[petsc-users] configuration option for PETSc on cluster
Samuel Lanthaler
s.lanthaler at gmail.com
Tue Apr 24 02:26:51 CDT 2018
Hi there,
I was wondering if you could help me with the correct configuration of
PETSc-dev version on a cluster (https://www.cscs.ch/)? I'm not sure
which information would be useful to you, but basically the problem
seems to be in correctly compiling it with intel compiler and the
existing mkl library.
The pre-installed mkl version is
intel/17.0.4.196
I have tried various things and finally, I got it at least to compile
with the following options (options chosen in reference to the mkl link
advisor...):
./configure --with-fc=ftn --with-cc=cc --with-cxx=CC --with-debugging=0
--with-scalar-type=complex --download-scalapack --download-mumps=yes
--download-superlu --with-batch --known-mpi-shared-libraries=1
*--with-blaslapack-lib=*" ${MKLROOT}/lib/intel64/libmkl_blas95_lp64.a
${MKLROOT}/lib/intel64/libmkl_lapack95_lp64.a -Wl,--start-group
${MKLROOT}/lib/intel64/libmkl_intel_lp64.a
${MKLROOT}/lib/intel64/libmkl_sequential.a
${MKLROOT}/lib/intel64/libmkl_core.a -Wl,--end-group -lpthread -lm -ldl"
*--with-blaslapack-include*="[/opt/intel/compilers_and_libraries_2017.4.196/linux/mkl/include,/opt/intel/compilers_and_libraries_2017.4.196/linux/mkl/include/intel64/lp64]"
--known-64-bit-blas-indices=0
After compilation, when trying to compile
/users/lanthale/petsc-git/src/snes/examples/tutorials/ex5f I get linking
errors (attached). Would anyone be able to help me out here? I really
don't have a good understanding of this.
I'm attaching the configuration.log file, as well as the linking errors
when trying to compile ex5f.
Thank you very much in advance!
Best regards,
Samuel
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20180424/2d0f5508/attachment-0001.html>
ftn -c -O -I/users/lanthale/petsc-git/include -I/users/lanthale/petsc-git/arch-complex/include -I/opt/intel/compilers_and_libraries_2017.4.196/linux/mkl/include -I/opt/intel/compilers_and_libraries_2017.4.196/linux/mkl/include/intel64/lp64 -o ex5f.o ex5f.F90
ftn -O -o ex5f ex5f.o -L/users/lanthale/petsc-git/arch-complex/lib -Wl,-rpath,/users/lanthale/petsc-git/arch-complex/lib -Wl,-rpath,/opt/intel/compilers_and_libraries_2017.4.196/linux/mkl/lib/intel64 -L/opt/intel/compilers_and_libraries_2017.4.196/linux/mkl/lib/intel64 -Wl,--start-group -Wl,--end-group -lpetsc -lcmumps -ldmumps -lsmumps -lzmumps -lmumps_common -lpord -lscalapack -lsuperlu -lmkl_blas95_lp64 -lmkl_lapack95_lp64 -lmkl_intel_lp64 -lmkl_sequential -lmkl_core -lpthread -lm -ldl -lstdc++ -ldl
/users/lanthale/petsc-git/arch-complex/lib/libpetsc.a(dlimpl.o): In function `PetscDLOpen':
dlimpl.c:(.text+0x38): warning: Using 'dlopen' in statically linked applications requires at runtime the shared libraries from the glibc version used for linking
/users/lanthale/petsc-git/arch-complex/lib/libpetsc.a(send.o): In function `PetscOpenSocket':
send.c:(.text+0xcf): warning: Using 'gethostbyname' in statically linked applications requires at runtime the shared libraries from the glibc version used for linking
/opt/intel/compilers_and_libraries_2017.4.196/linux/mkl/lib/intel64/libmkl_core.a(zgeqrf_offload_thunks.o): In function `mkl_lapack_ao_zgeqrf':
zgeqrf_offload.c:(.text+0x9f): undefined reference to `mkl_lapack_ao_zgeqrf_hao'
/opt/intel/compilers_and_libraries_2017.4.196/linux/mkl/lib/intel64/libmkl_core.a(zpotrf_offload_thunks.o): In function `mkl_lapack_ao_zpotrf':
zpotrf_offload.c:(.text+0x76): undefined reference to `mkl_lapack_ao_zpotrf_hao'
/opt/intel/compilers_and_libraries_2017.4.196/linux/mkl/lib/intel64/libmkl_core.a(zgetrf_offload_thunks.o): In function `mkl_lapack_ao_zgetrf':
zgetrf_offload.c:(.text+0x89): undefined reference to `mkl_lapack_ao_zgetrf_hao'
/opt/intel/compilers_and_libraries_2017.4.196/linux/mkl/lib/intel64/libmkl_core.a(xzgeqrf.o): In function `mkl_lapack_xzgeqrf':
xzgeqrf_gen.f:(.text+0x246): undefined reference to `mkl_lapack_zgeqrf_pfnr'
/opt/intel/compilers_and_libraries_2017.4.196/linux/mkl/lib/intel64/libmkl_core.a(zsytrf.o): In function `mkl_lapack_zsytrf':
zsytrf_gen.f:(.text+0x35b): undefined reference to `mkl_lapack_zlasyf'
zsytrf_gen.f:(.text+0x5d1): undefined reference to `mkl_lapack_zlasyf'
/opt/intel/compilers_and_libraries_2017.4.196/linux/mkl/lib/intel64/libmkl_core.a(zsteqr.o): In function `mkl_lapack_zsteqr':
zsteqr_gen.f:(.text+0xd4e): undefined reference to `mkl_lapack_dlasr3'
zsteqr_gen.f:(.text+0x1300): undefined reference to `mkl_lapack_dlasr3'
zsteqr_gen.f:(.text+0x2138): undefined reference to `mkl_lapack_dlasr3'
zsteqr_gen.f:(.text+0x3206): undefined reference to `mkl_lapack_dlasr3'
zsteqr_gen.f:(.text+0x33a2): undefined reference to `mkl_lapack_dlasr3'
/opt/intel/compilers_and_libraries_2017.4.196/linux/mkl/lib/intel64/libmkl_core.a(zsteqr.o):zsteqr_gen.f:(.text+0x353d): more undefined references to `mkl_lapack_dlasr3' follow
zsteqr_gen.f:(.text+0x3938): undefined reference to `mkl_lapack_zlaset'
/opt/intel/compilers_and_libraries_2017.4.196/linux/mkl/lib/intel64/libmkl_core.a(zlaqrf.o): In function `mkl_lapack_zlaqrf':
zlaqrf_gen.f:(.text+0x19c): undefined reference to `mkl_lapack_zgeqrf_pf'
/opt/intel/compilers_and_libraries_2017.4.196/linux/mkl/lib/intel64/libmkl_core.a(zhetrf.o): In function `mkl_lapack_zhetrf':
zhetrf_gen.f:(.text+0x35b): undefined reference to `mkl_lapack_zlahef'
zhetrf_gen.f:(.text+0x5d1): undefined reference to `mkl_lapack_zlahef'
/opt/intel/compilers_and_libraries_2017.4.196/linux/mkl/lib/intel64/libmkl_core.a(zheevx.o): In function `mkl_lapack_zheevx':
zheevx_gen.f:(.text+0x664): undefined reference to `mkl_lapack_zlanhe'
zheevx_gen.f:(.text+0x8e9): undefined reference to `mkl_lapack_zhetrd'
zheevx_gen.f:(.text+0xa46): undefined reference to `mkl_lapack_zlacpy'
zheevx_gen.f:(.text+0xfef): undefined reference to `mkl_blas_dscal'
/opt/intel/compilers_and_libraries_2017.4.196/linux/mkl/lib/intel64/libmkl_core.a(zheev.o): In function `mkl_lapack_zheev':
zheev_gen.f:(.text+0x267): undefined reference to `mkl_lapack_zhetrd'
zheev_gen.f:(.text+0x4d2): undefined reference to `mkl_lapack_zlanhe'
zheev_gen.f:(.text+0x5f5): undefined reference to `mkl_lapack_zhetrd'
zheev_gen.f:(.text+0x78f): undefined reference to `mkl_blas_dscal'
/opt/intel/compilers_and_libraries_2017.4.196/linux/mkl/lib/intel64/libmkl_core.a(zgetrs.o): In function `mkl_lapack_zgetrs':
zgetrs_gen.f:(.text+0x2df): undefined reference to `mkl_lapack_zlaswp'
zgetrs_gen.f:(.text+0x31c): undefined reference to `mkl_lapack_zlaswp'
/opt/intel/compilers_and_libraries_2017.4.196/linux/mkl/lib/intel64/libmkl_core.a(zgesvd.o): In function `mkl_lapack_zgesvd':
zgesvd_gen.f:(.text+0xda2): undefined reference to `mkl_lapack_zgelqf'
zgesvd_gen.f:(.text+0xdef): undefined reference to `mkl_lapack_zunglq'
zgesvd_gen.f:(.text+0xe46): undefined reference to `mkl_lapack_zunglq'
zgesvd_gen.f:(.text+0x1720): undefined reference to `mkl_lapack_zlange'
zgesvd_gen.f:(.text+0x1903): undefined reference to `mkl_lapack_zlaset'
zgesvd_gen.f:(.text+0x1afa): undefined reference to `mkl_lapack_zlacpy'
zgesvd_gen.f:(.text+0x1c69): undefined reference to `mkl_lapack_zlacpy'
zgesvd_gen.f:(.text+0x1cc0): undefined reference to `mkl_lapack_zlaset'
zgesvd_gen.f:(.text+0x2025): undefined reference to `mkl_lapack_zlacpy'
zgesvd_gen.f:(.text+0x233e): undefined reference to `mkl_lapack_zlacpy'
zgesvd_gen.f:(.text+0x239f): undefined reference to `mkl_lapack_zlaset'
zgesvd_gen.f:(.text+0x2501): undefined reference to `mkl_lapack_zlacpy'
zgesvd_gen.f:(.text+0x27d9): undefined reference to `mkl_lapack_zlacpy'
zgesvd_gen.f:(.text+0x288d): undefined reference to `mkl_lapack_zlacpy'
zgesvd_gen.f:(.text+0x28ee): undefined reference to `mkl_lapack_zlaset'
zgesvd_gen.f:(.text+0x2cf4): undefined reference to `mkl_lapack_zlacpy'
zgesvd_gen.f:(.text+0x2d4b): undefined reference to `mkl_lapack_zlaset'
zgesvd_gen.f:(.text+0x3062): undefined reference to `mkl_lapack_zlacpy'
zgesvd_gen.f:(.text+0x3133): undefined reference to `mkl_lapack_zlaset'
zgesvd_gen.f:(.text+0x3449): undefined reference to `mkl_lapack_zlacpy'
zgesvd_gen.f:(.text+0x34a0): undefined reference to `mkl_lapack_zlaset'
zgesvd_gen.f:(.text+0x3601): undefined reference to `mkl_lapack_zlacpy'
zgesvd_gen.f:(.text+0x381c): undefined reference to `mkl_lapack_zlacpy'
zgesvd_gen.f:(.text+0x38b0): undefined reference to `mkl_lapack_zlacpy'
zgesvd_gen.f:(.text+0x3981): undefined reference to `mkl_lapack_zlaset'
zgesvd_gen.f:(.text+0x3ca6): undefined reference to `mkl_lapack_zlacpy'
zgesvd_gen.f:(.text+0x3cfd): undefined reference to `mkl_lapack_zlaset'
zgesvd_gen.f:(.text+0x3e4e): undefined reference to `mkl_lapack_zlacpy'
zgesvd_gen.f:(.text+0x40d2): undefined reference to `mkl_lapack_zlacpy'
zgesvd_gen.f:(.text+0x416b): undefined reference to `mkl_lapack_zlacpy'
zgesvd_gen.f:(.text+0x41cb): undefined reference to `mkl_lapack_zlaset'
zgesvd_gen.f:(.text+0x4543): undefined reference to `mkl_lapack_zlacpy'
zgesvd_gen.f:(.text+0x4575): undefined reference to `mkl_lapack_zlacpy'
zgesvd_gen.f:(.text+0x45cc): undefined reference to `mkl_lapack_zlaset'
zgesvd_gen.f:(.text+0x4889): undefined reference to `mkl_lapack_zlacpy'
zgesvd_gen.f:(.text+0x491f): undefined reference to `mkl_lapack_zlacpy'
zgesvd_gen.f:(.text+0x49f0): undefined reference to `mkl_lapack_zlaset'
zgesvd_gen.f:(.text+0x4d17): undefined reference to `mkl_lapack_zlacpy'
zgesvd_gen.f:(.text+0x4daf): undefined reference to `mkl_lapack_zlacpy'
zgesvd_gen.f:(.text+0x4e06): undefined reference to `mkl_lapack_zlaset'
zgesvd_gen.f:(.text+0x4f06): undefined reference to `mkl_lapack_zlacpy'
zgesvd_gen.f:(.text+0x5128): undefined reference to `mkl_lapack_zlacpy'
zgesvd_gen.f:(.text+0x5151): undefined reference to `mkl_lapack_zlacpy'
zgesvd_gen.f:(.text+0x51e7): undefined reference to `mkl_lapack_zlacpy'
