[petsc-users] PDSLin hybrid solver performance with PETSc
Smith, Barry F.
bsmith at mcs.anl.gov
Mon Apr 30 10:39:52 CDT 2018
Looks like there is a divide by a variable that is zero in pdslin where the code doesn't first check if the value is not zero.
You can try using the option -start_in_debugger and in each debugger window use the debugger option to catch floating point exceptions and then type cont to continue the run. Yes this is annoying when you have so many debugger windows but is the only simple way to determine immediately the line of code that is producing the floating point exception.
Barry
> On Apr 30, 2018, at 6:20 AM, Afrah Najib <afrah.nacib at gmail.com> wrote:
> Hi all,
> I am testing PDSLin hybrid solver performance with PETSc krylov method on a SPD matrix called audik_1 matrix(format is ijv full matrix ordered by rows)
> https://sparse.tamu.edu/GHS_psdef/audikw_1
> I am also running on cluster with Intel(R) Xeon(R) CPU E5-2680 v4 @ 2.40GHz processor and 28 core , 128 ; 512GB per node
> but it takes a lot of time for Schur complement factorization.
> Compiler Subdomains processors Precond TmatrixPartition TmatrixDist Tfactorise TcompApproSchur TprepApproSchur Tfactoschur Tprecond_Total Tsolve
> gcc 8 128 Sparse 23.49532 0.6009915 6.059546 212.8243 0.04027608 38.74885 257.6796 13.69609
> gcc 8 16 Sparse 11.864 0.4385703 27.23499 1390.153 0.5523289 55.20706 1473.207 4.213825
> gcc 8 32 Sparse 9.912792 0.2592737 16.79125 934.3571 0.2372452 49.39175 1000.813 37.2029
> gcc 8 64 Sparse 12.61929 0.2336042 8.2316 632.839 0.1113939 52.21551 693.4153 13.94034
> My PETSc in stallation configuration is like this:
> export PETSC_DIR=/X/petsc
> export PETSC_ARCH=arch-real
> ./configure PETSC_DIR=/X/petsc \
> prefix=/X/petsc/petsc-install \
> PETSC_ARCH=arch-real \
> --with-debugging=0 \
> --with-cc=/Y/progs/openmpi/openmpi-3.0.0-gcc-7.1.0/bin/mpicc \
> --with-cxx=/Y/progs/openmpi/openmpi-3.0.0-gcc-7.1.0/bin/mpicxx \
> --with-fc=/Y/progs/openmpi/openmpi-3.0.0-gcc-7.1.0/bin/mpif90 \
> --with-valgrind=1 \
> --with-valgrind-dir=/X/root/usr/local/valgrind-3.13.0 \
> --with-hwloc-dir=/X/root/usr/local/hwloc-1.11.9 \
> --with-blas-lapack-dir=/Y/progs/intel/compilers_and_libraries_2017.0.098/linux/mkl/lib/intel64.
> My slurm scrpt content is like this:
> #!/bin/bash -l
> #SBATCH -J "Paudik16"
> #SBATCH -A X
> #SBATCH -p X
> #SBATCH --exclusive
> #SBATCH -o Paudik_8_2_16.%j.out
> #SBATCH -e Paudik_8_2_16.%j.err
> #SBATCH -N 8
> #SBATCH --ntasks-per-node=2
> #SBATCH --cpus-per-task=1
> export KMP_AFFINITY=verbose,disabled
> export MKL_NUM_THREADS=${SLURM_CPUS_PER_TASK}
> export OMP_NUM_THREADS=${SLURM_CPUS_PER_TASK}
> module purge
> module load gcc/7.1.0
> module load mpi/openmpi-3.0.0-gcc-7.1.0
> module load intel/mkl_2017.0.098
> file=input.in
> matrixFile=~/dataDir/ijv/audikw_1.ijv
> mpirun -np $SLURM_NTASKS ./dtest_pdslin $file $matrixFile
> I attached an output of one file along with the input configuration of PDSLin.
> Any idea of how to enhance these results.
