[petsc-users] MatDenseGetArrayF90
Smith, Barry F. bsmith at mcs.anl.gov
Fri Aug 3 13:47:30 CDT 2018
  Yikes, bad bug. It wasn't returning the diagonal block just the wrong wrong size for columns.
   Barry
> On Aug 3, 2018, at 1:42 PM, Jed Brown <jed at jedbrown.org> wrote:
> Can you test the patch below?
> diff --git i/src/mat/interface/f90-custom/zmatrixf90.c w/src/mat/interface/f90-custom/zmatrixf90.c
> index 0497d33fe7..7b2ab1011f 100644
> --- i/src/mat/interface/f90-custom/zmatrixf90.c
> +++ w/src/mat/interface/f90-custom/zmatrixf90.c
> @@ -31,10 +31,11 @@ PETSC_EXTERN void PETSC_STDCALL matgetghostsf90_(Mat *mat,F90Array1d *ptr,int *i
> PETSC_EXTERN void PETSC_STDCALL matdensegetarrayf90_(Mat *mat,F90Array2d *ptr,int *ierr PETSC_F90_2PTR_PROTO(ptrd))
>   PetscScalar *fa;
> -  PetscInt    m,n;
> +  PetscInt    m,N;
>   *ierr = MatDenseGetArray(*mat,&fa);       if (*ierr) return;
> -  *ierr = MatGetLocalSize(*mat,&m,&n); if (*ierr) return;
> -  *ierr = F90Array2dCreate(fa,MPIU_SCALAR,1,m,1,n,ptr PETSC_F90_2PTR_PARAM(ptrd));
> +  *ierr = MatGetLocalSize(*mat,&m,NULL); if (*ierr) return;
> +  *ierr = MatGetSize(*mat,NULL,&N); if (*ierr) return;
> +  *ierr = F90Array2dCreate(fa,MPIU_SCALAR,1,m,1,N,ptr PETSC_F90_2PTR_PARAM(ptrd));
> PETSC_EXTERN void PETSC_STDCALL matdenserestorearrayf90_(Mat *mat,F90Array2d *ptr,int *ierr PETSC_F90_2PTR_PROTO(ptrd))
> Marius Buerkle <mbuerkle at web.de> writes:
>> No I don't get the whole block, only the diagonal block of the matrix. Maybe I am doing something wrong.
>>>> Hi
>>>> When using MatDenseGetArrayF90 only the diaognal part of the matrix is
>>>> returned. Is it possible to get the whole matrix?
>>> You should get the entire block row (local size m by global size N).