zgesvd_gen.f:(.text+0x52b8): undefined reference to `mkl_lapack_zlaset'
zgesvd_gen.f:(.text+0x55df): undefined reference to `mkl_lapack_zlacpy'
zgesvd_gen.f:(.text+0x5674): undefined reference to `mkl_lapack_zlacpy'
zgesvd_gen.f:(.text+0x56cb): undefined reference to `mkl_lapack_zlaset'
zgesvd_gen.f:(.text+0x57b8): undefined reference to `mkl_lapack_zlacpy'
zgesvd_gen.f:(.text+0x59dd): undefined reference to `mkl_lapack_zlacpy'
zgesvd_gen.f:(.text+0x5a67): undefined reference to `mkl_lapack_zlacpy'
zgesvd_gen.f:(.text+0x5afd): undefined reference to `mkl_lapack_zlacpy'
zgesvd_gen.f:(.text+0x5b50): undefined reference to `mkl_lapack_zlaset'
zgesvd_gen.f:(.text+0x5ffc): undefined reference to `mkl_lapack_zlacpy'
zgesvd_gen.f:(.text+0x60f2): undefined reference to `mkl_lapack_zlacpy'
zgesvd_gen.f:(.text+0x64e0): undefined reference to `mkl_lapack_zgelqf'
zgesvd_gen.f:(.text+0x6541): undefined reference to `mkl_lapack_zlaset'
zgesvd_gen.f:(.text+0x6893): undefined reference to `mkl_lapack_zlacpy'
zgesvd_gen.f:(.text+0x6a05): undefined reference to `mkl_lapack_zgelqf'
zgesvd_gen.f:(.text+0x6a37): undefined reference to `mkl_lapack_zlacpy'
zgesvd_gen.f:(.text+0x6a96): undefined reference to `mkl_lapack_zlaset'
zgesvd_gen.f:(.text+0x6afc): undefined reference to `mkl_lapack_zunglq'
zgesvd_gen.f:(.text+0x6e13): undefined reference to `mkl_lapack_zlacpy'
zgesvd_gen.f:(.text+0x711c): undefined reference to `mkl_lapack_zgelqf'
zgesvd_gen.f:(.text+0x714c): undefined reference to `mkl_lapack_zlacpy'
zgesvd_gen.f:(.text+0x71b6): undefined reference to `mkl_lapack_zlaset'
zgesvd_gen.f:(.text+0x721c): undefined reference to `mkl_lapack_zunglq'
zgesvd_gen.f:(.text+0x731d): undefined reference to `mkl_lapack_zlacpy'
zgesvd_gen.f:(.text+0x75eb): undefined reference to `mkl_lapack_zlacpy'
zgesvd_gen.f:(.text+0x7674): undefined reference to `mkl_lapack_zgelqf'
zgesvd_gen.f:(.text+0x76a4): undefined reference to `mkl_lapack_zlacpy'
zgesvd_gen.f:(.text+0x770e): undefined reference to `mkl_lapack_zlaset'
zgesvd_gen.f:(.text+0x7770): undefined reference to `mkl_lapack_zunglq'
zgesvd_gen.f:(.text+0x7adc): undefined reference to `mkl_lapack_zgelqf'
zgesvd_gen.f:(.text+0x7b0e): undefined reference to `mkl_lapack_zlacpy'
zgesvd_gen.f:(.text+0x7b6d): undefined reference to `mkl_lapack_zlaset'
zgesvd_gen.f:(.text+0x7bd3): undefined reference to `mkl_lapack_zunglq'
zgesvd_gen.f:(.text+0x7e5a): undefined reference to `mkl_lapack_zgelqf'
zgesvd_gen.f:(.text+0x7e8a): undefined reference to `mkl_lapack_zlacpy'
zgesvd_gen.f:(.text+0x7ef1): undefined reference to `mkl_lapack_zunglq'
zgesvd_gen.f:(.text+0x7f6c): undefined reference to `mkl_lapack_zlaset'
zgesvd_gen.f:(.text+0x8263): undefined reference to `mkl_lapack_zgelqf'
zgesvd_gen.f:(.text+0x8295): undefined reference to `mkl_lapack_zlacpy'
zgesvd_gen.f:(.text+0x82f4): undefined reference to `mkl_lapack_zlaset'
zgesvd_gen.f:(.text+0x8358): undefined reference to `mkl_lapack_zunglq'
zgesvd_gen.f:(.text+0x845e): undefined reference to `mkl_lapack_zlacpy'
zgesvd_gen.f:(.text+0x867c): undefined reference to `mkl_lapack_zlacpy'
zgesvd_gen.f:(.text+0x86df): undefined reference to `mkl_lapack_zgelqf'
zgesvd_gen.f:(.text+0x870f): undefined reference to `mkl_lapack_zlacpy'
zgesvd_gen.f:(.text+0x8776): undefined reference to `mkl_lapack_zunglq'
zgesvd_gen.f:(.text+0x87f1): undefined reference to `mkl_lapack_zlaset'
zgesvd_gen.f:(.text+0x8ae5): undefined reference to `mkl_lapack_zgelqf'
zgesvd_gen.f:(.text+0x8b17): undefined reference to `mkl_lapack_zlacpy'
zgesvd_gen.f:(.text+0x8b76): undefined reference to `mkl_lapack_zlaset'
zgesvd_gen.f:(.text+0x8bda): undefined reference to `mkl_lapack_zunglq'
zgesvd_gen.f:(.text+0x8cd1): undefined reference to `mkl_lapack_zlacpy'
zgesvd_gen.f:(.text+0x8f29): undefined reference to `mkl_lapack_zgelqf'
zgesvd_gen.f:(.text+0x8f59): undefined reference to `mkl_lapack_zlacpy'
zgesvd_gen.f:(.text+0x8fc0): undefined reference to `mkl_lapack_zunglq'
zgesvd_gen.f:(.text+0x8ff0): undefined reference to `mkl_lapack_zlacpy'
zgesvd_gen.f:(.text+0x905a): undefined reference to `mkl_lapack_zlaset'
zgesvd_gen.f:(.text+0x93b3): undefined reference to `mkl_lapack_zgelqf'
zgesvd_gen.f:(.text+0x93e3): undefined reference to `mkl_lapack_zlacpy'
zgesvd_gen.f:(.text+0x9415): undefined reference to `mkl_lapack_zlacpy'
zgesvd_gen.f:(.text+0x9474): undefined reference to `mkl_lapack_zlaset'
zgesvd_gen.f:(.text+0x94d8): undefined reference to `mkl_lapack_zunglq'
zgesvd_gen.f:(.text+0x973a): undefined reference to `mkl_lapack_zlacpy'
zgesvd_gen.f:(.text+0x979d): undefined reference to `mkl_lapack_zgelqf'
zgesvd_gen.f:(.text+0x97cd): undefined reference to `mkl_lapack_zlacpy'
zgesvd_gen.f:(.text+0x9834): undefined reference to `mkl_lapack_zunglq'
zgesvd_gen.f:(.text+0x98aa): undefined reference to `mkl_lapack_zlaset'
zgesvd_gen.f:(.text+0x9baf): undefined reference to `mkl_lapack_zgelqf'
zgesvd_gen.f:(.text+0x9bdf): undefined reference to `mkl_lapack_zlacpy'
zgesvd_gen.f:(.text+0x9c43): undefined reference to `mkl_lapack_zunglq'
zgesvd_gen.f:(.text+0x9c75): undefined reference to `mkl_lapack_zlacpy'
zgesvd_gen.f:(.text+0x9cd4): undefined reference to `mkl_lapack_zlaset'
zgesvd_gen.f:(.text+0x9ddb): undefined reference to `mkl_lapack_zlacpy'
zgesvd_gen.f:(.text+0x9ff5): undefined reference to `mkl_lapack_zlacpy'
zgesvd_gen.f:(.text+0xa01f): undefined reference to `mkl_lapack_zlacpy'
zgesvd_gen.f:(.text+0xa082): undefined reference to `mkl_lapack_zgelqf'
zgesvd_gen.f:(.text+0xa0b2): undefined reference to `mkl_lapack_zlacpy'
zgesvd_gen.f:(.text+0xa119): undefined reference to `mkl_lapack_zunglq'
zgesvd_gen.f:(.text+0xa196): undefined reference to `mkl_lapack_zlaset'
zgesvd_gen.f:(.text+0xa49c): undefined reference to `mkl_lapack_zgelqf'
zgesvd_gen.f:(.text+0xa4cc): undefined reference to `mkl_lapack_zlacpy'
zgesvd_gen.f:(.text+0xa52d): undefined reference to `mkl_lapack_zunglq'
zgesvd_gen.f:(.text+0xa55f): undefined reference to `mkl_lapack_zlacpy'
zgesvd_gen.f:(.text+0xa5b8): undefined reference to `mkl_lapack_zlaset'
zgesvd_gen.f:(.text+0xa6ab): undefined reference to `mkl_lapack_zlacpy'
zgesvd_gen.f:(.text+0xa8d5): undefined reference to `mkl_lapack_zlacpy'
zgesvd_gen.f:(.text+0xa933): undefined reference to `mkl_lapack_zgelqf'
zgesvd_gen.f:(.text+0xa963): undefined reference to `mkl_lapack_zlacpy'
zgesvd_gen.f:(.text+0xa9c4): undefined reference to `mkl_lapack_zunglq'
zgesvd_gen.f:(.text+0xa9f4): undefined reference to `mkl_lapack_zlacpy'
zgesvd_gen.f:(.text+0xaa5e): undefined reference to `mkl_lapack_zlaset'
zgesvd_gen.f:(.text+0xaeff): undefined reference to `mkl_lapack_zlacpy'
zgesvd_gen.f:(.text+0xafc2): undefined reference to `mkl_lapack_zlacpy'
/opt/intel/compilers_and_libraries_2017.4.196/linux/mkl/lib/intel64/libmkl_core.a(zgerdb.o): In function `mkl_lapack_zgerdb':
zgerdb_gen.f:(.text+0x449): undefined reference to `mkl_lapack_zgbbrdm'
zgerdb_gen.f:(.text+0x666): undefined reference to `mkl_lapack_zlaset'
zgerdb_gen.f:(.text+0x6a9): undefined reference to `mkl_lapack_zlaset'
zgerdb_gen.f:(.text+0xf9d): undefined reference to `mkl_lapack_zunmlq'
zgerdb_gen.f:(.text+0x1030): undefined reference to `mkl_lapack_zlaset'
zgerdb_gen.f:(.text+0x1096): undefined reference to `mkl_lapack_zlaset'
zgerdb_gen.f:(.text+0x120f): undefined reference to `mkl_lapack_zgbbrdm'
/opt/intel/compilers_and_libraries_2017.4.196/linux/mkl/lib/intel64/libmkl_core.a(zgelss.o): In function `mkl_lapack_zgelss':
zgelss_gen.f:(.text+0x529): undefined reference to `mkl_lapack_zgelqf'
zgelss_gen.f:(.text+0x714): undefined reference to `mkl_lapack_zunmlq'
zgelss_gen.f:(.text+0xa7b): undefined reference to `mkl_lapack_zlange'
zgelss_gen.f:(.text+0xbc7): undefined reference to `mkl_lapack_zlaset'
zgelss_gen.f:(.text+0xbf9): undefined reference to `mkl_lapack_dlaset'
zgelss_gen.f:(.text+0xca8): undefined reference to `mkl_lapack_zlange'
zgelss_gen.f:(.text+0xf7e): undefined reference to `mkl_lapack_zlaset'
zgelss_gen.f:(.text+0x1311): undefined reference to `mkl_lapack_zlaset'
zgelss_gen.f:(.text+0x137c): undefined reference to `mkl_lapack_zlaset'
zgelss_gen.f:(.text+0x144e): undefined reference to `mkl_lapack_zlaset'
zgelss_gen.f:(.text+0x1527): undefined reference to `mkl_lapack_zlacpy'
zgelss_gen.f:(.text+0x16f8): undefined reference to `mkl_lapack_zlacpy'
zgelss_gen.f:(.text+0x17e0): undefined reference to `mkl_lapack_zgelqf'
zgelss_gen.f:(.text+0x1807): undefined reference to `mkl_lapack_zlacpy'
zgelss_gen.f:(.text+0x1861): undefined reference to `mkl_lapack_zlaset'
zgelss_gen.f:(.text+0x1c17): undefined reference to `mkl_lapack_zlaset'
zgelss_gen.f:(.text+0x1c7e): undefined reference to `mkl_lapack_zlaset'
zgelss_gen.f:(.text+0x1d54): undefined reference to `mkl_lapack_zlaset'
zgelss_gen.f:(.text+0x1e81): undefined reference to `mkl_lapack_zlacpy'
zgelss_gen.f:(.text+0x207f): undefined reference to `mkl_lapack_zlacpy'
zgelss_gen.f:(.text+0x2113): undefined reference to `mkl_lapack_zlaset'
zgelss_gen.f:(.text+0x21b7): undefined reference to `mkl_lapack_zunmlq'
zgelss_gen.f:(.text+0x252c): undefined reference to `mkl_lapack_zlaset'
zgelss_gen.f:(.text+0x2599): undefined reference to `mkl_lapack_zlaset'
zgelss_gen.f:(.text+0x2670): undefined reference to `mkl_lapack_zlaset'
zgelss_gen.f:(.text+0x2748): undefined reference to `mkl_lapack_zlacpy'
zgelss_gen.f:(.text+0x2925): undefined reference to `mkl_lapack_zlacpy'
/opt/intel/compilers_and_libraries_2017.4.196/linux/mkl/lib/intel64/libmkl_core.a(zgels.o): In function `mkl_lapack_zgels':
zgels_gen.f:(.text+0x4a7): undefined reference to `mkl_lapack_zlaset'
zgels_gen.f:(.text+0x564): undefined reference to `mkl_lapack_zlange'
zgels_gen.f:(.text+0x74b): undefined reference to `mkl_lapack_zlange'
zgels_gen.f:(.text+0xbc6): undefined reference to `mkl_lapack_zgelqf'
zgels_gen.f:(.text+0xc95): undefined reference to `mkl_lapack_zunmlq'