> Note in PDSLin, I tried with parallel Schur permutation but I got the following error :
> [1]PETSC ERROR: ------------------------------------------------------------------------
> [1]PETSC ERROR: Caught signal number 8 FPE: Floating Point E/Xception,probably divide by zero
> [1]PETSC ERROR: Try option -start_in_debugger or -on_error_attach_debugger
> [1]PETSC ERROR: or see http://www.mcs.anl.gov/petsc/documentation/faq.html#valgrind
> [1]PETSC ERROR: or try http://valgrind.org on GNU/linu/X and Apple Mac OS /X to find memory corruption errors
> [1]PETSC ERROR: configure using --with-debugging=yes, recompile, link, and run
> [1]PETSC ERROR: to get more information on the crash.
> [1]PETSC ERROR: --------------------- Error Message --------------------------------------------------------------
> MPI_ABORT was invoked on rank 1 in communicator MPI_COMM_WORLD
> with errorcode 59.
> NOTE: invoking MPI_ABORT causes Open MPI to kill all MPI processes.
> You may or may not see output from other processes, depending on
> e/Xactly when Open MPI kills them.
> [13]PETSC ERROR: ------------------------------------------------------------------------
> [13]PETSC ERROR: Caught signal number 8 FPE: Floating Point E/Xception,probably divide by zero
> [13]PETSC ERROR: Try option -start_in_debugger or -on_error_attach_debugger
> [13]PETSC ERROR: or see http://www.mcs.anl.gov/petsc/documentation/faq.html#valgrind
> [13]PETSC ERROR: or try http://valgrind.org on GNU/linu/X and Apple Mac OS /X to find memory corruption errors
> [13]PETSC ERROR: configure using --with-debugging=yes, recompile, link, and run
> [13]PETSC ERROR: to get more information on the crash.
> [11]PETSC ERROR: ------------------------------------------------------------------------
> [11]PETSC ERROR: Caught signal number 8 FPE: Floating Point E/Xception,probably divide by zero
> [11]PETSC ERROR: Try option -start_in_debugger or -on_error_attach_debugger
> [11]PETSC ERROR: or see http://www.mcs.anl.gov/petsc/documentation/faq.html#valgrind
> [11]PETSC ERROR: or try http://valgrind.org on GNU/linu/X and Apple Mac OS /X to find memory corruption errors
> [11]PETSC ERROR: configure using --with-debugging=yes, recompile, link, and run
> [11]PETSC ERROR: to get more information on the crash.
> [3]PETSC ERROR: ------------------------------------------------------------------------
> [3]PETSC ERROR: Caught signal number 8 FPE: Floating Point E/Xception,probably divide by zero
> [3]PETSC ERROR: Try option -start_in_debugger or -on_error_attach_debugger
> [3]PETSC ERROR: or see http://www.mcs.anl.gov/petsc/documentation/faq.html#valgrind
> [3]PETSC ERROR: or try http://valgrind.org on GNU/linu/X and Apple Mac OS /X to find memory corruption errors
> [3]PETSC ERROR: configure using --with-debugging=yes, recompile, link, and run
> [3]PETSC ERROR: to get more information on the crash.
> [3]PETSC ERROR: --------------------- Error Message --------------------------------------------------------------
> [3]PETSC ERROR: Signal received
> [3]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html for trouble shooting.
> [3]PETSC ERROR: Petsc Release Version 3.9.0, unknown
> [3]PETSC ERROR: [9]PETSC ERROR: ------------------------------------------------------------------------
> [9]PETSC ERROR: Caught signal number 8 FPE: Floating Point E/Xception,probably divide by zero
> [9]PETSC ERROR: Try option -start_in_debugger or -on_error_attach_debugger
> [9]PETSC ERROR: or see http://www.mcs.anl.gov/petsc/documentation/faq.html#valgrind
> [9]PETSC ERROR: or try http://valgrind.org on GNU/linu/X and Apple Mac OS /X to find memory corruption errors
> [9]PETSC ERROR: configure using --with-debugging=yes, recompile, link, and run
> [9]PETSC ERROR: to get more information on the crash.
