[petsc-users] understanding gmres output
Ganesh Diwan
gcdiwan at gmail.com
Thu Apr 26 09:46:01 CDT 2018
Dear Petsc developers,
I am trying to learn to use PETSc GMRES with petsc4py and also trying to
follow the codes in petsc/src/ksp/ksp/examples/tutorials. Here is the
Python code I use to read a linear system and solve it with GMRES in PETSc
(petsc4py)
# gmrestest.py
# usual imports
import numpy as np
import scipy.io as sio
import scipy
from sys import getrefcount
from petsc4py import PETSc
# read the matrix data
mat_contents = sio.loadmat('data.mat')
mat_A = mat_contents['A']
vec_b = mat_contents['b']
n = mat_contents['n']
vec_x = mat_contents['x']
mat_nnzA = mat_contents['nnzA']
# form the petsc matrices
x = PETSc.Vec().createWithArray(vec_x)
b = PETSc.Vec().createWithArray(vec_b)
p1=mat_A.indptr
p2=mat_A.indices
p3=mat_A.data
A = PETSc.Mat().createAIJ(size=mat_A.shape,csr=(p1,p2,p3))
A = scipy.transpose(A) # transpose the csr format as my matrix is column
major originally
A.assemblyBegin()
A.assemblyEnd()
# solve
ksp = PETSc.KSP()
ksp.create(PETSc.COMM_WORLD)
ksp.setType('gmres')
ksp.setOperators(A)
ksp.setFromOptions()
rtol = 1e-4
ksp.setTolerances(rtol, 1e-5, 10000., 10000)
ksp.view()
ksp.setConvergenceHistory()
ksp.solve(b, x)
# print
print 'iterations = ', ksp.getIterationNumber()
print 'residual = ', '{:.2e}'.format(ksp.getResidualNorm())# %.2E
print 'norm(b)*rtol = ', '{:.2e}'.format(PETSc.Vec.norm(b)*rtol)# %.2E
print 'converge reason# = ', ksp.getConvergedReason()
print 'residuals at each iter = ', ksp.getConvergenceHistory()
Here is the output from the above code for a linear system of dimension 100
by 100.
KSP Object: 1 MPI processes
type: gmres
restart=30, using Classical (unmodified) Gram-Schmidt Orthogonalization
with no iterative refinement
happy breakdown tolerance 1e-30
maximum iterations=10000, initial guess is zero
tolerances: relative=0.0001, absolute=1e-05, divergence=10000.
left preconditioning
using DEFAULT norm type for convergence test
PC Object: 1 MPI processes
type: ilu
PC has not been set up so information may be incomplete
out-of-place factorization
0 levels of fill
tolerance for zero pivot 2.22045e-14
matrix ordering: natural
linear system matrix = precond matrix:
Mat Object: 1 MPI processes
type: seqaij
rows=100, cols=100
total: nonzeros=2704, allocated nonzeros=2704
total number of mallocs used during MatSetValues calls =0
using I-node routines: found 25 nodes, limit used is 5
iterations = 5
residual = 1.38e-03
norm(b)*rtol = 1.99e-01
converge reason# = 2
residuals at each iter = [ 2.05677686e+01 4.97916031e+00
4.82888782e-01 1.16849581e-01
8.87159777e-03 1.37992327e-03]
Sorry if this sounds stupid, but I am trying to understand the output from
PETSc by contrasting it with Matlab GMRES.
I see that the residual < norm(b)*rtol for the 4th iteration itself, I am
not sure then why GMRES continues for one more iteration. Secondly, how
does one get total number of iterations? For eg. let's say if it takes 3
outer iterations each with the default restart of 30, then one would expect
the length of residual vector to be 150. In the above specific example, it
took GMRES a total of 5 iterations to converge. Does it mean the
convergence was achieved without having to restart?
Thank you, Ganesh
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20180426/5c4f8d86/attachment.html>