zgels_gen.f:(.text+0xe44): undefined reference to `mkl_lapack_zlaset'
zgels_gen.f:(.text+0x142d): undefined reference to `mkl_lapack_zunmlq'
/opt/intel/compilers_and_libraries_2017.4.196/linux/mkl/lib/intel64/libmkl_core.a(zgeev.o): In function `mkl_lapack_zgeev':
zgeev_gen.f:(.text+0x67f): undefined reference to `mkl_lapack_zlange'
zgeev_gen.f:(.text+0x82d): undefined reference to `mkl_lapack_zlacpy'
zgeev_gen.f:(.text+0x989): undefined reference to `mkl_lapack_zlacpy'
zgeev_gen.f:(.text+0x9ce): undefined reference to `mkl_lapack_zlacpy'
/opt/intel/compilers_and_libraries_2017.4.196/linux/mkl/lib/intel64/libmkl_core.a(zgebrd.o): In function `mkl_lapack_zgebrd':
zgebrd_gen.f:(.text+0x4ef): undefined reference to `mkl_lapack_zlabrd'
/opt/intel/compilers_and_libraries_2017.4.196/linux/mkl/lib/intel64/libmkl_core.a(zgbbrd.o): In function `mkl_lapack_zgbbrd':
zgbbrd_gen.f:(.text+0x2fb): undefined reference to `mkl_lapack_zlaset'
zgbbrd_gen.f:(.text+0x33b): undefined reference to `mkl_lapack_zlaset'
/opt/intel/compilers_and_libraries_2017.4.196/linux/mkl/lib/intel64/libmkl_core.a(zbdsqr.o): In function `mkl_lapack_zbdsqr':
zbdsqr_gen.f:(.text+0xcde): undefined reference to `mkl_lapack_dlasr3'
zbdsqr_gen.f:(.text+0xdd4): undefined reference to `mkl_lapack_dlasr3'
zbdsqr_gen.f:(.text+0xee0): undefined reference to `mkl_lapack_dlasr3'
zbdsqr_gen.f:(.text+0x1224): undefined reference to `mkl_lapack_dlasr3'
zbdsqr_gen.f:(.text+0x133c): undefined reference to `mkl_lapack_dlasr3'
/opt/intel/compilers_and_libraries_2017.4.196/linux/mkl/lib/intel64/libmkl_core.a(zbdsqr.o):zbdsqr_gen.f:(.text+0x1464): more undefined references to `mkl_lapack_dlasr3' follow
/opt/intel/compilers_and_libraries_2017.4.196/linux/mkl/lib/intel64/libmkl_core.a(zgerb2m.o): In function `mkl_lapack_zgerb2m':
zgerb2m_gen.f:(.text+0x156): undefined reference to `mkl_lapack_zgeqrf_pf'
zgerb2m_gen.f:(.text+0x181): undefined reference to `mkl_lapack_zlacpy'
zgerb2m_gen.f:(.text+0x1ac): undefined reference to `mkl_lapack_zlacpy'
zgerb2m_gen.f:(.text+0x438): undefined reference to `mkl_lapack_zgelqf_pf'
zgerb2m_gen.f:(.text+0x463): undefined reference to `mkl_lapack_zlacpy'
zgerb2m_gen.f:(.text+0x498): undefined reference to `mkl_lapack_zlacpy'
zgerb2m_gen.f:(.text+0x71a): undefined reference to `mkl_lapack_zlacpy'
zgerb2m_gen.f:(.text+0x8ad): undefined reference to `mkl_lapack_zlacpy'
/opt/intel/compilers_and_libraries_2017.4.196/linux/mkl/lib/intel64/libmkl_core.a(zgetrf_local.o): In function `mkl_lapack_zgetrf_local':
zgetrf_local.c:(.text+0x48e): undefined reference to `mkl_lapack_zlaswp'
zgetrf_local.c:(.text+0x4f9): undefined reference to `mkl_lapack_zlaswp'
/opt/intel/compilers_and_libraries_2017.4.196/linux/mkl/lib/intel64/libmkl_core.a(xspmm_r_s_i4_avx512_mic.o): In function `mkl_sparse_s_do_spmm_i4_avx512_mic':
xspmm.c:(.text+0x400): undefined reference to `mkl_sparse_s_csr__g_n_spmm_i4'
xspmm.c:(.text+0x5aa): undefined reference to `mkl_sparse_s_bsr__g_n_spmm_i4'
/opt/intel/compilers_and_libraries_2017.4.196/linux/mkl/lib/intel64/libmkl_core.a(optimize_r_s_i4_avx512_mic.o): In function `mkl_sparse_optimize_i4_avx512_mic':
optimize.c:(.text+0xd0): undefined reference to `mkl_sparse_copy_sparse_matrix_i4'
/opt/intel/compilers_and_libraries_2017.4.196/linux/mkl/lib/intel64/libmkl_core.a(hints_r_s_i4_avx512_mic.o): In function `mkl_sparse_set_mv_hint_i4_avx512_mic':
hints.c:(.text+0xe8): undefined reference to `mkl_sparse_optimize_csr_mv_i4'
hints.c:(.text+0xfa): undefined reference to `mkl_sparse_optimize_bsr_mv_i4'
/opt/intel/compilers_and_libraries_2017.4.196/linux/mkl/lib/intel64/libmkl_core.a(hints_r_s_i4_avx512_mic.o): In function `mkl_sparse_set_mm_hint_i4_avx512_mic':
hints.c:(.text+0x372): undefined reference to `mkl_sparse_optimize_csr_mm_i4'
hints.c:(.text+0x383): undefined reference to `mkl_sparse_optimize_bsr_mm_i4'
/opt/intel/compilers_and_libraries_2017.4.196/linux/mkl/lib/intel64/libmkl_core.a(hints_r_s_i4_avx512_mic.o): In function `mkl_sparse_set_sv_hint_i4_avx512_mic':
hints.c:(.text+0x5f8): undefined reference to `mkl_sparse_optimize_csr_trsv_i4'
hints.c:(.text+0x60a): undefined reference to `mkl_sparse_optimize_bsr_trsv_i4'
/opt/intel/compilers_and_libraries_2017.4.196/linux/mkl/lib/intel64/libmkl_core.a(hints_r_s_i4_avx512_mic.o): In function `mkl_sparse_set_sm_hint_i4_avx512_mic':
hints.c:(.text+0x884): undefined reference to `mkl_sparse_optimize_bsr_trsm_i4'
/opt/intel/compilers_and_libraries_2017.4.196/linux/mkl/lib/intel64/libmkl_core.a(xspmm_r_d_i4_avx512_mic.o): In function `mkl_sparse_d_do_spmm_i4_avx512_mic':
xspmm.c:(.text+0x3a0): undefined reference to `mkl_sparse_d_csr__g_n_spmm_i4'
xspmm.c:(.text+0x54a): undefined reference to `mkl_sparse_d_bsr__g_n_spmm_i4'
/opt/intel/compilers_and_libraries_2017.4.196/linux/mkl/lib/intel64/libmkl_core.a(xspmm_c_s_i4_avx512_mic.o): In function `mkl_sparse_c_do_spmm_i4_avx512_mic':
xspmm.c:(.text+0x3a0): undefined reference to `mkl_sparse_c_csr__g_n_spmm_i4'
xspmm.c:(.text+0x54e): undefined reference to `mkl_sparse_c_bsr__g_n_spmm_i4'
/opt/intel/compilers_and_libraries_2017.4.196/linux/mkl/lib/intel64/libmkl_core.a(xspmm_c_d_i4_avx512_mic.o): In function `mkl_sparse_z_do_spmm_i4_avx512_mic':
xspmm.c:(.text+0x3a0): undefined reference to `mkl_sparse_z_csr__g_n_spmm_i4'
xspmm.c:(.text+0x54e): undefined reference to `mkl_sparse_z_bsr__g_n_spmm_i4'
/opt/intel/compilers_and_libraries_2017.4.196/linux/mkl/lib/intel64/libmkl_core.a(xspmm_r_s_i4_avx512.o): In function `mkl_sparse_s_do_spmm_i4_avx512':
xspmm.c:(.text+0x35d): undefined reference to `mkl_sparse_s_csr__g_n_spmm_i4'
xspmm.c:(.text+0x4fa): undefined reference to `mkl_sparse_s_bsr__g_n_spmm_i4'
/opt/intel/compilers_and_libraries_2017.4.196/linux/mkl/lib/intel64/libmkl_core.a(optimize_r_s_i4_avx512.o): In function `mkl_sparse_optimize_i4_avx512':
optimize.c:(.text+0xbf): undefined reference to `mkl_sparse_copy_sparse_matrix_i4'
/opt/intel/compilers_and_libraries_2017.4.196/linux/mkl/lib/intel64/libmkl_core.a(hints_r_s_i4_avx512.o): In function `mkl_sparse_set_mv_hint_i4_avx512':
hints.c:(.text+0xd0): undefined reference to `mkl_sparse_optimize_csr_mv_i4'
hints.c:(.text+0xdf): undefined reference to `mkl_sparse_optimize_bsr_mv_i4'
/opt/intel/compilers_and_libraries_2017.4.196/linux/mkl/lib/intel64/libmkl_core.a(hints_r_s_i4_avx512.o): In function `mkl_sparse_set_mm_hint_i4_avx512':
hints.c:(.text+0x32e): undefined reference to `mkl_sparse_optimize_csr_mm_i4'
hints.c:(.text+0x33c): undefined reference to `mkl_sparse_optimize_bsr_mm_i4'
/opt/intel/compilers_and_libraries_2017.4.196/linux/mkl/lib/intel64/libmkl_core.a(hints_r_s_i4_avx512.o): In function `mkl_sparse_set_sv_hint_i4_avx512':
hints.c:(.text+0x580): undefined reference to `mkl_sparse_optimize_csr_trsv_i4'
hints.c:(.text+0x58f): undefined reference to `mkl_sparse_optimize_bsr_trsv_i4'
/opt/intel/compilers_and_libraries_2017.4.196/linux/mkl/lib/intel64/libmkl_core.a(hints_r_s_i4_avx512.o): In function `mkl_sparse_set_sm_hint_i4_avx512':
hints.c:(.text+0x7dc): undefined reference to `mkl_sparse_optimize_bsr_trsm_i4'
/opt/intel/compilers_and_libraries_2017.4.196/linux/mkl/lib/intel64/libmkl_core.a(xspmm_r_d_i4_avx512.o): In function `mkl_sparse_d_do_spmm_i4_avx512':
xspmm.c:(.text+0x2fd): undefined reference to `mkl_sparse_d_csr__g_n_spmm_i4'
xspmm.c:(.text+0x494): undefined reference to `mkl_sparse_d_bsr__g_n_spmm_i4'
/opt/intel/compilers_and_libraries_2017.4.196/linux/mkl/lib/intel64/libmkl_core.a(xspmm_c_s_i4_avx512.o): In function `mkl_sparse_c_do_spmm_i4_avx512':
xspmm.c:(.text+0x2fd): undefined reference to `mkl_sparse_c_csr__g_n_spmm_i4'
xspmm.c:(.text+0x49e): undefined reference to `mkl_sparse_c_bsr__g_n_spmm_i4'
/opt/intel/compilers_and_libraries_2017.4.196/linux/mkl/lib/intel64/libmkl_core.a(xspmm_c_d_i4_avx512.o): In function `mkl_sparse_z_do_spmm_i4_avx512':
xspmm.c:(.text+0x2fd): undefined reference to `mkl_sparse_z_csr__g_n_spmm_i4'
xspmm.c:(.text+0x49e): undefined reference to `mkl_sparse_z_bsr__g_n_spmm_i4'
/opt/intel/compilers_and_libraries_2017.4.196/linux/mkl/lib/intel64/libmkl_core.a(xspmm_r_s_i4_avx2.o): In function `mkl_sparse_s_do_spmm_i4_avx2':
xspmm.c:(.text+0x357): undefined reference to `mkl_sparse_s_csr__g_n_spmm_i4'
xspmm.c:(.text+0x4e8): undefined reference to `mkl_sparse_s_bsr__g_n_spmm_i4'
/opt/intel/compilers_and_libraries_2017.4.196/linux/mkl/lib/intel64/libmkl_core.a(optimize_r_s_i4_avx2.o): In function `mkl_sparse_optimize_i4_avx2':
/opt/intel/compilers_and_libraries_2017.4.196/linux/mkl/lib/intel64/libmkl_core.a(hints_r_s_i4_avx2.o): In function `mkl_sparse_set_mv_hint_i4_avx2':
hints.c:(.text+0xcd): undefined reference to `mkl_sparse_optimize_csr_mv_i4'
hints.c:(.text+0xdc): undefined reference to `mkl_sparse_optimize_bsr_mv_i4'
/opt/intel/compilers_and_libraries_2017.4.196/linux/mkl/lib/intel64/libmkl_core.a(hints_r_s_i4_avx2.o): In function `mkl_sparse_set_mm_hint_i4_avx2':
hints.c:(.text+0x33b): undefined reference to `mkl_sparse_optimize_csr_mm_i4'
hints.c:(.text+0x349): undefined reference to `mkl_sparse_optimize_bsr_mm_i4'
/opt/intel/compilers_and_libraries_2017.4.196/linux/mkl/lib/intel64/libmkl_core.a(hints_r_s_i4_avx2.o): In function `mkl_sparse_set_sv_hint_i4_avx2':
hints.c:(.text+0x58d): undefined reference to `mkl_sparse_optimize_csr_trsv_i4'
hints.c:(.text+0x59c): undefined reference to `mkl_sparse_optimize_bsr_trsv_i4'
/opt/intel/compilers_and_libraries_2017.4.196/linux/mkl/lib/intel64/libmkl_core.a(hints_r_s_i4_avx2.o): In function `mkl_sparse_set_sm_hint_i4_avx2':
hints.c:(.text+0x7f9): undefined reference to `mkl_sparse_optimize_bsr_trsm_i4'
/opt/intel/compilers_and_libraries_2017.4.196/linux/mkl/lib/intel64/libmkl_core.a(xspmm_r_d_i4_avx2.o): In function `mkl_sparse_d_do_spmm_i4_avx2':
xspmm.c:(.text+0x2f7): undefined reference to `mkl_sparse_d_csr__g_n_spmm_i4'
