[petsc-users] Solving Linear Systems with Scalar Real and Complex
Mark Adams mfadams at lbl.gov
Fri Aug 3 08:16:02 CDT 2018
So this is a complex valued indefinite Helmholtz operator (very hard to
solve scalably) with axisymmetric coordinates. ML, hypre and GAMG all
performed about the same, with a big jump in residual initially and
essentially not solving it. You scaled it and this fixed ML and hypre but
not GAMG.
>From this output I can see that the eigenvalue estimates are strange. Your
equations look fine so I have to assume that the complex values are the
problem. If this is symmetric the CG is a much better solver and eigen
estimator. But this is not a big deal, especially since you have two
options that work. I would suggest not using cheby smoother, it uses these
bad eigen estimates, and it is basically not smoothing on some levels. You
can use this instead:
-mg_levels_ksp_type richardson
-mg_levels_pc_type sor
Note, if you have a large shift these equations are very hard to solve
iteratively and you should just use a direct solver. Direct solvers in 2D
are not bad,
On Fri, Aug 3, 2018 at 3:02 AM Pierpaolo Minelli <pierpaolo.minelli at cnr.it>
wrote:
> In this simulation I'm solving two equations in a two-dimensional domain
> (z,r) at each time step. The first is an equation derived from the Maxwell
> equation. Taking advantage of the fact that the domain is axialsymmetric
> and applying a temporal harmonic approximation, the equation I am solving
> is the following:
> The second equation is a Poisson’s  equation in cylindrical coordinates
> (z,r) in the field of real numbers.
> This is the output obtained using these options (Note that at this moment
> of development I am only using a processor):
> *-pc_type gamg -pc_gamg_agg_nsmooths 1 -pc_gamg_reuse_interpolation true
> -pc_gamg_square_graph 1 -pc_gamg_threshold 0. -ksp_rtol 1.e-7
> -ksp_max_it 30 -ksp_monitor_true_residual -info | grep GAMG*
> [0] PCSetUp_GAMG(): level 0) N=321201, n data rows=1, n data cols=1,
> nnz/row (ave)=5, np=1
> [0] PCGAMGFilterGraph():   100.% nnz after filtering, with threshold 0.,
> 4.97011 nnz ave. (N=321201)
> [0] PCGAMGCoarsen_AGG(): Square Graph on level 1 of 1 to square
> [0] PCGAMGProlongator_AGG(): New grid 45754 nodes
> [0] PCGAMGOptProlongator_AGG(): Smooth P0: max eigen=1.972526e+00
> min=3.461411e-03 PC=jacobi
> [0] PCSetUp_GAMG(): 1) N=45754, n data cols=1, nnz/row (ave)=10, 1 active
> pes
> 10.7695 nnz ave. (N=45754)
> [0] PCGAMGProlongator_AGG(): New grid 7893 nodes
> [0] PCGAMGOptProlongator_AGG(): Smooth P0: max eigen=5.686837e+00
> min=5.062501e-01 PC=jacobi
> [0] PCSetUp_GAMG(): 2) N=7893, n data cols=1, nnz/row (ave)=23, 1 active
> pes
> 23.2179 nnz ave. (N=7893)
> [0] PCGAMGProlongator_AGG(): New grid 752 nodes
> [0] PCGAMGOptProlongator_AGG(): Smooth P0: max eigen=1.504451e+01
> min=2.124898e-02 PC=jacobi
> [0] PCSetUp_GAMG(): 3) N=752, n data cols=1, nnz/row (ave)=30, 1 active pes
> 30.7367 nnz ave. (N=752)
> [0] PCGAMGProlongator_AGG(): New grid 56 nodes
> [0] PCGAMGOptProlongator_AGG(): Smooth P0: max eigen=7.781296e+00
> min=2.212257e-02 PC=jacobi
> [0] PCSetUp_GAMG(): 4) N=56, n data cols=1, nnz/row (ave)=22, 1 active pes
> 22.9643 nnz ave. (N=56)
> [0] PCGAMGProlongator_AGG(): New grid 6 nodes
> [0] PCGAMGOptProlongator_AGG(): Smooth P0: max eigen=1.525086e+00
> min=1.375043e-01 PC=jacobi
> [0] PCSetUp_GAMG(): 5) N=6, n data cols=1, nnz/row (ave)=6, 1 active pes
> [0] PCSetUp_GAMG(): 6 levels, grid complexity = 1.43876
> pes
> pes
> [0] PCSetUp_GAMG(): level 0) N=271201, n data rows=1, n data cols=1,
> 4.97455 nnz ave. (N=271201)
> [0] PCGAMGProlongator_AGG(): New grid 38501 nodes
> [0] PCGAMGOptProlongator_AGG(): Smooth P0: max eigen=1.933798e+00
> min=4.684075e-02 PC=jacobi
> [0] PCSetUp_GAMG(): 1) N=38501, n data cols=1, nnz/row (ave)=10, 1 active
> pes
> 10.7732 nnz ave. (N=38501)
> [0] PCGAMGProlongator_AGG(): New grid 6664 nodes
> [0] PCGAMGOptProlongator_AGG(): Smooth P0: max eigen=1.623029e+00
> min=1.250957e-02 PC=jacobi
> [0] PCSetUp_GAMG(): 2) N=6664, n data cols=1, nnz/row (ave)=23, 1 active
> pes
> 23.2098 nnz ave. (N=6664)
> [0] PCGAMGProlongator_AGG(): New grid 620 nodes
> [0] PCGAMGOptProlongator_AGG(): Smooth P0: max eigen=1.763329e+00
> min=1.611776e-02 PC=jacobi
> [0] PCSetUp_GAMG(): 3) N=620, n data cols=1, nnz/row (ave)=29, 1 active pes
> 29.6129 nnz ave. (N=620)
> [0] PCGAMGProlongator_AGG(): New grid 46 nodes
> [0] PCGAMGOptProlongator_AGG(): Smooth P0: max eigen=1.497611e+00
> min=2.630403e-02 PC=jacobi
> [0] PCSetUp_GAMG(): 4) N=46, n data cols=1, nnz/row (ave)=20, 1 active pes
> [0] PCSetUp_GAMG(): 5 levels, grid complexity = 1.43639
> Il giorno 02 ago 2018, alle ore 17:39, Mark Adams <mfadams at lbl.gov> ha
> scritto:
> It looks like ML and hypre are working well now. If you want to debug GAMG
> you can run with -info, which is very noisy, and grep on GAMG or send the
> whole output.
