[petsc-users] Finite difference Jacobian in TS context
    Matthew Knepley
    knepley at gmail.com
    Sun Apr 29 19:03:46 CDT 2018
On Sun, Apr 29, 2018 at 7:44 PM, Oleksandr Koshkarov <olk548 at mail.usask.ca>
wrote:
> Thank you. A little clarification:
>     The above uses matrix-free to do matrix-vector products for linear
>> system but constructs the preconditioner by building the Jacobian via
>> differencing and then using that matrix to build the preconditioner.
> So SNESComputeJacobianDefaultColor will use memory (construct Jacobian)
> even if preconditioning is set to PCNONE and J=NULL? (that is what I saw in
> my example)
1) SNESComputeJacobianDefaultColor() creates the Jacobian, fullstop.
2) When you pass J=NULL, the Jacobian is created automatically by DMDA
3) The PC has no influence on the assembly process.
>     This does not build the Jacobian (only has matrix free matrix vector
>> products) so requires much less memory but likely for large problem sizes
>> the linear system solve will be slow (require many iterations) or won't
>> converge at all.   The conditioning of the linear system depends on the
>> exact problem you are solving and the type of discretization you are using.
>> There is no easy rules that always apply but for most discretizations of
>> PDEs the number of iterations needed by the linear solver increases with
>> the problem sizes. This means for most large problems matrix-free (without
>> building any sort of jacobean and preconditioner) is impractical and one
>> needs to pay the price of using more memory to get reasonable convergence.
> So the following command  ignores precoditioning?
Ignore is the wrong word. How do you form a preconditioner from an object
with no values in it?
> Can I still use something like PCSHELL?
What exactly would you do in your shell? If you are only using the action
of an operator, it
usually equivalent to some Krylov method.
> SNESSetJacobian(snes,J,J,MatMFFDComputeJacobian,0);
> p.s. for my problems if probably be unrealistic to construct Jacobian
> (state size will start from N > 1000^4).
The number of dofs does not tell us anything. You would need to know the
sparsity. People regularly solve
problems with billions of unknowns.
     Matt
> Thank you,
> Oleksandr.
> On 04/29/2018 05:26 PM, Smith, Barry F. wrote:
>> On Apr 29, 2018, at 5:40 PM, Oleksandr Koshkarov <olk548 at mail.usask.ca>
>>> wrote:
>>> Dear All,
>>> sorry for spam because of my poor PETSc knowledge (I am just starting
>>> with this nice framework).
>>> I think, I figured part of it out. However, I want to point that
>>> src/ts/examples/tutorials/ex15.c is misleading. (or maybe it is a bug?)
>>> in this example we have
>>> TSGetSNES(ts,&snes);
>>> MatCreateSNESMF(snes,&Jmf);
>>> SNESSetJacobian(snes,Jmf,J,SNESComputeJacobianDefault,NULL);
>>> // or this: SNESSetJacobian(snes,Jmf,J,SNESComputeJacobianDefaultColor,
>>> 0);
>>> which implies (I think) that Jacobian would be matrix free. And if one
>>> would use PCNONE for preconditioning the matrix would never be allocated.
>>> However, it seems in reality it allocates matrix.
>> To avoid it, I used
>>> MatCreateSNESMF(snes,&J);
>>> which seems to work fine. I am not sure I fully understand the
>>> difference and i have zero intuition and I also have no idea what happens
>>> with preconditioning in this case. If someone have some useful comets,
>>> please share :) (I read the relevant section in PETSc manual, but still not
>>> fully understanding what I should use when)
>>    Barry
>> Thank you and again sorry for the spam,
>>> Oleksandr.
>>> On 04/28/2018 07:20 PM, Smith, Barry F. wrote:
>>>> ~/Src/petsc/src/ts/examples/tutorials
>>>> $ grep SNESComputeJacobianDefaultColor *.c
>>>> ex10.c:    ierr = SNESSetJacobian(snes,A,B,SNESC
>>>> omputeJacobianDefaultColor,0);CHKERRQ(ierr);
>>>> ex15.c:      ierr = SNESSetJacobian(snes,Jmf,J,SNE
>>>> SComputeJacobianDefaultColor,0);CHKERRQ(ierr);
>>>> ex17.c:    ierr = SNESSetJacobian(snes,J,J,SNESC
>>>>     I don't think you need to explicitly create the MatFDColoring
>>>> object.