xspmm.c:(.text+0x485): undefined reference to `mkl_sparse_d_bsr__g_n_spmm_i4'
/opt/intel/compilers_and_libraries_2017.4.196/linux/mkl/lib/intel64/libmkl_core.a(xspmm_c_s_i4_avx2.o): In function `mkl_sparse_c_do_spmm_i4_avx2':
xspmm.c:(.text+0x2f7): undefined reference to `mkl_sparse_c_csr__g_n_spmm_i4'
xspmm.c:(.text+0x48c): undefined reference to `mkl_sparse_c_bsr__g_n_spmm_i4'
/opt/intel/compilers_and_libraries_2017.4.196/linux/mkl/lib/intel64/libmkl_core.a(xspmm_c_d_i4_avx2.o): In function `mkl_sparse_z_do_spmm_i4_avx2':
xspmm.c:(.text+0x2f7): undefined reference to `mkl_sparse_z_csr__g_n_spmm_i4'
xspmm.c:(.text+0x48c): undefined reference to `mkl_sparse_z_bsr__g_n_spmm_i4'
/opt/intel/compilers_and_libraries_2017.4.196/linux/mkl/lib/intel64/libmkl_core.a(xspmm_r_s_i4_avx.o): In function `mkl_sparse_s_do_spmm_i4_avx':
xspmm.c:(.text+0x336): undefined reference to `mkl_sparse_s_csr__g_n_spmm_i4'
xspmm.c:(.text+0x4d0): undefined reference to `mkl_sparse_s_bsr__g_n_spmm_i4'
/opt/intel/compilers_and_libraries_2017.4.196/linux/mkl/lib/intel64/libmkl_core.a(optimize_r_s_i4_avx.o): In function `mkl_sparse_optimize_i4_avx':
/opt/intel/compilers_and_libraries_2017.4.196/linux/mkl/lib/intel64/libmkl_core.a(hints_r_s_i4_avx.o): In function `mkl_sparse_set_mv_hint_i4_avx':
hints.c:(.text+0xc7): undefined reference to `mkl_sparse_optimize_csr_mv_i4'
hints.c:(.text+0xd5): undefined reference to `mkl_sparse_optimize_bsr_mv_i4'
/opt/intel/compilers_and_libraries_2017.4.196/linux/mkl/lib/intel64/libmkl_core.a(hints_r_s_i4_avx.o): In function `mkl_sparse_set_mm_hint_i4_avx':
hints.c:(.text+0x3a7): undefined reference to `mkl_sparse_optimize_csr_mm_i4'
hints.c:(.text+0x3b5): undefined reference to `mkl_sparse_optimize_bsr_mm_i4'
/opt/intel/compilers_and_libraries_2017.4.196/linux/mkl/lib/intel64/libmkl_core.a(hints_r_s_i4_avx.o): In function `mkl_sparse_set_sv_hint_i4_avx':
hints.c:(.text+0x667): undefined reference to `mkl_sparse_optimize_csr_trsv_i4'
hints.c:(.text+0x675): undefined reference to `mkl_sparse_optimize_bsr_trsv_i4'
/opt/intel/compilers_and_libraries_2017.4.196/linux/mkl/lib/intel64/libmkl_core.a(hints_r_s_i4_avx.o): In function `mkl_sparse_set_sm_hint_i4_avx':
hints.c:(.text+0x935): undefined reference to `mkl_sparse_optimize_bsr_trsm_i4'
/opt/intel/compilers_and_libraries_2017.4.196/linux/mkl/lib/intel64/libmkl_core.a(xspmm_r_d_i4_avx.o): In function `mkl_sparse_d_do_spmm_i4_avx':
xspmm.c:(.text+0x2d6): undefined reference to `mkl_sparse_d_csr__g_n_spmm_i4'
xspmm.c:(.text+0x46b): undefined reference to `mkl_sparse_d_bsr__g_n_spmm_i4'
/opt/intel/compilers_and_libraries_2017.4.196/linux/mkl/lib/intel64/libmkl_core.a(xspmm_c_s_i4_avx.o): In function `mkl_sparse_c_do_spmm_i4_avx':
xspmm.c:(.text+0x2d6): undefined reference to `mkl_sparse_c_csr__g_n_spmm_i4'
xspmm.c:(.text+0x46e): undefined reference to `mkl_sparse_c_bsr__g_n_spmm_i4'
/opt/intel/compilers_and_libraries_2017.4.196/linux/mkl/lib/intel64/libmkl_core.a(xspmm_c_d_i4_avx.o): In function `mkl_sparse_z_do_spmm_i4_avx':
xspmm.c:(.text+0x2d6): undefined reference to `mkl_sparse_z_csr__g_n_spmm_i4'
xspmm.c:(.text+0x46e): undefined reference to `mkl_sparse_z_bsr__g_n_spmm_i4'
/opt/intel/compilers_and_libraries_2017.4.196/linux/mkl/lib/intel64/libmkl_core.a(xspmm_r_s_i4_mc3.o): In function `mkl_sparse_s_do_spmm_i4_mc3':
/opt/intel/compilers_and_libraries_2017.4.196/linux/mkl/lib/intel64/libmkl_core.a(optimize_r_s_i4_mc3.o): In function `mkl_sparse_optimize_i4_mc3':
/opt/intel/compilers_and_libraries_2017.4.196/linux/mkl/lib/intel64/libmkl_core.a(hints_r_s_i4_mc3.o): In function `mkl_sparse_set_mv_hint_i4_mc3':
/opt/intel/compilers_and_libraries_2017.4.196/linux/mkl/lib/intel64/libmkl_core.a(hints_r_s_i4_mc3.o): In function `mkl_sparse_set_mm_hint_i4_mc3':
hints.c:(.text+0x397): undefined reference to `mkl_sparse_optimize_csr_mm_i4'
hints.c:(.text+0x3a5): undefined reference to `mkl_sparse_optimize_bsr_mm_i4'
/opt/intel/compilers_and_libraries_2017.4.196/linux/mkl/lib/intel64/libmkl_core.a(hints_r_s_i4_mc3.o): In function `mkl_sparse_set_sv_hint_i4_mc3':
hints.c:(.text+0x647): undefined reference to `mkl_sparse_optimize_csr_trsv_i4'
hints.c:(.text+0x655): undefined reference to `mkl_sparse_optimize_bsr_trsv_i4'
/opt/intel/compilers_and_libraries_2017.4.196/linux/mkl/lib/intel64/libmkl_core.a(hints_r_s_i4_mc3.o): In function `mkl_sparse_set_sm_hint_i4_mc3':
hints.c:(.text+0x915): undefined reference to `mkl_sparse_optimize_bsr_trsm_i4'
/opt/intel/compilers_and_libraries_2017.4.196/linux/mkl/lib/intel64/libmkl_core.a(xspmm_r_d_i4_mc3.o): In function `mkl_sparse_d_do_spmm_i4_mc3':
/opt/intel/compilers_and_libraries_2017.4.196/linux/mkl/lib/intel64/libmkl_core.a(xspmm_c_s_i4_mc3.o): In function `mkl_sparse_c_do_spmm_i4_mc3':
/opt/intel/compilers_and_libraries_2017.4.196/linux/mkl/lib/intel64/libmkl_core.a(xspmm_c_d_i4_mc3.o): In function `mkl_sparse_z_do_spmm_i4_mc3':
/opt/intel/compilers_and_libraries_2017.4.196/linux/mkl/lib/intel64/libmkl_core.a(xspmm_r_s_i4_mc.o): In function `mkl_sparse_s_do_spmm_i4_mc':
/opt/intel/compilers_and_libraries_2017.4.196/linux/mkl/lib/intel64/libmkl_core.a(optimize_r_s_i4_mc.o): In function `mkl_sparse_optimize_i4_mc':
/opt/intel/compilers_and_libraries_2017.4.196/linux/mkl/lib/intel64/libmkl_core.a(hints_r_s_i4_mc.o): In function `mkl_sparse_set_mv_hint_i4_mc':
hints.c:(.text+0xc8): undefined reference to `mkl_sparse_optimize_csr_mv_i4'
hints.c:(.text+0xd7): undefined reference to `mkl_sparse_optimize_bsr_mv_i4'
/opt/intel/compilers_and_libraries_2017.4.196/linux/mkl/lib/intel64/libmkl_core.a(hints_r_s_i4_mc.o): In function `mkl_sparse_set_mm_hint_i4_mc':
hints.c:(.text+0x358): undefined reference to `mkl_sparse_optimize_csr_mm_i4'
hints.c:(.text+0x366): undefined reference to `mkl_sparse_optimize_bsr_mm_i4'
/opt/intel/compilers_and_libraries_2017.4.196/linux/mkl/lib/intel64/libmkl_core.a(hints_r_s_i4_mc.o): In function `mkl_sparse_set_sv_hint_i4_mc':
hints.c:(.text+0x5c8): undefined reference to `mkl_sparse_optimize_csr_trsv_i4'
hints.c:(.text+0x5d7): undefined reference to `mkl_sparse_optimize_bsr_trsv_i4'
/opt/intel/compilers_and_libraries_2017.4.196/linux/mkl/lib/intel64/libmkl_core.a(hints_r_s_i4_mc.o): In function `mkl_sparse_set_sm_hint_i4_mc':
hints.c:(.text+0x856): undefined reference to `mkl_sparse_optimize_bsr_trsm_i4'
/opt/intel/compilers_and_libraries_2017.4.196/linux/mkl/lib/intel64/libmkl_core.a(xspmm_r_d_i4_mc.o): In function `mkl_sparse_d_do_spmm_i4_mc':
/opt/intel/compilers_and_libraries_2017.4.196/linux/mkl/lib/intel64/libmkl_core.a(xspmm_c_s_i4_mc.o): In function `mkl_sparse_c_do_spmm_i4_mc':
/opt/intel/compilers_and_libraries_2017.4.196/linux/mkl/lib/intel64/libmkl_core.a(xspmm_c_d_i4_mc.o): In function `mkl_sparse_z_do_spmm_i4_mc':
/opt/intel/compilers_and_libraries_2017.4.196/linux/mkl/lib/intel64/libmkl_core.a(xspmm_r_s_i4_def.o): In function `mkl_sparse_s_do_spmm_i4_def':
/opt/intel/compilers_and_libraries_2017.4.196/linux/mkl/lib/intel64/libmkl_core.a(optimize_r_s_i4_def.o): In function `mkl_sparse_optimize_i4_def':
/opt/intel/compilers_and_libraries_2017.4.196/linux/mkl/lib/intel64/libmkl_core.a(hints_r_s_i4_def.o): In function `mkl_sparse_set_mv_hint_i4_def':
/opt/intel/compilers_and_libraries_2017.4.196/linux/mkl/lib/intel64/libmkl_core.a(hints_r_s_i4_def.o): In function `mkl_sparse_set_mm_hint_i4_def':
/opt/intel/compilers_and_libraries_2017.4.196/linux/mkl/lib/intel64/libmkl_core.a(hints_r_s_i4_def.o): In function `mkl_sparse_set_sv_hint_i4_def':
/opt/intel/compilers_and_libraries_2017.4.196/linux/mkl/lib/intel64/libmkl_core.a(hints_r_s_i4_def.o): In function `mkl_sparse_set_sm_hint_i4_def':
/opt/intel/compilers_and_libraries_2017.4.196/linux/mkl/lib/intel64/libmkl_core.a(xspmm_r_d_i4_def.o): In function `mkl_sparse_d_do_spmm_i4_def':
/opt/intel/compilers_and_libraries_2017.4.196/linux/mkl/lib/intel64/libmkl_core.a(xspmm_c_s_i4_def.o): In function `mkl_sparse_c_do_spmm_i4_def':
/opt/intel/compilers_and_libraries_2017.4.196/linux/mkl/lib/intel64/libmkl_core.a(xspmm_c_d_i4_def.o): In function `mkl_sparse_z_do_spmm_i4_def':
/opt/intel/compilers_and_libraries_2017.4.196/linux/mkl/lib/intel64/libmkl_core.a(ztrevc3.o): In function `mkl_lapack_ztrevc3':
ztrevc3_gen.f:(.text+0x67e): undefined reference to `mkl_lapack_zlaset'
ztrevc3_gen.f:(.text+0x1837): undefined reference to `mkl_lapack_zlacpy'
ztrevc3_gen.f:(.text+0x1b8d): undefined reference to `mkl_lapack_zlacpy'
/opt/intel/compilers_and_libraries_2017.4.196/linux/mkl/lib/intel64/libmkl_core.a(zunmtr.o): In function `mkl_lapack_zunmtr':
zunmtr_gen.f:(.text+0x590): undefined reference to `mkl_lapack_zunmql'
/opt/intel/compilers_and_libraries_2017.4.196/linux/mkl/lib/intel64/libmkl_core.a(zunmbr.o): In function `mkl_lapack_zunmbr':
zunmbr_gen.f:(.text+0x793): undefined reference to `mkl_lapack_zunmlq'
zunmbr_gen.f:(.text+0x829): undefined reference to `mkl_lapack_zunmlq'
/opt/intel/compilers_and_libraries_2017.4.196/linux/mkl/lib/intel64/libmkl_core.a(zungtr.o): In function `mkl_lapack_zungtr':
zungtr_gen.f:(.text+0x75a): undefined reference to `mkl_lapack_zungql'
/opt/intel/compilers_and_libraries_2017.4.196/linux/mkl/lib/intel64/libmkl_core.a(zungbr.o): In function `mkl_lapack_zungbr':
zungbr_gen.f:(.text+0x35a): undefined reference to `mkl_lapack_zunglq'
zungbr_gen.f:(.text+0x3a7): undefined reference to `mkl_lapack_zunglq'
zungbr_gen.f:(.text+0x8a8): undefined reference to `mkl_lapack_zunglq'
zungbr_gen.f:(.text+0x8f9): undefined reference to `mkl_lapack_zunglq'
/opt/intel/compilers_and_libraries_2017.4.196/linux/mkl/lib/intel64/libmkl_core.a(zstein.o): In function `mkl_lapack_zstein':
zstein_gen.f:(.text+0x83c): undefined reference to `mkl_blas_dscal'
zstein_gen.f:(.text+0xce0): undefined reference to `mkl_blas_dscal'
