[petsc-users] Max color value exeeds 65535 limit
    Matthew Knepley
    knepley at gmail.com
    Tue Aug 14 11:02:17 CDT 2018
On Tue, Aug 14, 2018 at 10:12 AM Florian Kauer <florian.kauer at koalo.de>
wrote:
> Hi,
> I was just testing out if my calculations also work for several 10000
> variables and got the following error. Is this a fundamental limit with
> very large (or complex) systems of equations or does it hint to a bug/wrong
> configuration in my program? Everything works fine for smaller systems.
This is an artificial limit. However, you probably do not want to use that
coloring. Is this matrix sparse?
If so, I would try the greedy coloring based on the AIJ pattern.
    Matt
> [0]PETSC ERROR: --------------------- Error Message
> [0]PETSC ERROR: Argument out of range
> [0]PETSC ERROR: Max color value exeeds 65535 limit. This number is
> unrealistic. Perhaps a bug in code?
> Current max: 65535 user rewuested: 65536
> [0]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html
> for trouble shooting.
> [0]PETSC ERROR: Petsc Release Version 3.8.4, unknown
> [0]PETSC ERROR: ./csma_model on a linux-gnu-c-debug named h3a-srv-crunchie
> by cto7138 Tue Aug 14 15:59:57 2018
> [0]PETSC ERROR: Configure options --with-cc=gcc --with-cxx=g++
> --with-fc=gfortran --download-mpich --download-fblaslapack
> [0]PETSC ERROR: #1 ISColoringCreate() line 268 in
> /home/cto7138/petsc/src/vec/is/is/utils/iscoloring.c
> [0]PETSC ERROR: #2 MatColoringPatch_SeqAIJ_Inode() line 2715 in
> /home/cto7138/petsc/src/mat/impls/aij/seq/inode.c
> [0]PETSC ERROR: #3 MatColoringPatch() line 7566 in
> /home/cto7138/petsc/src/mat/interface/matrix.c
> [0]PETSC ERROR: #4 MatColoringApply_SL() line 101 in
> /home/cto7138/petsc/src/mat/color/impls/minpack/color.c
> [0]PETSC ERROR: #5 MatColoringApply() line 360 in
> /home/cto7138/petsc/src/mat/color/interface/matcoloring.c
> [0]PETSC ERROR: #6 SNESComputeJacobianDefaultColor() line 81 in
> /home/cto7138/petsc/src/snes/interface/snesj2.c
> [0]PETSC ERROR: #7 SNESComputeJacobian() line 2360 in
> /home/cto7138/petsc/src/snes/interface/snes.c
> [0]PETSC ERROR: #8 SNESSolve_NEWTONLS() line 222 in
> /home/cto7138/petsc/src/snes/impls/ls/ls.c
> [0]PETSC ERROR: #9 SNESSolve() line 4131 in
> [0]PETSC ERROR: #10 main() line 401 in
> /home/cto7138/evaluation/analyticalmultihop/src/csma_model/csma_model.cpp
> [0]PETSC ERROR: PETSc Option Table entries:
> [0]PETSC ERROR: --experiment
> /home/cto7138/evaluation/results/analytical-csma/inverse-model/21341_95/000/experiment_CSMA.json
> [0]PETSC ERROR: ----------------End of Error Message -------send entire
> error message to petsc-maint at mcs.anl.gov----------
> Greetings,
> Florian
experiments lead.
-- Norbert Wiener
https://www.cse.buffalo.edu/~knepley/ <http://www.caam.rice.edu/~mk51/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20180814/57d9134c/attachment.html>