> [7]PETSC ERROR: ------------------------------------------------------------------------
> [7]PETSC ERROR: Caught signal number 8 FPE: Floating Point E/Xception,probably divide by zero
> [7]PETSC ERROR: Try option -start_in_debugger or -on_error_attach_debugger
> [7]PETSC ERROR: or see http://www.mcs.anl.gov/petsc/documentation/faq.html#valgrind
> [7]PETSC ERROR: or try http://valgrind.org on GNU/linu/X and Apple Mac OS /X to find memory corruption errors
> [7]PETSC ERROR: configure using --with-debugging=yes, recompile, link, and run
> [7]PETSC ERROR: to get more information on the crash.
> [5]PETSC ERROR: ------------------------------------------------------------------------
> [5]PETSC ERROR: Caught signal number 8 FPE: Floating Point E/Xception,probably divide by zero
> [5]PETSC ERROR: Try option -start_in_debugger or -on_error_attach_debugger
> [5]PETSC ERROR: or see http://www.mcs.anl.gov/petsc/documentation/faq.html#valgrind
> [5]PETSC ERROR: or try http://valgrind.org on GNU/linu/X and Apple Mac OS /X to find memory corruption errors
> [5]PETSC ERROR: configure using --with-debugging=yes, recompile, link, and run
> [5]PETSC ERROR: to get more information on the crash.
> [5]PETSC ERROR: --------------------- Error Message --------------------------------------------------------------
> [5]PETSC ERROR: Signal received
> [5]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html for trouble shooting.
> [5]PETSC ERROR: Petsc Release Version 3.9.0, unknown
> [5]PETSC ERROR: [15]PETSC ERROR: ------------------------------------------------------------------------
> [15]PETSC ERROR: Caught signal number 8 FPE: Floating Point E/Xception,probably divide by zero
> [15]PETSC ERROR: Try option -start_in_debugger or -on_error_attach_debugger
> [15]PETSC ERROR: or see http://www.mcs.anl.gov/petsc/documentation/faq.html#valgrind
> [15]PETSC ERROR: [13]PETSC ERROR: --------------------- Error Message --------------------------------------------------------------
> [13]PETSC ERROR: Signal received
> [13]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html for trouble shooting.
> [13]PETSC ERROR: Petsc Release Version 3.9.0, unknown
> [13]PETSC ERROR: ./dtest_pdslin on a named s060 by afarea Mon Apr 30 05:29:53 2018
> [13]PETSC ERROR: Configure options PETSC_DIR=/X/petsc prefi/X=/X/petsc/petsc-install PETSC_ARCH=arch-real --with-debugging=0 --with-cc=/okyanus/progs/openmpi/openmpi-3.0.0-gcc-7.1.0/bin/mpicc --with-c/X/X=/okyanus/progs/openmpi/openmpi-3.0.0-gcc-7.1.0/bin/mpic/X/X --with-fc=/okyanus/progs/openmpi/openmpi-3.0.0-gcc-7.1.0/bin/mpif90 --with-valgrind=1 --with-valgrind-dir=/X/root/usr/local/valgrind-3.13.0 --with-hwloc-dir=/X/root/usr/local/hwloc-1.11.9 --with-blaslapack-dir=/okyanus/progs/intel/compilers_and_libraries_2017.0.098/linu/X/mkl/lib/intel64
> [11]PETSC ERROR: --------------------- Error Message --------------------------------------------------------------
> [11]PETSC ERROR: Signal received
> [11]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html for trouble shooting.