/opt/intel/compilers_and_libraries_2017.4.196/linux/mkl/lib/intel64/libmkl_core.a(zlatrs.o): In function `mkl_lapack_zlatrs':
zlatrs_gen.f:(.text+0x555): undefined reference to `mkl_blas_dscal'
zlatrs_gen.f:(.text+0x2085): undefined reference to `mkl_blas_dscal'
/opt/intel/compilers_and_libraries_2017.4.196/linux/mkl/lib/intel64/libmkl_core.a(zhseqr.o): In function `mkl_lapack_zhseqr':
zhseqr_gen.f:(.text+0x3bb): undefined reference to `mkl_lapack_zlaset'
zhseqr_gen.f:(.text+0x7b8): undefined reference to `mkl_lapack_zlacpy'
zhseqr_gen.f:(.text+0x814): undefined reference to `mkl_lapack_zlaset'
zhseqr_gen.f:(.text+0x8d7): undefined reference to `mkl_lapack_zlacpy'
zhseqr_gen.f:(.text+0x952): undefined reference to `mkl_lapack_zlaset'
/opt/intel/compilers_and_libraries_2017.4.196/linux/mkl/lib/intel64/libmkl_core.a(zherdb.o): In function `mkl_lapack_zherdb':
zherdb_gen.f:(.text+0x18d9): undefined reference to `mkl_lapack_zlacpy'
zherdb_gen.f:(.text+0x1939): undefined reference to `mkl_lapack_zlacpy'
zherdb_gen.f:(.text+0x1d0b): undefined reference to `mkl_lapack_zhbrdbm'
zherdb_gen.f:(.text+0x1eb6): undefined reference to `mkl_lapack_zungql'
/opt/intel/compilers_and_libraries_2017.4.196/linux/mkl/lib/intel64/libmkl_core.a(zherb2m.o): In function `mkl_lapack_zherb2m':
zherb2m_gen.f:(.text+0x108): undefined reference to `mkl_lapack_zgeqrf_pf'
zherb2m_gen.f:(.text+0x133): undefined reference to `mkl_lapack_zlacpy'
zherb2m_gen.f:(.text+0x15e): undefined reference to `mkl_lapack_zlacpy'
zherb2m_gen.f:(.text+0x30c): undefined reference to `mkl_lapack_zgeqlf_pf'
zherb2m_gen.f:(.text+0x337): undefined reference to `mkl_lapack_zlacpy'
zherb2m_gen.f:(.text+0x362): undefined reference to `mkl_lapack_zlacpy'
/opt/intel/compilers_and_libraries_2017.4.196/linux/mkl/lib/intel64/libmkl_core.a(xconvert_r_s_i4_avx512_mic.o): In function `mkl_sparse_s_convert_bsr_i4_avx512_mic':
xconvert.c:(.text+0x90a): undefined reference to `mkl_sparse_s_csrbsr_i4'
xconvert.c:(.text+0x9ba): undefined reference to `mkl_sparse_s_csrbsr_i4'
xconvert.c:(.text+0xb50): undefined reference to `mkl_sparse_s_bsrbsr_i4'
xconvert.c:(.text+0xbf3): undefined reference to `mkl_sparse_s_bsrbsr_i4'
xconvert.c:(.text+0xc25): undefined reference to `mkl_sparse_s_convert_bsr_transpose_i4'
xconvert.c:(.text+0xc60): undefined reference to `mkl_sparse_s_convert_bsr_transpose_i4'
/opt/intel/compilers_and_libraries_2017.4.196/linux/mkl/lib/intel64/libmkl_core.a(xconvert_r_s_i4_avx512_mic.o): In function `mkl_sparse_s_export_csr_data_i4_avx512_mic':
xconvert.c:(.text+0xdd9): undefined reference to `mkl_sparse_s_convert_coo_to_csr_i4'
/opt/intel/compilers_and_libraries_2017.4.196/linux/mkl/lib/intel64/libmkl_core.a(xconvert_r_s_i4_avx512_mic.o): In function `mkl_sparse_s_convert_csc_to_csr_i4_avx512_mic':
xconvert.c:(.text+0x18a3): undefined reference to `mkl_sparse_s_convert_csc_to_csr_omp_i4'
/opt/intel/compilers_and_libraries_2017.4.196/linux/mkl/lib/intel64/libmkl_core.a(xconvert_r_s_i4_avx512_mic.o): In function `mkl_sparse_s_transpose_csr3a_i4_avx512_mic':
xconvert.c:(.text+0x1b01): undefined reference to `mkl_sparse_s_convert_csc_to_csr_omp_i4'
/opt/intel/compilers_and_libraries_2017.4.196/linux/mkl/lib/intel64/libmkl_core.a(xconvert_r_d_i4_avx512_mic.o): In function `mkl_sparse_d_convert_bsr_i4_avx512_mic':
xconvert.c:(.text+0x29a): undefined reference to `mkl_sparse_d_csrbsr_i4'
xconvert.c:(.text+0x34a): undefined reference to `mkl_sparse_d_csrbsr_i4'
xconvert.c:(.text+0x4e0): undefined reference to `mkl_sparse_d_bsrbsr_i4'
xconvert.c:(.text+0x583): undefined reference to `mkl_sparse_d_bsrbsr_i4'
xconvert.c:(.text+0x5b5): undefined reference to `mkl_sparse_d_convert_bsr_transpose_i4'
xconvert.c:(.text+0x5f0): undefined reference to `mkl_sparse_d_convert_bsr_transpose_i4'
/opt/intel/compilers_and_libraries_2017.4.196/linux/mkl/lib/intel64/libmkl_core.a(xconvert_r_d_i4_avx512_mic.o): In function `mkl_sparse_d_export_csr_data_i4_avx512_mic':
xconvert.c:(.text+0x769): undefined reference to `mkl_sparse_d_convert_coo_to_csr_i4'
/opt/intel/compilers_and_libraries_2017.4.196/linux/mkl/lib/intel64/libmkl_core.a(xconvert_r_d_i4_avx512_mic.o): In function `mkl_sparse_d_convert_csc_to_csr_i4_avx512_mic':
xconvert.c:(.text+0x1248): undefined reference to `mkl_sparse_d_convert_csc_to_csr_omp_i4'
/opt/intel/compilers_and_libraries_2017.4.196/linux/mkl/lib/intel64/libmkl_core.a(xconvert_r_d_i4_avx512_mic.o): In function `mkl_sparse_d_transpose_csr3a_i4_avx512_mic':
xconvert.c:(.text+0x14a2): undefined reference to `mkl_sparse_d_convert_csc_to_csr_omp_i4'
/opt/intel/compilers_and_libraries_2017.4.196/linux/mkl/lib/intel64/libmkl_core.a(xconvert_c_s_i4_avx512_mic.o): In function `mkl_sparse_c_convert_bsr_i4_avx512_mic':
xconvert.c:(.text+0x29a): undefined reference to `mkl_sparse_c_csrbsr_i4'
xconvert.c:(.text+0x34a): undefined reference to `mkl_sparse_c_csrbsr_i4'
xconvert.c:(.text+0x4e0): undefined reference to `mkl_sparse_c_bsrbsr_i4'
xconvert.c:(.text+0x583): undefined reference to `mkl_sparse_c_bsrbsr_i4'
xconvert.c:(.text+0x5b5): undefined reference to `mkl_sparse_c_convert_bsr_transpose_i4'
xconvert.c:(.text+0x5f0): undefined reference to `mkl_sparse_c_convert_bsr_transpose_i4'
/opt/intel/compilers_and_libraries_2017.4.196/linux/mkl/lib/intel64/libmkl_core.a(xconvert_c_s_i4_avx512_mic.o): In function `mkl_sparse_c_export_csr_data_i4_avx512_mic':
xconvert.c:(.text+0x769): undefined reference to `mkl_sparse_c_convert_coo_to_csr_i4'
/opt/intel/compilers_and_libraries_2017.4.196/linux/mkl/lib/intel64/libmkl_core.a(xconvert_c_s_i4_avx512_mic.o): In function `mkl_sparse_c_convert_csc_to_csr_i4_avx512_mic':
xconvert.c:(.text+0x1248): undefined reference to `mkl_sparse_c_convert_csc_to_csr_omp_i4'
/opt/intel/compilers_and_libraries_2017.4.196/linux/mkl/lib/intel64/libmkl_core.a(xconvert_c_s_i4_avx512_mic.o): In function `mkl_sparse_c_transpose_csr3a_i4_avx512_mic':
xconvert.c:(.text+0x14a2): undefined reference to `mkl_sparse_c_convert_csc_to_csr_omp_i4'
/opt/intel/compilers_and_libraries_2017.4.196/linux/mkl/lib/intel64/libmkl_core.a(xconvert_c_d_i4_avx512_mic.o): In function `mkl_sparse_z_convert_bsr_i4_avx512_mic':
xconvert.c:(.text+0x29a): undefined reference to `mkl_sparse_z_csrbsr_i4'
xconvert.c:(.text+0x34a): undefined reference to `mkl_sparse_z_csrbsr_i4'
xconvert.c:(.text+0x4e4): undefined reference to `mkl_sparse_z_bsrbsr_i4'
xconvert.c:(.text+0x587): undefined reference to `mkl_sparse_z_bsrbsr_i4'
xconvert.c:(.text+0x5b9): undefined reference to `mkl_sparse_z_convert_bsr_transpose_i4'
xconvert.c:(.text+0x5f4): undefined reference to `mkl_sparse_z_convert_bsr_transpose_i4'
/opt/intel/compilers_and_libraries_2017.4.196/linux/mkl/lib/intel64/libmkl_core.a(xconvert_c_d_i4_avx512_mic.o): In function `mkl_sparse_z_export_csr_data_i4_avx512_mic':
xconvert.c:(.text+0x771): undefined reference to `mkl_sparse_z_convert_coo_to_csr_i4'
/opt/intel/compilers_and_libraries_2017.4.196/linux/mkl/lib/intel64/libmkl_core.a(xconvert_c_d_i4_avx512_mic.o): In function `mkl_sparse_z_convert_csc_to_csr_i4_avx512_mic':
xconvert.c:(.text+0x1248): undefined reference to `mkl_sparse_z_convert_csc_to_csr_omp_i4'
/opt/intel/compilers_and_libraries_2017.4.196/linux/mkl/lib/intel64/libmkl_core.a(xconvert_c_d_i4_avx512_mic.o): In function `mkl_sparse_z_transpose_csr3a_i4_avx512_mic':
xconvert.c:(.text+0x14a2): undefined reference to `mkl_sparse_z_convert_csc_to_csr_omp_i4'
/opt/intel/compilers_and_libraries_2017.4.196/linux/mkl/lib/intel64/libmkl_core.a(xconvert_r_s_i4_avx512.o): In function `mkl_sparse_s_convert_bsr_i4_avx512':
xconvert.c:(.text+0x836): undefined reference to `mkl_sparse_s_csrbsr_i4'
xconvert.c:(.text+0x8d3): undefined reference to `mkl_sparse_s_csrbsr_i4'
xconvert.c:(.text+0xa36): undefined reference to `mkl_sparse_s_bsrbsr_i4'
xconvert.c:(.text+0xaaf): undefined reference to `mkl_sparse_s_bsrbsr_i4'
xconvert.c:(.text+0xaed): undefined reference to `mkl_sparse_s_convert_bsr_transpose_i4'
xconvert.c:(.text+0xb13): undefined reference to `mkl_sparse_s_convert_bsr_transpose_i4'
/opt/intel/compilers_and_libraries_2017.4.196/linux/mkl/lib/intel64/libmkl_core.a(xconvert_r_s_i4_avx512.o): In function `mkl_sparse_s_export_csr_data_i4_avx512':
xconvert.c:(.text+0xc52): undefined reference to `mkl_sparse_s_convert_coo_to_csr_i4'
/opt/intel/compilers_and_libraries_2017.4.196/linux/mkl/lib/intel64/libmkl_core.a(xconvert_r_s_i4_avx512.o): In function `mkl_sparse_s_convert_csc_to_csr_i4_avx512':
xconvert.c:(.text+0x1690): undefined reference to `mkl_sparse_s_convert_csc_to_csr_omp_i4'
/opt/intel/compilers_and_libraries_2017.4.196/linux/mkl/lib/intel64/libmkl_core.a(xconvert_r_s_i4_avx512.o): In function `mkl_sparse_s_transpose_csr3a_i4_avx512':
xconvert.c:(.text+0x18cf): undefined reference to `mkl_sparse_s_convert_csc_to_csr_omp_i4'
/opt/intel/compilers_and_libraries_2017.4.196/linux/mkl/lib/intel64/libmkl_core.a(xconvert_r_d_i4_avx512.o): In function `mkl_sparse_d_convert_bsr_i4_avx512':
xconvert.c:(.text+0x226): undefined reference to `mkl_sparse_d_csrbsr_i4'
xconvert.c:(.text+0x2c3): undefined reference to `mkl_sparse_d_csrbsr_i4'
xconvert.c:(.text+0x426): undefined reference to `mkl_sparse_d_bsrbsr_i4'
xconvert.c:(.text+0x49f): undefined reference to `mkl_sparse_d_bsrbsr_i4'
xconvert.c:(.text+0x4dd): undefined reference to `mkl_sparse_d_convert_bsr_transpose_i4'
xconvert.c:(.text+0x503): undefined reference to `mkl_sparse_d_convert_bsr_transpose_i4'
/opt/intel/compilers_and_libraries_2017.4.196/linux/mkl/lib/intel64/libmkl_core.a(xconvert_r_d_i4_avx512.o): In function `mkl_sparse_d_export_csr_data_i4_avx512':
xconvert.c:(.text+0x642): undefined reference to `mkl_sparse_d_convert_coo_to_csr_i4'
/opt/intel/compilers_and_libraries_2017.4.196/linux/mkl/lib/intel64/libmkl_core.a(xconvert_r_d_i4_avx512.o): In function `mkl_sparse_d_convert_csc_to_csr_i4_avx512':
