[petsc-users] large number of iteration.
Josh L ysjosh.lo at gmail.com
Sun Aug 5 21:38:19 CDT 2018
I am using GRMES to solve the linear systems within Newton Raphson.
I am using finite element method to solve fracture problem with phase field
method.(the formulation gives symmetric but indefinite hessian so can't use
CG)
The total iteration number to solve one linear system is often very large(
> 2000) even for a small sized problem(120K degree of freedom). I've tried
different preconditioner, but it doesn't help a lot.  I have checked my
hessian and right hand side, and sure they are correct.
I think it might stem from the great difference in element
size(max/min=100) and damage stiffness around crack.
Anyone has idea to reduce the number of iteration?
Now, I get away with it by using LU, which is not ideal for large size
problem (I will have to run it in the future)
Josh
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20180805/ce73a071/attachment.html>