> [11]PETSC ERROR: Petsc Release Version 3.9.0, unknown
> [11]PETSC ERROR: ./dtest_pdslin on a named s054 by afarea Mon Apr 30 05:29:53 2018
> [11]PETSC ERROR: Configure options PETSC_DIR=/X/petsc prefi/X=/X/petsc/petsc-install PETSC_ARCH=arch-real --with-debugging=0 --with-cc=/okyanus/progs/openmpi/openmpi-3.0.0-gcc-7.1.0/bin/mpicc --with-c/X/X=/okyanus/progs/openmpi/openmpi-3.0.0-gcc-7.1.0/bin/mpic/X/X --with-fc=/okyanus/progs/openmpi/openmpi-3.0.0-gcc-7.1.0/bin/mpif90 --with-valgrind=1 --with-valgrind-dir=/X/root/usr/local/valgrind-3.13.0 --with-hwloc-dir=/X/root/usr/local/hwloc-1.11.9 --with-blaslapack-dir=/okyanus/progs/intel/compilers_and_libraries_2017.0.098/linu/X/mkl/lib/intel64
> ./dtest_pdslin on a named s034 by afarea Mon Apr 30 05:29:53 2018
> [3]PETSC ERROR: Configure options PETSC_DIR=/X/petsc prefi/X=/X/petsc/petsc-install PETSC_ARCH=arch-real --with-debugging=0 --with-cc=/okyanus/progs/openmpi/openmpi-3.0.0-gcc-7.1.0/bin/mpicc --with-c/X/X=/okyanus/progs/openmpi/openmpi-3.0.0-gcc-7.1.0/bin/mpic/X/X --with-fc=/okyanus/progs/openmpi/openmpi-3.0.0-gcc-7.1.0/bin/mpif90 --with-valgrind=1 --with-valgrind-dir=/X/root/usr/local/valgrind-3.13.0 --with-hwloc-dir=/X/root/usr/local/hwloc-1.11.9 --with-blaslapack-dir=/okyanus/progs/intel/compilers_and_libraries_2017.0.098/linu/X/mkl/lib/intel64
> [3]PETSC ERROR: #1 User provided function() line 0 in unknown file
> [9]PETSC ERROR: --------------------- Error Message --------------------------------------------------------------
> [9]PETSC ERROR: Signal received
> [9]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html for trouble shooting.
> [9]PETSC ERROR: Petsc Release Version 3.9.0, unknown
> [9]PETSC ERROR: ./dtest_pdslin on a named s044 by afarea Mon Apr 30 05:29:53 2018
> [9]PETSC ERROR: Configure options PETSC_DIR=/X/petsc prefi/X=/X/petsc/petsc-install PETSC_ARCH=arch-real --with-debugging=0 --with-cc=/okyanus/progs/openmpi/openmpi-3.0.0-gcc-7.1.0/bin/mpicc --with-c/X/X=/okyanus/progs/openmpi/openmpi-3.0.0-gcc-7.1.0/bin/mpic/X/X --with-fc=/okyanus/progs/openmpi/openmpi-3.0.0-gcc-7.1.0/bin/mpif90 --with-valgrind=1 --with-valgrind-dir=/X/root/usr/local/valgrind-3.13.0 --with-hwloc-dir=/X/root/usr/local/hwloc-1.11.9 --with-blaslapack-dir=/okyanus/progs/intel/compilers_and_libraries_2017.0.098/linu/X/mkl/lib/intel64
> [7]PETSC ERROR: --------------------- Error Message --------------------------------------------------------------
> [7]PETSC ERROR: Signal received
> [7]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html for trouble shooting.
> [7]PETSC ERROR: Petsc Release Version 3.9.0, unknown
> [7]PETSC ERROR: ./dtest_pdslin on a named s036 by afarea Mon Apr 30 05:29:53 2018
> [7]PETSC ERROR: Configure options PETSC_DIR=/X/petsc prefi/X=/X/petsc/petsc-install PETSC_ARCH=arch-real --with-debugging=0 --with-cc=/okyanus/progs/openmpi/openmpi-3.0.0-gcc-7.1.0/bin/mpicc --with-c/X/X=/okyanus/progs/openmpi/openmpi-3.0.0-gcc-7.1.0/bin/mpic/X/X --with-fc=/okyanus/progs/openmpi/openmpi-3.0.0-gcc-7.1.0/bin/mpif90 --with-valgrind=1 --with-valgrind-dir=/X/root/usr/local/valgrind-3.13.0 --with-hwloc-dir=/X/root/usr/local/hwloc-1.11.9 --with-blaslapack-dir=/okyanus/progs/intel/compilers_and_libraries_2017.0.098/linu/X/mkl/lib/intel64
> [7]PETSC ERROR: #1 User provided function() line 0 in unknown file
> ./dtest_pdslin on a named s035 by afarea Mon Apr 30 05:29:53 2018
> [5]PETSC ERROR: Configure options PETSC_DIR=/X/petsc prefi/X=/X/petsc/petsc-install PETSC_ARCH=arch-real --with-debugging=0 --with-cc=/okyanus/progs/openmpi/openmpi-3.0.0-gcc-7.1.0/bin/mpicc --with-c/X/X=/okyanus/progs/openmpi/openmpi-3.0.0-gcc-7.1.0/bin/mpic/X/X --with-fc=/okyanus/progs/openmpi/openmpi-3.0.0-gcc-7.1.0/bin/mpif90 --with-valgrind=1 --with-valgrind-dir=/X/root/usr/local/valgrind-3.13.0 --with-hwloc-dir=/X/root/usr/local/hwloc-1.11.9 --with-blaslapack-dir=/okyanus/progs/intel/compilers_and_libraries_2017.0.098/linu/X/mkl/lib/intel64
> [5]PETSC ERROR: #1 User provided function() line 0 in unknown file
> [15]PETSC ERROR: to get more information on the crash.