xconvert.c:(.text+0x1085): undefined reference to `mkl_sparse_d_convert_csc_to_csr_omp_i4'
/opt/intel/compilers_and_libraries_2017.4.196/linux/mkl/lib/intel64/libmkl_core.a(xconvert_r_d_i4_avx512.o): In function `mkl_sparse_d_transpose_csr3a_i4_avx512':
xconvert.c:(.text+0x12c0): undefined reference to `mkl_sparse_d_convert_csc_to_csr_omp_i4'
/opt/intel/compilers_and_libraries_2017.4.196/linux/mkl/lib/intel64/libmkl_core.a(xconvert_c_s_i4_avx512.o): In function `mkl_sparse_c_convert_bsr_i4_avx512':
xconvert.c:(.text+0x226): undefined reference to `mkl_sparse_c_csrbsr_i4'
xconvert.c:(.text+0x2c3): undefined reference to `mkl_sparse_c_csrbsr_i4'
xconvert.c:(.text+0x426): undefined reference to `mkl_sparse_c_bsrbsr_i4'
xconvert.c:(.text+0x49f): undefined reference to `mkl_sparse_c_bsrbsr_i4'
xconvert.c:(.text+0x4dd): undefined reference to `mkl_sparse_c_convert_bsr_transpose_i4'
xconvert.c:(.text+0x503): undefined reference to `mkl_sparse_c_convert_bsr_transpose_i4'
/opt/intel/compilers_and_libraries_2017.4.196/linux/mkl/lib/intel64/libmkl_core.a(xconvert_c_s_i4_avx512.o): In function `mkl_sparse_c_export_csr_data_i4_avx512':
xconvert.c:(.text+0x642): undefined reference to `mkl_sparse_c_convert_coo_to_csr_i4'
/opt/intel/compilers_and_libraries_2017.4.196/linux/mkl/lib/intel64/libmkl_core.a(xconvert_c_s_i4_avx512.o): In function `mkl_sparse_c_convert_csc_to_csr_i4_avx512':
xconvert.c:(.text+0x1085): undefined reference to `mkl_sparse_c_convert_csc_to_csr_omp_i4'
/opt/intel/compilers_and_libraries_2017.4.196/linux/mkl/lib/intel64/libmkl_core.a(xconvert_c_s_i4_avx512.o): In function `mkl_sparse_c_transpose_csr3a_i4_avx512':
xconvert.c:(.text+0x12c0): undefined reference to `mkl_sparse_c_convert_csc_to_csr_omp_i4'
/opt/intel/compilers_and_libraries_2017.4.196/linux/mkl/lib/intel64/libmkl_core.a(xconvert_c_d_i4_avx512.o): In function `mkl_sparse_z_convert_bsr_i4_avx512':
xconvert.c:(.text+0x226): undefined reference to `mkl_sparse_z_csrbsr_i4'
xconvert.c:(.text+0x2c3): undefined reference to `mkl_sparse_z_csrbsr_i4'
xconvert.c:(.text+0x42a): undefined reference to `mkl_sparse_z_bsrbsr_i4'
xconvert.c:(.text+0x4a3): undefined reference to `mkl_sparse_z_bsrbsr_i4'
xconvert.c:(.text+0x4e1): undefined reference to `mkl_sparse_z_convert_bsr_transpose_i4'
xconvert.c:(.text+0x507): undefined reference to `mkl_sparse_z_convert_bsr_transpose_i4'
/opt/intel/compilers_and_libraries_2017.4.196/linux/mkl/lib/intel64/libmkl_core.a(xconvert_c_d_i4_avx512.o): In function `mkl_sparse_z_export_csr_data_i4_avx512':
xconvert.c:(.text+0x65a): undefined reference to `mkl_sparse_z_convert_coo_to_csr_i4'
/opt/intel/compilers_and_libraries_2017.4.196/linux/mkl/lib/intel64/libmkl_core.a(xconvert_c_d_i4_avx512.o): In function `mkl_sparse_z_convert_csc_to_csr_i4_avx512':
xconvert.c:(.text+0x1075): undefined reference to `mkl_sparse_z_convert_csc_to_csr_omp_i4'
/opt/intel/compilers_and_libraries_2017.4.196/linux/mkl/lib/intel64/libmkl_core.a(xconvert_c_d_i4_avx512.o): In function `mkl_sparse_z_transpose_csr3a_i4_avx512':
xconvert.c:(.text+0x12b0): undefined reference to `mkl_sparse_z_convert_csc_to_csr_omp_i4'
/opt/intel/compilers_and_libraries_2017.4.196/linux/mkl/lib/intel64/libmkl_core.a(xconvert_r_s_i4_avx2.o): In function `mkl_sparse_s_convert_bsr_i4_avx2':
xconvert.c:(.text+0x746): undefined reference to `mkl_sparse_s_csrbsr_i4'
xconvert.c:(.text+0x7e3): undefined reference to `mkl_sparse_s_csrbsr_i4'
xconvert.c:(.text+0x946): undefined reference to `mkl_sparse_s_bsrbsr_i4'
xconvert.c:(.text+0x9bf): undefined reference to `mkl_sparse_s_bsrbsr_i4'
xconvert.c:(.text+0x9fd): undefined reference to `mkl_sparse_s_convert_bsr_transpose_i4'
xconvert.c:(.text+0xa23): undefined reference to `mkl_sparse_s_convert_bsr_transpose_i4'
/opt/intel/compilers_and_libraries_2017.4.196/linux/mkl/lib/intel64/libmkl_core.a(xconvert_r_s_i4_avx2.o): In function `mkl_sparse_s_export_csr_data_i4_avx2':
xconvert.c:(.text+0xb62): undefined reference to `mkl_sparse_s_convert_coo_to_csr_i4'
/opt/intel/compilers_and_libraries_2017.4.196/linux/mkl/lib/intel64/libmkl_core.a(xconvert_r_s_i4_avx2.o): In function `mkl_sparse_s_convert_csc_to_csr_i4_avx2':
xconvert.c:(.text+0x1480): undefined reference to `mkl_sparse_s_convert_csc_to_csr_omp_i4'
/opt/intel/compilers_and_libraries_2017.4.196/linux/mkl/lib/intel64/libmkl_core.a(xconvert_r_s_i4_avx2.o): In function `mkl_sparse_s_transpose_csr3a_i4_avx2':
xconvert.c:(.text+0x16bf): undefined reference to `mkl_sparse_s_convert_csc_to_csr_omp_i4'
/opt/intel/compilers_and_libraries_2017.4.196/linux/mkl/lib/intel64/libmkl_core.a(xconvert_r_d_i4_avx2.o): In function `mkl_sparse_d_convert_bsr_i4_avx2':
/opt/intel/compilers_and_libraries_2017.4.196/linux/mkl/lib/intel64/libmkl_core.a(xconvert_r_d_i4_avx2.o): In function `mkl_sparse_d_export_csr_data_i4_avx2':
/opt/intel/compilers_and_libraries_2017.4.196/linux/mkl/lib/intel64/libmkl_core.a(xconvert_r_d_i4_avx2.o): In function `mkl_sparse_d_convert_csc_to_csr_i4_avx2':
xconvert.c:(.text+0xf65): undefined reference to `mkl_sparse_d_convert_csc_to_csr_omp_i4'
/opt/intel/compilers_and_libraries_2017.4.196/linux/mkl/lib/intel64/libmkl_core.a(xconvert_r_d_i4_avx2.o): In function `mkl_sparse_d_transpose_csr3a_i4_avx2':
xconvert.c:(.text+0x11a0): undefined reference to `mkl_sparse_d_convert_csc_to_csr_omp_i4'
/opt/intel/compilers_and_libraries_2017.4.196/linux/mkl/lib/intel64/libmkl_core.a(xconvert_c_s_i4_avx2.o): In function `mkl_sparse_c_convert_bsr_i4_avx2':
/opt/intel/compilers_and_libraries_2017.4.196/linux/mkl/lib/intel64/libmkl_core.a(xconvert_c_s_i4_avx2.o): In function `mkl_sparse_c_export_csr_data_i4_avx2':
/opt/intel/compilers_and_libraries_2017.4.196/linux/mkl/lib/intel64/libmkl_core.a(xconvert_c_s_i4_avx2.o): In function `mkl_sparse_c_convert_csc_to_csr_i4_avx2':
xconvert.c:(.text+0xf65): undefined reference to `mkl_sparse_c_convert_csc_to_csr_omp_i4'
/opt/intel/compilers_and_libraries_2017.4.196/linux/mkl/lib/intel64/libmkl_core.a(xconvert_c_s_i4_avx2.o): In function `mkl_sparse_c_transpose_csr3a_i4_avx2':
xconvert.c:(.text+0x11a0): undefined reference to `mkl_sparse_c_convert_csc_to_csr_omp_i4'
/opt/intel/compilers_and_libraries_2017.4.196/linux/mkl/lib/intel64/libmkl_core.a(xconvert_c_d_i4_avx2.o): In function `mkl_sparse_z_convert_bsr_i4_avx2':
/opt/intel/compilers_and_libraries_2017.4.196/linux/mkl/lib/intel64/libmkl_core.a(xconvert_c_d_i4_avx2.o): In function `mkl_sparse_z_export_csr_data_i4_avx2':
/opt/intel/compilers_and_libraries_2017.4.196/linux/mkl/lib/intel64/libmkl_core.a(xconvert_c_d_i4_avx2.o): In function `mkl_sparse_z_convert_csc_to_csr_i4_avx2':
xconvert.c:(.text+0xf85): undefined reference to `mkl_sparse_z_convert_csc_to_csr_omp_i4'
/opt/intel/compilers_and_libraries_2017.4.196/linux/mkl/lib/intel64/libmkl_core.a(xconvert_c_d_i4_avx2.o): In function `mkl_sparse_z_transpose_csr3a_i4_avx2':
xconvert.c:(.text+0x11c0): undefined reference to `mkl_sparse_z_convert_csc_to_csr_omp_i4'
/opt/intel/compilers_and_libraries_2017.4.196/linux/mkl/lib/intel64/libmkl_core.a(xconvert_r_s_i4_avx.o): In function `mkl_sparse_s_convert_bsr_i4_avx':
xconvert.c:(.text+0x712): undefined reference to `mkl_sparse_s_csrbsr_i4'
xconvert.c:(.text+0x7aa): undefined reference to `mkl_sparse_s_csrbsr_i4'
xconvert.c:(.text+0x902): undefined reference to `mkl_sparse_s_bsrbsr_i4'
xconvert.c:(.text+0x974): undefined reference to `mkl_sparse_s_bsrbsr_i4'
xconvert.c:(.text+0x9ab): undefined reference to `mkl_sparse_s_convert_bsr_transpose_i4'
xconvert.c:(.text+0x9ca): undefined reference to `mkl_sparse_s_convert_bsr_transpose_i4'
/opt/intel/compilers_and_libraries_2017.4.196/linux/mkl/lib/intel64/libmkl_core.a(xconvert_r_s_i4_avx.o): In function `mkl_sparse_s_export_csr_data_i4_avx':
xconvert.c:(.text+0xb02): undefined reference to `mkl_sparse_s_convert_coo_to_csr_i4'
/opt/intel/compilers_and_libraries_2017.4.196/linux/mkl/lib/intel64/libmkl_core.a(xconvert_r_s_i4_avx.o): In function `mkl_sparse_s_convert_csc_to_csr_i4_avx':
xconvert.c:(.text+0x139c): undefined reference to `mkl_sparse_s_convert_csc_to_csr_omp_i4'
/opt/intel/compilers_and_libraries_2017.4.196/linux/mkl/lib/intel64/libmkl_core.a(xconvert_r_s_i4_avx.o): In function `mkl_sparse_s_transpose_csr3a_i4_avx':
xconvert.c:(.text+0x15c9): undefined reference to `mkl_sparse_s_convert_csc_to_csr_omp_i4'
/opt/intel/compilers_and_libraries_2017.4.196/linux/mkl/lib/intel64/libmkl_core.a(xconvert_r_d_i4_avx.o): In function `mkl_sparse_d_convert_bsr_i4_avx':
xconvert.c:(.text+0x212): undefined reference to `mkl_sparse_d_csrbsr_i4'
xconvert.c:(.text+0x2aa): undefined reference to `mkl_sparse_d_csrbsr_i4'
xconvert.c:(.text+0x402): undefined reference to `mkl_sparse_d_bsrbsr_i4'
xconvert.c:(.text+0x474): undefined reference to `mkl_sparse_d_bsrbsr_i4'
xconvert.c:(.text+0x4ab): undefined reference to `mkl_sparse_d_convert_bsr_transpose_i4'
xconvert.c:(.text+0x4ca): undefined reference to `mkl_sparse_d_convert_bsr_transpose_i4'
/opt/intel/compilers_and_libraries_2017.4.196/linux/mkl/lib/intel64/libmkl_core.a(xconvert_r_d_i4_avx.o): In function `mkl_sparse_d_export_csr_data_i4_avx':
xconvert.c:(.text+0x602): undefined reference to `mkl_sparse_d_convert_coo_to_csr_i4'
/opt/intel/compilers_and_libraries_2017.4.196/linux/mkl/lib/intel64/libmkl_core.a(xconvert_r_d_i4_avx.o): In function `mkl_sparse_d_convert_csc_to_csr_i4_avx':
xconvert.c:(.text+0xee1): undefined reference to `mkl_sparse_d_convert_csc_to_csr_omp_i4'
/opt/intel/compilers_and_libraries_2017.4.196/linux/mkl/lib/intel64/libmkl_core.a(xconvert_r_d_i4_avx.o): In function `mkl_sparse_d_transpose_csr3a_i4_avx':
xconvert.c:(.text+0x110a): undefined reference to `mkl_sparse_d_convert_csc_to_csr_omp_i4'
/opt/intel/compilers_and_libraries_2017.4.196/linux/mkl/lib/intel64/libmkl_core.a(xconvert_c_s_i4_avx.o): In function `mkl_sparse_c_convert_bsr_i4_avx':