>>>>     Please take a look at ex15.c and see if you can get it working like
>>>> that example. If that doesn't work let us know and we can take a closer
>>>> look at it.
>>>>     Barry
>>>> On Apr 28, 2018, at 8:05 PM, Oleksandr Koshkarov <olk548 at mail.usask.ca>
>>>>> wrote:
>>>>> Hello All,
>>>>> I hope someone can help :) I think I am doing something wrong, but
>>>>> cannot understand what. I have a huge time dependent system with 3d DMDA
>>>>> data structure and I am evolving it with explicit Runge-Kutta by using TS
>>>>> and basically only using "TSSetRHSFunction". Now I want to repeat it with
>>>>> implicit time stepper (for now Crank-Nicolson) and I am trying to provide
>>>>> finite difference Jacobian and I am failing miserably. I also cannot find
>>>>> appropriate example in PETSc tutorial (if you can point me to working
>>>>> example, it would be great).
>>>>> Here is my best attempt (what wrong with it?):
>>>>>    DMDACreate3d(PETSC_COMM_WORLD, DM_BOUNDARY_PERIODIC,
>>>>> DM_BOUNDARY_PERIODIC, DM_BOUNDARY_PERIODIC,
>>>>>             DMDA_STENCIL_STAR,
>>>>>             NX, NY, NZ,
>>>>>             PETSC_DECIDE, PETSC_DECIDE, PETSC_DECIDE,
>>>>>             2*3+NC*NS,
>>>>>             1,
>>>>>             NULL,  NULL, NULL,  &da);
>>>>>    DMSetUp(da);
>>>>>    DMCreateGlobalVector(da,&x);
>>>>>    TSCreate(PETSC_COMM_WORLD,&ts);
>>>>>    TSSetProblemType(ts,TS_NONLINEAR);
>>>>>    TSSetRHSFunction(ts,NULL,compute_RHS,NULL);
>>>>>    TSSetMaxTime(ts,T_FINAL);
>>>>>    TSSetExactFinalTime(ts,TS_EXACTFINALTIME_STEPOVER);
>>>>>    TSSetDM(ts,da);
>>>>>    TSSetType(ts,TSCN); //it works with: TSSetType(ts,TSRK);
>>>>>    set_IC(da,x);
>>>>>    TSSetTimeStep(ts,DT);
>>>>>    TSSetSolution(ts,x);
>>>>>    SNESGetKSP(snes,&ksp);
>>>>>    KSPGetPC(ksp,&pc);
>>>>>    PCSetType(pc,PCNONE);
>>>>>    DMSetMatType(da,MATAIJ);
>>>>>    DMCreateMatrix(da,&J);
>>>>>    ISColoring iscoloring;
>>>>>    MatFDColoring  matfdcoloring;
>>>>>    DMCreateColoring(da,IS_COLORING_GLOBAL,&iscoloring);
>>>>>    MatFDColoringCreate(J,iscoloring,&matfdcoloring);
>>>>>    MatFDColoringSetType(matfdcoloring,MATMFFD_DS);
>>>>> // I think I do something wrong in the following 3 lines
>>>>>    PetscErrorCode (*temp_f)(SNES,Vec,Vec,void*);
>>>>>    SNESGetFunction(snes,NULL,&temp_f,NULL);
>>>>>    MatFDColoringSetFunction(matfdcoloring,(PetscErrorCode
>>>>> (*)(void))temp_f,NULL);
>>>>>    MatFDColoringSetUp(J,iscoloring,matfdcoloring);
>>>>> SNESSetJacobian(snes,J,J,SNESComputeJacobianDefaultColor,
>>>>> matfdcoloring);
>>>>>    ISColoringDestroy(&iscoloring);
>>>>>    TSSolve(ts,x);
>>>>> Thank you,
>>>>> Oleksandr Koshkarov.
experiments lead.
-- Norbert Wiener
https://www.cse.buffalo.edu/~knepley/ <http://www.caam.rice.edu/~mk51/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20180429/6393acc2/attachment.html>