> [15]PETSC ERROR: --------------------- Error Message --------------------------------------------------------------
> [15]PETSC ERROR: Signal received
> [15]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html for trouble shooting.
> [15]PETSC ERROR: Petsc Release Version 3.9.0, unknown
> [15]PETSC ERROR: ./dtest_pdslin on a named s071 by afarea Mon Apr 30 05:29:53 2018
> [13]PETSC ERROR: #1 User provided function() line 0 in unknown file
> [11]PETSC ERROR: #1 User provided function() line 0 in unknown file
> [9]PETSC ERROR: #1 User provided function() line 0 in unknown file
> [15]PETSC ERROR: Configure options PETSC_DIR=/X/petsc prefi/X=/X/petsc/petsc-install PETSC_ARCH=arch-real --with-debugging=0 --with-cc=/okyanus/progs/openmpi/openmpi-3.0.0-gcc-7.1.0/bin/mpicc --with-c/X/X=/okyanus/progs/openmpi/openmpi-3.0.0-gcc-7.1.0/bin/mpic/X/X --with-fc=/okyanus/progs/openmpi/openmpi-3.0.0-gcc-7.1.0/bin/mpif90 --with-valgrind=1 --with-valgrind-dir=/X/root/usr/local/valgrind-3.13.0 --with-hwloc-dir=/X/root/usr/local/hwloc-1.11.9 --with-blaslapack-dir=/okyanus/progs/intel/compilers_and_libraries_2017.0.098/linu/X/mkl/lib/intel64
> [15]PETSC ERROR: #1 User provided function() line 0 in unknown file
> [1]PETSC ERROR: Signal received
> [1]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html for trouble shooting.
> [1]PETSC ERROR: Petsc Release Version 3.9.0, unknown
> [1]PETSC ERROR: ./dtest_pdslin on a named f002 by afarea Mon Apr 30 05:29:53 2018
> [1]PETSC ERROR: Configure options PETSC_DIR=/X/petsc prefi/X=/X/petsc/petsc-install PETSC_ARCH=arch-real --with-debugging=0 --with-cc=/okyanus/progs/openmpi/openmpi-3.0.0-gcc-7.1.0/bin/mpicc --with-c/X/X=/okyanus/progs/openmpi/openmpi-3.0.0-gcc-7.1.0/bin/mpic/X/X --with-fc=/okyanus/progs/openmpi/openmpi-3.0.0-gcc-7.1.0/bin/mpif90 --with-valgrind=1 --with-valgrind-dir=/X/root/usr/local/valgrind-3.13.0 --with-hwloc-dir=/X/root/usr/local/hwloc-1.11.9 --with-blaslapack-dir=/okyanus/progs/intel/compilers_and_libraries_2017.0.098/linu/X/mkl/lib/intel64
> [1]PETSC ERROR: #1 User provided function() line 0 in unknown file
> [6]PETSC ERROR: ------------------------------------------------------------------------
> [6]PETSC ERROR: Caught signal number 15 Terminate: Some process (or the batch system) has told this process to end
> [6]PETSC ERROR: Try option -start_in_debugger or -on_error_attach_debugger
> [6]PETSC ERROR: or see http://www.mcs.anl.gov/petsc/documentation/faq.html#valgrind
> [6]PETSC ERROR: or try http://valgrind.org on GNU/linu/X and Apple Mac OS /X to find memory corruption errors
> [6]PETSC ERROR: configure using --with-debugging=yes, recompile, link, and run
> [6]PETSC ERROR: to get more information on the crash.