xconvert.c:(.text+0x212): undefined reference to `mkl_sparse_c_csrbsr_i4'
xconvert.c:(.text+0x2aa): undefined reference to `mkl_sparse_c_csrbsr_i4'
xconvert.c:(.text+0x402): undefined reference to `mkl_sparse_c_bsrbsr_i4'
xconvert.c:(.text+0x474): undefined reference to `mkl_sparse_c_bsrbsr_i4'
xconvert.c:(.text+0x4ab): undefined reference to `mkl_sparse_c_convert_bsr_transpose_i4'
xconvert.c:(.text+0x4ca): undefined reference to `mkl_sparse_c_convert_bsr_transpose_i4'
/opt/intel/compilers_and_libraries_2017.4.196/linux/mkl/lib/intel64/libmkl_core.a(xconvert_c_s_i4_avx.o): In function `mkl_sparse_c_export_csr_data_i4_avx':
xconvert.c:(.text+0x602): undefined reference to `mkl_sparse_c_convert_coo_to_csr_i4'
/opt/intel/compilers_and_libraries_2017.4.196/linux/mkl/lib/intel64/libmkl_core.a(xconvert_c_s_i4_avx.o): In function `mkl_sparse_c_convert_csc_to_csr_i4_avx':
xconvert.c:(.text+0xea1): undefined reference to `mkl_sparse_c_convert_csc_to_csr_omp_i4'
/opt/intel/compilers_and_libraries_2017.4.196/linux/mkl/lib/intel64/libmkl_core.a(xconvert_c_s_i4_avx.o): In function `mkl_sparse_c_transpose_csr3a_i4_avx':
xconvert.c:(.text+0x10ca): undefined reference to `mkl_sparse_c_convert_csc_to_csr_omp_i4'
/opt/intel/compilers_and_libraries_2017.4.196/linux/mkl/lib/intel64/libmkl_core.a(xconvert_c_d_i4_avx.o): In function `mkl_sparse_z_convert_bsr_i4_avx':
xconvert.c:(.text+0x212): undefined reference to `mkl_sparse_z_csrbsr_i4'
xconvert.c:(.text+0x2aa): undefined reference to `mkl_sparse_z_csrbsr_i4'
xconvert.c:(.text+0x406): undefined reference to `mkl_sparse_z_bsrbsr_i4'
xconvert.c:(.text+0x478): undefined reference to `mkl_sparse_z_bsrbsr_i4'
xconvert.c:(.text+0x4af): undefined reference to `mkl_sparse_z_convert_bsr_transpose_i4'
xconvert.c:(.text+0x4ce): undefined reference to `mkl_sparse_z_convert_bsr_transpose_i4'
/opt/intel/compilers_and_libraries_2017.4.196/linux/mkl/lib/intel64/libmkl_core.a(xconvert_c_d_i4_avx.o): In function `mkl_sparse_z_export_csr_data_i4_avx':
xconvert.c:(.text+0x60a): undefined reference to `mkl_sparse_z_convert_coo_to_csr_i4'
/opt/intel/compilers_and_libraries_2017.4.196/linux/mkl/lib/intel64/libmkl_core.a(xconvert_c_d_i4_avx.o): In function `mkl_sparse_z_convert_csc_to_csr_i4_avx':
xconvert.c:(.text+0xf51): undefined reference to `mkl_sparse_z_convert_csc_to_csr_omp_i4'
/opt/intel/compilers_and_libraries_2017.4.196/linux/mkl/lib/intel64/libmkl_core.a(xconvert_c_d_i4_avx.o): In function `mkl_sparse_z_transpose_csr3a_i4_avx':
xconvert.c:(.text+0x117a): undefined reference to `mkl_sparse_z_convert_csc_to_csr_omp_i4'
/opt/intel/compilers_and_libraries_2017.4.196/linux/mkl/lib/intel64/libmkl_core.a(xconvert_r_s_i4_mc3.o): In function `mkl_sparse_s_convert_bsr_i4_mc3':
xconvert.c:(.text+0x701): undefined reference to `mkl_sparse_s_csrbsr_i4'
xconvert.c:(.text+0x799): undefined reference to `mkl_sparse_s_csrbsr_i4'
xconvert.c:(.text+0x8f0): undefined reference to `mkl_sparse_s_bsrbsr_i4'
xconvert.c:(.text+0x962): undefined reference to `mkl_sparse_s_bsrbsr_i4'
xconvert.c:(.text+0x999): undefined reference to `mkl_sparse_s_convert_bsr_transpose_i4'
xconvert.c:(.text+0x9b8): undefined reference to `mkl_sparse_s_convert_bsr_transpose_i4'
/opt/intel/compilers_and_libraries_2017.4.196/linux/mkl/lib/intel64/libmkl_core.a(xconvert_r_s_i4_mc3.o): In function `mkl_sparse_s_export_csr_data_i4_mc3':
xconvert.c:(.text+0xaf0): undefined reference to `mkl_sparse_s_convert_coo_to_csr_i4'
/opt/intel/compilers_and_libraries_2017.4.196/linux/mkl/lib/intel64/libmkl_core.a(xconvert_r_s_i4_mc3.o): In function `mkl_sparse_s_convert_csc_to_csr_i4_mc3':
xconvert.c:(.text+0x140b): undefined reference to `mkl_sparse_s_convert_csc_to_csr_omp_i4'
/opt/intel/compilers_and_libraries_2017.4.196/linux/mkl/lib/intel64/libmkl_core.a(xconvert_r_s_i4_mc3.o): In function `mkl_sparse_s_transpose_csr3a_i4_mc3':
xconvert.c:(.text+0x1638): undefined reference to `mkl_sparse_s_convert_csc_to_csr_omp_i4'
/opt/intel/compilers_and_libraries_2017.4.196/linux/mkl/lib/intel64/libmkl_core.a(xconvert_r_d_i4_mc3.o): In function `mkl_sparse_d_convert_bsr_i4_mc3':
xconvert.c:(.text+0x211): undefined reference to `mkl_sparse_d_csrbsr_i4'
xconvert.c:(.text+0x2a9): undefined reference to `mkl_sparse_d_csrbsr_i4'
xconvert.c:(.text+0x400): undefined reference to `mkl_sparse_d_bsrbsr_i4'
xconvert.c:(.text+0x472): undefined reference to `mkl_sparse_d_bsrbsr_i4'
xconvert.c:(.text+0x4a9): undefined reference to `mkl_sparse_d_convert_bsr_transpose_i4'
xconvert.c:(.text+0x4c8): undefined reference to `mkl_sparse_d_convert_bsr_transpose_i4'
/opt/intel/compilers_and_libraries_2017.4.196/linux/mkl/lib/intel64/libmkl_core.a(xconvert_r_d_i4_mc3.o): In function `mkl_sparse_d_export_csr_data_i4_mc3':
xconvert.c:(.text+0x600): undefined reference to `mkl_sparse_d_convert_coo_to_csr_i4'
/opt/intel/compilers_and_libraries_2017.4.196/linux/mkl/lib/intel64/libmkl_core.a(xconvert_r_d_i4_mc3.o): In function `mkl_sparse_d_convert_csc_to_csr_i4_mc3':
xconvert.c:(.text+0xf20): undefined reference to `mkl_sparse_d_convert_csc_to_csr_omp_i4'
/opt/intel/compilers_and_libraries_2017.4.196/linux/mkl/lib/intel64/libmkl_core.a(xconvert_r_d_i4_mc3.o): In function `mkl_sparse_d_transpose_csr3a_i4_mc3':
xconvert.c:(.text+0x1149): undefined reference to `mkl_sparse_d_convert_csc_to_csr_omp_i4'
/opt/intel/compilers_and_libraries_2017.4.196/linux/mkl/lib/intel64/libmkl_core.a(xconvert_c_s_i4_mc3.o): In function `mkl_sparse_c_convert_bsr_i4_mc3':
xconvert.c:(.text+0x211): undefined reference to `mkl_sparse_c_csrbsr_i4'
xconvert.c:(.text+0x2a9): undefined reference to `mkl_sparse_c_csrbsr_i4'
xconvert.c:(.text+0x400): undefined reference to `mkl_sparse_c_bsrbsr_i4'
xconvert.c:(.text+0x472): undefined reference to `mkl_sparse_c_bsrbsr_i4'
xconvert.c:(.text+0x4a9): undefined reference to `mkl_sparse_c_convert_bsr_transpose_i4'
xconvert.c:(.text+0x4c8): undefined reference to `mkl_sparse_c_convert_bsr_transpose_i4'
/opt/intel/compilers_and_libraries_2017.4.196/linux/mkl/lib/intel64/libmkl_core.a(xconvert_c_s_i4_mc3.o): In function `mkl_sparse_c_export_csr_data_i4_mc3':
xconvert.c:(.text+0x600): undefined reference to `mkl_sparse_c_convert_coo_to_csr_i4'
/opt/intel/compilers_and_libraries_2017.4.196/linux/mkl/lib/intel64/libmkl_core.a(xconvert_c_s_i4_mc3.o): In function `mkl_sparse_c_convert_csc_to_csr_i4_mc3':
xconvert.c:(.text+0xf20): undefined reference to `mkl_sparse_c_convert_csc_to_csr_omp_i4'
/opt/intel/compilers_and_libraries_2017.4.196/linux/mkl/lib/intel64/libmkl_core.a(xconvert_c_s_i4_mc3.o): In function `mkl_sparse_c_transpose_csr3a_i4_mc3':
xconvert.c:(.text+0x1149): undefined reference to `mkl_sparse_c_convert_csc_to_csr_omp_i4'
/opt/intel/compilers_and_libraries_2017.4.196/linux/mkl/lib/intel64/libmkl_core.a(xconvert_c_d_i4_mc3.o): In function `mkl_sparse_z_convert_bsr_i4_mc3':
xconvert.c:(.text+0x211): undefined reference to `mkl_sparse_z_csrbsr_i4'
xconvert.c:(.text+0x2a9): undefined reference to `mkl_sparse_z_csrbsr_i4'
xconvert.c:(.text+0x403): undefined reference to `mkl_sparse_z_bsrbsr_i4'
xconvert.c:(.text+0x475): undefined reference to `mkl_sparse_z_bsrbsr_i4'
xconvert.c:(.text+0x4ac): undefined reference to `mkl_sparse_z_convert_bsr_transpose_i4'
xconvert.c:(.text+0x4cb): undefined reference to `mkl_sparse_z_convert_bsr_transpose_i4'
/opt/intel/compilers_and_libraries_2017.4.196/linux/mkl/lib/intel64/libmkl_core.a(xconvert_c_d_i4_mc3.o): In function `mkl_sparse_z_export_csr_data_i4_mc3':
xconvert.c:(.text+0x606): undefined reference to `mkl_sparse_z_convert_coo_to_csr_i4'
/opt/intel/compilers_and_libraries_2017.4.196/linux/mkl/lib/intel64/libmkl_core.a(xconvert_c_d_i4_mc3.o): In function `mkl_sparse_z_convert_csc_to_csr_i4_mc3':
xconvert.c:(.text+0xf80): undefined reference to `mkl_sparse_z_convert_csc_to_csr_omp_i4'
/opt/intel/compilers_and_libraries_2017.4.196/linux/mkl/lib/intel64/libmkl_core.a(xconvert_c_d_i4_mc3.o): In function `mkl_sparse_z_transpose_csr3a_i4_mc3':
xconvert.c:(.text+0x11a9): undefined reference to `mkl_sparse_z_convert_csc_to_csr_omp_i4'
/opt/intel/compilers_and_libraries_2017.4.196/linux/mkl/lib/intel64/libmkl_core.a(xconvert_r_s_i4_mc.o): In function `mkl_sparse_s_convert_bsr_i4_mc':
xconvert.c:(.text+0x721): undefined reference to `mkl_sparse_s_csrbsr_i4'
xconvert.c:(.text+0x7b9): undefined reference to `mkl_sparse_s_csrbsr_i4'
xconvert.c:(.text+0x910): undefined reference to `mkl_sparse_s_bsrbsr_i4'
xconvert.c:(.text+0x982): undefined reference to `mkl_sparse_s_bsrbsr_i4'
xconvert.c:(.text+0x9b9): undefined reference to `mkl_sparse_s_convert_bsr_transpose_i4'
xconvert.c:(.text+0x9d8): undefined reference to `mkl_sparse_s_convert_bsr_transpose_i4'
/opt/intel/compilers_and_libraries_2017.4.196/linux/mkl/lib/intel64/libmkl_core.a(xconvert_r_s_i4_mc.o): In function `mkl_sparse_s_export_csr_data_i4_mc':
xconvert.c:(.text+0xb13): undefined reference to `mkl_sparse_s_convert_coo_to_csr_i4'
/opt/intel/compilers_and_libraries_2017.4.196/linux/mkl/lib/intel64/libmkl_core.a(xconvert_r_s_i4_mc.o): In function `mkl_sparse_s_convert_csc_to_csr_i4_mc':
xconvert.c:(.text+0x139b): undefined reference to `mkl_sparse_s_convert_csc_to_csr_omp_i4'
/opt/intel/compilers_and_libraries_2017.4.196/linux/mkl/lib/intel64/libmkl_core.a(xconvert_r_s_i4_mc.o): In function `mkl_sparse_s_transpose_csr3a_i4_mc':
xconvert.c:(.text+0x15c8): undefined reference to `mkl_sparse_s_convert_csc_to_csr_omp_i4'
/opt/intel/compilers_and_libraries_2017.4.196/linux/mkl/lib/intel64/libmkl_core.a(xconvert_r_d_i4_mc.o): In function `mkl_sparse_d_convert_bsr_i4_mc':
/opt/intel/compilers_and_libraries_2017.4.196/linux/mkl/lib/intel64/libmkl_core.a(xconvert_r_d_i4_mc.o): In function `mkl_sparse_d_export_csr_data_i4_mc':
xconvert.c:(.text+0x603): undefined reference to `mkl_sparse_d_convert_coo_to_csr_i4'
