be resumed on: I do not know how to preallocate a DM Matrix
>> correctly.
> There is only one matrix type, Mat. There are no separate DM matrices. A
> DM can create a matrix for you
> using DMCreateMatrix(), but that is a Mat and it is preallocated
> correctly. I am not sure what you are doing.
> Thanks,
> Matt
>> The interesting part is that it only breaks when i need to populate a GPU
>> matrix from MPI, so kudos on that, but it seems i need to do better on my
>> code to get this setup working,
>> Any help would be appreciated,
>> Thanks,
>> On Wed, Aug 15, 2018 at 2:15 PM, Matthew Knepley <knepley at gmail.com>
>> wrote:
>>> On Wed, Aug 15, 2018 at 4:53 PM Manuel Valera <mvalera-w at sdsu.edu>
>>> wrote:
>>>> Thanks Matthew,
>>>> I try to do that when calling:
>>>> call MatMPIAIJSetPreallocation(A,19,PETSC_NULL_INTEGER,19,PETSC_
>>>> NULL_INTEGER,ierr)
>>>> But i am not aware on how to do this for the DM if it needs something
>>>> more specific/different,
>>> The error says that your preallocation is wrong for the values you are
>>> putting in. The DM does not control either,
>>> so I do not understand your email.
>>> Thanks,
>>> Matt
>>>> Thanks,
>>>> On Wed, Aug 15, 2018 at 1:51 PM, Matthew Knepley <knepley at gmail.com>
>>>> wrote:
>>>>> On Wed, Aug 15, 2018 at 4:39 PM Manuel Valera <mvalera-w at sdsu.edu>
>>>>> wrote:
>>>>>> Hello PETSc devs,
>>>>>> I am running into an error when trying to use the MATMPIAIJVIENNACL
>>>>>> Matrix type in MPI calls, the same code runs for MATSEQAIJVIENNACL type in
>>>>>> one processor. The error happens when calling MatSetValues for this
>>>>>> specific configuration. It does not occur when using MPI DMMatrix types
>>>>>> only.
>>>>> The DM properly preallocates the matrix. I am assuming you do not here.
>>>>> Matt
>>>>>> Any help will be appreciated,
>>>>>> Thanks,
>>>>>> My program call:
>>>>>> mpirun -n 2 ./gcmLEP.GPU tc=TestCases/LockRelease/LE_6x6x6/
>>>>>> The error (repeats after each MatSetValues call):
>>>>>> [1]PETSC ERROR: --------------------- Error Message
>>>>>> [1]PETSC ERROR: Argument out of range
>>>>>> [1]PETSC ERROR: Inserting a new nonzero at global row/column (75, 50)
>>>>>> into matrix
>>>>>> [1]PETSC ERROR: See http://www.mcs.anl.gov/petsc/
>>>>>> documentation/faq.html for trouble shooting.
>>>>>> [1]PETSC ERROR: Petsc Development GIT revision: v3.9.2-549-g779ab53
>>>>>> GIT Date: 2018-05-31 17:31:13 +0300
>>>>>> [1]PETSC ERROR: ./gcmLEP.GPU on a cuda-debug named node50 by valera
>>>>>> Wed Aug 15 13:10:44 2018
>>>>>> [1]PETSC ERROR: Configure options PETSC_ARCH=cuda-debug
>>>>>> --download-viennacl
>>>>>> [1]PETSC ERROR: #1 MatSetValues_MPIAIJ() line 608 in
>>>>>> /home/valera/petsc/src/mat/impls/aij/mpi/mpiaij.c
>>>>>> [1]PETSC ERROR: #2 MatSetValues() line 1339 in
>>>>>> /home/valera/petsc/src/mat/interface/matrix.c
>>>>>> My Code structure:
>>>>>>> call MPI_Comm_size(PETSC_COMM_WORLD, numprocs, ierr)
>>>>>>> if (numprocs > 1) then ! set matrix type parallel
>>>>>>> ! Get local size
>>>>>>> call DMDACreateNaturalVector(daDummy,Tmpnat,ierr)
>>>>>>> call VecGetLocalSize(Tmpnat,locsize,ierr)
>>>>>>> call VecDestroy(Tmpnat,ierr)
>>>>>>> ! Set matrix
>>>>>>> #ifdef GPU
>>>>>>> call MatSetType(A,MATAIJVIENNACL,ierr)
>>>>>>> print*,'SETTING GPU TYPES'
>>>>>>> #else
>>>>>>> call DMSetMatType(daDummy,MATMPIAIJ,ierr)
>>>>>>> call DMSetMatType(daDummy,VECMPI,ierr)
>>>>>>> call MatSetType(A,MATMPIAIJ,ierr)!
>>>>>>> #endif
>>>>>>> else ! set matrix type sequential
>>>>>>> #ifdef GPU
>>>>>>> call DMSetMatType(daDummy,MATSEQAIJVIENNACL,ierr)
>>>>>>> call DMSetVecType(daDummy,VECSEQVIENNACL,ierr)
>>>>>>> call MatSetType(A,MATSEQAIJVIENNACL,ierr)
>>>>>>> #else
>>>>>>> call DMSetMatType(daDummy,MATSEQAIJ,ierr)
>>>>>>> call DMSetMatType(daDummy,VECSEQ,ierr)
>>>>>>> call MatSetType(A,MATSEQAIJ,ierr)
>>>>>>> #endif
>>>>>>> call getCenterInfo(daGrid,xstart,ystart,zstart,xend,yend,zend)
>>>>>>> do k=zstart,zend-1
>>>>>>> do j=ystart,yend-1
>>>>>>> do i=xstart,xend-1
>>>>>>> call MatSetValues(A,1,row,sumpos,
>>>>> What most experimenters take for granted before they begin their
>>>>> experiments is infinitely more interesting than any results to which their
>>>>> experiments lead.
>>>>> -- Norbert Wiener
>>>>> https://www.cse.buffalo.edu/~knepley/
>>>>> <http://www.caam.rice.edu/~mk51/>
>>> experiments lead.
>>> -- Norbert Wiener
>>> https://www.cse.buffalo.edu/~knepley/ <http://www.caam.rice.edu/~mk51/>
> experiments lead.
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20180815/a5399e88/attachment.html>