> [6]PETSC ERROR: --------------------- Error Message --------------------------------------------------------------
> [6]PETSC ERROR: Signal received
> [6]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html for trouble shooting.
> [6]PETSC ERROR: Petsc Release Version 3.9.0, unknown
> [6]PETSC ERROR: ./dtest_pdslin on a named s036 by afarea Mon Apr 30 05:29:53 2018
> [6]PETSC ERROR: Configure options PETSC_DIR=/X/petsc prefi/X=/X/petsc/petsc-install PETSC_ARCH=arch-real --with-debugging=0 --with-cc=/okyanus/progs/openmpi/openmpi-3.0.0-gcc-7.1.0/bin/mpicc --with-c/X/X=/okyanus/progs/openmpi/openmpi-3.0.0-gcc-7.1.0/bin/mpic/X/X --with-fc=/okyanus/progs/openmpi/openmpi-3.0.0-gcc-7.1.0/bin/mpif90 --with-valgrind=1 --with-valgrind-dir=/X/root/usr/local/valgrind-3.13.0 --with-hwloc-dir=/X/root/usr/local/hwloc-1.11.9 --with-blaslapack-dir=/okyanus/progs/intel/compilers_and_libraries_2017.0.098/linu/X/mkl/lib/intel64
> [6]PETSC ERROR: #1 User provided function() line 0 in unknown file
> [4]PETSC ERROR: ------------------------------------------------------------------------
> [4]PETSC ERROR: Caught signal number 15 Terminate: Some process (or the batch system) has told this process to end
> [4]PETSC ERROR: Try option -start_in_debugger or -on_error_attach_debugger
> [4]PETSC ERROR: or see http://www.mcs.anl.gov/petsc/documentation/faq.html#valgrind
> [4]PETSC ERROR: or try http://valgrind.org on GNU/linu/X and Apple Mac OS /X to find memory corruption errors
> [4]PETSC ERROR: configure using --with-debugging=yes, recompile, link, and run
> [4]PETSC ERROR: to get more information on the crash.
> [4]PETSC ERROR: --------------------- Error Message --------------------------------------------------------------
> [4]PETSC ERROR: Signal received
> [4]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html for trouble shooting.
> [4]PETSC ERROR: Petsc Release Version 3.9.0, unknown
> [4]PETSC ERROR: ./dtest_pdslin on a named s035 by afarea Mon Apr 30 05:29:53 2018
> [4]PETSC ERROR: Configure options PETSC_DIR=/X/petsc prefi/X=/X/petsc/petsc-install PETSC_ARCH=arch-real --with-debugging=0 --with-cc=/okyanus/progs/openmpi/openmpi-3.0.0-gcc-7.1.0/bin/mpicc --with-c/X/X=/okyanus/progs/openmpi/openmpi-3.0.0-gcc-7.1.0/bin/mpic/X/X --with-fc=/okyanus/progs/openmpi/openmpi-3.0.0-gcc-7.1.0/bin/mpif90 --with-valgrind=1 --with-valgrind-dir=/X/root/usr/local/valgrind-3.13.0 --with-hwloc-dir=/X/root/usr/local/hwloc-1.11.9 --with-blaslapack-dir=/okyanus/progs/intel/compilers_and_libraries_2017.0.098/linu/X/mkl/lib/intel64
> [4]PETSC ERROR: #1 User provided function() line 0 in unknown file
> [0]PETSC ERROR: ------------------------------------------------------------------------
> [0]PETSC ERROR: Caught signal number 15 Terminate: Some process (or the batch system) has told this process to end
> [0]PETSC ERROR: Try option -start_in_debugger or -on_error_attach_debugger
> [0]PETSC ERROR: or see http://www.mcs.anl.gov/petsc/documentation/faq.html#valgrind
> [0]PETSC ERROR: or try http://valgrind.org on GNU/linu/X and Apple Mac OS /X to find memory corruption errors
> [0]PETSC ERROR: configure using --with-debugging=yes, recompile, link, and run
> [0]PETSC ERROR: to get more information on the crash.
> [0]PETSC ERROR: --------------------- Error Message --------------------------------------------------------------
> [0]PETSC ERROR: Signal received
> [0]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html for trouble shooting.