/opt/intel/compilers_and_libraries_2017.4.196/linux/mkl/lib/intel64/libmkl_core.a(xconvert_r_d_i4_mc.o): In function `mkl_sparse_d_convert_csc_to_csr_i4_mc':
xconvert.c:(.text+0xf30): undefined reference to `mkl_sparse_d_convert_csc_to_csr_omp_i4'
/opt/intel/compilers_and_libraries_2017.4.196/linux/mkl/lib/intel64/libmkl_core.a(xconvert_r_d_i4_mc.o): In function `mkl_sparse_d_transpose_csr3a_i4_mc':
xconvert.c:(.text+0x1159): undefined reference to `mkl_sparse_d_convert_csc_to_csr_omp_i4'
/opt/intel/compilers_and_libraries_2017.4.196/linux/mkl/lib/intel64/libmkl_core.a(xconvert_c_s_i4_mc.o): In function `mkl_sparse_c_convert_bsr_i4_mc':
/opt/intel/compilers_and_libraries_2017.4.196/linux/mkl/lib/intel64/libmkl_core.a(xconvert_c_s_i4_mc.o): In function `mkl_sparse_c_export_csr_data_i4_mc':
xconvert.c:(.text+0x603): undefined reference to `mkl_sparse_c_convert_coo_to_csr_i4'
/opt/intel/compilers_and_libraries_2017.4.196/linux/mkl/lib/intel64/libmkl_core.a(xconvert_c_s_i4_mc.o): In function `mkl_sparse_c_convert_csc_to_csr_i4_mc':
xconvert.c:(.text+0xe90): undefined reference to `mkl_sparse_c_convert_csc_to_csr_omp_i4'
/opt/intel/compilers_and_libraries_2017.4.196/linux/mkl/lib/intel64/libmkl_core.a(xconvert_c_s_i4_mc.o): In function `mkl_sparse_c_transpose_csr3a_i4_mc':
xconvert.c:(.text+0x10b9): undefined reference to `mkl_sparse_c_convert_csc_to_csr_omp_i4'
/opt/intel/compilers_and_libraries_2017.4.196/linux/mkl/lib/intel64/libmkl_core.a(xconvert_c_d_i4_mc.o): In function `mkl_sparse_z_convert_bsr_i4_mc':
/opt/intel/compilers_and_libraries_2017.4.196/linux/mkl/lib/intel64/libmkl_core.a(xconvert_c_d_i4_mc.o): In function `mkl_sparse_z_export_csr_data_i4_mc':
xconvert.c:(.text+0x609): undefined reference to `mkl_sparse_z_convert_coo_to_csr_i4'
/opt/intel/compilers_and_libraries_2017.4.196/linux/mkl/lib/intel64/libmkl_core.a(xconvert_c_d_i4_mc.o): In function `mkl_sparse_z_convert_csc_to_csr_i4_mc':
xconvert.c:(.text+0xfa0): undefined reference to `mkl_sparse_z_convert_csc_to_csr_omp_i4'
/opt/intel/compilers_and_libraries_2017.4.196/linux/mkl/lib/intel64/libmkl_core.a(xconvert_c_d_i4_mc.o): In function `mkl_sparse_z_transpose_csr3a_i4_mc':
xconvert.c:(.text+0x11c9): undefined reference to `mkl_sparse_z_convert_csc_to_csr_omp_i4'
/opt/intel/compilers_and_libraries_2017.4.196/linux/mkl/lib/intel64/libmkl_core.a(xconvert_r_s_i4_def.o): In function `mkl_sparse_s_convert_bsr_i4_def':
xconvert.c:(.text+0x731): undefined reference to `mkl_sparse_s_csrbsr_i4'
xconvert.c:(.text+0x7c9): undefined reference to `mkl_sparse_s_csrbsr_i4'
xconvert.c:(.text+0x921): undefined reference to `mkl_sparse_s_bsrbsr_i4'
xconvert.c:(.text+0x993): undefined reference to `mkl_sparse_s_bsrbsr_i4'
xconvert.c:(.text+0x9e9): undefined reference to `mkl_sparse_s_convert_bsr_transpose_i4'
/opt/intel/compilers_and_libraries_2017.4.196/linux/mkl/lib/intel64/libmkl_core.a(xconvert_r_s_i4_def.o): In function `mkl_sparse_s_export_csr_data_i4_def':
xconvert.c:(.text+0xb22): undefined reference to `mkl_sparse_s_convert_coo_to_csr_i4'
/opt/intel/compilers_and_libraries_2017.4.196/linux/mkl/lib/intel64/libmkl_core.a(xconvert_r_s_i4_def.o): In function `mkl_sparse_s_convert_csc_to_csr_i4_def':
xconvert.c:(.text+0x13ab): undefined reference to `mkl_sparse_s_convert_csc_to_csr_omp_i4'
/opt/intel/compilers_and_libraries_2017.4.196/linux/mkl/lib/intel64/libmkl_core.a(xconvert_r_s_i4_def.o): In function `mkl_sparse_s_transpose_csr3a_i4_def':
xconvert.c:(.text+0x15d8): undefined reference to `mkl_sparse_s_convert_csc_to_csr_omp_i4'
/opt/intel/compilers_and_libraries_2017.4.196/linux/mkl/lib/intel64/libmkl_core.a(xconvert_r_d_i4_def.o): In function `mkl_sparse_d_convert_bsr_i4_def':
xconvert.c:(.text+0x401): undefined reference to `mkl_sparse_d_bsrbsr_i4'
xconvert.c:(.text+0x473): undefined reference to `mkl_sparse_d_bsrbsr_i4'
xconvert.c:(.text+0x4aa): undefined reference to `mkl_sparse_d_convert_bsr_transpose_i4'
xconvert.c:(.text+0x4c9): undefined reference to `mkl_sparse_d_convert_bsr_transpose_i4'
/opt/intel/compilers_and_libraries_2017.4.196/linux/mkl/lib/intel64/libmkl_core.a(xconvert_r_d_i4_def.o): In function `mkl_sparse_d_export_csr_data_i4_def':
/opt/intel/compilers_and_libraries_2017.4.196/linux/mkl/lib/intel64/libmkl_core.a(xconvert_r_d_i4_def.o): In function `mkl_sparse_d_convert_csc_to_csr_i4_def':
/opt/intel/compilers_and_libraries_2017.4.196/linux/mkl/lib/intel64/libmkl_core.a(xconvert_r_d_i4_def.o): In function `mkl_sparse_d_transpose_csr3a_i4_def':
/opt/intel/compilers_and_libraries_2017.4.196/linux/mkl/lib/intel64/libmkl_core.a(xconvert_c_s_i4_def.o): In function `mkl_sparse_c_convert_bsr_i4_def':
xconvert.c:(.text+0x401): undefined reference to `mkl_sparse_c_bsrbsr_i4'
xconvert.c:(.text+0x473): undefined reference to `mkl_sparse_c_bsrbsr_i4'
xconvert.c:(.text+0x4aa): undefined reference to `mkl_sparse_c_convert_bsr_transpose_i4'
xconvert.c:(.text+0x4c9): undefined reference to `mkl_sparse_c_convert_bsr_transpose_i4'
/opt/intel/compilers_and_libraries_2017.4.196/linux/mkl/lib/intel64/libmkl_core.a(xconvert_c_s_i4_def.o): In function `mkl_sparse_c_export_csr_data_i4_def':
/opt/intel/compilers_and_libraries_2017.4.196/linux/mkl/lib/intel64/libmkl_core.a(xconvert_c_s_i4_def.o): In function `mkl_sparse_c_convert_csc_to_csr_i4_def':
/opt/intel/compilers_and_libraries_2017.4.196/linux/mkl/lib/intel64/libmkl_core.a(xconvert_c_s_i4_def.o): In function `mkl_sparse_c_transpose_csr3a_i4_def':
/opt/intel/compilers_and_libraries_2017.4.196/linux/mkl/lib/intel64/libmkl_core.a(xconvert_c_d_i4_def.o): In function `mkl_sparse_z_convert_bsr_i4_def':
xconvert.c:(.text+0x405): undefined reference to `mkl_sparse_z_bsrbsr_i4'
xconvert.c:(.text+0x477): undefined reference to `mkl_sparse_z_bsrbsr_i4'
xconvert.c:(.text+0x4ae): undefined reference to `mkl_sparse_z_convert_bsr_transpose_i4'
xconvert.c:(.text+0x4cd): undefined reference to `mkl_sparse_z_convert_bsr_transpose_i4'
/opt/intel/compilers_and_libraries_2017.4.196/linux/mkl/lib/intel64/libmkl_core.a(xconvert_c_d_i4_def.o): In function `mkl_sparse_z_export_csr_data_i4_def':
/opt/intel/compilers_and_libraries_2017.4.196/linux/mkl/lib/intel64/libmkl_core.a(xconvert_c_d_i4_def.o): In function `mkl_sparse_z_convert_csc_to_csr_i4_def':
/opt/intel/compilers_and_libraries_2017.4.196/linux/mkl/lib/intel64/libmkl_core.a(xconvert_c_d_i4_def.o): In function `mkl_sparse_z_transpose_csr3a_i4_def':
/opt/intel/compilers_and_libraries_2017.4.196/linux/mkl/lib/intel64/libmkl_core.a(zlaqr0.o): In function `mkl_lapack_zlaqr0':
zlaqr0_gen.f:(.text+0xe05): undefined reference to `mkl_lapack_zlacpy'
/opt/intel/compilers_and_libraries_2017.4.196/linux/mkl/lib/intel64/libmkl_core.a(zlahr2.o): In function `mkl_lapack_zlahr2':
zlahr2_gen.f:(.text+0xa21): undefined reference to `mkl_lapack_zlacpy'
/opt/intel/compilers_and_libraries_2017.4.196/linux/mkl/lib/intel64/libmkl_core.a(zlaqr5.o): In function `mkl_lapack_zlaqr5':
zlaqr5_gen.f:(.text+0x87f): undefined reference to `mkl_lapack_zlaset'
zlaqr5_gen.f:(.text+0x2c0e): undefined reference to `mkl_lapack_zlacpy'
zlaqr5_gen.f:(.text+0x2e12): undefined reference to `mkl_lapack_zlacpy'
zlaqr5_gen.f:(.text+0x2ffb): undefined reference to `mkl_lapack_zlacpy'
zlaqr5_gen.f:(.text+0x31fa): undefined reference to `mkl_lapack_zlacpy'
zlaqr5_gen.f:(.text+0x3229): undefined reference to `mkl_lapack_zlaset'
zlaqr5_gen.f:(.text+0x3389): undefined reference to `mkl_lapack_zlacpy'
zlaqr5_gen.f:(.text+0x3524): undefined reference to `mkl_lapack_zlacpy'
zlaqr5_gen.f:(.text+0x3704): undefined reference to `mkl_lapack_zlacpy'
zlaqr5_gen.f:(.text+0x3733): undefined reference to `mkl_lapack_zlaset'
zlaqr5_gen.f:(.text+0x38be): undefined reference to `mkl_lapack_zlacpy'
zlaqr5_gen.f:(.text+0x3ab6): undefined reference to `mkl_lapack_zlacpy'
zlaqr5_gen.f:(.text+0x3c71): undefined reference to `mkl_lapack_zlacpy'
zlaqr5_gen.f:(.text+0x3ca0): undefined reference to `mkl_lapack_zlaset'
zlaqr5_gen.f:(.text+0x3e25): undefined reference to `mkl_lapack_zlacpy'
zlaqr5_gen.f:(.text+0x4007): undefined reference to `mkl_lapack_zlacpy'
/opt/intel/compilers_and_libraries_2017.4.196/linux/mkl/lib/intel64/libmkl_core.a(zlaqr4.o): In function `mkl_lapack_zlaqr4':
zlaqr4_gen.f:(.text+0xe05): undefined reference to `mkl_lapack_zlacpy'
/opt/intel/compilers_and_libraries_2017.4.196/linux/mkl/lib/intel64/libmkl_core.a(zlaqr3.o): In function `mkl_lapack_zlaqr3':
zlaqr3_gen.f:(.text+0x51e): undefined reference to `mkl_lapack_zlacpy'
zlaqr3_gen.f:(.text+0x5c6): undefined reference to `mkl_lapack_zlaset'
zlaqr3_gen.f:(.text+0xd8b): undefined reference to `mkl_lapack_zlaset'
zlaqr3_gen.f:(.text+0xfa8): undefined reference to `mkl_lapack_zlacpy'
zlaqr3_gen.f:(.text+0x1229): undefined reference to `mkl_lapack_zlacpy'
zlaqr3_gen.f:(.text+0x13c8): undefined reference to `mkl_lapack_zlacpy'
zlaqr3_gen.f:(.text+0x156d): undefined reference to `mkl_lapack_zlacpy'
/opt/intel/compilers_and_libraries_2017.4.196/linux/mkl/lib/intel64/libmkl_core.a(zlaqr2.o): In function `mkl_lapack_zlaqr2':
zlaqr2_gen.f:(.text+0x465): undefined reference to `mkl_lapack_zlacpy'
zlaqr2_gen.f:(.text+0x525): undefined reference to `mkl_lapack_zlaset'
zlaqr2_gen.f:(.text+0xc59): undefined reference to `mkl_lapack_zlaset'
zlaqr2_gen.f:(.text+0xe8a): undefined reference to `mkl_lapack_zlacpy'
zlaqr2_gen.f:(.text+0x1117): undefined reference to `mkl_lapack_zlacpy'
zlaqr2_gen.f:(.text+0x12b8): undefined reference to `mkl_lapack_zlacpy'
zlaqr2_gen.f:(.text+0x145f): undefined reference to `mkl_lapack_zlacpy'
/usr/bin/ld: link errors found, deleting executable `ex5f'
/usr/bin/X11/sha1sum: ex5f: No such file or directory
makefile:50: recipe for target 'ex5f' failed
make: [ex5f] Error 1 (ignored)
/usr/bin/rm -f ex5f.o
Type: text/x-log
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20180424/2d0f5508/attachment-0001.bin>
