[petsc-users] Why PETSc needs PetscScalar datatype?
Karl Rupp
rupp at iue.tuwien.ac.at
Tue Aug 7 08:22:23 CDT 2018
Hi Youjun,
PetscFortranComplex has been merged to our `master` development branch
and is also available via the `maint` branch. It will be part of the
next 3.9.x point release.
Best regards,
Karli
On 08/04/2018 04:43 PM, Youjun Hu wrote:
> Thank Satish.
> PetscFortranComplex works.
> I just want to distinguish between real and complex variables in my
> Fotran code, so I prefer to use PetscFortranComplex when a variables is
> complex.
> I began to learn petsc just several weeks ago.
> Another unusual thing I noticed is that petsc keywords are
> case-sensitive in Fotran codes, which breaks the convention that Fortran
> is case-insensitive.
> Correct me if I am wrong.
> Youjun
> On Sat, Aug 4, 2018 at 3:24 PM Satish Balay <balay at mcs.anl.gov
> <mailto:balay at mcs.anl.gov>> wrote:
> For some reason it is PetscFortranComplex [on fortran side]
> I'm not sure I understand your logic for using PetscComplex and not
> PetscScalar.
> We recommend using PetscScalar. You can choose not to follow our
> recommendation.
> But we don't say 'PetscScalar' is the wrong thing for users [as you
> appear to infer]
> Satish
> On Sat, 4 Aug 2018, Youjun Hu wrote:
> > I just tried to change PetscScalar to the specific datatype
> PetscComplex in
> > my Fortran code, but the compiler raised the following error:
> > PetscComplex my_coeff
> > Error: Unclassifiable statement at (1)
> > It seems that the compiler does not know this datatype.
> > My Petsc was configured with ./configure --with-scalar-type=complex
> > --with-precision=double
> > Before the modification, the code was complied successfully.
> > Could someone help?
> > Thanks,
> > Youjun