> [0]PETSC ERROR: Petsc Release Version 3.9.0, unknown
> [0]PETSC ERROR: ./dtest_pdslin on a named f002 by afarea Mon Apr 30 05:29:53 2018
> [0]PETSC ERROR: Configure options PETSC_DIR=/X/petsc prefi/X=/X/petsc/petsc-install PETSC_ARCH=arch-real --with-debugging=0 --with-cc=/okyanus/progs/openmpi/openmpi-3.0.0-gcc-7.1.0/bin/mpicc --with-c/X/X=/okyanus/progs/openmpi/openmpi-3.0.0-gcc-7.1.0/bin/mpic/X/X --with-fc=/okyanus/progs/openmpi/openmpi-3.0.0-gcc-7.1.0/bin/mpif90 --with-valgrind=1 --with-valgrind-dir=/X/root/usr/local/valgrind-3.13.0 --with-hwloc-dir=/X/root/usr/local/hwloc-1.11.9 --with-blaslapack-dir=/okyanus/progs/intel/compilers_and_libraries_2017.0.098/linu/X/mkl/lib/intel64
> [0]PETSC ERROR: #1 User provided function() line 0 in unknown file
> [10]PETSC ERROR: ------------------------------------------------------------------------
> [10]PETSC ERROR: Caught signal number 15 Terminate: Some process (or the batch system) has told this process to end
> [10]PETSC ERROR: Try option -start_in_debugger or -on_error_attach_debugger
> [10]PETSC ERROR: or see http://www.mcs.anl.gov/petsc/documentation/faq.html#valgrind
> [10]PETSC ERROR: or try http://valgrind.org on GNU/linu/X and Apple Mac OS /X to find memory corruption errors
> [10]PETSC ERROR: configure using --with-debugging=yes, recompile, link, and run
> [10]PETSC ERROR: to get more information on the crash.
> [10]PETSC ERROR: --------------------- Error Message --------------------------------------------------------------
> [10]PETSC ERROR: Signal received
> [10]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html for trouble shooting.
> [10]PETSC ERROR: Petsc Release Version 3.9.0, unknown
> [10]PETSC ERROR: ./dtest_pdslin on a named s054 by afarea Mon Apr 30 05:29:53 2018
> [8]PETSC ERROR: ./dtest_pdslin on a named s044 by afarea Mon Apr 30 05:29:53 2018
> [8]PETSC ERROR: Configure options PETSC_DIR=/X/petsc prefi/X=/X/petsc/petsc-install PETSC_ARCH=arch-real --with-debugging=0 --with-cc=/okyanus/progs/openmpi/openmpi-3.0.0-gcc-7.1.0/bin/mpicc --with-c/X/X=/okyanus/progs/openmpi/openmpi-3.0.0-gcc-7.1.0/bin/mpic/X/X --with-fc=/okyanus/progs/openmpi/openmpi-3.0.0-gcc-7.1.0/bin/mpif90 --with-valgrind=1 --with-valgrind-dir=/X/root/usr/local/valgrind-3.13.0 --with-hwloc-dir=/X/root/usr/local/hwloc-1.11.9 --with-blaslapack-dir=/okyanus/progs/intel/compilers_and_libraries_2017.0.098/linu/X/mkl/lib/intel64
> [8]PETSC ERROR: #1 User provided function() line 0 in unknown file
> [14]PETSC ERROR: ------------------------------------------------------------------------
> [14]PETSC ERROR: Caught signal number 15 Terminate: Some process (or the batch system) has told this process to end
> [14]PETSC ERROR: Try option -start_in_debugger or -on_error_attach_debugger
> [14]PETSC ERROR: or see http://www.mcs.anl.gov/petsc/documentation/faq.html#valgrind
> [14]PETSC ERROR: or try http://valgrind.org on GNU/linu/X and Apple Mac OS /X to find memory corruption errors
> [14]PETSC ERROR: configure using --with-debugging=yes, recompile, link, and run
> [14]PETSC ERROR: to get more information on the crash.
> [14]PETSC ERROR: --------------------- Error Message --------------------------------------------------------------
> [14]PETSC ERROR: Signal received
> [14]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html for trouble shooting.