> BTW, what equations are you solving?
> On Thu, Aug 2, 2018 at 5:12 AM Pierpaolo Minelli <pierpaolo.minelli at cnr.it>
> wrote:
>> Thank you very much for the correction.
>> By rebalancing the matrix coefficients, making them dimensionless, in my
>> complex problem i managed to obtain a better result with both ML and HYPRE.
>> GAMG instead seems to be unable to converge and in fact I get unexpected
>> results. I report the outputs of the three simulations again (i tried to
>> use also -pc_gamg_square_graph 20 without any improvement).
>> Pierpaolo
>> *-pc_type hypre -ksp_rtol 1.e-7 -ksp_monitor_true_residual*
>>   0 KSP preconditioned resid norm 1.984853668904e-02 true resid norm
>> 2.979865703850e-03 ||r(i)||/||b|| 1.000000000000e+00
>>   1 KSP preconditioned resid norm 1.924446712661e-04 true resid norm
>> 1.204260204811e-04 ||r(i)||/||b|| 4.041323752460e-02
>>   2 KSP preconditioned resid norm 5.161509100765e-06 true resid norm
>> 2.810809726926e-06 ||r(i)||/||b|| 9.432672496933e-04
>>   3 KSP preconditioned resid norm 9.297326931238e-08 true resid norm
>> 4.474617977876e-08 ||r(i)||/||b|| 1.501617328625e-05
>>   4 KSP preconditioned resid norm 1.910271882670e-09 true resid norm
>> 9.637470658283e-10 ||r(i)||/||b|| 3.234196308186e-07
>>   0 KSP preconditioned resid norm 2.157687745805e+04 true resid norm
>> 3.182001523188e+03 ||r(i)||/||b|| 1.000000000000e+00
>>   1 KSP preconditioned resid norm 1.949268476386e+02 true resid norm
>> 1.243419788627e+02 ||r(i)||/||b|| 3.907665598415e-02
>>   2 KSP preconditioned resid norm 5.078054475792e+00 true resid norm
>> 2.745355604400e+00 ||r(i)||/||b|| 8.627763325675e-04
>>   3 KSP preconditioned resid norm 8.663802743529e-02 true resid norm
>> 4.254290979292e-02 ||r(i)||/||b|| 1.336985839979e-05
>>   4 KSP preconditioned resid norm 1.795605563039e-03 true resid norm
>> 9.040507428245e-04 ||r(i)||/||b|| 2.841138623714e-07
>>   0 KSP preconditioned resid norm 6.728304961395e+02 true resid norm
>> 1.879478105170e+02 ||r(i)||/||b|| 1.000000000000e+00
>>   1 KSP preconditioned resid norm 2.190497539532e+01 true resid norm
>> 4.630095820203e+02 ||r(i)||/||b|| 2.463500802413e+00
>>   2 KSP preconditioned resid norm 8.425561564252e-01 true resid norm
>> 7.012565302251e+01 ||r(i)||/||b|| 3.731123700223e-01
>>   3 KSP preconditioned resid norm 3.029848345705e-02 true resid norm
>> 4.379018464663e+00 ||r(i)||/||b|| 2.329911932795e-02
>>   4 KSP preconditioned resid norm 7.374025528575e-04 true resid norm
>> 1.337183702137e-01 ||r(i)||/||b|| 7.114654320570e-04
>>   5 KSP preconditioned resid norm 3.009400175162e-05 true resid norm
>> 7.731135032616e-03 ||r(i)||/||b|| 4.113447776459e-05
>> *-pc_type ml -ksp_rtol 1.e-7 -ksp_monitor_true_residual*
>>   0 KSP preconditioned resid norm 1.825767020538e-02 true resid norm
>>   1 KSP preconditioned resid norm 6.495628259383e-04 true resid norm
>> 3.739440526742e-04 ||r(i)||/||b|| 1.254902367550e-01
>>   2 KSP preconditioned resid norm 4.971875712015e-05 true resid norm
>> 2.118856024328e-05 ||r(i)||/||b|| 7.110575559127e-03
>>   3 KSP preconditioned resid norm 3.726806462912e-06 true resid norm
>> 1.370355844514e-06 ||r(i)||/||b|| 4.598716790303e-04
>>   4 KSP preconditioned resid norm 2.496898447120e-07 true resid norm
>> 9.494701893753
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20180803/f46af6be/attachment.html>
Type: image/png
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20180803/f46af6be/attachment.png>
Type: image/png
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20180803/f46af6be/attachment-0001.png>
