[petsc-users] Why PETSc needs PetscScalar datatype?
Youjun Hu
youjunhu at gmail.com
Sat Aug 4 16:43:36 CDT 2018
Thank Satish.
PetscFortranComplex works.
I just want to distinguish between real and complex variables in my Fotran
code, so I prefer to use PetscFortranComplex when a variables is complex.
I began to learn petsc just several weeks ago.
Another unusual thing I noticed is that petsc keywords are case-sensitive
in Fotran codes, which breaks the convention that Fortran is
case-insensitive.
Correct me if I am wrong.
Youjun
On Sat, Aug 4, 2018 at 3:24 PM Satish Balay <balay at mcs.anl.gov> wrote:
> For some reason it is PetscFortranComplex [on fortran side]
> I'm not sure I understand your logic for using PetscComplex and not
> PetscScalar.
> We recommend using PetscScalar. You can choose not to follow our
> recommendation.
> But we don't say 'PetscScalar' is the wrong thing for users [as you
> appear to infer]
> Satish
> On Sat, 4 Aug 2018, Youjun Hu wrote:
> > I just tried to change PetscScalar to the specific datatype PetscComplex
> in
> > my Fortran code, but the compiler raised the following error:
> > PetscComplex my_coeff
> > Error: Unclassifiable statement at (1)
> > It seems that the compiler does not know this datatype.
> > My Petsc was configured with ./configure --with-scalar-type=complex
> > --with-precision=double
> > Before the modification, the code was complied successfully.
> > Could someone help?
> > Thanks,
> > Youjun
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20180804/435ac9ef/attachment.html>