> [14]PETSC ERROR: Petsc Release Version 3.9.0, unknown
> [14]PETSC ERROR: ./dtest_pdslin on a named s071 by afarea Mon Apr 30 05:29:53 2018
> [14]PETSC ERROR: Configure options PETSC_DIR=/X/petsc prefi/X=/X/petsc/petsc-install PETSC_ARCH=arch-real --with-debugging=0 --with-cc=/okyanus/progs/openmpi/openmpi-3.0.0-gcc-7.1.0/bin/mpicc --with-c/X/X=/okyanus/progs/openmpi/openmpi-3.0.0-gcc-7.1.0/bin/mpic/X/X --with-fc=/okyanus/progs/openmpi/openmpi-3.0.0-gcc-7.1.0/bin/mpif90 --with-valgrind=1 --with-valgrind-dir=/X/root/usr/local/valgrind-3.13.0 --with-hwloc-dir=/X/root/usr/local/hwloc-1.11.9 --with-blaslapack-dir=/okyanus/progs/intel/compilers_and_libraries_2017.0.098/linu/X/mkl/lib/intel64
> [14]PETSC ERROR: #1 User provided function() line 0 in unknown file
> [15]PETSC ERROR: Caught signal number 15 Terminate: Some process (or the batch system) has told this process to end
> [15]PETSC ERROR: or try http://valgrind.org on GNU/linu/X and Apple Mac OS /X to find memory corruption errors
> [15]PETSC ERROR: configure using --with-debugging=yes, recompile, link, and run
> [15]PETSC ERROR: #2 User provided function() line 0 in unknown file
> [2]PETSC ERROR: ------------------------------------------------------------------------
> [2]PETSC ERROR: Caught signal number 15 Terminate: Some process (or the batch system) has told this process to end
> [2]PETSC ERROR: Try option -start_in_debugger or -on_error_attach_debugger
> [2]PETSC ERROR: or see http://www.mcs.anl.gov/petsc/documentation/faq.html#valgrind
> [2]PETSC ERROR: or try http://valgrind.org on GNU/linu/X and Apple Mac OS /X to find memory corruption errors
> [2]PETSC ERROR: configure using --with-debugging=yes, recompile, link, and run
> [2]PETSC ERROR: to get more information on the crash.
> [2]PETSC ERROR: --------------------- Error Message --------------------------------------------------------------
> [2]PETSC ERROR: Signal received
> [2]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html for trouble shooting.
> [2]PETSC ERROR: Petsc Release Version 3.9.0, unknown
> [2]PETSC ERROR: ./dtest_pdslin on a named s034 by afarea Mon Apr 30 05:29:53 2018
> [2]PETSC ERROR: Configure options PETSC_DIR=/X/petsc prefi/X=/X/petsc/petsc-install PETSC_ARCH=arch-real --with-debugging=0 --with-cc=/okyanus/progs/openmpi/openmpi-3.0.0-gcc-7.1.0/bin/mpicc --with-c/X/X=/okyanus/progs/openmpi/openmpi-3.0.0-gcc-7.1.0/bin/mpic/X/X --with-fc=/okyanus/progs/openmpi/openmpi-3.0.0-gcc-7.1.0/bin/mpif90 --with-valgrind=1 --with-valgrind-dir=/X/root/usr/local/valgrind-3.13.0 --with-hwloc-dir=/X/root/usr/local/hwloc-1.11.9 --with-blaslapack-dir=/okyanus/progs/intel/compilers_and_libraries_2017.0.098/linu/X/mkl/lib/intel64
> [2]PETSC ERROR: #1 User provided function() line 0 in unknown file
> [3]PETSC ERROR: Caught signal number 15 Terminate: Some process (or the batch system) has told this process to end
> [3]PETSC ERROR: ./dtest_pdslin on a named s034 by afarea Mon Apr 30 05:29:53 2018
> [3]PETSC ERROR: #2 User provided function() line 0 in unknown file
> [f002:38724] 17 more processes have sent help message help-mpi-api.t/Xt / mpi-abort
> [f002:38724] Set MCA parameter "orte_base_help_aggregate" to 0 to see all help / error messages
> <Paudik_8_2_16.100234.out>
